2005-11-14 by lcdpublishing
Hi All,
I figure I might as well keep reporting my toner transfer failures
and successes as it may help someone else.
Brief recap of problem..
Using a wide variety of papers and laser printers, I could not get
the toner to stick to some PCB material I purchased. Prior to this
PCB material, I had very good success doing toner transfer.
During a last ditch effort to complete some circuit boards, I pre-
etched the boards in Ferric Chloride before doing the toner
transfer, this helped but still wasn't great.
Yesterday, I tried this approach again, pre-etch for about 2
minutes, followed with a gentle scrubbing with an abrasive pad
(Scotch bright). The toner transfered pretty good - about 98%.
Still not sure what the problem is with this particular batch of PCB
material but I can say that no amount of sanding, cleaning, or
polishing would allow toner to stick. So far, the only solution has
been to pre-etch it.
Perhaps as I get some time to actually experiement, I can't dig in a
little further, however, should you run into something similar, try
pre-etching your boards.
Chris
2005-11-15 by mikezcnc
Chris,
I presume you are using a laminator (if not- that is a different
subject :))) I am not in favor of pre-etching because it adds
another wet-dirt operation. What I do is this:
1. Use paper from Staples, stock number is in the database. That ia
an inkjet paper that I use in my laser printer I got used for $20,
rather unimpressive (small) Lexmark Optra. I have add that before I
was trying all kinds of paper and the results were all over the map.
In fact I have a collection of all kinds of papers and nothing worked
well FOR ME. I hear that lots of guys are happy with Menstruation
Press Paper (Bridal Magazine for You, Baking Laminated Cookies, Heavy
Duty Knitting, etc)- I have't tested that option yet.
2. GBC laminaotor, converted according to a dissertation at
www.pulsar.gs Great result but I hope never to do it again.
3. kitchen 3M cleaning pad, non metallic.
4. I don't do heavy cleaning in fact I do very little cleaning, clean
with detergent, clean with the pad, again detergent and dry it out. I
takes maybe 2 minutes to get it including drying...
5. Stick the paper onto the PCB roll dozen or so times thru a magic
Printed Circuit Board Producing Device (PCBPD) and off to a bathtub.
Few minutes and it's 100% proof.
Now, I recall having problems that you described when I used steam
iron (no steam), large PCBs, thin tracks and chancy paper. No amount
of cleaning would help and I even used a palm sander with all kinds
of different sand papers. What helped me is using a laminator and the
correct (for me :))) paper. Mike
2005-11-15 by lcdpublishing
Hi Mike, thanks for the info. How thick of a board can you pass
through that laminator that you modified?
Chris
--- In Homebrew_PCBs@yahoogroups.com, "mikezcnc" <eemikez@c...>
wrote:
> Chris,
ia
I
map.
worked
Heavy
clean
out. I
magic
bathtub.
amount
kinds
Chris,
Thickness of the board is another issue I didn't want to add it to
my answer to simplify the matteer. I am using 40 and 60 mills
fiberglass and 60 mills phenolic crap, that is 45 years old. I am
also using 10 mills flex. All of them work fine but only AS LONG AS I
am using that secret paper. The minute I switch to something else I
get results all over teh map. In fact I can use common laser bond
paper and get the same results as any other paper except for that
secret Staples paper.
I tried making my own dextrine paper, I tried printing on aluminum,
wax paper, baking paper, lables backing paper (whose idea was that?
That was insane!), I tried tracing paper, photographic paper, I tried
plotting on copper directly, I sacrificed my laser printer to laser
print on copper directly, I tried making my own ink for inkjet *hello
a new inkjest printer...), I tried machinists paint and scratch and
etch... and many variations. Now, steam iron works but on small POCBs
with heavy (to be defined ;) tracks...
All methods produced ok to good results some of the time to most of
the time. I do not believe in using a pen to correct a laminated PCB.
Once I run out of my secret paper supply I will switch to the PMS
paper.
What works (FOR ME) is this combination...ok, I won't mention it
agin, I mentioned it in a previous email. Mike
2005-11-15 by Stefan Trethan
It should be possible to figure out if the paper is the problem by
inspecting the results.
Did the toner stick to the paper? Is it too fibery? Where it transferred,
are there fibers left or only a white "powder".
If the paper comes off well in some areas, with the right sort of
grey/white residue left and no (0%) toner left on the paper, in those
areas, i don't really think the paper is the issue.
With the right pressure and heat you should be able to fuse the toner to
the board with _any_ paper, the only question beeing if you get the paper
off without taking the toner with it. But if the toner doesn't even stick
the problem must be either pressure, temperature, board
preparation/surface, or some other contamination, but not the paper.
I dunno, it's sure strange, but when i had the problem that it just
stopped working reliably (with the same paper and material) i decided it
is my ironing and got the fuser, and the problems went away. I didn't look
into it then why it suddenly stopped working.
Of course, a paper that works better will be slightly more tolerant
towards the other factors, but it can't solve a major issue.
ST
Hi Mike,
I think with the toner transfer stuff, what works for any of us
doesn't actually mean it is going to work for someone else. There
are a lot of variables in the process as a whole and that is part of
the problem with getting universal results.
Stefan, I believe, is the proponent of using a fuser from a laser
printer. I use mostly the .062" thick PCB material and nothing less
(for no other reason than that is what I can find easily when I need
it). So, I am going to keep a watchful eye out for either a used
laminator or an old laser printer that I can hack the fuser out of.
I really hate buying something new (like a new laminator) to hack it
up only to find that it won't work to my expectations :-( Don't
mind hacking apart older used stuff though, even if I have to pay a
few bucks for it.
Thanks again for all the input!
Chris
wrote:
> Chris,
to
AS I
I
aluminum,
that?
tried
laser
*hello
and
POCBs
of
PCB.
> paper.
Stefan,
The fuser that you are using, where did you get it from? Is there
anything in particular that I should look for in a used laser
printer that would make for a good salvageable fuser assembly?
CHris
by
transferred,
those
toner to
the paper
even stick
paper.
just
decided it
didn't look
tolerant
> ST
On Tue, 15 Nov 2005 16:13:24 +0100, lcdpublishing
<lcdpublishing@...> wrote:
> Hi Mike,
> up only to find that it won't work to my expectations Don't
> few bucks for it.
> Chris
I agree, i wouldn't like buying something to hack it, especially if it is
mostly cheap plastic crap you get these days. OTOH by using current
products you can offer a reproduceable thing, like pulsar etc.
Also i agree toner transfer seems to be one of the hardest processes to
communicate to others, although it is so easy to do once it works.
> Stefan,
> anything in particular that I should look for in a used laserprinter
> CHris
You should look that it is metal not plastic, much easier to work with.
You should look that the rollers can move apart the 2mm or whatever you
need, often the lower roller is sprung and the bearings ride in a slot,
this is what you want as it allows you to change spring tension if you
want. I reckon the newer fusers are probably built like the laminators,
"fixed width".
Also, you should look that it has a comfortable axle or gear to interface
your motor to.
You'll also need the thermistor that is usually pressed against the upper
roller, for temperature control. Remember to keep the electronics for that
if you have a whole printer, but if you only have a fuser they are cheap
to build.
I got mine out of a copier, and it's really ideal for the job. nice and
wide too. In general, the older the machine the better i'd say. Go to the
place where trash office stuff goes, you are bound to find a printer or
copier for free. A large copier has HEAPS of interesting parts in it.
ST
aaa, fuser... Chris is not using a laminator!!! Chris, save your time
on making your own laminator and get yourself a real laminator. I have
two, one is the GBC200, look in the database section, there is an
overview what works and what not. Or, get a real laminator, one like
they used to be, the bigger and bulkier. Those will laminate anything
you want to anything you have.
So, Chris was was using a steam iron, who would have thunk of
that... :)) Mike
OKay, that sounds good. There is a place a few miles away that
recycles computers and such. The next time I am up that way I will
check with them to see what they have.
When using yours, do you have to run the board through a single
time, or multiple times?
CHris
with.
whatever you
slot,
you
laminators,
> "fixed width".
interface
> your motor to.
the upper
for that
cheap
> to build.
nice and
to the
printer or
it.
Yes, the iron has been working perfect for me up to the point when I
got some new PCB material. That's when everything went to hell with
the process. The process I was using that worked perfect was this..
Turn on iron - check with digital thermometer for proper temp
Put toner transfer paper on PCB
Press down firmly for 15 seconds
Repeat pressing in different locations to cover complete board
Soak board in water for 2 minutes
Etch it.
No problems, till I got the new PCB material. However, I can easily
see where a laminator or fuser can give much better and hopefully
consistant results.
Chris
time
have
anything
> that... :)) Mike
That's true Stefan, I just wanted to give Chris a clue what might work
for him because it worked for me and chances are very high it will work
for everybody, unless they cannot concentrate too well. What did not
cross my mind that anybody would still use a steam iron ;)))
I like your idea of a fuser but I wanted my PCBs done right now and
that is why I bought the lamiantor. Then, by sheer accident I got a
cheap commerical laminator and that just was amazing how well it
pressed paper against teh PCBs. Many ways to pet a cat. Mike
On Tue, 15 Nov 2005 16:46:03 +0100, lcdpublishing
> CHris
single time, i took care to make it run extra slow.
I'm not a 100% sure, but i think i once timed a A4 page (long side) with
very close to one minute exactly.
Sometimes i will let it run two times, like when i'm using a cardboard
"feeder" or when i'm transferring both sides at once.
ST
Chris, I see you somewhat admitted your guilt of not using a
laminator ;) Welcome to a group that can make a 100% proof PCB under 1
hour at midnight.
10 times. Wax on, wax off concept... you put it in, you take it out,
you put it in. 10 times. Your mileage may vary. My Big Berta Laminator
(BBL) can do it in one pass, hehehe. Mike
I know it works. It works on some sizes, some tracks and now on some
PCBs. Ironing is not a way to live a quality life. Never was ;) Mike
LOL!
I agree!
> PCBs. Ironing is not a way to live a quality life. Never was Mike
You forgot "sometimes". Even on the same PCB with the same iron and layout
and operator i had it work one time, and not the other. Just too many
variables i think.
ST
2005-11-15 by Les Newell
I think I'll stick to photo etching. Print onto transparency with my
cheap Epson inkjet (green works best for some reason), expose in a light
box for 7 minutes, Develop in weak caustic soda solution for 2 mins,
etch. Works great for me :-) Afterwards I stick board in the cnc mill
and drill the holes for a perfect finish. Apart from the hassle of
rubbing off the paper and fixing track breaks with an etch resist pen
the distortion you get with TT made it impossible for me to drill the
holes with CNC.
Les
Checked by AVG Free Edition.
Version: 7.1.362 / Virus Database: 267.13.1/169 - Release Date: 15/11/2005
2005-11-15 by Jim Miller
Hi Les
Is your method written up somewhere?
What sort of linewidths do you have success with? I'm looking at doing some
work with AD9958 this winter and it has 0.25mm pads on 0.5mm pitch.
tnx
jim
Les, I agree that that is the ultimate method of making PCBs
but...you forgot to mention follwing problems:
1. You must have a good UV exposure box-- let's not start another
dicussioon today what that means. It is not a trivial issue although
for some it might be. The issue here is the resolution because I have
seen a keproo UV box for $500 failing to give a good resolution on
TSOP- it was all FUXXY! On quality PCB material, too.I will only
state that depending what you are building, the uv light may or may
not work for some or many applications. And let's not expose to sun
light for a while either :)
2. Once you have the box you need to calibrate the bloody box and
depending what light it uses the timing might be all over the map,
depending on the preheated condition of the lamp. Depending on what
you are using. Calibration alone is not for weak people either.
3. PCB material: buy ready made (expensive), use negative or positive
(explain it to a nenwcomer), apply film, make your own secret
emulsion, dry, spray, develop (how long, oops, lets strip it and do
it again, and again... what teh hell is that today...). Then finally
comes etching which is trivial..
Now, I am waiting for someone to say that he is happy with scratch
and etch or printing directly on copper!
Overall, I know that UV is best, and I know it works fine because I
have the whole process prepared when... when I get tired of TT-ing
PCBs. So far I don't foresee it. Stick a secret Staples paper in the
laser printer, hit 'print' and pull the paper out of the printer.
etch it and remove the paper. Then you drill. No adjustment process,
no secret uv boxes. Mike
On Tue, 15 Nov 2005 18:55:28 +0100, Jim Miller <jim@...> wrote:
> Hi Les
> some
> tnx
> jim
I do this on toner transfer no problems.
Must work easily with photo.
ST
There isn't much to my system. I use an Epson colour printer with Rapid
Electronics inkjet transparency. I found that green works best. Black
and red both seem to have a crazing effect which can cause broken
tracks. This is with the new Durabrite inks. The older inks seemed to
work better but my old Stylus Color 600 died. The layout has to be
printed so the ink side goes towards the board.
The light box is a simple wooden box with four UV tubes about 100mm
under sheet of glass. There is a sheet of aluminium foil under the tubes
to reflect the light upwards. There is a lid to clamp the board in place
while exposing it and I found that a couple of layers of bubble wrap
between the lid and board gives a good even pressure. When you first set
up you need to work out how long an exposure is needed. This is pretty
simple. Print a layout and stick the transparency to a piece of board
with sticky tape. On the back of the board make a series of marks,
roughly even spaced. About 7 or 8 will probably do. Place it in the
light box with a piece of aluminium foil between the board and the
glass, with one edge lined up with the first mark leaving a small strip
exposed. Expose the board for 1 minute, move the strip to line up with
the next mark, expose for 1 minute and so on. You now have a board that
at one end has been exposed for 8 or 9 minutes and the other end that
has only been exposed for 1 minute. When you develop the board it is
quite easy to see where it is under and over developed. Find the best
part of the board and you will know how long you need to expose the
board. This is a bit tedious but you only need to do it once. Some
boards are very sensitive so you may have to repeat the experiment using
different timing.
Exposure time varies as the tubes warm up so I usually turn them on
10-15 minutes in advance to give them time to warm up. I use precoated
board and I can recommend Microtrak board from Mega Electronics - I
think It is actually made by Bungard. It has a thin coating which
reduces undercutting and the resist coating is fairly tolerant to
under/over exposure. Developer is a level teaspoon of caustic soda
granules in a litre of water. A few drops of detergent added to the mix
helps the developer wet the surface. I drop the board in a tray, add
enough developer to cover the surface then rock the tray. As developing
progresses you see streaks of darker resist appearing in the developer.
Once they stop appearing the board is done. A quick dip in the etch tank
will hilight any areas that have been missed.
I normally use .012" track+gap (~0.3mm) because I know it is reliable.
0.25T&G shouldn't be a problem. The most important thing is to get a
good quality print out of your printer. I tried a Lexmark and that
produced a very fuzzy print.
Les
about 100mm awa
Jim Miller wrote:
>Hi Les
>tnx
>jim
>http://groups.yahoo.com/group/Homebrew_PCBs
>If Files or Photos are running short of space, post them here:
>http://groups.yahoo.com/group/Homebrew_PCBs_Archives/
>Yahoo! Groups Links
2005-11-16 by Les Newell
Hi Mike,
I have no problems with a very basic setup. I admit I tend to stick to
12 thou track/gap because I know it will work every time. For one-offs
size isn't usually a problem so you can afford to space things out a bit.
Leaving the box on for 10-15 minutes before use solves the warmup
problem. Calibration is a little tedious but it isn't exactly difficult.
You only have to do it once.
Ready made works for me. Yes it is more expensive but not that much more
expensive. In the small quantities most of us use the increased cost is
not going to make a noticeable difference to the overall cost of
building a circuit. The quality of ready made does vary quite widely
between different suppliers. Mega Electronics for instance sell two
different types, Microtrak and Fotoboard. They are both near as dammit
the same price but the Microtrak is miles easier to use.
I used to plot directly onto copper but I had problems with the ink
spreading. One method that did work, and you are gonna laugh at this
one, was to plot onto photoresist board then expose and etch. The ink
didn't spread on the photo resist. Exposure time was whatever you
wanted. Anything from 5 minutes to 30 minutes gave good results.
Printing onto film is a lot quicker than plotting so I use film these
days. I like the idea of scratch and etch. One day when I get the right
software and a few spare hours...
Your experience with TT must be very different to mine. I spent a cople
of days in total trying to get it to work and never ended up with
anything useable. I have a big stack of assorted papers bought from
Staples and other suppliers. None of them worked reliably. Distortion
was the final straw. If I got the cnc lined up perfecly on one end of
the board it would be missing pads completely at the other end of the
board. Maybe my Samsung laser was the problem. I don't know. I'll stick
with what works for me :-)
Les
2005-11-16 by Russell Shaw
Les Newell wrote:
> Hi Mike,
I've done 10cm x 10cm boards full of 8mil tracks and spacing for fine pitch
128pin DSP chips and FPGAs using the uv method and there was no track
breakages or shorts.
I've found with my 4-flouro tube box, results are consistant as soon as
i use it, which is usually less than 1-2mins after switch-on.
I use a 125 Watt HID box mostly now, and it certainly needs a warm-up
of 5-10mins. Exposure works to ~80-90% in 30secs with precoated negative
pcb, so i use 90secs for excellent results. Calibration was easy.
I get my pcb vendor to coat and cut a whole panel, and it works
out very cheap. I store the stuff in the fridge.
2005-11-16 by derekhawkins
made from two draws (from a roadside garbage dump) sawn in half and
epoxied together. No form of collimation whatsoever, can do .007"
tracks and spacing with ease. Uses standard daylight bulbs, takes 5
minutes per side for proper exposure using positive pre-sensitized
boards ($3.38 each for double sided 6"X4"). I can go from print to
etched board in less than 30 minutes. You just cannot get this sort
of workflow or board quality from TT. TT is something for the
absolute novice IMO....Which was me 5 years ago.
http://www.pbase.com/eldata/image/52321530
http://www.pbase.com/eldata/image/52321539
although
have
may
sun
what
positive
do
finally
I
process,
2005-11-16 by ballendo
Les,
Excellent post.
Masny will find that TT combined with CNC drilling is a bad
combination. (Assuming the CNC is of decent accuracy<G>)
Ballendo
--- In Homebrew_PCBs@yahoogroups.com, Les Newell <lesnewell@h...>
my
light
mins,
mill
pen
> holes with CNC.
> Les
Think and tinker has step by step directions for an excellent
exposure setup. Not expensive either.
Calibration is easy inexpensive, and also described.
Ballendo
although
have
may
sun
what
positive
do
finally
I
process,
Seems a lightbox is easier and cheaper than making a laminator...
Ballendo
Rapid
Black
to
100mm
tubes
place
wrap
first set
pretty
board
strip
with
that
that
is
best
using
> different timing.
on
precoated
I
soda
the mix
add
developing
developer.
etch tank
reliable.
a
> Les
> about 100mm awa
> Jim Miller wrote:
> >Hi Les
doing some
pitch.
> >tnx
> >jim
and Photos:
> >Yahoo! Groups Links
Did you use a single ballast and series connection for those tubes?
How many starters did it need?
Each "tube" is actually a separate lamp with its own ballast and
starter. The lamps were on sale at the time with each costing less
than a single UV tube. Here's a shot of the box with the lamps open
when only four were installed;
http://www.pbase.com/eldata/image/52324065
2005-11-16 by Mike Young
More out of curiousity than actually contemplating switching technologies...
Would it be alright to run acetate through a Laserjet? I have this (likely
unfounded) fear that it'll make a gooey mess, or at least come out warped
from the heat. It's probably OK, right? The laminator gets hotter, and I
don't have a conceptual problem with that.
I've looked at photo-inkjet prints through a 50x microscope (color photos,
hitting a personal all-time low in grain sniffing), and don't expect the
print quality to approach that of even my eight year old LJ4. Comments?
Also, is Datak's Tinnit "plating" effective as an etch resist? I'm thinking
of it in reversing a negative image to a positive.
Sent: Tuesday, November 15, 2005 7:32 PM
Subject: [Homebrew_PCBs] A $500.00 "UV" non-trivial exposure box.....
2005-11-16 by Stefan Trethan
On Wed, 16 Nov 2005 02:32:08 +0100, derekhawkins <derekhawkins@...>
Well, that's just an opinion, and as such just as valid as mine, which is
the board quality you get with tt is more than sufficient for 0.5mm pitch
ICs, and workflow is more streamlined, besides beeing a lot cheaper.
Photoprocess is surely somethig for the absolute novice, look what radio
shack and others sell as beginner PCB sets ;-). I was using photoboards 5
years ago, and i have no desire to go back.
ST
> Ballendo
But a lightbox doesn't laminate anything and a laminator doesn't expose
anything.
What good is the one when you require the other?
ST
2005-11-16 by Adam Seychell
Hay Derek, you have done some really nice work with your Cannon EOS 20D.
Hi Mike,
It is probably a bad idea to use ordinary acetate. You can get laser
safe acetate but the results are usually lacking in contrast. As you
say, lasers do producde nice crisp edges. Inkjet tends to be slightly fuzzy.
Les
If we aren't careful we could end up with a holy war here. I couldn't
get TT to work and photo etching works well for me. For others the
opposite is true. Which is the best? The best system is the one that
works for you.
Les
>ST
I think Ballendo was referring to using a laminator for TT rather than
for applying photoresist film.
Les
>anything.
>ST
>Yahoo! Groups Links
2005-11-16 by adicont2
You are wright, is a holy war, but let's make it creative and realy
useful.
The problem <one method versus another one> is a false problem. "The
best system is the one that works for you" I agree whith you.
We should try to improve both systems or, if we can, inovate a new
one.
Adrian
couldn't
> works for you.
20D.
Thanks!
> useful.
> one.
> Adrian
I agree with you.
However, i will not stand by letting people say things i disagree with
without providing a different point of view.
I do fully accept the photomethod, it is valid, and you get good results,
and i said so before.
But TT _can_ produce results that are by far enough for advanced people
(0.5mm pitch ICs is easily sufficient for most, and it isn't even pushing
the limits). A good TT board is easily as good as a bad photoboard. (and i
made plenty of those ;-).)
I appreciate it if people say their opinion, which is very valid and sure
true from their experience. But when i have a different experience i will
add my point of view. There's no need discussing it to find a agreement,
the reader can easily find what is true for his situation, but it would be
unfair not to offer different opinions if they exist.
ST
2005-11-16 by lcdpublishing
Well, said Stefan.
All too often people get caught up in the belief there is only one
way or one opinion on something and everyone should follow that
singular direction. If only one side of ANY topic is allowed for
discussion, well, then we might as well call ourselves lemmings and
not have any discussions about anything.
To blindly follow: a concept, idea, method, technique, or otherwise
anything, is selling oneself short. All of these topics we discuss
will have two sides of the story. Folks can either take what is
written as gospel and follow along, or they can challenge it, try
something on their own and perhaps shed some new light on an old
subject. Nearly everything written in these forums is based on
personal experiences and opinions of those experiences. To squelch
them, only serves to stiffle creativity and the exploration of
further truths.
However, this is just my humble opinion :-)
realy
> > useful.
problem. "The
new
> > one.
> > Adrian
> I agree with you.
with
results,
people
pushing
photoboard. (and i
and sure
i will
agreement,
would be
> ST
2005-11-16 by mikezcnc
..any comments on safety of using Sodium hydroxide?
Mike
..and I know of a guy who can layout 5 mills PLCC44 tracks using just
3M blue masking tape...
>works for you.
Well, TT worked for me. And all was fine until I started comparing my
boards to those that were photoetched. TT is cheaper and that's about
all it has going for it. If your standards and expectations are near
entry level and you want them to remain there then TT is the way to go.
However, there should be no question as to which method is able to
achieve faster and consistently better results.
In your opinion, not mine. I'm not discussing it further, i've made my
point.
ST
On Wed, 16 Nov 2005 18:31:00 +0100, derekhawkins <derekhawkins@...>
> Mike
I'd say the usual. eyes, skin in higher concentrations. Feels funny, you
won't like to touch it anyway.
ST
>way
So true. If one comes to this forum with little or no PCB experience
one will certainly go away believing that TT is the only sensible way
to go.
Well, for those whose TT experience is fraught with problems and issues
(yes you know who you are) there is another way. It's a little more
expensive and may seem more involved at first but trust me, once
mastered it will provide faster and better results. So much so, that
you will be saying to yourself "why did I even waste my time with TT".
Yes, that was me 5 years ago.
--- In Homebrew_PCBs@yahoogroups.com, "lcdpublishing"
>point.
If you were not able to achieve faster and consistently better results
using photoetching then you never mastered the process due to one
reason or another. It's as simple as that.
--- In Homebrew_PCBs@...m, "Stefan Trethan"
2005-11-16 by Leon Heller
Sent: Wednesday, November 16, 2005 6:01 PM
Subject: [Homebrew_PCBs] Re: A $500.00 "UV" non-trivial exposure box.....
>>point.
I've tried both TT and photo-etching, and much prefer the latter.
Admittedly, I only used a clothes iron for the TT rather than a laminator,
but I couldn't see the point of getting a fairly expensive piece of
equipment that might not work when a simple home-made UV exposure unit would
cost a lot less and give better results.
Leon
[This E-mail has been scanned for viruses but it is your responsibility
to maintain up to date anti virus software on the device that you are
currently using to read this email. ]
Sent: Wednesday, November 16, 2005 5:23 PM
Once it's mixed it's quite safe, as the solution isn't all that strong
(about 10 g per litre). Don't get it in your eyes, and rinse it off if it
gets on the skin.
Leon
way
> to go.
Well, I wouldn't say that with any certainty. When I came here a few
months back (or however long ago it was), I looked at the variety of
options presented here in the messages, files, and photos sections.
Being familiar with CNC machines, I figured the most direct route for
me was to do isolation routing. However, after some discussions and
some further thinking, I realized isolation routing is probably not
the best solution for me.
Then I say the photosensitive boards in the catalogs and thought about
that process. Having worked in a darkroom and working with
photography, I figured that would be a good direction to go.
Then I looked at what I could about toner transfer. I have laser
printers - 3 of them. I have a pretty wide variety of paper on hand to
try various methods and I have an iron for use in the shop. It also
looks like the cheapest to "Get started" with method - didn't really
need to purchase anything.
So, in my case, I just looked at the options everyone here has
presented, I chose a path and it worked great the first time out.
Then things went south when I bought some different PCB material.
However, being pretty darn new at this, I can't say if I am even close
to understanding the problems associated with the process, nor do I
expect to master it anytime soon. However, trying various things to
make the process work better and more reliable doesn't cost me much
(perhaps paper if I see something I want to try). But, the toner and
the paper is pretty much zero cost to me.
In my experience, toner transfer is worth further exploration - I have
all the stuff I need, just not the understanding what causes certain
problems. Slowly I am working through the problems and finding
solutions. Photo masking will be something I try at some point when I
need to, but toner transfer will do everything I need it to as I don't
do any of the tiny trace stuff.
>laminator, but I couldn't see the point of getting a fairly expensive
>piece of equipment that might not work when a simple home-made UV
>exposure unit would cost a lot less and give better results.
The prevailing view seems to be that since industry uses photoetching
then it's far too expensive and too involved for the home. Either that
or "we must do things differently" prevails. Normally, I don't get
involved in these TT debates but the insinuation by a poster that one
needs a $500.00 exposure box for photoetching was too much to resist.
--- In Homebrew_PCBs@yahoogroups.com, "Leon Heller" <leon.heller@b...>
Sent: Wednesday, November 16, 2005 6:46 PM
Mine cost me under 25 GBP - just a couple of UV tubes, ballasts and
starters, some MDF, wood and a piece of glass. It doesn't look very pretty
but it works very well.
Leon
On Wed, 16 Nov 2005 19:01:29 +0100, derekhawkins <derekhawkins@...>
>> point.
Same true in reverse.
ST
2005-11-16 by Alan King
>>useful.
>>one.
>>Adrian
>I agree with you.
Hmm I'd say 'educated opinions' for that, everyone has opinions, some
just form them without even beginning to look at all possibilities
properly first.. An opinion on having only one known or favorite method
is pretty useless for comparative purposes, no matter who it's from or
how strongly they have it. Anti TT people generally never did it enough
or tried enough printers and materials to achieve success, 'only
laminators work' people generally just aren't repeatable enough in their
techniques to get reasonable results with an iron. Other things can
work and may even be a bit easier, but TT even with an iron can work
quite well after a little experimentation and sorting it all out.
"Many will find that TT combined with CNC drilling is a bad
combination. (Assuming the CNC is of decent accuracy<G>)"
Ballendo
Of course, this was more than a bit off. Takes 3 minutes of 10th grade geometry to fix axis scaling errors. Anyone not able to use the relative accuracy of both and scale for absolute accuracy in 15 minutes should really turn their high school diploma back in, they should've flunked the math requirements.
TT combined with CNC is terrific. TT, CNC, and someone who doesn't know or isn't willing to spend 5 minutes on the net figuring out how to scale something is the bad combination, but of course the fault doesn't lie in either the TT or CNC. Some people couldn't get to the moon with a space shuttle at hand, others could do it from scratch with a slide rule. The difference between the two is almost never in the tools, so not much point in blaming them, regardless of which tools are being talked about..
Alan
> Ballendo
I found you must first adjust your printer properly, then make a trial
transfer which you measure, and then simply compensate.
The thing is, if the printer isn't aligned horizontally and vertically you
usually will have some amount of skew or trapezoid distortions, which is
hard to compensate. Once it's aligned properly (see service manual, on the
web for many printers) you have only linear error in x and y which is
easily compensated for.
This way i got it down to no measurable deviation easily.
Also, while inkjets are often more accurate, you still need a true print
just the same with photoprocess.
If you have any shrinkage while transferring from the heat simply run the
paper through the laminator before printing, to dry it properly, then it
won't shrink any more.
I readily admit i didn't master the photoprocess, but i also now make
great boards (with legend by the way), much faster, cheaper, and easier
than i ever did with photoprocess. Even if i mastered it i would need
considerably more gear, effort, and cost than i do now for TT.
For photoprocess you _need_ sensitized boards (or you have to add the step
of sensitizing which is again not that easy). They are much more expensive
than the cheap blank offcuts i get. You _need_ a lightbox to do it
properly, not necessarily expensive, but surely comparable in building
effort to a fuser. You _need_ either a inkjet or special (expensive) laser
paper, i don't have an inkjet and don't want to keep one ever again. You
need to develop them, which means another step making mess and effort and
chemicals.
When i make TT i don't need all that. I plug in the fuser to heat up,
meanwhile go and cutoff and clean a suitable PCB, and print the layout. 3
minutes max.. Then i cut the layout out, put it on the pcb, feed it
through the fuser - another minute max.. When it's out i scratch the paper
with a wirebrush i keep in a desk drawer, and submerge in water (the brush
rips open the paper and allows water in quicker. Do not brush too much or
it'll go through and damage the transfer). After a moment in water i take
it out, hold it over the dustbin, and "roll" the paper off with my thumb
starting at the center. submerge again to wet it and rub off the rest.
Submerge again to flush off any paper remains and put in the etcher. two
minutes max.
That's 6 minutes, and i have have estimated very generously - i'll time it
next time i make a board.
Did you notice there's NOTHING to prepare or put away? All waste lands in
the dustbin already. I don't have a sink in the shop so the container with
the water is filled and emptied when i go by one anyway.
I don't think you can make a photoprocess in the same time, and if it
surely requires more space to leave all the gear prepared.
But what am i doing, wasting my time here. Let them believe what they want
i have work to do.
ST
What size board are you talking about? Can that process as you mention
even work for a double sided board?
That's a little too far over the top. From a complexity and startup cost
point of view, the choice is rather simple:
** cost of a UV box, versus cost of a laminator;
** cost of sensitized pre-clad or laminant, versus cost of transfer paper;
** cost and dimensional stability of mylar or acetate, versus short-term
stability of card stock backed transfer paper.
** cost of developer, versus cost of plain water to remove transfer paper;
** reusability of acetate or mylar, versus one-shot nature of transfer
paper;
** inkjet or plotter on hand, versus laserjet on hand.
For production runs of many multiples on automated equipment, photo exposure
has some advantages. For production runs of one or very few, the case for
100% of "HOMEBREW PCBs", you'll have to explain as though to a young child
the advantages that offset the cost and complexity of photo exposure.
>child the advantages that offset the cost and complexity of photo
>exposure.
We'll get into the quality of the finished product later. Have you ever
done a double sided board using TT? If yes then explain the TT process.
Sent: Wednesday, November 16, 2005 9:11 PM
Subject: Re: [Homebrew_PCBs] Re: A $500.00 "UV" non-trivial exposure
box.....
> From: "derekhawkins" <derekhawkins@...>
> paper;
> exposure
The process is very reliable, equipment is cheap, dense boards with narrow
tracks and SM parts are easy, and it is quite fast. Most of my boards are
one-offs. The main expense is the resist-coated boards.
Leon
Leon
Of course, it is "unfair not to offer different opinions if they
exist". From different opinions, we (or some of as)learn something.
The word "comunication" means "to share" (from Latin). We share ideas,
opinions and first of all - experencies.
Adrian
realy
> > useful.
"The
> > one.
> > Adrian
> I agree with you.
with
results,
people
pushing
(and i
sure
will
agreement,
would be
> ST
> paper;
Good comparison. I can add.
* learning curve finding a good inkjet transparency/ink combo verses
finding good TT paper.
* added mess of photoresist developer verses stripping paper from copper.
The choice depends on what process your are currently familiar with and
what quality you desire. The *potential* quality of photo method will
always be greater than TT method. If you cannot get expected results
with TT then switch to the photo method. If TT is working for you then
why change and go through a whole new leaning curve. If your starting
out then you have to weigh up the pros/cons of each. IMO both have a
similar degree of learning. As for subject tile of $500 UV light boxes,
that surly indicates to me a novice's conception of the photo method.
Adam
On Wed, 16 Nov 2005 22:11:27 +0100, derekhawkins <derekhawkins@...>
'Course it does, any size you can print.
I'm not going to explain it to someone who has no interest in using that
knoweledge, look in the archives it was discussed often enough.
Don't say something is no good when you don't have more than a rough idea
about it please.
ST
Sent: Wednesday, November 16, 2005 3:18 PM
>>exposure.
The workflow for both the top vs. bottom (or bottom vs. top) are identical.
-- Combine in Photoshop the artwork for top, bottom, and silkscreen. Print
this centered onto ordinary bond paper. Trim and tape a piece of transfer
paper over the artwork, and run it through the printer again, this time
printing onto the just-right sized piece of transfer paper. Separate the
three images.
-- Print the drill guide and legend. Stick it to the board with spray mount
adhesive.
-- Drill and debur the board. There are three unconnected vias in the board
corners for alignment pins.
-- Pierce the alignment vias on the top artwork; place the pins in the
board; place the top artwork over the pins. Visually confirm alignment, and
tape in place. Black toner should occlude all holes.
-- Remove the pins. Tear off a suitable size scrap of bond paper to use as
slip sheet. Fold in half; place the board with top artwork in the crease.
Run it through the laminator.
-- Soak off the transfer paper. Pulsar's paper comes off cleanly in a few
seconds. Dry the board. Examine for alignment errors and incomplete traces.
-- Cut a piece of green sealer paper to size; laminate to the exposed toner.
-- Repeat for the bottom. The sealer prevents the completed top artwork from
sticking to the slip sheet.
-- Etch.
With one success for one try with the alignment pins, I'm ready to try both
sides at once. Pulsar's paper releases completely when wet and makes it
brain dead simple with a clean and deburred board. Slight hole misalignments
are entirely attributable to imprecise manual drilling. Since the drill
guide is printed on the same printer as the transferred artwork, I'm not at
all surprised to not find any systematic errors.
Quality differences? It's difficult to see where the TT process can be
improved.
You drill before etching?
I do it this order:
For two sides copper and two sides legend:
Print all 4 views, cut out.
Align copper views against light, hold together, place in folded
cardboard, slide in PCB, run through fuser. (turn over and run again, note
that the folded cardboard is the secret to keep alignment.)
Remove paper, etch, rinse, scrape off toner.
Do the same as above with legend, only use silicone paper which peels
easily to leave a black legend (I still have coverage/pinholes problems
with the silicone paper, so i only use it for legend. But for etching the
grey paper residue bothers nobody ;-) )
If i only make single-sided i like to do the copper bottom and top legend
in one go, but sometimes i only have doublesided material so i will
transfer the legend after etching, like with 2-sided.
I'm not entirely sure if i understood your instructions.
I also use TT to make transfers to aluminum panels and stuff.
ST
On Wed, 16 Nov 2005 23:13:11 +0100, Mike Young <mikewhy@...>
> mount
> adhesive.
> board
> and
> as
> traces.
> toner.
> from
> -- Etch.
>identical.
So if you had to do 5 boards you would have to do the following steps
5 times, once for each board;
Printthis centered onto ordinary bond paper. Trim and tape a piece of
transferpaper over the artwork, and run it through the printer again,
this time printing onto the just-right sized piece of transfer paper.
Separate the three images.
mount adhesive.
board corners for alignment pins.
alignment, and tape in place. Black toner should occlude all holes.
Do you know how double sided boards are done using photoetching?
> From: "derekhawkins" <derekhawkins@y...>
box.....
young
> >>exposure.
you ever
process.
identical.
silkscreen. Print
transfer
time
Separate the
> three images.
spray mount
> adhesive.
the board
alignment, and
use as
crease.
a few
traces.
exposed toner.
artwork from
> -- Etch.
try both
makes it
misalignments
drill
I'm not at
be
> improved.
Oh yeah, takes only 5 seconds. So if you had five boards it would only
set you back 25 seconds. Do you have any shots of your double sided
work?
Sent: Wednesday, November 16, 2005 4:37 PM
>>identical.
The same would seem to apply to photo resist. Drill it; align artwork;
expose/laminate; develop/strip the paper backing. The step-by-step for photo
would seem to be longer.
In my mind, photo resist is still coming up short. There are more variables,
more opportunities for error, more equipment to acquire, maintain, and
adjust. And more junk in the sewers (not that I lose sleep over what my
neighbors might be doing or not).
All that aside, the quality of the artwork would seem to be paramount. The
laserjet prints very clean, very crisp edges. Filled areas are very dense
black and consistent. The Epson 1280 (28800 dpi) only manages a fuzzy edge,
not crisp at all, and not nearly as dense. If both are available, I expect
you would choose the laserjet. And if you're printing on the laserjet
anyway, why not go straight to the board for the onesie-twosie?
Actually, I didn't intend to seem so polarized. I'm asking it as a question,
as a newbie with no experience with photo, and only very little with TT.
What is the advantage of photo-resist compared to toner transfer?
On Wed, 16 Nov 2005 23:45:18 +0100, derekhawkins <derekhawkins@...>
> work?
Not one where you see what you want (alignment i guess).
<http://tinypic.com/ftn5nn.jpg>
was the last one, but i made no straight on shot and none from the bottom
where most stuff is. Also, it's barely two sided, using only the pin
headers as vias. Note that i use oblong pads so the copper you see on the
left (where it isn't soldered top-side) isn't offset.
If you take care you can get the alignment just as good as with photo,
it's the same task, but i still prefer single-sided quite often because
without THP the second side isn't so useful to me.
Especially if you have no lightbox with light on both sides it can be
tricky to align, and flip over, photoboards, as i remember.
ST
Sent: Wednesday, November 16, 2005 4:25 PM
box.....
Eagle's drill legend makes it a breeze; turn off the brain and poke the
right sized drill at the right symbols.
Also, I'm working up the verve to try plating the through-holes. The holes
have to be there before etching to plate them. I wrote Dow Corning for a
30cc sample of their conductive ink; too expensive to buy (Think and Tinker)
just for an experiment. Anyway, it's a long proof of concept. There's no
hope of plating the holes if drilling before etching doesn't work for me.
It's working well enough; I would be more pleased if I could remove my fat
fingers from the results.
What grey paper is that? I'm using Pulsar's paper, which works very well:
releases very cleanly and easily.
Just a long winded way of saying: align, heat and press, soak in the sink
for a few seconds. Repeat for side two.
2005-11-17 by Russell Shaw
>>>identical.
It's much easier. You only need to make the front and back printouts *once*.
(I have a draw full of re-useable printouts).
You lay one printout on top of the other and align them and stick them together
with two small pieces of double-sided foam tape (it is commonly 1.6mm which is
the same as the pcb thickness). This is a 30s operation, and easy after the
first time.
From then-on, whenever you want to make a double-sided pcb, just put the
blank into the sandwich, then put that into the lightbox and expose for
90secs. Turn over and do the other side for 90secs. Pull out pcb and remove
cellophane plastic layer from pcb. Put into flat container that has 10g/L
of swimming-pool NaCO3 (sodium carbonate pre-heated in microwave for 30secs
to 25-30degC). Brush developer for 1-2mins until well done, repeating for
both sides. Rinse, then put into flat tray with 10g/L NaOH (sodium hydroxide
garage floor cleaner), and heat in microwave for 1min to 50-60degC. The resist
just wrinkles and falls off. Rinse then dry. No scrubbing or cleaning is needed
anywhere.
Calibrate the lightbox *once* to match your pcb. Nothing else needs adjusting.
You're obviously using either crap ink, crap transparency or both. Genuine
epson ink and transparency gives a sharpness and density you couldn't fault.
There are certain refill inks and transparency that give acceptable results
too.
Double-sided pcbs with TT are a pain. Laminators cost a lot more than
building a lightbox. Lightboxes are a lot easier to build than a laminator.
TT can use non-coated pcb. You can spray on positive resist to pcb after
adequate cleaning, but a lot of users don't master the cleaning step.
You can apply your own dry-film resist to pcb, but it's a bit tedious
without the right machine.
2005-11-17 by derekhawkins
Not quite. You print the artwork only once (both sides for double
sided). You then align both sides and permanently fix the alignment
of top and bottom transparencies using tape. A lightbox is not
necessary for the alignment since you're dealing with
transparencies. This packet is then good for any amount of boards.
You never have to print or align the artwork again.
You then slide a board in the packet, temporarily fix it using tape
and expose one side. Flip it for the other side. Remove the tape,
slide out the board then insert another and so on. When done you
develop them.
>paramount. The laserjet prints very clean, very crisp edges. Filled
>areas are very dense black and consistent.
Quite the opposite on transparencies. Take a look here;
http://www.pbase.com/eldata/lasvsink
While the inkjet edges are more jagged this is actually a non-issue
since with the right exposure time those edges disappear. What you
cannot see in the laser print is the pin holes and dropouts that
will lead to holes and pits in the tracks. The same holes and pits
that are often there after etching a TT board. You just need greater
magnification in order to see them. The transfer of toner from paper
to copper is far from perfect.
>The Epson 1280 (28800 dpi) only manages a fuzzy edge,not crisp at
Fuzzy edge was discussed above but density of an inkjet print on
transparencies should always be several times greater than that of a
laserjet. You need to use Epson inkjet transparencies.
>If both are available, I expect you would choose the laserjet.
No, just the opposite. Furthermore, just about every laser printer I
have used has issues when it comes to CNC drilling. And this is not
something scaling can correct since it's inconsistent.
>And if you're printing on the laserjet anyway, why not go straight
When you magnify the tracks of your TT boards, do you really like
what you see?
I should have posted this shot of a single sided board (made from
inkjet artwork) in my previous post to demonstrate why injket jagged
edges in print are a non-issue but forgot. This is a macro shot at
original size, look carefully at the edges;
http://www.pbase.com/eldata/image/46673206/original
--- In Homebrew_PCBs@yahoogroups.com, "derekhawkins"
<derekhawkins@y...> wrote:
2005-11-17 by Mike Young
> together
> which is
> the
> first time.
I like that. Simple is good. Seems to me I have room for a small lightbox on
the worktable. What would you suggest?
>> The
>> edge,
> fault.
> results
> too.
Actually, it's very expensive ink, and better in the Epson than the Epson
ink. I fancy myself a photographer in other moments. Granted, everything
seen through a 50x microscope looks flawed. The LJ is just less flawed than
the inkjet.
> laminator.
My laminator cost $50. Even with a lightbox, I would still want to use it
for panels.
And expensive, at least at Think and Tinker's prices. Committing to 50 sq.
ft. of material is asking quite a bit.
Very nice. What's the plating? or is that just a trick of the light?
Sent: Wednesday, November 16, 2005 8:03 PM
> Photos:
It's tinned using plumber's solder paste. Doesn't wet and smoothen as
well as the more expensive stuff, hence the little pips here and
there. It was discussed here sometime back.
Sent: Wednesday, November 16, 2005 7:49 PM
Yes, Russell made the same point. Almost compelling. We could have gotten
here sooner without the posturing, no?
The Pulsar paper releases very cleanly. You'll see the dropouts as effluent
in the soak water. That hasn't happened since fugging up the first board
with raised burrs.
It won't be even close. Pigment inks, maybe possibly, but not dyes. If you
also have a laserjet, hold up one of each to a bright light.
That will be surprising, and I'll check it later as well. Seems
counter-intuitive that the rickety mechanism on plebian inkjets can hold
tighter tolerance than non-moving parts. (I'm assuming a lot, since I don't
really know what the laserjet really does in its dark innards.)
> what you see?
They're icky, likely from over etching. Still working on that part. I'll
hook up the scanner later and see what we see at 4800 dpi.
> From: "Russell Shaw" <rjshaw@...>
>>together with two small pieces of double-sided foam tape (it is commonly 1.6mm
>>which is the same as the pcb thickness). This is a 30s operation, and easy after
>>the first time.
A box with four 15Watt flouros (tubes about 20cm long), and 10-20cm from glass
where PCBs lie. Because i haven't used a flouro box for a while, there's a
chance that exposure may be too quick and you'll have to use less tubes.
Paint the inner sides of the box matt black, and have a good flat white
reflective surface behind the tubes. You can use long parabolic reflectors
if you can get them, and that they don't put out extra bright spots on your pcb
(reflectors are best if you want long distance like 20cm or more).
>>>The laserjet prints very clean, very crisp edges. Filled areas are very dense
>>>edge, not crisp at all, and not nearly as dense.
>>fault. There are certain refill inks and transparency that give acceptable
>>results too.
> ink.
It doesn't matter how expensive it is, if it's not compatible with the
transparency. I've seen replacement ink that's supposed to give equal
results on photo quality inkjet paper, but it doesn't work on the
epson transparency.
Unlike other transparencies that are just a rough sandpapery surface,
the epson stuff has a gelatine absorbing coating. Print heavy in epson
ink and you'll see the droplets absorb and sink into it. Other ink just
sits on top.
Certain combinations of refill ink and transparency can give adequate
resolution, but take longer to dry, and may not be as dark (still dark
enough tho).
If you use expensive epson transparency and ink, do a quick rough printout
on normal paper, then stick down a piece of transparency the right size,
and feed back thru for a final print. A packet of transparency lasts a
lot longer then. I only use the epson stylus 400 color (720dpi) for pcbs,
so the ink lasts a long time. I also only do negative printouts and have
large copper fills, so minimal ink is used for large boards. It would be
better to use a later model epson because the ink is cheaper and you get
1440 or 2880dpi (720dpi is adequate tho).
> the inkjet.
Non-linear dimensional warming of paper in a laser printer is a problem for
cnc and doing larger double-sided PCBs.
>>laminator.
> for panels.
Sent: Wednesday, November 16, 2005 8:24 PM
I caught the tail-end of some discussion when I joined the list. Can you
recap very briefly? Just smear it on and then into the toaster oven?
>If you also have a laserjet, hold up one of each to a bright light.
Regardless of ink type, the density of laserjet print **on
transparencies** will always be vastly inferior to inkjet print. Just
about everybody knows that.
You're a prime candidate for switching if that bothers you because
that's the characteristic signature of a TT board. It's due to hand-me-
down toner....LOL!
Russell Shaw wrote:
> Mike Young wrote:
>> ----- Original Message ----- From: "derekhawkins"
>> <derekhawkins@...>
> both sides.
Now etch for 7-8mins in ferric-chloride bubble etcher at room-temp, or put
into flat tray and brush over with paint brush. After bubble etching, it's
always a good idea to brush a bit to etch any stubborn parts. Precoated
boards get more stubborn areas of unetched copper you can get etched by
this brushing step, and the problem gets worse with age. I've still got
perfect results from 5-year old board i kept in a fridge, after some
brushing. The bubble etcher was $50 from a shop and is slightly larger
area than an A4 page (it stands vertical).
> hydroxide garage floor cleaner), and heat in microwave for 1min to 50-60degC. The
> resist just wrinkles and falls off. Rinse then dry. No scrubbing or cleaning is
> needed anywhere.
2005-11-17 by Ron
again, note
Could you elaborate on the folded cardboard? I'm having a problem
visualizing exactly what you are doing. I'm assuming you tape the
copperviews to maintian alignment, and then slip them into the folded
over cardboard to hold them and the pcb laminate static during the 2
passes through the laminator.
Also, did you have to mod the laminator to deal with the thicker
stack? Then again, I tend to think of cardboard as 3-4mm thick,
perhaps what you are using is thinner.
Currently, I use a Kepro exposure system, and it works extremely well,
but the time savings for TT are making me think of revisiting the process.
Ron
2005-11-17 by Jim Miller
i've got an hp7960 printer. is there any experience with inks and
transparencies that might indicate potential success with this unit?
tnx
jtm
I tested canons and HPs a few years ago and they had crappy transparency
that took ages for the ink to dry.
HPs use thermal boiling of the ink which easily leads to heads clogged
with viscous half boiled goo. Epsons use piezo electric plungers that
don't heat the ink. Canons were thermal too iirc.
Haven't tried lexmark or other brands since. Things may be better now.
Even with a slower drying printout, the resolution may be adequate
depending on what you want. All you can do is try.
Stay away from epson stylus 680 (a fairly old model, but newer than the
stylus 400/440/460 series) because mechanically they're a piece of crap
with unreliable paper pickup.
I don't know it, so I guess I'll have to prove it for myself. I'll run some
through the lab's densitometer later in the week.
> down toner....LOL!
I puzzled over this for a little bit, and it niggled at me as I hurried
through a small board so I would have something to scan. Could it be your
standards differ than mine? Higher? Lower? That doesn't seem right; quality
is quality. I'm used to commercially produced prototype boards. Certainly I
have no expectation my own boards will be in the same league. But laughably
inferior? No, that doesn't seem right. The first few boards were OK. Not
great; just OK. The holes aren't plated, and the pads could use a good
fluxing and tinning. But the copper itself was just fine, better than just
OK. And then it hit me, as I stared at the toner black traces staring back
at me from the rinse water. That's rather odd...
Pulsar sells a green sealing film to overcoat the toner. In my haste this
evening, I forgot to apply it. I had etched the board with only the toner
for a resist. Sure enough, wiping off the toner with Goof-Off left a behind
a mottled mess where there should be shiny copper. The trace edges were
pitted; and the SL3 pads were... just yuck. It would take a blind man to
miss the difference, never mind the microscopy.
Derek, I know now what you must be saying. Toner alone is not a very good
resist. However, combined with a sealing film, such as Pulsar's green TRF,
toner transfer is every bit as good as any other process. And it's fast,
too. As late as it is over here, I know I can just run off another one
before heading to bed.
2005-11-17 by Leon Heller
Sent: Thursday, November 17, 2005 2:30 AM
box.....
> epson transparency.
> sits on top.
> enough tho).
Mega sells sheets of film specifically made for PCB transparencies in both
laser and ink-jet printers. The laser printer stuff works very well, but is
expensive, so I usually use tracing paper. I keep meaning to buy some of the
ink-jet film to try in my Epson.
http://www.megauk.com/
Look for JetStar and LaserStar under Artwork Aids. There is a new JetStar
Premium film for high res.
I'll get some JetStar film when I get back from a short holiday, and try it.
I'll ask them what the best printer is, for it.
Leon
2005-11-17 by Terry Mickelson
I have the Techniks Press n peel heat press and ran into some bad
luck with a bad batch of pnp. If I were to use Pulsar paper, what
would be a good starter time and temperature for the press?
TM
2005-11-17 by JMBlanco
Hi Derek and group
Good job Derek with drawers & camera.
I read all messages in this group and have never read something I want to
point to the group.
The idea is to build a UV box "from a roadside garbage dump" desktop
scanner. You have the box, the glass, the lid and maybe the mains switch in
the older (newer have DC supply) and pilot led. All of them already cut and
assembled. Of course, you must to empty the remaining hardware and
accomodate the lamps, starters and only one ballast for 4/5 lamps (the ones
that are employed in the mosquitos traps of abt 30 cms.)
I guess the glasses in these scanners must be good quality, ie., well flat
and parallel faces.
Here I have already "empty" 3 scanners that are waiting in my shelves to
accept the modification.
Additionally, if you save the original neon lamp+support+inverter you get a
nice 12VDC neon lamp to operate from battery in black-outs. Do not forget
the steppers, belts, etc.
Thanks for reading.
Jose.
Sent: Wednesday, November 16, 2005 2:32 AM
2005-11-17 by Les Newell
The best thing to do is try. Get some transparency and print a board on
it. Hold the transparency up to the light. If the lines are dense and
clean then you are probably on to a winner. A lot of modern inks have UV
blocking pigments so you don't always have to use black. For instance
with Epson Durabrite inks I found green seems to work best. The
transparencies come out looking fairly pale but they work well.
As with any pcb making system the secret of success is to keep
experimenting.
Les
>tnx
>jtm
2005-11-17 by Stefan Trethan
On Thu, 17 Nov 2005 00:34:14 +0100, Mike Young <mikewhy@...>
It's not grey, but the white clay on the paper and the black toner make
the residue appear greyish. It's just inkjet paper.
ST
On Thu, 17 Nov 2005 02:49:28 +0100, derekhawkins <derekhawkins@...>
> what you see?
YES! ;-)
2005-11-17 by guja
Is there anyone going to change the subject line?
tnx
Stefan Trethan <stefan_trethan@...> wrote: On Thu, 17 Nov 2005 02:49:28 +0100, derekhawkins
> what you see?
YES! ;-)
Yahoo! FareChase - Search multiple travel sites in one click.
You guessed right, relatively thin cardboard. maybe 0.5mm. Like the big
parts of cornflakes boxes.
Again, the procedure:
You cut your layout pretty close to the board edge, but with 2cm border on
one side (same side both layouts).
Then you put together the toner sides, and slide around holding against a
light until it matches.
Now you should have prepared that cardboard, folded in the middle, well
larger than the PCB, because you open the folded piece with one hand, and
slide the layout in with the excess border towards the folded edge. Now
you hold the three pieces together with your other hand, from the outside
of the cardboard, on the folded edge. This allows you to slide the PCB in
and position (this is why you had to cut it close to the board outline on
all but one side, makes positioning easier). Let the cardboard close and
simply hold the stack together (pressing at the PCB). Feed the whole thing
folded edge first. Depending on your fuser you might want a second pass
flipped over, or even two more runs with the cardboard missing. The paper
should be stuck fast by now.
The strange thing is, if you do this without the cardboard the fuser will
"drag" one paper forward, at the board edge. If you imagine the papers
beeing together with zero distance before the board, and 1.5mm then,
there's a 1.5mm length to be taken from somewhere. With the cardboard
feeder, although it makes a crease in it where the board starts, there
seems to be no such movement.
The fuser could easily take the added thickness without modification,
dunno about other machines. But you can also tack it with a iron if you
run into trouble. Then you needn't even use the cardboard, as the iron
doesn't move anything.
ST
2005-11-17 by whoop@blueyonder.co.uk
Greetings from the UK. I joined this group a week or so ago. So I am
new to all this. I have just used the toner method and it seems to
work fine for me. I am happy.
1] I used one of those abrasive PCB cleaner blocks to get a shiny
board, making sure not to touch it with greasy fingers afterwards.
Deburring the edges is easy, you just whack them down the edge of a
metal table to fold the copper back down. Use a file if you must.
2] Printed my images using an Apple Laserwriter 4/600. I found an
ancient Mac OS9 version of the laserwriter utility that lets a person
set the default print density on the printer. The toner cartridge was
an exchange refill, so nothing special there.
3] Used the wife's domestic iron on a hot setting. Once the paper had
started to stick down I could happily move the iron around to give an
even heat. I think the art here is to maintain intimate connection of
paper and PCB without using undue pressure on the iron to squidge the
pads and tracks. I didn't time it or anything. After a few trial
boards it worked fine for me.
I Tried several papers I had around the house. I used a paper often
used for digital prints called 'Mellotex'. This is made by Tullis
Russel. Free UK samples 0800 74 74 77. This seems to work OK, I get a
good dense black but it is a bit hairy. After a good soak in water
the hairs mostly come off. I found the black toner was so well bonded
on I could scrub the boards. I also tried a paper called Detec, also
used a lot by digital print houses, but that was no good at all. The
wife's silicon baking parchment worked wonderfully on the transfer
side of things, but didn't accept a very dense coating of toner to
start with, so I abandoned it.
I looked up that Staples glossy paper, but the UK order codes don't
seem to match the US ones. Can anyone identify the paper I should try
for me please?
<http://www.staples.co.uk/ENG/Catalog/cat_class.asp?
CatIds=1101,1287&name=UK%5FCL%5FPhoto+Paper>
4] Did a quick very minor touch-up with a Staedtler Lumocolor pen.
318 series. I read that people insist on the red pen, but I used
black and it works just fine. This I shall have to hide so that my
wife doesn't steal it for writing on freezer bags in the kitchen.
5] Into a ferric chloride bath
6] Erm, not sure my wife realises her nail varnish remover has
disappeared yet.
7] Drilled the holes with a cheap but very solid cast metal pillar
drill that takes a standard drill. This cost 5 GBP, about 8.6 US
bucks, from LIDL, a European chain store. I've been drilling .5mm
holes happily on this.
Excellent. Job done. A cheap answer to my needs. I was going to use
Press'n'Peel but I won't bother with that expense unless I want to
get down to really fine work. Is P'n'P really that great?
Whoop John
i'm a complete newbie to this. what transparencies would you suggest? are
there pcb specific ones? what are sources in the US? i assume this isn't
office depot stuff...
tnx
jim
Sent: Thursday, November 17, 2005 4:25 AM
box.....
it.
Sent: Thursday, November 17, 2005 12:46 PM
box.....
Tracing paper works quite well and is cheap. It might look opaque, but it is
quite transparent to UV. It's what I use most of the time with a laser
printer.
Leon
Leon Heller, G1HSM
leon.heller@...
2005-11-17 by lcdpublishing
ANother thought I had about using the photo-resist boards was the
potential for another problem that I don't know if there is a work
around or not.
If you expose a board and the exposure doesn't work out as planed,
it is then ruined isn't it?
For example, with toner transfer, if it turns out bad, a missing or
pitted traces or whatever else can go wrong, I wash off the toner
and do it again and again till it is good enough for what I need.
The only loss I have is time and paper.
However, from an ignorant point of view ( I have never tried this
process), if something goes wrong, the board can't be used again in
the potoresist process can it?
Also, as I don't know what things look like along the way, can you
see the traces with the resist on them after developing? If so,
what does the developed photoresist look like?
TIA
Chris
Sent: Thursday, November 17, 2005 3:55 PM
> around or not.
When you get the process right, that is very rare.
Not unless you strip off all the old resist and use dry-film or spray
resist. The latter doesn't work very well.
There is a faint image after developing.
Leon
Hi Jim,
Actually it is Office Depot stuff :-) Transparencies are often used on
overhead projectors so any decent stationery supplier should stock it.
You must make sure you get transparency that is designed for inkjet.
Les
>tnx
>jim
Version: 7.1.362 / Virus Database: 267.13.3/173 - Release Date: 16/11/2005
Hmm, that sounds like a good idea. I must give it a go.
Les
>printer.
>Leon
It usually doesn't go wrong once you figured out how to do it, but the
same is the case with TT, i very rarely have a bad transfer.
With my photoboards the resist was discolored faintly after exposure (i
think it was yellowish but not 100% sure). After developing one could see
it quite well, it was kind of smoky transparent.
My main problems were exposure (getting a decent film was impossible with
my laser printer and the papers/transparencies i had. I used this spray
for a while that makes paper translucent, but it was not really good, it
works great as label remover tho.)
Also, i had some old board material that didn't develop very well.
I'm sure i could have gotten it to work eventually, but TT seemed, and is,
so much less work, and this way i can also make component legend and front
panels and stuff (even my a house number sign is a PCB!).
ST
On Thu, 17 Nov 2005 16:55:36 +0100, lcdpublishing
> TIA
> Chris
2005-11-17 by cristian
Could you accept to change the subject?
>ST
> > TIA
> > Chris
>Yahoo! Groups Links
2005-11-17 by Alan King
>i have work to do.
>ST
Heard that. Part of the reason I've dropped in and out of the
discussions lately has been working on more important things.
Especially now with PCBEx cutting the quantity in half from CustomPCB, a
single even low volume producing product can pay for made boards.
$125+ship for five 8x10 boards is simply very reasonable. I still have
my stack of 4 laserjets and will test out direct print to board fully
when other things are going a bit more smoothly, but until then I doubt
I'll make many more boards by hand, TT or UV. Simply too cheap to have
them made, I doubt you can come out much ahead even if you just count
minimum wage for your time.. Still ok if you just have to have an
instant board, but that usually isn't so important vs a week or so.
Alan
2005-11-17 by David P Harris
Alan King wrote:
>...Especially now with PCBEx cutting the quantity in half from CustomPCB, a
Can you be a bit more specific about this?
David
Hi John, sounds like our processes are very similar! I have been
trying different papers around the house and office and most seem to
work. Don't use my wifes nail polish remover though, I use
the "Manly" version called acetone :-)
I haven't tried the staples paper yet myself, but will sooner or
later.
As for press-n-peel, I have no idea as I have never used it.
However, I have seen some of the stuff at the local radio shack and
most of it looks wider than the .010" I am getting using toner
transfer. Don't know anything more about it other than a quick
glance of the "stickers" hanging on the wall there.
The most recent toner transfer lesson I have learned (or am
learning) is that not all PCB material is the same. I have tried
about 3 different brands/types of pcb material and all worked
fantastic. Then I bought some from a different company and
everything started getting really bad for the toner transfer. I
tried sanding, buffing with 1000 grit, scrubbing with scotch bright
pads, cleaning with every solvent in sight and nothing worked. The
final solution - a pre-soak in Ferric Chloride for a few minutes,
then a good cleaning etc. Worked good on the last two circuit boards
I etched.
It's a neat process and kind of fun too!
Chris
am
to
afterwards.
a
person
was
had
an
of
often
get a
water
bonded
also
The
transfer
to
don't
try
> for me please?
pen.
my
> disappeared yet.
pillar
use
to
> Whoop John
just got back from office depot with some of their house brand inkjet
transparency material. also got some translucent vellum used for making
fancy greeting card inserts with inkjets.
i'm going to make up some test patterns with a fineline serpentine next to a
fineline interwoven to act as open/short test patterns. i'm then planning to
step and repeat this on a page so i can try different colors on the
patterns. finally i'm planning to do this with a 1-8 interval exposure test.
any recommendations on any of these phases? any suggestions on color
selection? i was going to try straight hp primaries (red, yellow, blue) and
black. i also saw green mentioned which would be a yellow/blue mix i guess.
of course i'll post results.
tnx
jim
>David
http://www.pcbex.com/
https://maxima5.abac.com/pcbex/product_index.asp
http://www.pcbex.com/product_help.asp
But some hinges on their "We do not accommodate gold fingers, step &
repeat, cutouts or blind/buried vias in our standard prototype PCB
online order.". Actually a bit irritating that someone ever wrote that
sentence as is, 'step & repeat' refers to so many different things it's
a silly error to have not qualified it. Panelizing your order for you
is a small PITA for them so many won't do it on prototypes etc, on the
other hand some people slackly use it to also refer to a pre-done
board. Long as they'll take my 8x10 then they'll be right in line with
CustomPCB's 8x11, and have mask too. If on the other hand they complain
about my several boards that I will cut out to my needs later, then
they'll be a bit behind CustomPCB on overall pricing. Needless to say
I'll be sure and report how it goes. I should have already had these
in, just had too many other things happening at once. Actually, while I
have it up I'm sending an email to support and a picture of the panel to
see, may as well find out now. They'd still be quite reasonable on some
things, just not on a panelized setup if they won't..
Alan
> Whoop John
I've never used PnP, but i strongly doubt it can increase the resolution.
My experiments have shown that you can make traces down to 6.66 mil
reliably with inkjet paper, but 3.33mil and smaller won't come out right
due to underetching. I don't think this is a resist question, i suspect it
can only be overcome with a better etching system, although the resist
might also have to do with it. See
<http://trethan.at.tf/pub/img1/PCB2.JPG>
for a test i did a while back.
ST
P.S.: Better get a old clothes iron, some acetone for yourself, and a
stock of spare staedtler pens to surrender as long as you still can ;-)
I think it comes from CNC.
It is about as silly as "silkscreen" for component legend, i don't like it
either.
You considered olimex?
ST
The sticker like things are dry transfer, not press n peel, so maybe
you're mixing the two. Never seen PnP at Rat Shack, but haven't been
there much recently either.. PnP looks like a blank sheet, and is
almost the same as TT since it's just a special sheet to print on for TT..
http://www.techniks.com/retail.htm
Look there, the sheet is all blue and you print on it, there isn't
anything pre-printed..
Alan
2005-11-18 by Russell Shaw
>>i have work to do.
> Alan
Even if they gave the boards to me for free, it's still much more expensive
than doing it myself. If i design a pcb, i can build it in an hour keeping
my same train of thought and get a result, and even iterate a new board if
needed. Getting them made outside means waiting atleast a week (usually two
or three unless you pay double).
> around or not.
If you haven't developed it, you can expose it more if you align
the printout again with what you can see on the resist.
Not after developing. However, you can scrape bits of resist
off with a scriber and add bits with a resist pen.
Undeveloped, the patterns look slightly lighter or darker than
unexposed areas. When developed, you can see the copper.
2005-11-18 by Alan King
Hey, if you need that, then knock yourself out. I can generally
remember exactly what I was doing a week or two later, and don't have
the slightest problem with a 2 week delay on that front.. But for sure,
after costs and time you're not coming out as much ahead of my $3 per
board as you are thinking, and I'm getting PTH, mask, and not even
having to make a board..
Alan
That means i have to find something else to do while the client waits
because of ones laziness to do it themself.
> But for sure,
I'd still be in front compared to waiting for two weeks for a pcb and
having the pcb vendor pay me $200. Anything more than simple PCBs usually
need a second refinement, and it's far better to have the vendor make
only the final design.
>>But for sure,
Great, guess what, your special need for immediate boards was already
excepted in my original message with "Still ok if you just have to have
an instant board, but that usually isn't so important vs a week or so.",
you must have missed it. So everything you've said doesn't have
anything to do with what was being discussed in the first place, actual
dollar cost of the boards, and no, you're not really ahead on that by
much. At $150ish for 5 8x10"s you can't be more than $150 ahead, and
after taking out board costs etc it'll be notably less. Plus your time
not spent doing more productive things than making boards, or wasted if
you like being lazy or don't have any work to do. Plus no mask. Plus
you had the work of making the boards. Just like I said in the original..
Alan
>>>But for sure,
If i save 2 weeks (it's
usually more than that) on an item that's made in a product to a total
value of $100k/month, i've moved the income stream closer by a value of
$50k. That's the reason there's buyers for crappy little milling machines
for $20k. Hopefully someone on the group will come out with a better and
cheaper one. I'm going to make my own anyway.
So regardless of a pissy little $3 a board or $200, time is everything,
hence this group.
2005-11-18 by Stefan Trethan
On Fri, 18 Nov 2005 01:40:03 +0100, Russell Shaw <rjshaw@...>
> expensive
> keeping
> if
> two
I'm with you there.
If they'd make them for free i would still make my own boards. I might let
them make some of those that are non-urgent, but usually i want to have a
board right when i finished the layout.
In a weeks time it is probably useless because i'd have found a couple of
things to change or add in the meantime ;-).
Also, i do have experience with board houses, and the effort of preparing,
checking/verifying, and sending the files plus placing an order is, for
small quantities, far more than the work i have making my own. I know
_everything_ about the design, i can omit many of the steps necessary to
have another person make it.
ST
> Alan
Alan, you must consider some of us don't charge for work on our own
projects ;-)
I for one much prefer working for myself than working for someone else
half the time.
I can sometimes not even remember what i was planning to do ten seconds
ago, so.....
ST
2005-11-20 by lists
In article <437C1364.5040001@...>,
I've been using a Cannon S4500 with 3M film (couldn't easily find Cannon
film) and it seems OK to me.
2005-12-10 by Russell Shaw
I got a 20W (equiv. to 100W filament) spiral-type black-light blue UV
compact flourescent lamp yesterday from Bunnings for $10. These would
work well in a conventional round reflector.
http://www.nelsonlamps.com.au/
Page 5 of:
http://www.nelsonlamps.com.au/products%20page/PDF%20Files/Lamps%20CFL%20Superior%205000hr.pdf
You could just mount a few light sockets in the bottom of a box (or one socket and
a reflector) for these and put a plate of glass and lid on top of the box.
