Song Mode
Song Mode
2003-04-07 by thematthammon
Hey folks, I'm thinking strongly about getting an XL-7, and need to
know some things.  Is it possible to train 15-20 sequences together,
convert that into one master sequence, and start to overdub song-
length performances, i.e. bass and piano tracks that are not loop-
based?
I had an MPC2000XL, and the sequencer-especially song mode was
seamless, but the sound manipulation required alot of external gear.
Thanks for your input.
Matt Hammon
Re: [xl7] Song Mode
2003-04-07 by David
Yes.  That's EXACTLY what you can do.  YOu can chain a bunch of patterns
together and then you get 2 extra tracks in song mode to tweek, play fills,
and pump the mofo up!
To: <xl7@yahoogroups.com>
Sent: Monday, April 07, 2003 2:15 PM
Subject: [xl7] Song Mode
> based?
> Matt Hammon
Re: Song Mode
So song mode turns all of the chained patterns into one long sequence
that you can perform real time tracks on?  Do you just tell it which
pattern to insert where and for how many repeats?  Do you still have
individual track control in song mode? Can you do spot erasing on
each track to bring things in and out without having to automate
mutes? And do you have to save to your computer via the included
software?  How much info can be stored internally and how can I
expand that potential? Can you describe the differences between the
MP sounds and the XL sounds?
thanks
Matt
patterns
play fills,
> From: "thematthammon" <thematthammon@y...>
to
together,
> > based?
gear.
> > Matt Hammon
Song Mode
2003-07-18 by erik_magrini@Baxter.com
Sure, it's on page 106 of the latest XX-7 manual (revision G), which you
can download here:
http://groups.yahoo.com/group/xl7/files/Command%20Station%20Info/
It's the file called "XL-7 OpMan-G.zip"
If you meant how to chain patterns in the ER-1, then that's on page 34 of
the Er-1 manual.
Cheers,
could you point me to a page in the manual that shows how to link
different patterns up into a song mode please
Song Mode
2004-01-17 by xkrider1
Has ANYONE ever actually done the Copy/Paste procedure in the Song
Mode?
Re: Song Mode
2004-01-18 by realm619
Sorry man, only in Pattern Mode.
> Mode?
Song Mode
2004-05-20 by steve_the_composer
I am finally getting into using the E-Mu sequencer for composing and
orchestrating and am discovering even more complexity than I had
imagined.  It seems like all of the E-Mu components need to be
considered as separate subsystems.  I am seeking (1) confirmation of
stuff I am discovering and (2) insights that others may have
discovered.
I am working on a song that (so far) has Drums (Track 1 Channel 1)
and Keyboard (Track 2 Channel 2).  I am overdubbing midi sax leads
with realtime song mode record.
1.  Track mutes buttons seem only to apply to pattern data .  Correct?
2.  Volume and pan knobs seem to apply to both pattern and song
data.  Correct?
Perhaps there are settings that affect these, but I haven't found
them yet.  Thanks.
Re: [xl7] Song Mode
2004-05-20 by erik_magrini@Baxter.com
>>>You can record Mute buttons toggles only in Song mode, not Pattern
Mode.  However, if I remember correctly, they do function tha same for
both modes regardless.  What problems are you seeing with these? <<<
2.  Volume and pan knobs seem to apply to both pattern and song data.
Correct?
>>>Depends.  If you mean changes in real-time, then yes they affect
pattern and songs.  However, you can specify in the Song Edit menu whether
Vol & Pan settings are used from the Pattern, the song, or both. <<<
use of, or taking of any action in reliance upon, this information by
material from any computer.
For Translation:
Re: Song Mode
2004-05-21 by steve_the_composer
Thanks for the replies.
Re: (2) I found the the EVENT SOURCE menu and will play around with
that.  Thanks for pointing me in that direction.
Re: (1) In song/step mode I created a chain of patterns.  Then I over
dubbed the midi sax in song/realtime mode.  When playing back the
song, the mute buttons only turn on/off pattern tracks.
I was trying to do a music-minus-one thing where I have some
performance options to (1) to mute the realtime data, (2) to play
harmony/counterpoint to the realtime track, etc.
It seems like there is just one song/realtime mode track.  This track
can be routed to MultiA OR MultiB with none, int, ext, both
destinations.
SO, I duplicated each of the individual patterns and laid down some
lines with the midi sax on a pattern by pattern basis and created a
new song chain of just patterns.  (This gave me good practice doing
mulitple retakes--I just left the pattern edit menu at erase track.
Couldn't be easier!)
It would seem (in theory at least) I can copy the song chain and just
set up different intros as my first pattern with mute configurations
for the different music-minus-one options.
Thats for another day.
Looking forward to having songs in a box without having to cart
around a computer.
Correct?
Pattern
for
data.
> Correct?
whether
> rEalm
entity
legally
than
privilege
other
by
> For Translation:
Re: [xl7] Re: Song Mode
2004-05-22 by Aaron Eppolito
Correct, the track mutes mute PATTERN tracks only.
Hmm, muting the song track isn't doable.  My bad.  I see two
workarounds:
1) if you don't have volume events in your song track and you're only
really sequencing one channel, you could use the volume knob
corresponding to the channel you're sequencing.
2) not particularly user friendly, but you could go to the routing
screen and turn the song track destination to "none" when you wanted to
mute it.  I *knew* there might be a use for "none"... =)
> (This gave me good practice doing mulitple retakes--
Actually it could!  Press Erase+Track button to erase that track.  It
doesn't even take you out of record mode or stop playback!
> Correct?
Volume and pan knobs affect *channels* not tracks.  Think of the synth
engine and sequencer as two different entities (cuz they really are).
[song track    ] --> / ------- \ --> [internal synth channels 0-31]
                     | routing | --> [external port A ch 1-16]
[pattern tracks] --> \ ------- / --> [external port B ch 1-16]
Mutes affect pattern tracks, knobs affect internal synth channels.
-Aaron
Do you Yahoo!?
Yahoo! Domains \ufffd Claim yours for only $14.70/year
http://smallbusiness.promotions.yahoo.com/offer
Re: Song Mode
2004-05-22 by steve_the_composer
Thanks for confirmations, clarifications, corrections, and
workarounds.
--- In xl7@yahoogroups.com, Aaron Eppolito <synthesis77@y...> wrote:
[snip]
> workarounds:
> only really sequencing one channel, you could use the volume knob
> wanted to mute it.  I *knew* there might be a use for "none"... =)
Makes sense to have a canned lead (or harmony/counterpoint) on
seperate designated channels (with no realtime volume in there) and
play-though live on a different channel.
> It doesn't even take you out of record mode or stop playback!
Fantastic!!  With enough practice I may get to master hardware-based
song-writing, composing, and orchestration on the E-Mu sequencer.
> > data. Correct?
> synth engine and sequencer as two different entities (cuz they
> really are).
Gotcha!   Thanks.
--Steve
2004-05-23 by Aaron Eppolito
PS. if you did want volume changes recorded in, you could use cc#11
which is expression.  Simply assign a programmable knob to cc#11 and
record that instead of volume (cc#7).  Actually, this is a good idea in
general, because you can then use expression for musical things while
still being able to use the volume knobs for "mixing" purposes.
-Aaron
Do you Yahoo!?
