Recording multichannel arps from triggers
2004-08-10 by joepm.rm
Just reviewing bits of the manual and appear to be stuck on pages 26-
8!
XL7, v2.0, using PX7 manual.
Setup the multichannel arps, tried to record the trigger buttons
to "automate your multichannel arpeggiator performance".
followed the instructions, but it's not working.
Have set triggers to seq, tracks 1-3 are set to channels 1-3 and
different arp presets.  with rechannelize on though, the triggers
only use the track in the display.  with it off, things work until i
try to record, at which point it sounds fine but either nothing gets
recorded or only one of the tracks intermittantly (as if triggering
the other tracks is cutting it off)
is there a known problem with this?
I've read in the tips and tricks:
To record into the internal sequencer, set the TRIGGERS destination to
be "seq" instead of "int" or "ext" This way, the triggers will be
routed to the sequencer, which will then decide where to route it
based on the track settings (provided you have rechannelize on).
but it does no good.
Re: Recording multichannel arps from triggers
2004-08-10 by steve_the_composer
A year ago or so, I got into using Trigger Notes (latched) to turn
arps on/off for developing a possible performance modality. I forgot
entirely what I did, but I do notice that the trigger notes setup
allows you to set the channel to Basic, C01A -> C16B (as well as to
various destinations).
Over the past few days, I have been wanting to set up my E-Mu so I
can play tracks and triggers as arps, so I am ripe for testing your
setup.
What are your channel settings for the triggers?
Intuitively, I am thinking of comparing rechannelize always and
rechannelize on record to test your particular condition.
Have you tested both?  If so, any difference?
--Steve_the_diagnostician
26-8!
i
gets
to
T1 Trigger, Ch 01A
T2 Trigger, Ch 02A
T3 Trigger, Ch 03A
all are set to seq
with rechannelise always, i only get one arp (the one in the display)
over all three triggers.
with on record, the arps sound right until i try and record them,
after which i think (not at XL7 at moment) i get the one arp playing
sporadically (sounds as if it gets cut off as the other triggers are
played)
--- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@p...>
forgot
> setup.
> 26-8!
until
> i
> gets
triggering
destination
> to
Re: [xl7] Re: Recording multichannel arps from triggers
2004-08-10 by Aaron Eppolito
Again, you can only record one track at a time.  If you want to record
three different channels of arps, you must record into a MultiA (or B)
track.  Second to last screen in the pattern/song edit menus.
With rechannelize on, you're getting all three triggers rechannelized
to the current track.  With it off, you'll only hear the
rechannelization on playback.  Leaving rechannelize all the time is
recommended since you'll always hear the same thing as when you play
back.  If it's wrong with rechannelize on, it'll be wrong at playback.
-Aaron
--- "joepm.rm" <joe@...> wrote:
> T1 Trigger, Ch 01A
> T2 Trigger, Ch 02A
> T3 Trigger, Ch 03A
> all are set to seq
> played)
Do you Yahoo!?
New and Improved Yahoo! Mail - 100MB free storage!
http://promotions.yahoo.com/new_mail
It would seem that the only thing you need to do differently is to
use Multi-A [CHANNEL ASSIGN] when you record the track with the multi-
channelled arp triggers [with rechannelize always on].
Thanks for raising the issue.  It ties in with a performance modality
I have been developing.  In fact, I learned today that I can have the
following live setup (for example):
Triggers 1 -> 3 start/stop beats groups 1 -> 3
Trigger 4 start group 4 [unlatched]
Trigger 7 mute/unmute all active beats
Trigger 8 stop all beats
Triggers 9 -> 12 internal arps, bpm, and other sounds
Triggers 13 -> 16 external arps, bpm, and other sounds
and still switch back to my track mutes for pattern looping!
Thanks for the reminders on rechannelize and track recording, Aaron.
--Steve
> record three different channels of arps, you must record into a
> MultiA (or B) track.  Second to last screen in the pattern/song
> edit menus.
[snip]
> -Aaron
> --- "joepm.rm" <joe@m...> wrote:
> > T1 Trigger, Ch 01A
> > T2 Trigger, Ch 02A
> > T3 Trigger, Ch 03A
> > all are set to seq
> > display)
> > playing sporadically (sounds as if it gets cut off as the other
> > triggers are
> > played)
2004-08-11 by joepm.rm
Cheers Aaron (and Steve), I'll try it tonight when i get home.
Even though i thought i did have it recording into a multi A track, i
seem to of somehow forgotten the old "recording one-track at a time"
so i am sure that is the flaw in my thinking.
record
B)
rechannelized
playback.
> -Aaron
> > T1 Trigger, Ch 01A
> > T2 Trigger, Ch 02A
> > T3 Trigger, Ch 03A
> > all are set to seq
display)
playing
are
> > played)
> Do you Yahoo!?
2004-08-11 by steve_the_composer
Hope thatfixes it for you!
I keep forgetting that after I muck up my first take of a track and
revert to a saved version that has the track name, length, etc.
stored, the channel assign loses the MultiA [or B] and Destination
settings because there's no data [multitrack or otherwise] on the
track.
--Steve
> i seem to of somehow forgotten the old "recording one-track at a
> time"  so i am sure that is the flaw in my thinking.
2004-08-11 by djnorythm
Hey Joe,
  Where ya going w/ that arp in your hand? ;)
  I would like to hear the command station do the "machine gun"
multi arp thang.
  Seriously,  I would like to hear the mp3 w/ you finish.
  I will try doing a multi arp freak out this weekend.
thanks for the post...
2004-08-11 by Aaron Eppolito
Good point to make.  I'd recommend two things: first, before you save a
pattern with a new track, throw a quick volume message on the track
(step edit tick 0, wiggle volume knob) so you won't lose your settings.
 Second, and more importantly, try using the "erase track" button
shortcut when you mess up a take.  Simply press Erase+TrackButton to
delete the events on a track.  You can even do it while recording (I
use it instead of replace record).
-Aaron
> track.
Do you Yahoo!?
New and Improved Yahoo! Mail - Send 10MB messages!
2004-08-12 by steve_the_composer
Excellent suggestions.  I have avoided erase track for some reason.
(Is it an instant erase without a second query?)  Also, I seem to
recall that I would need data on two channels to avoid losing the
MultiA/B assignment when saving the pattern.
--Steve
> save a pattern with a new track, throw a quick volume message on
> the track (step edit tick 0, wiggle volume knob) so you won't lose
> your settings.
> -Aaron
and
Destination
> > track.
> Do you Yahoo!?
2004-08-12 by joepm.rm
Right i've got it working, but i'm not sure whether this matches the
explanation i've been given!!
triggers 1-3 set to ch1-3 and seq.
ch1-3 set to three different arps
channel assign for track 1 set to multi A, int
(in the midi menu) rechannelize input set to off
now it works on play and record, track one has three different
channels of different arps. (or should i say three note events on dif
channels playing arps, assuming all i've done is pressed each trigger
once!)
if rechannelize input is set to always, then all that gets played and
recorded are three note events on the basic channel - that is,
whichever is in the display.
(i've checked this in the event list)
slightly concerned that my command station is working back-to-front
regarding the "rechannelize input" function
record
B)
rechannelized
playback.
> -Aaron
2004-08-12 by erik_magrini@Baxter.com
Yep, one press and BAM, your track is gone :)  I use this one all the
time...
use of, or taking of any action in reliance upon, this information by
material from any computer.
For Translation:
