Emax
Chinese floppy emulator
2014-08-13 by cheju_99@...
Anybody have tried to put a cheap chinese floppy usb emulator onto an emax 1 ????
disk brake Picture - More Detailed Picture about 1Pcs NEW Floppy Disk Drive to USB emulator Simulation For Musical Keyboard DropShipping Picture in Floppy Drives from Shopping In Lisa's Store
best regards
Ricardo
Re: [emax] Chinese floppy emulator
2014-08-13 by Robert Van Kuran
Get an HxC much more support for images.
-RVK
> On Aug 12, 2014, at 5:56 PM, "cheju_99@... [emax]" <emax@yahoogroups.com> wrote:
> disk brake Picture - More Detailed Picture about 1Pcs NEW Floppy Disk Drive to USB emulator S...
> disk brake Picture from Shopping In Lisa's Store about 1Pcs NEW Floppy Disk Drive to USB emulator Simulation For Musical Keyboard DropShipping Picture, disk drive adapter Picture, disk Picture and more on Aliexpress.com
> View on www.aliexpress.com
> Preview by Yahoo
> best regards
> Ricardo
2014-08-13 by Ted Summers
My understanding is that these don't support other than DOS images.
To clarify- the manufacturer GOTEK supports FAT12, FAT16, FAT32
Image size 1.44 MB.
Emax doesn't use those MS_DOS based formats.
Emax doesn't use 1.44MB, only 720K disk (DSDD)
In addition, there is no information on jumpers to select DS0.
Someone got it to work in Amiga by re-engineering the firmware to use the AMIGA format.
So it is not a plug and play solution from my research.
If it was, believe me for the price everyone would be buying them as they can be had for as low as $12.
-Ted
-RVK
best regards
Ricardo
Re: [emax] Re: Chinese floppy emulator
2014-08-13 by JAMIE logan
no it does not work
even in dos based machines it can be a right pain to get working
there is jumpers for ds1 ds0 there are jumpers for ready and other signals
there is no support for them when you receive them you get some one else's software
i have fitted them to k5000r
yamaha sy85 and sy99
there a few other yams it works on but apart from that they dont work on most only dos based systems if it uses a pre pc format
like the special formats that many synths and samplers used you need drivers so that the emulators can do that format
and why the hxc works as they add the code so specific floppy formats work and are always adding them when people ask about there machines and they buy one and they send jeff the image format and he always tries his best to add it
On 13 August 2014 12:49, cheju_99@... [emax] <emax@yahoogroups.com> wrote:
Ok, thanks for the support!!.. I supposed it will not work....
Ricardo
2014-08-13 by bmacdoug1 .
It's too bad it doesn't work, because i use it with my 720kb Akai MPC60 perfectly. Works great with this application, even has internal memory that holds your last work. Couldn't be any easier.
What i would like to try is this:
CF AztecMonster CF-3.5" SCSI Converter Card
  • This card can convert CF memory card or MicroDrive to 3.5inc. desktop SCSI interface HDD, such as Mac SE/30, Quadra, or AKAI sampler.
  • If it works with a MAC SE/30 why wouldn't it work with the EMAX?
    On Wed, Aug 13, 2014 at 5:24 AM, JAMIE logan jammie.emma@... [emax] <emax@yahoogroups.com> wrote:
    no it does not work
    Ricardo
    Are you saying you tried it in the Mac SE/30, and it worked, but it did not work in the Emax?
    If so, then I would suspect a difference in the SCSI implementation on the Emax logic.
    But if the question is rhetorical, and you wanted to spend the money you could always try it and let us know... ;-)
    -T
    On Wed, Aug 13, 2014 at 9:38 AM, 'bmacdoug1 .' jasonmcdougal@... [emax] <emax@yahoogroups.com> wrote:
    no it does not work
    Ricardo
    take the plunge and try it thats the only way your going to find out
    but just because it works in a mac se 30 does not mean it will work in an emax
    take the pcd-50/60b they dont work in akai mpc 60 or the 3000 but do work in the akais3000 but work great in the emaxes
    its like the iodata cards dont work in the emu but they work with ensoniqs
    the acard 7720u dont work in ensoniqs but work in the emax1 and 2
    the acard 7720uw works great in the emax2 but i cant get it to work at all in the emax1 yet the 7720u with same firmware and same device works great but the uw version just get hd errors it will load the os but you cant load any banks
    On 13 August 2014 17:38, 'bmacdoug1 .' jasonmcdougal@... [emax] <emax@yahoogroups.com> wrote:
    On Wed, Aug 13, 2014 at 5:24 AM, JAMIE logan jammie.emma@blueyonder.co.uk [emax] <emax@yahoogroups.com> wrote:
    no it does not work
    Ricardo
    Regarding the CF Aztec device, i will order one and give it a try in my Emax. Will report back to the group if it works.....if not i will use it to replace the scsi hd in my Mac se/30.
    On Wed, Aug 13, 2014 at 10:03 AM, JAMIE logan jammie.emma@... [emax] <emax@yahoogroups.com> wrote:
    On 13 August 2014 17:38, 'bmacdoug1 .' jasonmcdougal@... [emax] <;emax@yahoogroups.com> wrote:
    no it does not work
    Ricardo
    2014-08-14 by djrgary@...
    The CF Aztec device works well on EmaxII as long as you don't let it verify after formatting. Have not got it to work with Emax I. Believe there is a firmware or clock issue, or incompatibility with single ended scsi
    Sent from Yahoo Mail on Android
    To: ;
    Subject: Re: [emax] Re: Chinese floppy emulator
    Sent: Wed, Aug 13, 2014 9:59:49 PM
    On Wed, Aug 13, 2014 at 10:03 AM, JAMIE logan jammie.emma@blueyonder.co.uk [emax] <emax@yahoogroups.com> wrote:
    no it does not work
    Ricardo
    2014-08-14 by xeelox@...
    I've spoken with the manufacturer of the AztecMonster and he confirmed it does NOT work with Emax I. He says it will only work w/ Emax II & III.
    Unless the firmware is the problem AND it can be hacked, save your money.
    - Jim
    2014-08-14 by bmacdoug1 .
    OK thanks for the heads up.
    I wish i knew how to program low level machine code and make a scsi/usb interface that had firmware allowing it to work with multiple applications/devices........Just installed the Korg DSS1(Straylight Engineering) scsi/usb interface/memory upgrade and it works awesome. No more unreliable floppy drive or slow floppy emulator. Another underrated synthesizer/sampler with some beautiful sounding analog filters
    On Wed, Aug 13, 2014 at 7:27 PM, xeelox@... [emax] <emax@yahoogroups.com> wrote:
    - Jim
    2014-08-14 by JAMIE logan
    its because his design based on the 7720uw from acard he uses the same chips and the same bios and i know he gets disk errors
    as i just cant get the 7720uw to work with the emax 1 i dont know what acard did or if its anything todo with the 68pin interface
    but i just cant get it to work with the emax1 but it works great with the emax2 with the same devices tested
    and the 7720u which is the scsi1/2 with the 50pin scsi connection works with the emax1 and the same devices and even though the bios is the same for both cards the 7720uw just wont work all you get is disk error trying to load banks
    the version i am working on is bios based and the firmware can be updated it also scans the scsi pins and does a diagnostic which you can have a look at to see what signals the scsi is getting this allows to write new firmware so that it can work with any device
    its almost ready and i will be sending ted one for testing
    and it will include the slim floppy inside the casing and the adapter so all you will have to do is fit it just like a floppy drive and fit 3 cables the scsi the floppy and power
    On 14 August 2014 03:57, 'bmacdoug1 .' jasonmcdougal@gmail.com [emax] <emax@yahoogroups.com> wrote:
    - Jim
    as for the dss1 upgrade yes it is great
    but we had the os code for that so that it was possible to add the usb and extra bank switching for the memory
    and making wave file support any thing is possible when you have the code and fpga for interfacing and the floppy drive can still be used
    and its going to happen also to the dsm1 the rack version but tom does not have the os code for that so he has to disassemble it which is taking a very long time + his day job keeps him very busy im his registered installer in uk and i have gone through all the revisions of the boards
    which started as 2mb with just scsi
    then the full digiboard with scsi and usb
    and the third revision board was scraped because of problems and version 4 which is a small addon board that is used with the original digiboard because it was a lot cheaper to manufacture tom used to hand solder each one he now has them done in china
    On 14 August 2014 03:57, 'bmacdoug1 .' jasonmcdougal@... [emax] <emax@yahoogroups.com> wrote:
    - Jim
    2014-08-18 by bmacdoug1 .
    Has anybody tried this with the Emax?
    Product Name : CF Raizin Monster HOT SWAP corresponding CF-SCSI conversion adapter
    Price : 12,900 yen (converts to $127US)
    Description
    It is the adapter card by replacing MO, etc. ZIP drive so that it can be used as a SCSI device CF memory card.
    • Removable function (HOT SWAP) possible *
    • 3.5 inches FDD drive bay size
    • Type I / II support
    • SCSI I / II / III support
    • Mac, Win, Linux bootable
    On Thu, Aug 14, 2014 at 5:47 AM, JAMIE logan jammie.emma@blueyonder.co.uk [emax] <emax@yahoogroups.com> wrote:
    - Jim
    2014-08-18 by JAMIE logan
    its a new product its only been out a few weeks try if you like but it is based on the same tech as the aztec monster
    On 18 August 2014 06:21, 'bmacdoug1 .' jasonmcdougal@... [emax] <emax@yahoogroups.com> wrote:
    Description
    On Thu, Aug 14, 2014 at 5:47 AM, JAMIE logan jammie.emma@... [emax] <emax@yahoogroups.com> wrote:
    - Jim
    2014-08-18 by xeelox@...
    I'm inclined to agree w/ Jamie for the exact reasons mentioned, but I have emailed the manufacturer to see if he has any reason to believe it will behave differently than the Aztec.
    -Jim
    if it is based on the same 7720uw design as the aztec it wont work with the emax 1
    but for emax2 users its a good buy as it is the cheapest option to add with a slim floppy but you are going to need to make special brackets as thesde only come with a front and you will need some type of insulation sheet between that and a slim floppy as the pcb is exposed
    -Jim
    2014-08-18 by Mitch Bryson
    It;s not that new.
    RaizinMonster has been around since May or something.
    On Monday, 18 August 2014, 17:25, "JAMIE logan jammie.emma@... [emax]" <emax@yahoogroups.com> wrote:
    >Description
    >>>>>-  Jim
    may is new its a new product its not been around long your just splitting hairs
    but by all means try it if you want
    thats what i have had to do in the past for years to find solutions
    it was announced in may but as of yet i dont know a single person who has brought one to test with any samplers
    as some people were having problems with the aztec devices with samplers
    On 18 August 2014 17:40, Mitch Bryson acidmitch@... [emax] <emax@yahoogroups.com> wrote:
    It;s not that new.
    On Monday, 18 August 2014, 17:25, "JAMIE logan jammie.emma@blueyonder.co.uk [emax]" <emax@yahoogroups.com> wrote:
    Description
    - Jim
    I thought about getting one to test, but they were already sold out when I emailed them on July 1st. Here's their reply:
    >>I am sorry that now CF RaizinMonster is out of stock. The next delivery date
    >>is at August late. I apologize for inconvenience.
    >>Best Regards.
    >>Manabu Sakai
    I'll let you know what they say about any known incompatibility with Emax 1 when they answer my current email.
    In the mean time you can zoom in on the image and play guess-the-integrated circuit, but the Windbond is just flash memory and the main chip isn't marked so no telling if it's an Acard 7720.
    - Jim
    thats the same 512kx8 flash chip used on the 7720uw the chip used is the arc760-B which is still a chip that acard still make
    i noticed he has removed the white chip lettering so that acard can not tell that they are using there design or any one else knowing what chip they used
    there aztec monster is a one for one exact 7720uw design as i had one and checked and it was a copy of the circuits but there own pcb design
    but also they might have a license for the design from acard
    >>Best Regards.
    >>Manabu Sakai
    - Jim
    2014-08-19 by xeelox@...
    Save your money boys and girls. RaizinMonster is not compatible w/ Emax 1 as confirmed to me by the manufacturer last night. Emax II users would likely have success w/ this one though.
    >>Dear Sir.
    >>I am sorry that CF RaizinMonster is out of stock. It will come August late.
    >>It has bad compatibility with E-mu Emax I like as CF AztecMonster.
    >>Best Regards.
    >>Manabu Sakai
    - Jim
    2014-08-19 by bmacdoug1 .
    OK well maybe somebody will make it happen someday. wish i could compile firmware? anybody have any suggestions on where to start learn such a talent......
    Do you guys think it would work with an Ensoniq ESP16+ with SCSI? (just scored this for $49.00 at a thrift store, another sweet sounding early digital, that can do awesome transwaves!)
    Dear Sir.
    I am sorry that I have heard CF RaizinMonster does not work well with Emax I. It works Emax II or later.
    I do not have a plan firmware update. Sorry.
    Best Regards.
    Manabu Sakai
    - artmix
    Off Topic:
    Im selling my EMAX 1, SE HD REV 1, with pcd-50 Slim floppy/cf drive combo, recapped power supply and cool blue OLED (makes reading the display a breeze)
    on the auction bay. Located in SF Bay Area
    On Tue, Aug 19, 2014 at 8:24 AM, xeelox@yahoo.com [emax] <emax@yahoogroups.com> wrote:
    >>Dear Sir.
    >>Best Regards.
    >;>Manabu Sakai
    - Jim
    2014-08-19 by JAMIE logan
    thats because he does not right the firmware it is the 7720uw firmware form acard that he uses he flashes them with the mac firmware version but you can use the firmware utilities from acard to flash them to any of the firmwares
    as for the floppy emulators no it does not work with the ensoniq
    and same again you are going to buy the device and try with the eps16+ as the only ever cards i got to work were the iodata ones and i sold my last one to james sanger
    the floppy emulators those flash chips need to be flashed before they are soldered into place you cant flash them once they are soldered you need to desolder them then flash them
    by the time you have learnt all this a hxc emulator would of been the best bet for floppy emulation the slim versions with no lcd are £50 so thats not a bad price and you know it works
    On 19 August 2014 19:32, 'bmacdoug1 .' jasonmcdougal@... [emax] <emax@yahoogroups.com> wrote:
    Dear Sir.
    Best Regards.
    Manabu Sakai
    - artmix
    Off Topic:
    On Tue, Aug 19, 2014 at 8:24 AM, xeelox@... [emax] <emax@yahoogroups.com> wrote:
    >>Dear Sir.
    >>Best Regards.
    >>Manabu Sakai
    - Jim
    write
    predictive text i hate it
    On 19 August 2014 19:32, 'bmacdoug1 .' jasonmcdougal@gmail.com [emax] <emax@yahoogroups.com> wrote:
    Dear Sir.
    Best Regards.
    Manabu Sakai
    - artmix
    Off Topic:
    >>Dear Sir.
    >>Best Regards.
    >>Manabu Sakai
    - Jim
    2014-08-20 by bmacdoug1 .
    Regarding flashing the Gotek floppy emulators, I found this interesting article.
    According to the author of the article "Transforming the Gotek Floppy Emulator into an Amiga Floppy Emulator"
    http://cortexamigafloppydrive.wordpress.com/2014/02/03/transform-the-gotek-floppy-emulator-into-an-amiga-floppy-emulator/
    Firware can be flashed directly using a usb>ttl driver. no need flashing then soldering flash onto pcb.
    And then I found another interesting post on the ESP16+ via yahoo group Ensoniq-ASR10-EPS16
    "the acard 7720uw and a hot swap drive works with the eps16+ as an external device the problem with the acards is that they are slow for the interrogation routine and so come back with no scsi disk enter floppy disk
    but with an external drive if you switch it on 1-2 mins before the eps16+ and it will boot"
    On Tue, Aug 19, 2014 at 1:09 PM, JAMIE logan jammie.emma@... [emax] <emax@yahoogroups.com> wrote:
    write
    Dear Sir.
    Best Regards.
    Manabu Sakai
    - artmix
    Off Topic:
    >>Dear Sir.
    >>Best Regards.
    >>Manabu Sakai
    - Jim
    2014-08-20 by JAMIE logan
    thats from the eps site is from me yes a 7720uw will work but it has to be external as its to slow for the asr10 from boot so you have to switch on the external device at least 1 to 2 minutes before the asr10 or it wont see it
    the only one that worked inside the machine is the iodata as it was faster so that the asr10 would see it
    my new dual combo drive slim floppy and scsi reader works with the asr10 as it was what i used first for testing
    i have also the single slot hot swap drives for the asr10 that work with the iodata and the acard 7720uw
    as for flashing the floppy emulator if its possible to flash them with out removing the ic thats a good thing but some one need to write the firmware so that it works like the hxc but as seeing it uses totally different tech
    i dont think it will ever be done but the cheap models do work with a lot of newer synths i have one in my k5000r and it works great
    On 20 August 2014 03:35, 'bmacdoug1 .' jasonmcdougal@gmail.com [emax] <emax@yahoogroups.com> wrote:
    write
    Dear Sir.
    Best Regards.
    Manabu Sakai
    - artmix
    Off Topic:
    >>Dear Sir.
    >>Best Regards.
    >>Manabu Sakai
    - Jim
    october - november
    im waiting on metal work the mock version was agreed i now have to wait for final production as i got a bare metal bracket
    but the finished item is black
    On 20 August 2014 16:32, xeelox@yahoo.com [emax] <emax@yahoogroups.com> wrote:
    Jamie, what's a rough ETA on your dual combo drive?
    Jim
    2014-08-21 by bmacdoug1 .
    Jamie, because of the efforts of you and Ted, I am thankful.
    I would have never got this far in my appreciation of these wonderful instruments.
    I'm here in the silicon valley surrounded by gold miners.(until the next bust!)
    Do you or anyone else know where/what application the scsi>ide converter cards like IOdata/ACard, where originally installed in?
    Maybe more of it can be saved etc.
    On Wed, Aug 20, 2014 at 9:08 AM, JAMIE logan jammie.emma@... [emax] <emax@yahoogroups.com> wrote:
    october - november
    Jim
    2014-09-05 by niklas.ehrlin@...
    Hi
    I think I've missed this thing. What is this dual combo-drive, Jamie?
    /Niklas
    2014-09-05 by Ted Summers
    It's a project he is working on. It is not complete yet. Slim floppy and media drive in 1 to just put in Emax directly, no adapters, etc.
    Please follow the posts for any announcement when it is available.
    Ted
    On Thu, Sep 4, 2014 at 11:39 PM, niklas.ehrlin@... [emax] <emax@yahoogroups.com> wrote:
    Hi
    /Niklas
    2014-09-05 by Niklas Ehrlin
    Aha ok, sounds very interesting.
    I managed to install the slim floppy, with the modded adapter, and the machine seems to be working just fine! Thanks for all your help and wisdom Ted :)
    So as Im still concidering different options to make use of the SCSI in my machine, this thing Jamie is working on could perhaps be a solution.
    Have anyone heard of any preorders to be sent or something?
    Niklas
    2014-09-05 18:44 GMT+02:00 Ted Summers djtbs1@... [emax] <emax@yahoogroups.com>:
    Ted
    Hi
    /Niklas
    No- Jammie is waiting to get metalwork from manufacturing and powdercoated.
    At least that is my understanding. Last also Jammie commented I think it is 1 to 2 months out before they may be available.
    (not speaking for him, this is just my understanding from what he has posted).
    Ted
    On Fri, Sep 5, 2014 at 12:01 PM, Niklas Ehrlin niklas.ehrlin@... [emax] <emax@yahoogroups.com> wrote:
    Niklas
    Ted
    On Thu, Sep 4, 2014 at 11:39 PM, niklas.ehrlin@yahoo.com [emax] <emax@yahoogroups.com> wrote:
    Hi
    /Niklas
    2014-09-07 by JAMIE logan
    im away at the moment for all of september meeting with manufacturers
    i have 3 prototypes which were bare metal cases 2 normal size 3.5" drives
    and 1 emax larger type drive which will fit also the eps16+ eps classic epsm and the EIII and Emax1/2 this is the shugart 3.5" type
    i have now spray painted these in black these are for beta testers ted is receiving the emax type prototype
    and the others are being fitted into asr10 racks
    i have to do product control and making sure the finished bracket is to spec
    i then have to purchase more pcbs and have the components reflowed in a pick and place conveyer oven
    i have a cash of nos slim floppy drives and i remade the slim floppy adapter so that normal mfc flat cable can be used as at the moment they use a special one where pin one is pin one to match the slim floppy drive connection as if you use a normal mfc cable which has connection on the same side when you flip it to fit the slim floppy they are reversed
    no doubt as soon as these are released there will be knock off Chinese versions in no time so i will be only doing as limited run so that i know that i wont be left with lots of spare drives ads its all set up and tooling has already been payed for its easier just to order batches
    this is what the aztec monster guy does
    On 5 September 2014 21:46, Ted Summers djtbs1@...m [emax] <emax@yahoogroups.com> wrote:
    Ted
    Niklas
    Ted
    Hi
    /Niklas
    2014-09-07 by bmacdoug1 .
    Jammie, Ted,
    Put me down as very interested in the combo drive.
    Have installed Ted's Scsi kits in Emax 1's along with OLED display. Currently have Emax rack im going through.
    along with Ensoniq EPS16+ with SCSI will be installing Flashbank-2.
    Other Synth work includes:
    Installing Tom's SCSI/Memory Upgrade on the DSS-1 (along with new back light LED display, USB Combo drive)
    CPU upgrade on Sequential Circuits Pro-1
    Europa upgrade on Jupiter 6
    v8.3 PPG Wave 2.2 upgrade, hand soldered Midi Interface, back light display, and new key rubber bushings
    At least 10 years of experience troubleshooting repairing most of the gear i own. I'm not a "certified" technician i just enjoy keeping this old gear alive and have learned along the way. Let me know if you need a beta tester etc.. Will be interested in purchasing a couple of these combo drives.
    On Sun, Sep 7, 2014 at 5:30 AM, JAMIE logan jammie.emma@... [emax] <emax@yahoogroups.com> wrote:
    On 5 September 2014 21:46, Ted Summers djtbs1@... [emax] <emax@yahoogroups.com> wrote:
    Ted
    Niklas
    Ted
    Hi
    /Niklas
    RE: [emax] Re: Chinese floppy emulator
    2014-09-07 by Lorne Hammond
    put me down for one unit.
    Lorne
    From: emax@yahoogroups.com [mailto:emax@yahoogroups.com]
    Sent: September-07-14 12:15 PM
    To: emax@yahoogroups.com
    Jammie, Ted,
    On 5 September 2014 21:46, Ted Summers djtbs1@gmail.com [emax] <emax@yahoogroups.com> wrote:
    Ted
    On Fri, Sep 5, 2014 at 12:01 PM, Niklas Ehrlin niklas.ehrlin@... [emax] <emax@...m> wrote:
    Niklas
    Ted
    Hi
    /Niklas
    2014-09-07 by xeelox@...
    Put me down as well; I am quite interested.
    And maybe I missed it somewhere along the way, but what is the media type?
    - Jim
