Doepfer
Dark energy external out question
2010-10-15 by Diego
i can feed  any external signal  in the DE external input ?
For example  i can feed the audio that come from an external keyboard or from one of my pedals ? Or i have to preamp  it ?
thanks in advance
diego
Re: [Doepfer_a100] Dark energy external out question
2010-10-15 by Bakis Sirros
Ingo has a Dark Energy.
Ingo any help on this?
Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist
[Doepfer_a100] group owner
www. parallel - worlds - music. com
www. myspace. com/ parallelworldsmusic
www. myspace. com/ interconnectedmusic
www. myspace. com/ memorygeist
www. DiN. org. uk
www. musicamaximamagnetica. com
www. vu-us. com
--- On Fri, 10/15/10, Diego <amsonx@yahoo.com> wrote:
Subject: [Doepfer_a100] Dark energy external out question
To: Doepfer_a100@yahoogroups.com
Date: Friday, October 15, 2010, 9:40 AM
thanks in advance
diego
Re: Dark energy external out question
2010-10-15 by Diego
Thanks for this clarification Dieter
Diego
--- In Doepfer_a100@yahoogroups.com, <yahoo@...> wrote:
> > Hi,
> > thanks in advance
> > diego
> You can feed any audio signal with line level to the DE audio input (i.e.
> typ 1V level). But it's not possible to use a microphone or electric guitar.
> These need to be amplified. If you want to adjust the level of the external
> signal (in relation to the internal VCO) and external attenuator (e.g.
> A-183-1) or amplifier/attenuator (e.g. A-183-3) is recommended.
> Best wishes
> Dieter Doepfer
2010-10-15 by andy butler
hi Diego,
Yes, you can do that.
Your pedals will already have pre-amps in them
(unless they have true bypass).
What's an "external keyboard?", if it has line level
audio outputs then that would work also.
You probably need some kind of volume control on the
input signal though.
The DE input doesn't have a lot of headroom, it's easy to make
it distort, especially if you're thinking of running the input sound
at a level that matches that of the oscillator.
Best to just plug in and try.
andy butler
DE user
Diego wrote:
> Hi,
> thanks in advance
> diego
AW: [Doepfer_a100] Dark energy external out question
2010-10-15 by yahoo@doepfer.de
> Hi,
> thanks in advance
> diego
Best wishes
Dieter Doepfer
Re: AW: [Doepfer_a100] Dark energy external out question
Is there anything you'd recommend as a way to *reduce* the level
of the oscillator, in that situation or otherwise?
andy butler
> Best wishes
> Dieter Doepfer
AW: AW: [Doepfer_a100] Dark energy external out question
> andy butler
You may simply turn it off. If you want to adjust the relation please refer
to the additional technical documents on our website:
www.doepfer.com > PRODUCTS > DARK ENERGY >
Dark_Energy_technical_information.pdf
The pin of JP6 can be used also to apply a voltage in the
range -5V...GND...+5V to adjust the relation between internal VCO and
external signal (GND = same level, -5V VCO only, +5V external signal only).
If a jumper is put on JP6 -5V are applied (i.e. VCO only).
Best wishes
Dieter Doepfer
Re: AW: AW: [Doepfer_a100] Dark energy external out question
>  > andy butler
figured that :-)
Also I found it's more or less possible to adjust the value
of the the pulse width near to the "off" position.
so what happens for a voltage of, for instance
-2.5V
+2.5V
> Best wishes
> Dieter Doepfer
many thanks
andy butler
AW: AW: AW: [Doepfer_a100] Dark energy external out question
2010-10-18 by yahoo@doepfer.de
> signal only).
> -2.5V
> +2.5V
A CV change from -5V...+5V causes a change in the relation between the
internal VCO and the external signal (voltage controller input panning).
Best wishes
Dieter Doepfer
Re: AW: AW: AW: [Doepfer_a100] Dark energy external out question
2010-10-18 by andy butler
>> signal only).
>> -2.5V
>> +2.5V
Sure, that much is evident from the original post.
The question on my mind is whether it is a switch, or a continuous
controller.
Hence the otherwise bizarre seeming use of the 2.5V & -2.5V voltages
as examples as to what wasn't clear ;-)
andy
> Best wishes
> Dieter Doepfer
Re: AW: AW: AW: AW: [Doepfer_a100] Dark energy external out question
2010-10-19 by andy butler
>> controller.
> It's not a switch but a continuous controller (a bit like the A-134 when
> used as crossfader or input panner).
> Best wishes
> Dieter Doepfer
hi Dieter,
wow, that's amazing.
2 whole VCAs.
Very cool.
Seems like it's designed to be friendly to a hacker.
Is the an available component level schematic
for the Dark Energy?
that would at least save you and this list from my pedantic questions ;-)
(really, though, I think I'll have enough fun just adding
 a few extra sockets to the DE for now)
best wishes
andy butler
AW: AW: AW: AW: AW: [Doepfer_a100] Dark energy external out question
2010-10-19 by yahoo@doepfer.de
> Is the an available component level schematic for the Dark Energy?
We have available only the document I mentioned earlier:
This document describes all possible modifications. Sorry - we have no
further documents available that are published. We do not publish the DARK
ENERGY schematics.
Best wishes
Dieter Doepfer
Re: : [Doepfer_a100] Dark energy external out question..Jumper pins and extra CV in/out
2010-10-27 by andy butler
hi Dieter, thanks again for that
I've now obtained the hardware sockets to bring those Dark Energy
jumpers out of the box.
Any chance you could help to fill in some gaps?
Problem I now have is that it's not always clear which pin to attach to.
The docs often only tell which pairs of pins have to be connected, not
which is which.
I'm looking at
JP6.. apply CV to mix between osc and ext.   ..which pin to use?
JP7.. 2 pins are LFO1 o/p and Inverter Input ..which is which?
JP8.. 2 pins are Inverter o/p and to the LFO1bar socket on the top panel, ...which is which?
Any hints gratefully accepted.
For interest, my plan is to add 5 sockets:
Outputs
1. ADSR
2. LFO1
3. LFO2
Inputs
1. Inverter (normalled to LFO1)
2. VCO/ext Mix
The existing LFO1bar  Output on the top panel will function
as before unless the Inverter input socket is used.
best regards
andy butler
>> controller.
> Best wishes
> Dieter Doepfer
AW: : [Doepfer_a100] Dark energy external out question..Jumper pins and extra CV in/out
2010-10-28 by yahoo@doepfer.de
We have updated the technical information on our website with the details
about the pins.
Best wishes
Dieter Doepfer
> -----Ursprüngliche Nachricht-----
> Von: Doepfer_a100@yahoogroups.com
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von andy butler
> Gesendet: Mittwoch, 27. Oktober 2010 17:10
> An: Doepfer_a100@yahoogroups.com
> Betreff: Re: : [Doepfer_a100] Dark energy external out question..Jumper
> which is which.
> I'm looking at
> Outputs
> 1. ADSR
> 2. LFO1
> 3. LFO2
> Inputs
> 2. VCO/ext Mix
> best regards
> andy butler
> >> controller.
> > Best wishes
> > Dieter Doepfer
Re: AW: : [Doepfer_a100] Dark energy external out question..Jumper pins and extra CV in/out
2010-10-28 by andy butler
Many thanks,
that's brilliant!!!
andy
> about the pins.
> Best wishes
> Dieter Doepfer
>> which is which.
>> I'm looking at
>> Outputs
>> 1. ADSR
>> 2. LFO1
>> 3. LFO2
>> Inputs
>> 2. VCO/ext Mix
>> best regards
>> andy butler
Re: AW: : [Doepfer_a100] Dark energy..Jumper pins and extra CV in/out
2010-10-29 by andy butler
ok, another question, hope that's ok.
I guess the jumper 13 is hidden under the midi board,
(I have the v2)
...but looking for it I discovered
JP14
and
JP15
...and of course I'd love to know if there's a use for them.
(uh, and any others I didn't see yet)
Having the triangle-wave available seems like fun.
many thanks
andy
> about the pins.
> Best wishes
> Dieter Doepfer
AW: AW: : [Doepfer_a100] Dark energy..Jumper pins and extra CV in/out
2010-10-30 by yahoo@doepfer.de
You find my answers written inline.
Best wishes
Dieter Doepfer
> I guess the jumper 13 is hidden under the midi board, (I have the v2)
yes, it's right from the CEM3394
> JP14 and JP15
These are reset inputs for the LFOs. As it's a very special function planned
for the DARK MATTER expansion box they are not mentioned in the technical
document. A short circuit resets the triangle of the corresponding LFO (JP14
LFO2, JP15 LFO1). E.g. a momentary switch or an electronical switch can be
connected there. Do not apply a voltage. This may damage the circuits !
> many thanks
> andy
