Re: [Doepfer_a100] A-183-2 suitable for this?
2010-10-29 by Richard Horsman
Thanks for your help again Bakis Wherever I put the offset knob I can only ever get 4V from that point (e.g. offset set to -2V, 4V in I get a range of -2 to +2V out. Offset set to -4V, 4V in I get a range of -4 to 0 volts out). This is with att. set to fully clockwise (10 on the dial). So, with x Volts in in I cannot get more than (offset+x) volts out. Attenuation works fine. Offset works fine, but amplification..... nothing. :-/ Cheers Rich hi Rich, first of all: offset knob at '1' position (the 1 according to the scale that is marked on the module front panel) should give you -4 volts offset, not 0volts. now, the a183-2 module should give x2 amplification, according to specs... Dieter? Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist [Non-text portions of this message have been removed]
