hello krys not tire our loved kris.
De : emax@yahoogroups.com [mailto:emax@yahoogroups.com] De la part de
esynthesist
Envoyé : dimanche 8 juillet 2012 01:25
À : emax@yahoogroups.com
Objet : [emax] Re: Emuser Parts List
Well... I'm coping with a major lack of time too.
Maybe when I have a few weeks off (holiday), I can spend a few days to build
another small batch of EmuSers.
But I haven't even planned any holidays yet ;)
My job and the ongoing development of a huge maintenance release of EMXP are
almost killing me.
///E-Synthesist
--- In emax@yahoogroups.com <mailto:emax%40yahoogroups.com> , "lindenlovede"
<andre@...> wrote:
> Hey E-Synthesist,
> i am about to build an Emuser for my newly acquired EII. Anyways i am so
busy to recap other samplers and upgrade displays to VFD ones i was
wondering if you would build one for me, so i could save myself a lot of
time. I would pay for it of course.
> Best
> André
"esynthesist" <esynthesist@> wrote:
> > The labelling/coding system of these ICs can evolve in time, that's why
I only mentioned the basic "root" identifier of the RS422 ICs.
> > But since the EmuSer uses DIP packages, the UA9638CP and UA9637ACP can
certainly be used; FYI these are the ones that I always use when I build
EmuSers.
> > If you intend to use the EmuSer primarily for transferring complete
BANKS between a PC and the Emax/Emax-II, you should consider using SCSI
drives attached to the Emax instead of using the EmuSer. Transferring banks
through RS422 takes between 30 and 40 seconds; SCSI is much faster.
Moreover, if you are using an Emax-II, the banks can only be transferred
from PC to Emax-II through RS422 (not the other way around) and the bank
should be a 512K compressed bank (so not e.g. a 16 bit 2MB bank). Both
restrictions are imposed by the Emax-II operating system, not by the EmuSer
or EMXP.
> > However, if you intend to use the EmuSer for transferring individual
samples (WAV files), it can be an attractive alternative for MIDI, because
it's much faster.
> > ///E-Synthesist
"philippe.69" <philippe.69@> wrote:
> > > !!!! you can not send more than 512kb as a floppy disk
> > > emuser is designed for the emulator II it works like a disk drive no
> > > interest on an Emax
> > > De : emax@yahoogroups.com <mailto:emax%40yahoogroups.com>
[mailto:emax@yahoogroups.com <mailto:emax%40yahoogroups.com> ] De la part de
> > > freddy1771994
> > > Envoyé : mercredi 4 juillet 2012 15:02
> > > À : emax@yahoogroups.com <mailto:emax%40yahoogroups.com>
> > > Objet : [emax] Emuser Parts List
> > > Hi,
> > > I'm currently searching the parts for the emuser which is not that
easy and
> > > cheap if you live in Germany.
> > > I have the following - hopefully not stupid - questions:
> > > In the manual, the part number of the "UA9638C" is obviously not
complete. I
> > > checked mouser.com
> > > (http://eu.mouser.com/Search/Refine.aspx?Keyword=UA9638C). It shows
many
> > > different UA9638's. Which one is the one I need?
> > > Same with the "UA9637AC"
> > > (http://eu.mouser.com/Semiconductors/_/N-5gcb?Keyword=UA9637AC
> > > <http://eu.mouser.com/Semiconductors/_/N-5gcb?Keyword=UA9637AC
<http://eu.mouser.com/Semiconductors/_/N-5gcb?Keyword=UA9637AC&FS=True>
&FS=True>
> > > &FS=True). Which one do I need?
> > > Does anyone has experiences, is it a cool thing and how much did it
cost you
> > > all in all?
> > > Thank you!
> > > Freddy
> > > [Non-text portions of this message have been removed]
