Emax
Emax won't boot anymore
2012-07-08 by krikorola
Hi
my emax won't boot anymore
it stays on this state
http://imageshack.us/photo/my-images/826/lehavre2012070800207.jpg/
once it gave me the CRC DATA message.
i tried with two different floppy disk
do you think it's the floppy drive?
thks
Re: [emax] Emax won't boot anymore
2012-07-08 by Ted Summers
Reseat all the connectors and socketed IC's on the logic board.
That is where I would start.
On Jul 8, 2012, at 2:42 PM, krikorola wrote:
Hi
thks
2012-07-08 by jammie
either bad floppy disk or the disk drive try using a floppy drive dry disk cleaner
also what disks are you using
  To: emax@yahoogroups.com
  Sent: Sunday, July 08, 2012 10:42 PM
  Subject: [emax] Emax won't boot anymore
  Hi
  thks
2012-07-09 by krikor kouchian
Thanks i'm gonna try that.
http://www.krikor.fr
+33632199413
bookings:
France/Suisse/Benelux: fanyktdj@...
World: laetitia@...
2012/7/9 jammie <jammie.emma@...>
> cleaner
> From: krikorola
> Hi
> thks
i'm using a DD disk and i tried whith a HD with a sticker on the HD hole
+33632199413
bookings:
World: laetitia@...
> cleaner
> From: krikorola
> Hi
> thks
the weird thing is that i didn't move the unit itself, i already check that
before i first ran it 2 month ago (it had been off for years)
i will do it again
+33632199413
bookings:
World: laetitia@...
2012/7/9 Ted Summers <djtbs1@...>
> Hi
> thks
> Emax and Emax II User's Group Website
> http://www.silveriafamily.comYahoo! Groups Links
I forgot to mention that it does exactly the same thing without any floppy
in the drive.
Le lundi 9 juillet 2012, jammie <jammie.emma@....uk> a �crit :
disk cleaner
> From: krikorola
> Hi
> thks
+33632199413
bookings:
World: laetitia@...
2012-07-09 by jammie
have you disconected the analog board as thats what you get when you put the
cable back the wrong way
its a analog board problem
your not even getting to boot status
do what ted says re seat the chips in there sockets
and make sure the pinone on the analog board is lined up with pin 1 on the
cable from the main board
To: <emax@yahoogroups.com>
Sent: Monday, July 09, 2012 9:56 AM
Subject: Re: [emax] Emax won't boot anymore
in the drive.
Le lundi 9 juillet 2012, jammie <jammie.emma@...> a \ufffdcrit :
disk cleaner
> From: krikorola
> Hi
> thks
+33632199413
bookings:
World: laetitia@...
Re: Emax won't boot anymore
2012-07-09 by cheju_99
I have exactly the same fault, check the power supply or any capacitor exploited, otherwise you have a logig issue with some IC, hopefully not the main processor, Pals or the TCU. Forgot to mention that you could check any "cold soldering" in the board.
suerte!
> in the drive.
> disk cleaner
> > From: krikorola
> > Hi
> > thks
> +33632199413
> bookings:
> World: laetitia@...
thank you Cheju,
i'm gonna go through the capacitor check.
i hope it's not an IC which would be a real pain in the ass to fix.
+33632199413
bookings:
World: laetitia@...
from what i read in the service manual, Cheju is right, it could be either
the CPU, the Echip/MCL, or the timer.
But the fact that the LED and display go crazy is directly related to the
main CPU, from the block diagram info.
Can this part be replaced? i have the feeling it can't
+33632199413
bookings:
World: laetitia@...
i'm afraid the cpu is dead as the led and display is directly controlled by
it:
http://img207.imageshack.us/img207/8782/lehavre2012070900215.jpg
i checked all ribbons, everything seems fine, sometimes it starts up as
usual but won't access the floppy, sometimes it starts up as in the first
picture i posted yesterday.
+33632199413
bookings:
World: laetitia@...
2012-07-09 by Ted Summers
You have bad connections to the IC's in the board, IMO.
> it:
> +33632199413
> bookings:
> World: laetitia@decked-out.co.uk
I'm gonna test voltages and the IC connections tommorow
+33632199413
bookings:
World: laetitia@...
> by
> > it:
> > +33632199413
> > bookings:
> > World: laetitia@...
i agree with ted
send it to ted or send it tome and we can diagnos it
Sent: Monday, July 09, 2012 7:54 PM
>> by
>> it:
>> +33632199413
>> bookings:
>> World: laetitia@...
Where are you guys located?
i will check the voltage on the CPU pin tomorrow, if the IC don't address
correctly then it might be related to a bad capacitor.
Thks
K
+33632199413
bookings:
World: laetitia@...
> i agree with ted
> From: "Ted Summers" <djtbs1@...>
> controlled
> >> by
> >> it:
> first
> >> +33632199413
> >> bookings:
> >> World: laetitia@...
im in uk
ted is in usa
Sent: Monday, July 09, 2012 9:56 PM
> Thks
> K
> +33632199413
> bookings:
> World: laetitia@...
>> i agree with ted
>> controlled
>> >> by
>> >> it:
>> >> as
>> first
>> >> +33632199413
>> >> bookings:
>> >> World: laetitia@...
Archh I'm in france, if i can't fix i will ask a tech friend of mine to
look at it
Thanks a lot
Le lundi 9 juillet 2012, jammie <jammie.emma@blueyonder.co.uk> a �crit :
> im in uk
> ted is in usa
> From: "krikor kouchian" <krikorola@...>
>> Thks
>> K
>> +33632199413
>> bookings:
>> France/Suisse/Benelux: fanyktdj@gmail.com
>> World: laetitia@...
>>> i agree with ted
>>> controlled
>>> >> by
>>> >> it:
>>> >> as
>>> first
>>> >> +33632199413
>>> >> bookings:
>>> >> World: laetitia@...
+33632199413
bookings:
World: laetitia@...
Archh I'm in france, if i can't fix it i will ask a tech friend of mine to
look at it
Thanks a lot
> im in uk
> ted is in usa
>> Thks
>> K
>> +33632199413
>> bookings:
>> World: laetitia@...
>>> i agree with ted
>>> controlled
>>> >> by
>>> >> it:
>>> >> as
>>> first
>>> >> +33632199413
>>> >> bookings:
>>> >> World: laetitia@...
+33632199413
bookings:
World: laetitia@...
look at it
Thanks a lot
> im in uk
> ted is in usa
>> Thks
>> K
>> +33632199413
>> bookings:
>> World: laetitia@...
>>> i agree with ted
>>> controlled
>>> >> by
>>> >> it:
>>> >> as
>>> first
>>> >> +33632199413
>>> >> bookings:
>>> >> World: laetitia@...
+33632199413
bookings:
World: laetitia@...
2012-07-10 by narfman96
I just fixed a DX7II-FD main board for Jon Morgan. Same symptoms floppy drive errors then all of a sudden it would not boot anymore. The floppy disk controller chip was bad. If you can find a WD1772PH controller chip (Ebay) try it and you may be back in business. This FDC chip can interrupt the CPU and prevent it from booting.
> +33632199413
> bookings:
> World: laetitia@...
Re: [emax] Re: Emax won't boot anymore
2012-07-10 by jammie
i have some spare floppy controler chips
  Sent: Tuesday, July 10, 2012 1:59 PM
  Subject: [emax] Re: Emax won't boot anymore
  > +33632199413
  > bookings:
  > World: laetitia@...
2012-07-10 by krikor kouchian
Sweet, would you sell me one?
2012/7/10, jammie <jammie.emma@...>:
>   From: narfman96
> either
> the
>   > +33632199413
>   > bookings:
>   > World: laetitia@...
+33632199413
bookings:
World: laetitia@...
2012-07-17 by krikorola
I can't find the value of two caps on the PSU board.
anybody knows?
there are the ones on the pictures here:
http://img88.imageshack.us/img88/3565/img2012071700242.jpg
and
http://img684.imageshack.us/img684/9669/lehavre2012071000230.jpg
Also i don't understand what it being referred as the "CS PAL" in the trim and diagnostic manual, page 9 problem: No Boot -> Bad CS PAL -> Replace CS PAL
thanks
K
> +33632199413
> bookings:
> World: laetitia@...
