Emax
replace the display
replace the display
2012-07-04 by Niklas N
I going to replace the display on my Emax Plus, when it has begun to fade away after 20 years. Does anyone have tips and ideas on what to consider before I start screwing on my Emax.
The display that I have obtained is of type FDCC1602D
http://www.rjselectronics.com/?Displays:LCD_Displays:Character_LCD_Panels
cheers
NON
EMXP Emax zip drive Windows 7 64 bit
2012-07-04 by blchrr@...
Hi there chaps,
Can someone tell me if EMXP works with IDE zip drives on a Windows 7 64 bit
computer?
My Emax has an internal SCSI zip drive and basically i want to use EMXP on
the PC to transfer banks on zip disks and use it in the Emax.
Thanks!
Rob.
RE: [emax] replace the display
2012-07-04 by philippe.69
the backlight is changed without replacing all display
De : emax@yahoogroups.com [mailto:emax@yahoogroups.com] De la part de Niklas
N
Envoyé : mercredi 4 juillet 2012 15:48
À : emax@yahoogroups.com
Objet : [emax] replace the display
cheers
NON
http://www.backlight4you.com/product_info.php/info/p906_Leuchtfolie--blau-gr
uen--18mm-x-74mm--laminiert.html
*	Backlight Ersatz Leuchtfolie für EMU EMAX I + II
N
cheers
NON
