On Dec 1, 2013, at 2:55 PM, Ted Summers <djtbs1@...> wrote:
> Assuming you are using an PCMCIA card adapter- it is possible Emax may not be compatible with the adapter.
> Also, assuming you disconnected the internal hard drive, correct? as otherwise you would have two scsi device at ID 0.
> Termination- do you have an ACTIVE terminator? I would not recommend when using it as external drive to use the onboard PASSIVE termination circuit.
> If you have it in a case, verify the external terminator clearly says ACTIVE.
> This provides better termination- often they have a light on them to indicate they are working properly.
> -T
> On Dec 1, 2013, at 1:54 PM, <kcnvc@...> wrote:
> 1. I got SCSI retrofit (from Ted) for mu EMAX I rack installed and upgraded OS to Emax Plus rev1.0 SE
> 2. I got PCD 50b (form Mech) and PCMCIA-SD card adapter.
> now,
> 1. My Emax reads and writes an old scsi HD (=> retrofit works).
> 2. My Roland S760 sampler reads and writes SD cards in 50b (=> 50b works).
> 3. Connected 50b to Emax, terminated and set scsi ID=0
> 4. My Emax can not format SD cards in 50b (HD Format error)
> Why ?
> I am tired of searching old posts.
> I will appreciate any wise suggestion.
> ---In emax@yahoogroups.com, <brandt@...> wrote:
> Great, thanks Jack. I'm in the U.S.
> Ted, I'll get in touch off list.
> --- In emax@yahoogroups.com, "jammie" <jammie.emma@...> wrote:
> > yes i can if you live in uk
> > or ted can if you live in usa
> > ----- Original Message -----
> > From: ditabeardmemo
> > To: emax@yahoogroups.com
> > Sent: Sunday, December 04, 2011 11:27 PM
> > Subject: [emax] Re: Emax/PCD 50B Installation Problems
> > So the good news is I got the PCD 50B working! As Ted and Jack noted, the firmware on the unit was read only. I installed the PCD 50B in my PC, re-flashed the firmware and then it worked perfectly in the Emax. I can even confirm that the Emax will format/read/write the 512 MB SanDisk cards.
> > The bad news is that I can't get the slim floppy working because my soldering/cutting skills aren't up to snuff (I screwed up the JM215A mod twice and don't plan to try again.)
> > Is there anyone on the list who can mod three JM215As for a small me?
> > --- In emax@yahoogroups.com, "jack" <jammie.emma@> wrote:
> > > theres a slot in the side of the scsi connector you use a hook tool to lift it
> > > thats the proper way
> > > most people pull on the cable but pul;ling to hard can stretch the scsi ribbon giving bad contact
> > > on the emax i use 2 hook tools at the sides of ribbon cables
> > > From: ditabeardmemo
> > > Sent: Sunday, November 27, 2011 4:21 PM
> > > Jack, I'm working on this now and am going to put the PCD 50B in a computer this afternoon to check the firmware.
> > > Quick question: Is there a special tool or process you recommend for removing an internal 50-pin SCSI cable from a device? I'm having a lot of difficulty with this because the cable is very snug in the socket, and don't want to force it.
> > > > right get it next time from the amiga4000 site as they are cheaper and have the correct firmware
> > > > psism stoped selling them for a while but must of got a new batch
> > > > if you have scsi on a comp you will be able to flash to the os for it to work
> > > > it sounds like its a read only drive
> > > > you need an internal pc scsi ribbon usually with 4-7 internal connections and i stick the term on the last connector
> > > > From: ditabeardmemo
> > > > Sent: Monday, November 21, 2011 6:15 PM
> > > > How do I install an internal terminator on the cable? I re-used the original 50 pin SCSI cable from the Emax's internal hard drive.
> > > > I don't know what firmware version is on the PCD 50B, but I hope to install it in a PC this week to find out. I purchased the drive new directly from the psism.com Web site about a month and a half ago.
> > > > > scratch that i was looking at the wrong set of pictures that is a pcd-50b
> > > > > try a internal terminator on the 50pin scsi idc cable to see if the pcd-50 term is working
> > > > > do you know if the firmware has been st to the 1 that ted has as that is the correct read and write os
> > > > > you might only have a read only drive where did you get it from
> > > > > From: jack
> > > > > Sent: Monday, November 21, 2011 5:44 PM
> > > > > Subject: Re: [emax] Re: Emax/PCD 50B Installation Problems
> > > > > thats your mistake that drive ted uses is not the pcd -50b
> > > > > it a totally different drive its a spyrus 300 with 2 pcmcia card slots and can run on 2 scsi ids
> > > > > as it does this with term switching ic instead of the luns like on the pcd-50b
> > > > > From: ditabeardmemo
> > > > > Sent: Monday, November 21, 2011 4:51 PM
> > > > > I thought the same thing at first, but I have the termination jumper set exactly like this photo from Ted's Web site:
> > > > > http://tinyurl.com/7yzht4k
> > > > > SCSI ID 0, termination on, write protect off.
> > > > > > thats usually a termination problem
> > > > > > From: ditabeardmemo
> > > > > > Sent: Monday, November 21, 2011 2:03 AM
> > > > > > Subject: [emax] Emax/PCD 50B Installation Problems
> > > > > > I recently picked up an Emax SE HD keyboard with the intention of installing a slim floppy and PCD 50B, as the original internal Miniscribe hard drive was dead. I installed the PCD 50B, but I can't get it to correctly format a Compact Flash card. Every time it produces an "HD Format Error" or freezes on "Formatting HD..." indefinitely. In one case, the unit froze while it was saving a bank to the formatted disk.
> > > > > > Here is what I've checked thus far:
> > > > > > 1. The machine boots normally from a floppy disk with the PCD 50B installed, and all functions appear to work.
> > > > > > 2. When formatting, I tried a floppy disk with the Plus OS 4.0 (from E-Synthesist's Web site) and an original HD OS 1.1 that came with the unit.
> > > > > > 3. I tried to format a SanDisk 512 MB card (connected via a PCMCIA adapter) and a SanDisk D2 Flashdisk 20 MB card, but neither worked.
> > > > > > 4. I confirmed that the SCSI cable has data line 1 (red stripe) lined up with pin 1 on the PCD 50B.
> > > > > > 5. The only jumper on the PCD 50B is for termination. I have all other jumpers removed. This means the device is set to SCSI ID 0 and "Write Protect" is off.
> > > > > > I'm out of ideas for what to try next. Any thoughts?
> > > > > > No virus found in this message.
> > > > > > Checked by AVG - www.avg.com
> > > > > > Version: 2012.0.1872 / Virus Database: 2101/4630 - Release Date: 11/21/11
> > > > > > [Non-text portions of this message have been removed]
> > > Version: 2012.0.1873 / Virus Database: 2101/4642 - Release Date: 11/27/11
