2015-03-20 by haroldeastman1984@...
Previously on “Lost” [In EZ Ink Land]…
I had my C88+ loaded with my EZ ink set, but was puzzling over print settings from four years ago.
So…here’s the next chapter. [I should probably indicate at this point that I’m working on a Mac Pro with OS X Yosemite installed. Just so you know.)
I opened a BW .tif file in Photoshop, set image size, resolution to 300 dpi, mode to greyscale (it was RGB for some reason), made my best guess at translating print dialog settings from Photoshop CS2 to Photoshop CC 2014…and hit print.
The printer whizzed away busily and a few minutes later kicked out...
...a blank sheet of paper.
I tried various settings in Photoshop, then tried printing from Lightroom 5 and Preview 8. Nada.
So I fired off an email to MIS, and also to Paul Roark. I got a nice job ticket number and the promise of follow-up from MIS, and to my great surprise, an actual reply from Paul. He suggested that the problem might be that I hadn’t removed the plugs/tapes from the air intake vents in the EZ carts.
It sounded like he had it right. But where were those pesky vents? I went to the online instruction sheets at the MIS site and found the cart I guessed was the model they’d sent me. The somewhat obscure sheet gave instructions for refilling and went on to say, “Be sure to remove the foil covering the vent hole. Some carts come with foil, some don't. The vent hole on top of the sponge section must be open or the cartridge will not work.”
Ummm. Okay.
No foil, unless the're colored strips on the color position carts. But working from the images on the online instruction sheet, I was able to infer which openings were probably the vents. Except that these vents on my carts were plugged with coloured tabs with a stern warning Do Not Remove.
Being somewhat between a rock and a hard place instructions-wise, I decided to remove them anyway.
And voila: prints! Bad prints with lots of fine lines, but prints none the less.
It looked like the beginning of the end of my initial woes. Just run some cleanings, then I could start to fine tune my prints until I’d get results that would make Ansel Adams weep with envy.
But my woes have continued. Stay tuned…
