subouts?
subouts?
2005-04-25 by subjay27
Hi (hope my english is not to strange ;-)
I got my XL7 only a couple of days. In generell is it really easy to
work with, but i`m not sure if i understand the subouts correctly. I
have the sounds always on the Main-out even when the set them
at the subouts. No way to subtract it from the sum?
Thanks for help - Jay
Re: subouts?
2005-04-25 by malik
yeah i didnt really understand the manual's explanation of this
feature and really wanted them to be six or at least 3 individual
assignable outputs.
but i think it's just for some sillyy sends thing. i am not sure tho.
Re: subouts?
2005-04-25 by mike
The subouts can do a couple of things.  Using a TRS (tip,ring,sleeve) cable you can assign
tracks to the sub outs and route the dry signal to an external effects unit.  The effected
sound comes back into the command station and plays out of the mains with the rest of
the tracks.
The other thing you can do (which I just tried over the weekend) is route tracks to the sub
outs using a regular 1/4" cable to external gear.  Whatever is assigned to the sub outs
won't have any effects from the command station (dry signal).
I assigned track using the Global menu, then saved as a Multi Setup.  I was in song mode,
so I set the Event Source- Mix: to "Song Only"- otherwise the patterns seemed to reset my
track destinations.  I was recording a song on my multi track recorder and had the drums
out of Sub1 going to one track and synth from the Mains going to another track.  Don't
know if I did this right according to the manual, but it worked perfectly for me.
Hope this helps (or at least made some sense)
Mike
> assignable outputs.
RE: [xl7] Re: subouts?
2005-04-25 by Matt Picone
I need a primer on effects in general in the command station.
Why isn't it just as easy as having an effect A and effect B send knob per
Track, which scales the values set up in the patch?
Can someone help me get my head around this?
-m@
> -----Original Message-----
> From: xl7@yahoogroups.com [mailto:xl7@yahoogroups.com] On
> Behalf Of mike
> Sent: Monday, April 25, 2005 1:20 PM
> To: xl7@yahoogroups.com
> Subject: [xl7] Re: subouts?
> (tip,ring,sleeve) cable you can assign tracks to the sub outs
> effected sound comes back into the command station and plays
> out of the mains with the rest of the tracks.
> weekend) is route tracks to the sub outs using a regular 1/4"
> Setup.  I was in song mode, so I set the Event Source- Mix:
> recorder and had the drums out of Sub1 going to one track and
> synth from the Mains going to another track.  Don't know if I
> perfectly for me.
> Mike
> > assignable outputs.
> sure tho.
> really easy to
> correctly. I
> them at the
> --------------------~--> What would our lives be like without
> music, dance, and theater?
> Donate or volunteer in the arts today at Network for Good!
> http://us.click.yahoo.com/rKxVKC/SOnJAA/n1hLAA/pWZylB/TM
Re: subouts?
2005-04-25 by malik
NICE!! I''LL HAVE TO TRY THAT!!
THANKS!
with the rest of
> the tracks.
 I was in song mode,
perfectly for me.
> Mike
> > assignable outputs.
easy to
correctly. I
Re: subouts?
2005-04-25 by malik
sorry i donthave a helpful answer to this. all i know is that it isnt
set up in any ay that i'm familiar with and what mark told me makes me
want to go and re-research what a trs jack is....
knob per
> -m@
> > Behalf Of mike
> > perfectly for me.
> > Mike
> > > assignable outputs.
> > sure tho.
> > really easy to
> > correctly. I
> > them at the
> > Yahoo! Groups Links
Output Sends/Effects Sends (was Re: subouts?)
2005-04-26 by steve_the_composer
(1) Take a look at the diagrams in the manual: (a) Output --> Tip-Ring-
Sleeve [TRS] Return/Send sub outs, and (b) Output/Effects Send Routing.
(2) Notice on (b) the diagram shows two comingled send systems--output
and effects.  Think of them as separate systems first before trying to
figure out how the comingled system functions.
(3) You have in effect 4 send busses. These are a function of synth
settings (global and preset), NOT a function of the sequencer. (Also
remember: channels [midi/synth functionality] are NOT tracks
[sequencer functionality].
OUTPUT SENDS FUNCTIONALITY:
(1) Notice the Jack Detect switches. If there are no plugs in the sub
outs, the output sends are routed to the main outs.
(2) The sub outs do not go through the effects processor. They are dry
signals.
EFFECTS SENDS FUNCTIONALITY:
(1) With the synth part of your e-mu [global and preset settings], you
can route audio signal to FXA and FXB via 4 sends.
(2) With each of the FX modules [A and B] you can set the % levels of
each send.
Hope this helps.
--Steve
knob per
> -m@
Re: subouts?
You can also use the e-mu as a passive mixer for external modules
using the return/send sub outs.  The returned signals get added to the
internal signal and come out the main outs.
--Steve
> THANKS!
Re: subouts?
2005-04-26 by gonzinigonz
Is there a parameter somewhere that allows you to control the volume
of incomming audio that gets mixed back into the mains? (via the sub
ins)
I found that it was far too hot to use. I tryed it with a waldorf
pulse that doesnt have a master volume as its stored on a patch by
patch basis.
Volume was far too high when switching between un-edited patches :o(
Cheers
Gonz
--- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@p...>
> --Steve
> > THANKS!
Re: subouts?
2005-04-26 by malik
damn i had no idea it was so versatile....
does it have to be a stereo jack? for the sound to come back in though?
> --Steve
> > THANKS!
Re: subouts?
Nope. The volume needs to be controlled from the external [incoming]
source. Too bad the waldorf doesn't have some sort of master or
global volume. It sounds like it would be a pain to have to edit
every patch.
--Steve
volume
sub
> ins)
> patch basis.
> Cheers
> Gonz
modules
to
> the
> > --Steve
> > > THANKS!
2005-04-26 by subjay27
sub
Thanks for the hint, but no success.
No matter if i have the subs plugged or unplugged, i have always
the sounds on main-out :(
I really dont undestand why EMU didnt took the same system as
at the samplers. With my e6400 is it no problem, just set a
channel on main or sub 1, 2, 3 and thats it.
Re: subouts?
Yup. The e-mu is quite flexible.
The tip is the send, the ring is the return. Mono plugs only have
the tip and the sleeve, so you will only get the outgoing signal.
--Steve
though?
modules
to the
> > --Steve
> > > THANKS!
I have not used e-mu samplers,  but it sounds the same. Mix Output
[Global Parameter] lets you choose an output routing assignment on a
channel by channel basis. Or you can use the output assignments based
on a specific channel's preset.
"The Mix Output parameter allows you to override the routing
assignments made in each preset and instead assign the outputs
according to MIDI channel. For each of the 32 MIDI channels, you can
select Send 1-4, or Preset. When Preset is selected, the output
assignment defined in the Preset Edit menu is used."
I would assume that your presets use main outs by default.  So, it
should be a matter of routing the channel to a sub out using the
global Mix Output menu.
Hope this helps.
--Steve
> sub
PS: Also, try setting FX Mode [Global Parameter] to >> bypassed <<.
I just did a test and found that with FX Mode enabled, the various FX
settings were sending some processed signal through the main outs.
Hope this provides the final clue you need.
--Steve
Re: subouts?
Thats what i thought..
No global master volume on the pulse, so it would be a pain, but if i
had too i would.
Also its a bit dangerous as if something happened to jump right up in
volume..
Maybe a special jack to jack that has attenuation in the plug do
reduce the level is in order. That wouldnt be too hard to do.
Cheers
Gonz
[incoming]
> every patch.
> --Steve
> volume
> sub
> > ins)
by
> > patch basis.
patches :o
> > Cheers
> > Gonz
> modules
> to
> > the
> > > --Steve
> > > > THANKS!
try leaving the jack plug in for a little while, it takes a bit of time
for the xl to respond to the jack being plugged in.
Other than its just a case of setting up routing, like steve says in
the master/global menu
Gonz
> sub
Re: subouts?
2005-04-27 by malik
hmm i tried to use the global menu and setup the mp-7 to recieve a
signal from my synth but i got nothing. can't find the answer in the
manual either. got some stereo plugs too....
> --Steve
> though?
> modules
> to the
> > > --Steve
> > > > THANKS!
2005-04-27 by subjay27
Thanks for all your tips, i will try some - at weekend with enough
time of experiments .
The FX i have always turned off, because they sounds .... ;-)
Ciao
bypassed <<.
various FX
main outs.
> --Steve
always
system as
Re: [xl7] subouts?
2005-04-27 by BEAUFILS Adrien
Hello ( hope my english is not too strange too  i'm a french user of american material )
I have just a little precision to had ( many things have been said but not this feature ):
When your three output jacks are used ( linked with a stereo jack to a mixer ) and the effect are enable the signal of the fx return is only send in the main output .Despite the fact that you have send the channel 2 to sub 1 with 10 per cent of fx A for example the wet signal will go in the sub 1 and the dry portion ( the 10 per cent of fxA ) will go to the master output. It's very strange but it's like that.
Hope that help.
Yahoo! Groups Links
   To visit your group on the web, go to:
 Découvrez le nouveau Yahoo! Mail : 250 Mo d'espace de stockage pour vos mails !
Créez votre Yahoo! Mail
Re: [xl7] Output Sends/Effects Sends (was Re: subouts?)
2005-04-27 by José Sáez
Me too... i'd rather add some FX with software later. More control, less
hassle. I hate when i discover that some sound is being played with a lot of
fx, and distorts the sound of every other channel. I'd like to rewire some
knobs in order to control the effects right away. Would that be possible ?
Jose
2005-04-27 by Aaron Eppolito
> > sub outs, the output sends are routed to the main outs.
This is by design (and is also identical to the E4).  When you plug
something into a sub out, its DRY SIGNAL gets removed from the mains
and instead is sent to the sub jack.  However, the WET SIGNAL still
goes to the mains at the amount specified in the FXA/FXB send amounts
screens.  This allows you to do BOTH what you want and what you don't
want (but what someone else might want).  Simply set the send % to zero
for subs that you don't want to be effected (and thus heard at the
mains).
-Aaron
Do You Yahoo!?
http://mail.yahoo.com
