mute buttons useless when controlling xx7 from computer sequencer?
2004-08-25 by ignant666
I think I have figured out that the mute buttons are useless when controlling the xx7
from computer sequencer because they mute sequencer tracks, not midi channels-is
this right? In other words, using xx7 as a sound module,  the synth sections will play
notes regardless of whether the track light is lit (on) or unlit ("muted")- muting must
be done from the computer sequencing application.
If this is right,is there any any way to control muting of tracks in computer sequencer
from xx7,short of configuring it to send trigger messages that sequence application
will interpret as mutes?
This machine is so devious i hope there is some way to do this that Ican't figure out.
Thanx much for any help on this
ignant666
BTW, sequencer app in question is the very groovy Numerology from http://
www.five12.com -check it out!
Re: mute buttons useless when controlling xx7 from computer sequencer?
2004-08-25 by steve_the_composer
It really depends what you are trying to do. The mute/trigger buttons
can do several things based on your set up. However, if you are
trying to turn E-Mu tracks on and off remotely from your software
sequencer, I don't think you can do that on a one-to-one basic.
If you have single channel data on separate tracks (track one only
has midi data on channel 10 and no other track has data on channel
10, for example), you could mute that track by setting channel 10
volume to 0.
I am not sure this is what you are trying to do, though.
--Steve
> controlling the xx7 from computer sequencer because they mute
> sequencer tracks, not midi channels-is this right?
[snip]
okay, I'm being unclear. I'm  running my mp7 sequenced by my mac. when I hit play,
sound comes out of every channel w/data regardless of whether the track mute light
is lit or dark, although the volume controller knobs work normally. I'm guessing this
is because they are sequencer track mutes and I'm not using the sequencer, only the
synth part.
I want to have the track mute buttons work like they do when using the internal mp7
sequencer, ie if button is lit, track is heard, unlit, track is muted.
It occurred to me that the workaround might involve configuring the trigger buttons
to send mute messages to the computer app- is there a more straightforward way to
do this?
Thanx for prompt reply to muddled question and any further illumination
ignant666
> volume to 0.
> --Steve
> [snip]
2004-08-25 by robotchas
You guessed right, the mutes only interrupt the output from the
internal sequencer (to the synth or MIDI out).
Triggers can send note-ons but not CCs, so I don't know if there's a
workaround unless you have something like Max (www.cycling74.com),
which will allow you to remap MIDI messages at will (along with lots
of other cool things - it's a great tool).
when I hit play,
track mute light
I'm guessing this
sequencer, only the
> synth part.
the internal mp7
muted.
trigger buttons
> do this?
illumination
> ignant666
buttons
only
channel
> > volume to 0.
> > --Steve
when
> > [snip]
[snip]
> when I hit play,
> track mute light is lit or dark, although the volume controller
[snip]
> the internal mp7 sequencer, ie if button is lit, track is heard,
I think I understand. Let me know if this is right: You want to use
the MP-7 as a sound module only with the sequences being played from
the Mac sequencer (no sequences being played from the MP-7).
BUT:
You want to be able to mute the Mac sequences with buttons on the MP-
7.
If so, the only way I can think to do that is if your Mac software
can be programmed to turn the sequences on and off with note
triggers.  If so, you might be able to use the 16 MP-7 buttons in
>>note<< trigger mode.
trigger buttons
> do this?
illumination
> ignant666
Yes, you both confirm that there is no way to do this, short of convincing computer
app to mute say channel 1 when receiving a note triggered by trigger button 1.
i just want to be able to mute multiple channels of sound with hardware buttons.
Oh well.
Thanx
ignant666
> [snip]
> > when I hit play,
> [snip]
> BUT:
> 7.
> trigger buttons
> > do this?
> illumination
> > ignant666
Re: [xl7] Re: mute buttons useless when controlling xx7 from computer sequencer?
2004-08-26 by erik_magrini@Baxter.com
Yeah, I think you would need to set up the Mutes in trigger mode (probably
to note mode?), and then make sure you software interprets these as
channel mutes.  This can be done in SX's generic remote setup, not sure
what app you're using though.
trigger buttons
way to
do this?
material from any computer.
For Translation:
Yeah, but it shouldn't be that hard to do this, so you can still get it to
work.
ignant666 <ignant666@...>
08/25/2004 06:28 PM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] Re: mute buttons useless when controlling xx7 from computer
sequencer?
computer
button 1.
buttons.
Oh well.
Thanx
ignant666
> [snip]
> > when I hit play,
> [snip]
> BUT:
> 7.
> trigger buttons
> > do this?
> illumination
> > ignant666
Yahoo! Groups Links
For Translation:
