Early Rizer Filter Problem
2004-08-22 by steve_the_composer
I have uploaded an *.asf file temporarily to demonstrate a problem
of popping sounds I ran across with a preset using the EarlyRizer
filter.  On another board, another user was also having a problem
with a preset (Vintage ROM) that used this filter.  I am not sure if
others faced this problem, but here's a solution I found (in case it
helps others).
I isolated the offending layer by turning off layers in the
offending preset.  After testing scores of possibilities, I found a
layer level patchcord as follows:
MidiE --> VEnvAtk  -60
By increasing MidiE (thereby decreasing the VEnvAtk), I got rid of
the popping.  If you listen to the EarlyRizer.asf file, you will
notice it goes away after about 20-25 seconds.  Yes, it changes the
sound slighly, but its better than the popping and still retains
much of the filter characteristics.
Sorry its an asf file; my mp3 program isn't working. Also, since the
file takes up a large chunck of space, I will be removing it
shortly.  If you faced this problem and found other solutions, I'd
be interested in them.  Thanks.
--Steve
Re: [xl7] Early Rizer Filter Problem
2004-08-22 by Aaron Eppolito
Congratulations, you found the culprit of the problem (i.e the filter)
much quicker than people have in the past.  We had a relatively long
discussion on preset pops that took quite a while to track down in the
past.
An alternate solution (which may or may not change the sound less) is
to turn down Q ever so slightly.  Same deal.  The filter has a lot of
resonance that when combined with certain sounds, clips the filter.  As
a side note, you'll notice that most filters have their max Q set at 80
instead of 100.  At your own risk, you can turn them up... =)
-Aaron
> helps others).
> --Steve
Do you Yahoo!?
New and Improved Yahoo! Mail - Send 10MB messages!
http://promotions.yahoo.com/new_mail
Re: Early Rizer Filter Problem
2004-08-24 by steve_the_composer
Thanks for the reminder.  I remember the discussion here and your
previous advice about Q.  In fact, before I ran into the problem
myself I suggested to the other user adjusting the filter
parameters.  In my case, the offending preset [P2500: pad:Richness]
had Q=0 on both layers.
With EarlyRizer, it almost seems like the filter starts rising
before the sample is completely out of the gate!! :-)
I ended up tweaking VEnv Attack1 Rate on both layers.  This let me
have the least change on each layer (from 0 to 2 on one layer; from
0 to 7 or 8 on the other layer).  Since its a pad, the miniscule
attack change is hardly noticeable.
As for high Q's, I have an ART X-15 controller with 2 pedals.  99
44/100% of the time, I have them controlling cutoff and resonance.
Noodling with my midi sax, I play the cuttoff pedal, esp. with delay
or pan delay effects.  But I almost always have Q backed off from
max.  Its definitely too intense, but nice to know its there if I
need it.  Occasionally, I momentarily push the Q to the floor.
--Steve
filter)
long
> past.
is
of
filter.  As
at 80
> -Aaron
Re: [xl7] Re: Early Rizer Filter Problem
2004-08-26 by erik_magrini@Baxter.com
Tried listening to it, but Ithink you recorded it too hot, there's
clipping all over it!  :)
(yes, that was a joke)
08/26/2004 09:57 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] Re: Early Rizer Filter Problem
Thanks to everyone who listened to the file I posted and to those who
posted comments on this issue.  Since the asf.file (335k) takes up
most of the file space that was left before I posted the file, I will
be deleting the file either this evening or in the early morning
hours.
SO:
If you want to hear what the EarlyRizer filter problem sounds like,
give it a listen.  (Its in a folder named TEMPORARY in the files
section.)
--Steve
Yahoo! Groups Links
use of, or taking of any action in reliance upon, this information by
material from any computer.
For Translation:
