Odd master volume problem, bug or hardware issue??
2004-08-24 by gonzinigonz
Ive just received my new headphones and to try them out i plugged
them into the XL-7.
Well i happened to stumble across this..
I had all the track volumes down via the 16 knobs on the left of the
unit. It was playing back a seq then i turned up the master volume to
be greeted by a loud poping and the tracks would break through as if
id cranked up the idividual volumes!!
It only happens with the first quarter turn.
Then if i increase one of the tracks volume to say about 2 the
problem dissapears.
Then i tryed it with other presets, the same problem :o(
Can someone else try this to see if i have a hardware problem?
Ive been having problems with notes being cut off as well..
So select a bts preset on any track. Set if off playing say 4 parts
(E1, F1, F#1, G1 etc..)turn down the track volume. Turn down the
master volume and increase.
The problem is erractic, fast or slow movement of the knob set if
off. Higher tracks seem worse, but lower ones do it as well.
Also happens with normal presets.
I realise you wouldnt use the unit like this, but im wondering if it
is connected with the other issues i have wih the unit
Ive just reset the unit = same problem
Ive just re-downloaded the OS (v2.0) = same problem
Arghhh!
Gonz
Re: [xl7] Odd master volume problem, bug or hardware issue??
2004-08-24 by erik_magrini@Baxter.com
How long have you had your XX-7?  With all the issues you've been having
it could very well be a dud unit.  I'd take it back to the store for
another one if you still can, or send it to Emu for repairs.
gonzinigonz <gonzini@...>
08/24/2004 07:22 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] Odd master volume problem, bug or hardware issue??
them into the XL-7.
problem dissapears.
Arghhh!
Gonz
Yahoo! Groups Links
material from any computer.
For Translation:
Re: Odd master volume problem, bug or hardware issue??
2004-08-26 by gonzinigonz
having
for
> rEalm
Hi
Brought it second hand from the states, its like new though plastic
still on the LCD.. Could well be having problems, take it that you've
not come across this problem then?
Cheers
Gonz
Re: [xl7] Re: Odd master volume problem, bug or hardware issue??
2004-08-26 by erik_magrini@Baxter.com
Not personally.
08/26/2004 02:46 PM
        cc:
        Subject:        [xl7] Re: Odd master volume problem, bug or hardware issue??
having
for
> rEalm
Hi
Cheers
Gonz
Yahoo! Groups Links
use of, or taking of any action in reliance upon, this information by
For Translation:
> Not personally.
> rEalm
Dont look good then.. l'll try and pull some of the roms out to see
if that makes a differance.
Im off to do a festival so it will have wait til i get back.
Cheers a
Gonz
