Emax
floppy drive?
floppy drive?
2006-01-25 by Andy
I know i may be cryin down a well here, but my floppy drive appears to
be on its last legs, i have an emax HD (with a later OS plus upgrade)
and an external zip drive (hardset to ID 5 or 6 only) that gets past
diagnostics then chokes on the disks, what do i do??? is there a way to
get the emax to boot without being forced to buy a new disk drive which
is only useful for booting?
~AJB
Re: [emax] floppy drive?
2006-01-25 by David Dehart
Andy..........
Can you elaborate on "chokes on the disk" ?  What
exactly happens.......what does the lcd say
?...........What sound does the drive make ?
Dave
drive appears to
OS plus upgrade)
that gets past
is there a way to
disk drive which
~AJB
Emax and Emax II User's Group Website
http://www.silveriafamily.com
      SPONSORED LINKS
Electronic instrument
  Emax                                    Synthesizer
music
              Electronic music
           Music sampler
     Electronic musical instrument
  YAHOO! GROUPS LINKS
    Visit your group "emax" on the web.
 emax-unsubscribe@yahoogroups.com
    Your use of Yahoo! Groups is subject to the Yahoo!
Terms of Service.
2006-01-25 by zorax
>From: David Dehart <mytunes@...>
>Sent: Jan 24, 2006 7:19 PM
>To: emax@yahoogroups.com
>Subject: Re: [emax] floppy drive?
>Andy..........
>Dave
>drive appears to
>OS plus upgrade)
>that gets past
>is there a way to
>disk drive which
>~AJB
>To Dave Dehart, Hi, I wish I could be of help concerning your floppy drive, but, am having some of my own troubles that sound similar to your probs. My floppy seems spastic too, sometimes is OK but often finicky and hard to get booted. I am beginning to think it may be errors along the way not from the floppy. These old machines run hot and mine starts thumping after half our. I installed a computer fan inside and helped a little, but know that I need electronic repair. Your floppy may be fine and trouble from errors along the circuit pathes...? good luck, zorax
    cm_zorax@...
>      SPONSORED LINKS
>  Emax                                    Synthesizer
>music
>              Electronic music
>           Music sampler
>  YAHOO! GROUPS LINKS
>Terms of Service.
>Yahoo! Groups Links
[emax] Emax II not powering on
2006-01-25 by s*
Hi I have an Emax II.  When I went to power it on last, it just makes a
clicking noise and all of the lights flash on and of repeatedly with the
clicks.  Any ideas?  I sincerely hope my power supply is not dead.
Any help is greatly appreciated,
-s*
Re: [emax] Emax II not powering on
2006-01-25 by ted Summers
Sounds like either a capacitor has blown (easy to get and replace),
or a cold solder on the bottom of the board is arcing....
remove the power supply. You may see the top of one of the
"cylinders" with the metal tops bulging upward or just plain blown.
That would be a capacitor. A cold solder would be a break in the
contact on the bottom of the board- this could be less obvious to the
layman w/ minimal electronics experience....
Just my opinion though....
T
> makes a
> with the
> Thanks,
> -s*
Re: floppy drive?
2006-01-25 by mrdazobee
Have you tried a floppy disk cleaner?A long shot but worth a try
cause you can buy them for peanuts........
--- In emax@yahoogroups.com, zorax <zorax@e...> wrote:
> -----Original Message-----
> >From: David Dehart <mytunes@s...>
> >Andy..........
> >Dave
> >drive appears to
> >OS plus upgrade)
> >that gets past
> >is there a way to
> >disk drive which
> >~AJB
>     cm_zorax@y...
> >      SPONSORED LINKS
> >  Emax                                    Synthesizer
> >music
> >              Electronic music
> >           Music sampler
> >  YAHOO! GROUPS LINKS
> >Terms of Service.
> >Yahoo! Groups Links
2006-01-25 by s*
Thanks Ted.  Fortunately I used to work at one of the main music stores here
in Toronto and I know a bunch of repair guys.  The downside is, very few
people know how to fix EMU gear in this city but, if it is that easy of a
fix, I'll see if they can take care of it for me (as my electronic
soldiering skills are still somewhat novice.)
Thanks again,
-s*
> T
> > makes a
> > with the
> > Thanks,
> > -s*
> > Yahoo! Groups Links
>  SPONSORED LINKS
>   Electronic instrument<http://groups.yahoo.com/gads?t=ms&k=Electronic+instrument&w1=Electronic+instrument&w2=Emax&w3=Synthesizer+music&w4=Electronic+music&w5=Music+sampler&w6=Electronic+musical+instrument&c=6&s=136&.sig=aecyjh6f3P0_jh1KjIykPA>
> Emax<http://groups.yahoo.com/gads?t=ms&k=Emax&w1=Electronic+instrument&w2=Emax&w3=Synthesizer+music&w4=Electronic+music&w5=Music+sampler&w6=Electronic+musical+instrument&c=6&s=136&.sig=-_3jyavMRH8D4cBr9cevag>  Synthesizer
> music<http://groups.yahoo.com/gads?t=ms&k=Synthesizer+music&w1=Electronic+instrument&w2=Emax&w3=Synthesizer+music&w4=Electronic+music&w5=Music+sampler&w6=Electronic+musical+instrument&c=6&s=136&.sig=bAqfMK9DBwENQOJVQHH0gg>   Electronic
> music<http://groups.yahoo.com/gads?t=ms&k=Electronic+music&w1=Electronic+instrument&w2=Emax&w3=Synthesizer+music&w4=Electronic+music&w5=Music+sampler&w6=Electronic+musical+instrument&c=6&s=136&.sig=JIRW630YAjGfr0mxwvnGeA>  Music
> sampler<http://groups.yahoo.com/gads?t=ms&k=Music+sampler&w1=Electronic+instrument&w2=Emax&w3=Synthesizer+music&w4=Electronic+music&w5=Music+sampler&w6=Electronic+musical+instrument&c=6&s=136&.sig=Vn2A4FIJ6W7oa2PayjrvLA>  Electronic
> musical instrument<http://groups.yahoo.com/gads?t=ms&k=Electronic+musical+instrument&w1=Electronic+instrument&w2=Emax&w3=Synthesizer+music&w4=Electronic+music&w5=Music+sampler&w6=Electronic+musical+instrument&c=6&s=136&.sig=-XFdhqWkgTF0Vl8NhFUBbQ>
> YAHOO! GROUPS LINKS
>    -  Visit your group "emax <http://groups.yahoo.com/group/emax>" on
>    the web.
>    -  To unsubscribe from this group, send an email to:
>     emax-unsubscribe@yahoogroups.com<emax-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>    -  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>    Service <http://docs.yahoo.com/info/terms/>.
Re: floppy drive?
2006-01-25 by Andy
hey, sorry... k generally it used to give me the standard "disk error"
msg and would take many tries to get going, but now it gives me a "bad
timeout" error, which sounds much worse... when it was doingthe disk
error msg, i found it wasn't reading the disk until the drive made
a "swish" noise,  which seemed to indicate it was finally reading the
drive but now the "bad timeout" seems to be far worse... any help at
all would be most appreciated
~AJB
2006-01-25 by gray
You better hope its the power supply thats the easiest thing to
check and fix....if its on the board is what you better hope its
not....you should be able to get the spec for the trans and check
the output of the power supply....and see what its doing.
gray
  Sent: Tuesday, January 24, 2006 11:59 PM
  Subject: [emax] Emax II not powering on
  -s*
  YAHOO! GROUPS LINKS
    a..  Visit your group "emax" on the web.
    b..  To unsubscribe from this group, send an email to:
    c..  Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Re: floppy drive?
2006-01-25 by Andy
for that matter, does anyone know what floppy drive models are useable
as replacements for the emax? is the route66 drive the only one that
will work or are there alternative (i have heard that mac classic
drives, as well as a certain sony model will work as well as the TEAC
but am not really sure) any info would be great, thanks very much
~AJB
2006-01-25 by s*
Might you know where I can get these specs?  I know that my friend had a
really hard time finding any specs for his Emulator III.  I have found
someone who is willing to take a look at it but, he can give no guarantee
that he can fix the problem so, the more info I can give him, the better.
It's also my controller keyboard so, if it's dead, I'm kinda screwed until I
find a replacement and I am kinda partial to the Emax's key action.
thanks a lot,
-s*
> gray
>   ----- Original Message -----
>   From: s*
>   Thanks,
>   -s*
>   YAHOO! GROUPS LINKS
> Service.
> YAHOO! GROUPS LINKS
>    the web.
2006-01-26 by gray
these are also good points.....and easy to a point.....
Sounds like either a capacitor has blown (easy to get and replace),or a cold solder on the bottom of the board is arcing....
gray
  Sent: Wednesday, January 25, 2006 1:43 PM
  Subject: Re: [emax] Emax II not powering on
  thanks a lot,
  -s*
  > gray
  >   From: s*
  >   Thanks,
  >   -s*
  >   YAHOO! GROUPS LINKS
  > Service.
  > YAHOO! GROUPS LINKS
  >    the web.
  SPONSORED LINKS Electronic instrument  Emax  Synthesizer music
        Electronic music  Music sampler  Electronic musical instrument
  YAHOO! GROUPS LINKS
Re: [emax] Re: floppy drive?
2006-01-26 by elmacaco
are you booting from the floppy?  you should copy the OS to the internal HD.
  Sent: Wednesday, January 25, 2006 1:18 PM
  Subject: [emax] Re: floppy drive?
  ~AJB
  YAHOO! GROUPS LINKS
