It really would help a lot if you try EMX for DOS and let me know the
results.
You can do this by making an MSDOS startup disk (see BOOT***.EXE in
the files section - or anywhere on the internet), putting the floppy
in your PC, then reboot and run EMX from MSDOS.
Some useful information can also be gathered by running the
EMXPINFO.EXE program (in XP). You can find this small program in the
files section: http://launch.groups.yahoo.com/group/emax/files/EMXP/
Can you run this program
(a) once for a disk formatted by EMXP.
(b) once for a disk formatted by your EMAX.
and e-mail the two EMXPINFO.TXT output files to me ?
(esynthesist@...).
Check your email addresses also, because I don't think it's necessary
to send all messages related to EMXP support into the public message
board (although this is OK to me).
Craig or maybe someone else can also try to compare the results of
EMX and EMXP ?
///E-Synthesist
--- In emax@yahoogroups.com, Marcelo Simoni - Condor Aircraft Aero
Agrícola <marcelo@d...> wrote:
> Dear E-Synthesist
> My EMX never worked anyway, because I never used a non XP PC.
> Although the EMXP worked fine on creating sound disks t omy Emax.
> Whenever I tried to format an OS disk, it shows strange caracters
and Bad Disk message.
> Thanks once more
> Marcelo
> Condor Aircraft Aero Agrícola Ltda
> Representante Exclusivo PZL-Mielec
> Office/Fax: +(43)3538-5524
> Mobile: +(43)9977-0058
> Visit our web site: www.condoraircraft.com.br
> From: esynthesist
> To: emax@yahoogroups.com
> Sent: Friday, January 06, 2006 10:29 AM
> Subject: [emax] Re: EMXP Test
> Craig, Marcello,
> Can you give more details, I'm not sure I understand the problem.
> Is the following true:
> - disks formatted on EMAX:
> * banks written to this disk with EMXP
> --> disk can be read by EMAX, everything works fine
> * banks written to this disk with EMAX and then read to PC
with
> EMXP
> --> disk can be read by EMXP, everything works fine
> - disks formatted with EMXP:
> --> disk not usable on EMAX
> * OS written to this disk with EMXP
> --> disk not usabel on EMAX
> --> not possible
> Am I correct ?
> So basically the format function of EMXP does not work for EMAX
SE
> machines ?
> Is there a difference depending on the OS version you're using on
> EMAX ?
> Have you tried the same thing with the original EMX program (on a
DOS
> booted PC) ? Do you have the same problem ? That's important for
me
> in order to be able to debug the software. If EMX works and EMXP
> doesn't, I can compare the code and perhaps make some changes to
both
> EMXP and the Emax Floppy Driver.
> No need to tell you that everything works fine on my EMAX II
> machines :-). I don't have an EMAX-I machine though so I can't
test
> my software on that type of machine. I want one but they're hard
to
> find or too expensive here in Belgium...
> Regards
> ///E-Synthesist.
Aero
> > Hi I2web_net
> > I'm having exactly the same problems.
> > Although, we have to thank esynthesist for taking the action
and
> producing an effective working program to send our files to Emax
> disks. It had been many years since I last used a new bank on my
Emax.
> > I'm sure he'll come up with a new version with all goodies we
are
> looking for.
> > Thanks anyway
> > Marcelo
> > From: l2web_net
> > Sent: Thursday, January 05, 2006 7:56 PM
> > Subject: [emax] EMXP Test
> > Hi,
> > I just tried out the new version of EMXP. Seem to be getting
> same results.
> > Writing a bank works fine.
> > Writing the OS works fine.
> > Formatting produces an usuable disk. Emax will say "Bad Bank
on
> Disk" if I attempt to access
> > the bank (which I guess would be blank after format). If I
try to
> boot from the disk or use an
> > OS function I get the crash, scrambled freak-out screen and
weird
> noises.
> > Hope this confirmation helps with the debug.
> > Cheers!
> > C.
> > Emax and Emax II User's Group Website
> > http://www.silveriafamily.com
> > SPONSORED LINKS Electronic instrument Emax Synthesizer
music
> > Electronic music Music sampler Electronic musical
> instrument
> > YAHOO! GROUPS LINKS
> > a.. Visit your group "emax" on the web.
> > b.. To unsubscribe from this group, send an email to:
> > emax-unsubscribe@yahoogroups.com
> > c.. Your use of Yahoo! Groups is subject to the Yahoo!
Terms
> of Service.
> > No virus found in this incoming message.
> > Checked by AVG Free Edition.
> > Version: 7.1.371 / Virus Database: 267.14.14/222 - Release
Date:
> 5/1/2006
> > No virus found in this outgoing message.
Date:
> 5/1/2006
> > [Non-text portions of this message have been removed]
> YAHOO! GROUPS LINKS
> c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms
of Service.
> Version: 7.1.371 / Virus Database: 267.14.14/222 - Release Date:
5/1/2006
5/1/2006
