DIsk Error! when formatting
2006-01-25 by synthmdl76
Hi all... I searched the past post but found nothing. When I try to format a disk, I get the normal chugging sound out of the hard drive, then after a minute the displace shows Disk Error! I am using a disk that I just loaded a sample from. So I know I can read from the disk, I just cant format it. So, Before i tried to format the disk I loaded a sample off it and it worked fine. After I tries to format and bot the disk error, I tried to load the sample off the disk just to see if anything happened to the disk. And yes, when I try to load from this disk, the display says "bad bank on disk" Anyone else see this before? I even tried multible disk and Im doing it the way the manual says to do it. thanks all
