Dark Time low gate out signal
2013-09-23 by nuipb1@gmail.com
Hi group,
Dark TIme has this strange behaviour: the gate out signal seems low, sending around only 2 to 3V (probably 2,5V but my measuring tool is not accurate) when it should be sending 5V and around 5V when it should be sending 12V (jumper in the 12V position).
Would anyone have any idea what could cause this ?
Also, I noticed that in the "Update DT firmware" PDF page 2 first picture, 1 of the 2 jumpers circled in red (the one at the right ) is not in the same position as the one in my DT. The one in my DT is directly perpendicular to the left side of the other instead of being parallel to its right side.
Should I correct this or this has nothing to do with the first issue and is not source of any other issue ?
Thanks for your advices,
Cheers,
Phil
