Re: [xl7] going insane ..presets changing on patterns
2003-05-08 by erik_magrini@Baxter.com
Do you have any data on the Patterns?  If you don't have any data saved on
a track, switching to a new Pattern will mean that the old Presets will
still be assigned to the track.
honkeyhindu <honkeyhindu@...>
05/07/2003 06:19 PM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] going insane ..presets changing on patterns
lets say i go to a pattern(test x) and change the presets on that
pattern and then save the pattern .. then  move on to another pattern
the persets on that pattern will xfer to what ever pattern that i
move to ie test x presets move to test y presets...
now when i shutoff the xl and reboot it does the same thing ..
on the boot up process right b4 i can auctually start using the data
the xl goes thru the normal boot up screens and then comes to this
LOADING 001 0 (not exactly but i think you understand ) it looks like
its loading pattern 001 bank 0
when i go to any pattern and pres the stop button three time to
reinitialze the pattern ..b4 it switches the pattern it dispays the
same thing 0001 0 before it switches ...what is it doing there ??
i am giuessing that this one will only be fixed thru an os update ..
oh yea my os is 1.32
Re: going insane ..presets changing on patterns
2003-05-08 by honkeyhindu
hmm ..i found out that it was the multisetup that was causing this
whole prb .. but i still do not know why ???
yes ...i have the pattern that i am working  000 0 and the rest of
the xl preset patterns are still there after that ...
the way it was freaking out was really crazy
i went to the emu site to check out the prb last night and found my
prb ..but i cant understandy why emu would do this or if it just a
way of thinking that i am not used to ..
"the Multisetups channel settings will be saved to Pattern, instead
of the correct values you wanted"
i do not get this at all .. why would a multiset up save a preset
assigment ..there is already a way to save the preset to
pattern ..and it is simple and logical ..save it to pattern ...in my
head the multisetup should contain information about the channel
assigment ...like what sub groups the tracks are assigned to and the
effects percentage such that if a person wanted to have one pattern
start out with one effect setting and change to another all they
would have to do is switch the mutisetup ..
in my case say .i am on one of the orginal xl patterns ..and i switch
the multisetup the pattern goes all wacky ..it changes all the
presets in that pattern...  how do i fix this ?? it seems that my
mutisetup 000  001  002 all change the presets ..NOno no .me no want
that ...
"and if you save your Pattern before playing it, the Multisetups
channel settings will be saved to Pattern"  err why why why ??
how is this undone ?????
thanks again to all
saved on
will
> rEalm
> honkeyhindu <honkeyhindu@c...>
> 05/07/2003 06:19 PM
>         cc:
patterns
pattern
data
like
Re: [xl7] Re: going insane ..presets changing on patterns
hmm ..i found out that it was the multisetup that was causing this whole
>>>Well, if you load a multisetups, it loads the presets that were on each
Track when you saved the Multi.  So if you save the pattern after loading
a Multi, it will save the Presets assigned in the Multi, not the ones you
saved as part of the Pattern.   Best bet, is to Revert to Saved Pattern
before you save the Pattern! <<<
i went to the emu site to check out the prb last night and found my prb
..but i cant understandy why emu would do this or if it just a way of
>>>99% sure it's the later, no offense. :) <<
"the Multisetups channel settings will be saved to Pattern, instead of the
assigment ..there is already a way to save the preset to pattern ..and it
is simple and logical ..save it to pattern ...in my head the multisetup
should contain information about the channel assigment ...like what sub
effects percentage such that if a person wanted to have one pattern start
out with one effect setting and change to another all they would have to
>>>You can do what you suggest too, but Multisetups are more flexible than
that.  Say you were sequencing from an external sequencer, like Cubase,
then you wouldn't need to create a pattern (since the notes would be
stored in Cubase).  However, you'd still want the right sounds on each
track, so you could save a Multisetup to store this data.  There's lots
more uses for Multi's, they're not JUST to save Preset assignments, though
that is a nice benefit. <<<
in my case say .i am on one of the orginal xl patterns ..and i switch the
multisetup the pattern goes all wacky ..it changes all the presets in that
>>>Easy, just perform a "Revert To Saved Pattern" (Pattern Edit menu).
This will relaod the Presets that were saved with the Pattern.  Now resave
the Multi.  Whenever you load the Multi, it will recall the Presets from
the Pattern now.  You will need to do this for each of Multi's you want to
load durring a Pattern, and you will nee to do it for all Patterns.  Think
of Multi's as a snapshot of every setting within the XX-7 at the moment
you save it. Everytime you load a Multi, EVERYTHING will revert to how the
XX-7 was when you saved the multi. <<<
"and if you save your Pattern before playing it, the Multisetups channel
>>>Because when you load the multisetup, it will assign the Presets to
each track that were there when you saved the multi.  As far as the
Pattern is concerned, it has no idea the Presets aren't what you want,
it's like you manually changed them one at a time as far as it's
concerned.  So when you save the Pattern, it will now store the new
Presets, instead of the ones you had orginally saved. <<<
>>>If you load a multi and it doesn't have the Presets you want, perform a
Revert to Saved. <<<
thanks again to all
>>>Let me know if I didn't explain it well enough.  Believe it or not,
it's a really, really flexible feature, you just need to get your head
around and it'll make more sense. <<<
2003-05-22 by honkeyhindu
ok .i am back with the same prb
here is what i am doing
write a pattern
set the knobs to different controls
save the pattern first..
the play the pattern and then save the muti ( to save the controller
set up )
save it then name it
i do this for two patterns ..
the controller vaules being different for both patterns
pattern A   multi A
pattern B   multi B
when i go from pattern A to B   the controller vaules remian the same
in order for me to get the right pattern with the right multisetup is
to stop play change
multi then do a revert to pattern .. but how are you supposed to do
that live ?
i am truly sorry that i do not understand this concept.
whole
on each
loading
ones you
Pattern
prb
of
of the
pattern ..and it
multisetup
sub
start
have to
flexible than
Cubase,
be
each
lots
though
switch the
in that
menu).
resave
from
want to
Patterns.  Think
moment
how the
channel
to
want,
perform a
> thanks again to all
not,
head
> rEalm
2003-05-22 by erik_magrini@Baxter.com
What knob settings are you changing?  Are they set to Volume, or Quick
Edit?
05/22/2003 12:30 AM
        cc:
        Subject:        [xl7] Re: going insane ..presets changing on patterns
write a pattern
set up )
pattern A   multi A
pattern B   multi B
to stop play change
that live ?
whole
on each
loading
ones you
Pattern
prb
of
of the
pattern ..and it
multisetup
sub
start
have to
flexible than
Cubase,
be
each
lots
though
switch the
in that
menu).
resave
from
want to
Patterns.  Think
moment
how the
channel
to
want,
perform a
> thanks again to all
not,
head
> rEalm
controller assigment
k1    assigned to 74 for ch 2
k2    assigned to 71 for ch 4
the for pattern two
say k1 assigned to control 1  ch 4
whatever you get the idea ..
after i set the controller assigment i play the pattern then i save
the pattern and then i save the muti and then name it and then save
it to that name ..
i do this for the two patterns ..
again in oder for the pattern and controller vaules to be right.
these are the steps that i have to take ..
go to multi ..select the multi ..then revert the pattern
..when i switch the pattern i ahve to do the same for that pattern as
well ....HOW DO I DO THIS LIVE ..i cant stop the show and start it up
again ..thanks again
Quick
> Edit?
> rEalm
> 05/22/2003 12:30 AM
>         cc:
on patterns
> write a pattern
controller
> set up )
> pattern A   multi A
> pattern B   multi B
same
is
> to stop play change
> that live ?
this
> whole
were
> on each
> loading
> ones you
> Pattern
my
> prb
way
> of
instead
> of the
> pattern ..and it
> multisetup
what
> sub
pattern
> start
> have to
> flexible than
> Cubase,
> be
> each
There's
> lots
assignments,
> though
> switch the
presets
> in that
> menu).
Now
> resave
Presets
> from
you
> want to
> Patterns.  Think
> moment
to
> how the
> channel
Presets
> to
> want,
new
> perform a
> > thanks again to all
> not,
> head
> > rEalm
2003-05-23 by erik_magrini@Baxter.com
Ok, so it sounds like you're using the knobs in Program mode, since you're
assignments are on different channels.  The only way to save this is via a
Multi as you are doing, which of course saves the current Presets too. Not
much you can do to get around this, except plan ahead in your patterns, or
switch channels manually (EDIT + TRACK MUTE is the fastest way) and use
the knobs in Quick Edit mode (knobs A and B will be 74 and 71 by default).
the for pattern two
it to that name ..
2003-05-25 by honkeyhindu
hello everyone  ..what am i doing wrong here ..please tell me that
this is a function that i can do
> the for pattern two
> it to that name ..
as
up
> Quick
> > Edit?
> > rEalm
> > 05/22/2003 12:30 AM
> >         cc:
> on patterns
> > write a pattern
> controller
> > set up )
> > pattern A   multi A
> > pattern B   multi B
> same
multisetup
> is
> > to stop play change
do
> > that live ?
> this
> > whole
> were
> > on each
after
> > loading
> > ones you
> > Pattern
found
> my
> > prb
> way
> > of
> instead
> > of the
preset
> > pattern ..and it
> > multisetup
> what
> > sub
> pattern
> > start
would
> > have to
> > flexible than
> > Cubase,
would
> > be
on
> > each
> There's
> > lots
> assignments,
> > though
> > switch the
> presets
> > in that
> > menu).
> Now
> > resave
> Presets
> > from
> you
> > want to
> > Patterns.  Think
> > moment
> to
> > how the
Multisetups
> > channel
> Presets
> > to
> the
you
> > want,
it's
> new
want,
> > perform a
> > > thanks again to all
or
> > not,
your
> > head
> > > rEalm
no longer insane ..getting muti to work with presets
2003-05-29 by honkeyhindu
i must say that i am surprised that no one sets up multis with
presets and if they do ..on one wanted to ans the question..i fianlly
turned to the emu website and they helped me out.Wonderfull feeling
this is what i got from the tech support
You can recall the multisetup from within the pattern and that should
solve the problem.
In pattern edit go to Event and enter program change data and Bank
select change data. For Multisetups : MSB=80, LSB=00 and then the
Program change = the Multisetup number.
but there is more to go ..this did not work for me
you have to make shure that prg ch is enabled for that particular midi
ch and you have to set the destination both,inter would prb work but
i did not check that out. hoora ho ra   peace
> > the for pattern two
save
save
> > it to that name ..
pattern
> as
it
> up
or
> > Quick
> > > Edit?
> > > rEalm
> > > 05/22/2003 12:30 AM
> > >         cc:
changing
> > on patterns
> > > write a pattern
> > controller
> > > set up )
> > > pattern A   multi A
> > > pattern B   multi B
> > same
> multisetup
> > is
> > > to stop play change
to
> do
> > > that live ?
> > this
> > > whole
> > were
> > > on each
> after
> > > loading
> the
> > > ones you
Saved
> > > Pattern
> found
> > my
> > > prb
a
> > way
> > > of
> > instead
> > > of the
> preset
> > > pattern ..and it
> > > multisetup
assigment ...like
> > what
> > > sub
> > pattern
> > > start
> would
> > > have to
> > > flexible than
like
> > > Cubase,
> would
> > > be
sounds
> on
> > > each
> > There's
> > > lots
> > assignments,
> > > though
i
> > > switch the
> > presets
> > > in that
Edit
> > > menu).
Pattern.
> > Now
> > > resave
> > Presets
> > > from
Multi's
> > you
> > > want to
> > > Patterns.  Think
> the
> > > moment
revert
> > to
> > > how the
> Multisetups
> > > channel
> > Presets
> > > to
as
> > the
> you
> > > want,
> it's
> > new
> want,
> > > perform a
> > > > thanks again to all
it
> or
> > > not,
> your
> > > head
> > > > rEalm
Re: no longer insane ..getting muti to work with presets
2003-05-30 by dwoodaman
maybe you could dump this in the tips database?
fianlly
should
> solve the problem.
midi
but
that
> > > the for pattern two
> save
> save
> > > it to that name ..
right.
> pattern
> > as
> it
> > up
> or
> > > Quick
> > > > Edit?
> > > > rEalm
> > > > 05/22/2003 12:30 AM
> > > >         cc:
> changing
> > > on patterns
> > > > write a pattern
> > > controller
> > > > set up )
> > > > pattern A   multi A
> > > > pattern B   multi B
> the
> > > same
> > multisetup
> > > is
> > > > to stop play change
> to
> > do
> > > > that live ?
causing
> > > this
> > > > whole
that
> > > were
> > > > on each
> > after
> > > > loading
not
> > the
> > > > ones you
> Saved
> > > > Pattern
> > found
> > > my
> > > > prb
just
> a
> > > way
> > > > of
> > > instead
> > > > of the
> > preset
> > > > pattern ..and it
> > > > multisetup
> assigment ...like
> > > what
> > > > sub
> > > pattern
> > > > start
> > would
> > > > have to
more
> > > > flexible than
> like
> > > > Cubase,
> > would
> > > > be
> sounds
> > on
> > > > each
> > > There's
> > > > lots
> > > assignments,
> > > > though
patterns ..and
> i
> > > > switch the
> > > presets
> > > > in that
> Edit
> > > > menu).
> Pattern.
> > > Now
> > > > resave
> > > Presets
> > > > from
> Multi's
> > > you
> > > > want to
> > > > Patterns.  Think
at
> > the
> > > > moment
> revert
> > > to
> > > > how the
> > Multisetups
> > > > channel
> > > Presets
> > > > to
far
> as
> > > the
what
> > you
> > > > want,
> > it's
> the
> > > new
> > want,
> > > > perform a
> > > > > thanks again to all
> it
> > or
> > > > not,
get
> > your
> > > > head
> > > > > rEalm
