Patch editor? Save soundbank?
2003-03-25 by Erika
2003-03-25 by Erika
Is there one? I'm sure it will be on the EMU website, but I'm missing it if there is one. Also, if I write midi sequences in an external sequencer, I'll have to encode the patch/bank change commands so when I reopen the file or download it to the XL7 the correct instruments will be in the right places... Right?
2003-03-25 by erik_magrini@Baxter.com
Is there one? >>No. <<< I'm sure it will be on the EMU website, but I'm missing it if there is one. >>>If there was I'm sure it would be there, but there's not. <<< Also, if I write midi sequences in an external sequencer, I'll have to encode the patch/bank change commands so when I reopen the file or download it to the XL7 the correct instruments will be in the right places... Right? >>>Yeah, or just save the current Multisetup after you select all your patches while the midi file is still being written in the PC. Then, after you reimport the midi file into the XL-7, reload that Multi and immdeiately save the pattern. The multi will remember the patches you used, and will overwrite any patches currently on each channel upon reload. Err, does that make sense? <<< rEalm [Non-text portions of this message have been removed]
2003-03-25 by james
dunno myself ! The Emulator 5 software was supposed to be the control surface for the modules and samplers and most EMU equipment - if its still being developed updated ??
Sent: Tuesday, March 25, 2003 6:12 PM
Subject: [xl7] Patch editor? Save soundbank?
it if there is one.
places... Right?
Yahoo! Groups Sponsor
[Non-text portions of this message have been removed]2003-03-25 by Andre Lewis
If you use soundiver you can use the Audity 2000 presets to control the XL-7, just make sure you are using the same device ID. If anyone knows how to edit patches for these I believe the only difference or soundiver is the ROM ID identifiers, don't know that would be a problem though for soundiver... ? Andre
Sent: Tuesday, March 25, 2003 12:28 PM
Subject: Re: [xl7] Patch editor? Save soundbank?
it if there is one.
places... Right?
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/2003-03-25 by Justin Grimley
REALLY!!!! So I can use Sound Diver with the Audity 2000 adaptation as an XL7 librarian? I will check it out this evening. -grimley --- In xl7@yahoogroups.com, "Andre Lewis" <andrel@s...> wrote: > If you use soundiver you can use the Audity 2000 presets to control the XL-7, > just make sure you are using the same device ID. If anyone knows how to edit > patches for these I believe the only difference or soundiver is the ROM ID > identifiers, don't know that would be a problem though for soundiver... ? > > Andre > > -----Original Message----- > From: james [mailto:JDPatch@s...] > Sent: Tuesday, March 25, 2003 12:28 PM > To: xl7@yahoogroups.com > Subject: Re: [xl7] Patch editor? Save soundbank? > > > dunno myself ! The Emulator 5 software was supposed to be the control surface > for the modules and samplers and most EMU equipment - if its still being > developed updated ?? > ----- Original Message ----- > From: Erika > To: xl7@yahoogroups.com > Sent: Tuesday, March 25, 2003 6:12 PM > Subject: [xl7] Patch editor? Save soundbank? > > > Is there one? I'm sure it will be on the EMU website, but I'm missing > it if there is one. > > Also, if I write midi sequences in an external sequencer, I'll have > to encode the patch/bank change commands so when I reopen the file or > download it to the XL7 the correct instruments will be in the right > places... Right? > > > > > > > Yahoo! Groups Sponsor > > > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@yahoogroups.com > > > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > [Non-text portions of this message have been removed] > > > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@yahoogroups.com > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
2003-03-25 by Nick Rothwell
> So I can use Sound Diver with the Audity 2000 adaptation as an XL7 > librarian? I wrote a librarian in Max/MSP. I tested it against a Proteus 2000; it worked with my XL-7 without alteration. -- nick rothwell -- composition, systems, performance -- http://www.cassiel.com
2003-03-26 by ufound12
There is a really good editor from Sound Quest that supports the Proteus 200 series. I dont know where they stand with the xx-7 gear but worth an email. I have been using their software since Dt. T retired X-or. Joe
