Midi recording question
2003-01-21 by Sergio Teixeira Jr. <steixeirajr@yahoo.c
Hello there,
I am playing with a drum pad to program the drum parts in the MP-7,
but it didn't work quite as I expected. Each of the pads can be
assigned to a midi channel, effectively allowing you to create your
own drum kits with the mp-7 internal sounds. When playing that works
really nice.
But when I hit "record", I thought each pad would be recorded to its
own track (or midi channel), so that I would benefit from separate
quantizing, mute/unmute etc. What is going on? Can't the MP-7 record
to 2 different tracks at the same time?
Cheers
Sergio
RE: [xl7] Midi recording question
2003-01-21 by ByronIV
> really nice.
Mmm, good question, I've never actually tried that, and am not sure if it
can or not (although it SHOULD be able to!!!). If your 'reroute external
midi' is 'on', try turning it off. Perhaps then it will?
ByronIV
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.438 / Virus Database: 246 - Release Date: 1/7/2003
Re: [xl7] Midi recording question
2003-01-21 by erik_magrini@Baxter.com
What did you do to set up each pad to be a different channel?  That might
help us figure out what's not working.
Re: Midi recording question
might
> rEalm
Well the each of the pads can be assigned to a midi channel. Say, on
pad 1 I have a kick drum assigned to channel 1 (using the
corresponding MP-7 preset) and on pad 2 I have the snare assigned to
channel 2 (using another preset) etc. I can even edit each preset
independently. The problem starts when I record. All the data (from
two different channels) is saved in a single track.
Is it clear?
Cheers
Sergio
Re: [xl7] Re: Midi recording question
Yes, but how are you assigning each pad a seperate midi channel?  Are you
just specifying that the preset for each channel has only a one note key
range?  Regardless of how you're doing it (though I'd personally still
like to know) I think this happens because you can only record onto a
single TRACK at once, though that track can be set to Multi and therefore
record on more than one CHANNEL at once.  Record something like you're
describing, and then go into List Edit mode for that track and see if all
the data is on the same channel or not....
"Sergio Teixeira Jr. <steixeirajr@...>" <steixeirajr
01/21/2003 09:34 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] Re: Midi recording question
might
> rEalm
Is it clear?
Cheers
Sergio
Well, the drum pad allows me to configure each pad's midi channel.
Are you
note key
still
> like to know)
Sorry, but I don't think I understand your question very well.
therefore
Yes, probably this is the reason. Is there a way to record to more
than on track at a time?
Yo, EMU people, is this issue (recording to multiple tracks at once)
being taken care of in the new OS?
Thnak you.
Sergio
AHHHH!  You're using an external drum pad?  I thought you were using the
XX-7's drum pads, this makes more sense now.  You don't have Rechannelize
turned on in the MIDI menu?  I don't think there's a way to record to more
than one track at once, but there is a workaround.  Simply copy the track
containing all of the data to other tracks, and then set eachof those to
the specific midi channel you need.  For instance, say you record you drum
pad playing onto a XX-7 track, and you're using 6 midi channels.  You
would then copy the track to 5 other tracks, and set each of their midi
channels to a  different number that matches what you were playing from
the drum pad.
Thnak you.
Sergio
2003-01-21 by drK
On 1/21/03 8:34 AM, "Sergio Teixeira Jr. <steixeirajr@...>"
> really nice.
First I think people are confusing your external drum pad controller with
the pads on the XX-7.  That's why all the questions and doubt about how you
are doing this.
Second you can record multiple channels to a single track by setting the
track to one of the "multi" assignments. (MultiA/MultiB).
Unfortunately there is no simple way to separate a multichannel track into
new tracks with one channel of information per track.  You can though use
the selective note range in the edit commands to accomplish the same thing
in this case (cut all kick notes to track one, snares to track 2 and so on).
This of course can be done without having done the multichannel recording in
the first place.
Unfortunately there is no way to record on two or more tracks.  Hopefully
E-mu will create some easy solution or alternative in a subsequent OS
release.
drk
www.delora.com/music
www.mp3.com/zdrk
drk.iuma.com
2003-01-21 by drK
On 1/21/03 3:43 PM, "erik_magrini@..." <erik_magrini@...>
> the drum pad.
> rEalm
This does not work.  The XX-7 channel output assignment will simply force
all MIDI data recorded on that track to play on the assigned channel.  it
does not filter out the off-channel notes.  You still need to cut/erase the
off-channel data which can only be accomplished in the XX-7 using the
select-by-note-range edit command features.
drk
www.mp3.com/zdrk
drk.iuma.com
