Subject: Re: [xl7] EFX
A good method for creating this effect is; create a layer with your
desired pad sound, copy that layer to a second. Tweak layer two so that
LFO 2 is modulating AMP using one of the square or pulse wavefroms and
is tempo locked (1/8. 1/16 etc.). Now, with cord N (knob 14) have that
crossfade between the two layers. Save the preset with the pad played as
normal and then crossfade when you wanted the gated effect. Add extra
release on layer two to give a bit of a delay feel. Also, you can fatten
your preset by using all four layers (1 and 2 normal, 3 and 4 gated). To
set the crossfade you'll need set the initial amp of layer 2 to -96db
and have cord N work in a positive path and layer 1 have cord N work in
a negative path.
sean at e-mu / ensoniq
> Byron wrote:
> Mmmm, understood, I guess I was assuming that a 'slicer' effect was
> more of a modulable gater or stutter effect....it could still be fun
> to do something like this useing different randomized lfo shapes on
> separate layers though, could be like a continuous morphing machine or
> something. I may have to try that...mmmm
> Byron
> We haven't the money, so we've got to think.
> -Lord Rutherford
> -----Original Message-----
> From: erik_magrini@...
> [mailto:erik_magrini@...]
> Sent: Wednesday, July 10, 2002 8:39 AM
> To: xl7@yahoogroups.com
> Subject: RE: [xl7] EFX
> If it was just simple 1/16th note on and off's, then yes.
> The slicer effect has a tone of ramping slices and other
> features that would be pretty hard to emulate with LFO's, or
> tempo locked envelopes (I've tried).
> rEalm
> You could probably set up an lfo to work as a controllable
> slicer fx....as I have stated earlier, I havent dug into the
> XL7's patch editing too much yet (been WAY to busy), but
> from what I have seen in it, I'm sure it could be done!
> Byron
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service.
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
