I got the Techno Synth Rom, i wanted to download to the XL Extension Presets...
2002-06-10 by nbaryosef100
I got the Techno Synth Rom, I wanted to download to the XL Extension Presets and ARP patterns from Papen web site but before I do that small question. Now I have 2 ROMs inside my XL I will make sure that the *.mid will be downloaded into the Techno Synth Yard ROM and not the XL1 Rom inside. Is there anything I need to do before downloading the files??? Thank you <<|_NiR_|>>
2002-06-10 by emufreak1
NiR, You will not(cannot)overwrite the "ROM". The arp patterns will load in the "User" arp locations on your unit and the presets will load into user bank 2(make sure you relocate any personal presets that you have in that bank). If you open up the read me file that is enclosed in the Zip file, it will have all the info you need. Also verify which ver. ROM you received so that you download the correct presets. This can be done simply by scrolling to Techno ROM preset 127 in bank 3 which is usually a default and should have the version # in it. Later, M2 --- In xl7@y..., "nbaryosef100" <nir.baryosef@v...> wrote: > I got the Techno Synth Rom, I wanted to download to the XL Extension
> Presets and ARP patterns from Papen web site but before I do that > small question. > > Now I have 2 ROMs inside my XL I will make sure that the *.mid will > be downloaded into the Techno Synth Yard ROM and not the XL1 Rom > inside. > Is there anything I need to do before downloading the files??? > > > Thank you > > <<|_NiR_|>>
Yes I meant the user bank, but if I want to download one pattern to one specific user memory example 005 or other, is there way to do it. Because I downloaded one and I can't find where it is stored on the XL. Any hints. Plus, I downloaded the files from Papen web site into my XL but when I checked the locations the files weren't there. 1- I used E-loader to download 2- The midi in (Red led) shows receiving information. 3- Device ID is 000 4- Midi is enabled Do you think there is something that I am doing wrong??? Any help will be appreciated NiR --- In xl7@y..., "emufreak1" <mmcquay@m...> wrote: > NiR, > > You will not(cannot)overwrite the "ROM". The arp patterns will load > in the "User" arp locations on your unit and the presets will load > into user bank 2(make sure you relocate any personal presets that you > have in that bank). If you open up the read me file that is enclosed > in the Zip file, it will have all the info you need. Also verify > which ver. ROM you received so that you download the correct > presets. This can be done simply by scrolling to Techno ROM preset > 127 in bank 3 which is usually a default and should have the version > # in it. > > Later, > > M2 > > > --- In xl7@y..., "nbaryosef100" <nir.baryosef@v...> wrote: > > I got the Techno Synth Rom, I wanted to download to the XL > Extension > > Presets and ARP patterns from Papen web site but before I do that > > small question. > > > > Now I have 2 ROMs inside my XL I will make sure that the *.mid will
> > be downloaded into the Techno Synth Yard ROM and not the XL1 Rom > > inside. > > Is there anything I need to do before downloading the files??? > > > > > > Thank you > > > > <<|_NiR_|>>
Problem 1 was solved, i used eloader but using the bank browser. --- In xl7@y..., "nbaryosef100" <nir.baryosef@v...> wrote: > Yes I meant the user bank, but if I want to download one pattern to > one specific user memory example 005 or other, is there way to do it. > Because I downloaded one and I can't find where it is stored on the > XL. > Any hints. > Plus, I downloaded the files from Papen web site into my XL but when > I checked the locations the files weren't there. > 1- I used E-loader to download > 2- The midi in (Red led) shows receiving information. > 3- Device ID is 000 > 4- Midi is enabled > > Do you think there is something that I am doing wrong??? > > Any help will be appreciated > > NiR > --- In xl7@y..., "emufreak1" <mmcquay@m...> wrote: > > > NiR, > > > > You will not(cannot)overwrite the "ROM". The arp patterns will > load > > in the "User" arp locations on your unit and the presets will load > > into user bank 2(make sure you relocate any personal presets that > you > > have in that bank). If you open up the read me file that is > enclosed > > in the Zip file, it will have all the info you need. Also verify > > which ver. ROM you received so that you download the correct > > presets. This can be done simply by scrolling to Techno ROM preset > > 127 in bank 3 which is usually a default and should have the > version > > # in it. > > > > Later, > > > > M2 > > > > > > --- In xl7@y..., "nbaryosef100" <nir.baryosef@v...> wrote: > > > I got the Techno Synth Rom, I wanted to download to the XL > > Extension > > > Presets and ARP patterns from Papen web site but before I do that > > > small question. > > > > > > Now I have 2 ROMs inside my XL I will make sure that the *.mid > will > > > be downloaded into the Techno Synth Yard ROM and not the XL1 Rom
> > > inside. > > > Is there anything I need to do before downloading the files??? > > > > > > > > > Thank you > > > > > > <<|_NiR_|>>
www.robpapen.com --- In xl7@y..., "mp3.com/koering" <A.Libi@b...> wrote: > where can i find the site of rop papen... > can anyone give me the link? > > ----- Original Message ----- > From: "emufreak1" <mmcquay@m...> > To: <xl7@y...> > Sent: Monday, June 10, 2002 9:50 PM > Subject: [xl7] Re: I got the Techno Synth Rom, i wanted to download to the > XL Extension Presets... > > > > NiR, > > > > You will not(cannot)overwrite the "ROM". The arp patterns will load > > in the "User" arp locations on your unit and the presets will load > > into user bank 2(make sure you relocate any personal presets that you > > have in that bank). If you open up the read me file that is enclosed > > in the Zip file, it will have all the info you need. Also verify > > which ver. ROM you received so that you download the correct > > presets. This can be done simply by scrolling to Techno ROM preset > > 127 in bank 3 which is usually a default and should have the version > > # in it. > > > > Later, > > > > M2 > > > > > > --- In xl7@y..., "nbaryosef100" <nir.baryosef@v...> wrote: > > > I got the Techno Synth Rom, I wanted to download to the XL > > Extension > > > Presets and ARP patterns from Papen web site but before I do that > > > small question. > > > > > > Now I have 2 ROMs inside my XL I will make sure that the *.mid will > > > be downloaded into the Techno Synth Yard ROM and not the XL1 Rom > > > inside. > > > Is there anything I need to do before downloading the files??? > > > > > > > > > Thank you > > > > > > <<|_NiR_|>> > > > > > > > > To unsubscribe from this group, send an email to: > > xl7-unsubscribe@y... > > > > > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
NiR, For the Rob Papen Extension presets, it is one giant midi file with all 128 presets. They are not broken down individually. When I downloaded them to my P2K, I used a playback only sequencer called Massiva which used to be freeware ( www.massiva.com ) which once the file was ready for playback, I hit enter and playback began and the files appeared in UB 2. I will try with E-loader tonight on the XL-7 to see if the transfer method works. You had the sequence downloader portion open in E-Loader correct? When you clicked add file and picked the midi file from the folder in which you had it stored, nothing appeared? Later, M2 --- In xl7@y..., "nbaryosef100" <nir.baryosef@v...> wrote: > Yes I meant the user bank, but if I want to download one pattern to > one specific user memory example 005 or other, is there way to do it. > Because I downloaded one and I can't find where it is stored on the > XL. > Any hints. > Plus, I downloaded the files from Papen web site into my XL but when > I checked the locations the files weren't there. > 1- I used E-loader to download > 2- The midi in (Red led) shows receiving information. > 3- Device ID is 000 > 4- Midi is enabled > > Do you think there is something that I am doing wrong??? > > Any help will be appreciated > > NiR > --- In xl7@y..., "emufreak1" <mmcquay@m...> wrote: > > > NiR, > > > > You will not(cannot)overwrite the "ROM". The arp patterns will > load > > in the "User" arp locations on your unit and the presets will load > > into user bank 2(make sure you relocate any personal presets that > you > > have in that bank). If you open up the read me file that is > enclosed > > in the Zip file, it will have all the info you need. Also verify > > which ver. ROM you received so that you download the correct > > presets. This can be done simply by scrolling to Techno ROM preset > > 127 in bank 3 which is usually a default and should have the > version > > # in it. > > > > Later, > > > > M2 > > > > > > --- In xl7@y..., "nbaryosef100" <nir.baryosef@v...> wrote: > > > I got the Techno Synth Rom, I wanted to download to the XL > > Extension > > > Presets and ARP patterns from Papen web site but before I do that > > > small question. > > > > > > Now I have 2 ROMs inside my XL I will make sure that the *.mid > will > > > be downloaded into the Techno Synth Yard ROM and not the XL1 Rom
--- In xl7@y..., "mp3.com/koering" <A.Libi@b...> wrote: > where can i find the site of rop papen... > can anyone give me the link? http://216.71.56.251/ http://groups.yahoo.com/group/orbit3 > ----- Original Message ----- > From: "emufreak1" <mmcquay@m...> > To: <xl7@y...> > Sent: Monday, June 10, 2002 9:50 PM > Subject: [xl7] Re: I got the Techno Synth Rom, i wanted to download to the > XL Extension Presets... > > > > NiR, > > > > You will not(cannot)overwrite the "ROM". The arp patterns will load > > in the "User" arp locations on your unit and the presets will load > > into user bank 2(make sure you relocate any personal presets that you > > have in that bank). If you open up the read me file that is enclosed > > in the Zip file, it will have all the info you need. Also verify > > which ver. ROM you received so that you download the correct > > presets. This can be done simply by scrolling to Techno ROM preset > > 127 in bank 3 which is usually a default and should have the version > > # in it. > > > > Later, > > > > M2 > > > > > > --- In xl7@y..., "nbaryosef100" <nir.baryosef@v...> wrote: > > > I got the Techno Synth Rom, I wanted to download to the XL > > Extension > > > Presets and ARP patterns from Papen web site but before I do that > > > small question. > > > > > > Now I have 2 ROMs inside my XL I will make sure that the *.mid will > > > be downloaded into the Techno Synth Yard ROM and not the XL1 Rom > > > inside. > > > Is there anything I need to do before downloading the files??? > > > > > > > > > Thank you > > > > > > <<|_NiR_|>> > > > > > > > > To unsubscribe from this group, send an email to: > > xl7-unsubscribe@y... > > > > > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Yes, you are right i used the sequence downloader portion then i added the files then used the download button, then download sequence starts. yes it will be useful if you can try it too, thank you NiR --- In xl7@y..., "emufreak1" <mmcquay@m...> wrote: > NiR, > > For the Rob Papen Extension presets, it is one giant midi file with > all 128 presets. They are not broken down individually. When I > downloaded them to my P2K, I used a playback only sequencer called > Massiva which used to be freeware ( www.massiva.com ) which once the > file was ready for playback, I hit enter and playback began and the > files appeared in UB 2. I will try with E-loader tonight on the XL- 7 > to see if the transfer method works. > > You had the sequence downloader portion open in E-Loader correct? > When you clicked add file and picked the midi file from the folder in > which you had it stored, nothing appeared? > > Later, > > M2 > > > --- In xl7@y..., "nbaryosef100" <nir.baryosef@v...> wrote: > > Yes I meant the user bank, but if I want to download one pattern to > > one specific user memory example 005 or other, is there way to do > it. > > Because I downloaded one and I can't find where it is stored on the > > XL. > > Any hints. > > Plus, I downloaded the files from Papen web site into my XL but > when > > I checked the locations the files weren't there. > > 1- I used E-loader to download > > 2- The midi in (Red led) shows receiving information. > > 3- Device ID is 000 > > 4- Midi is enabled > > > > Do you think there is something that I am doing wrong??? > > > > Any help will be appreciated > > > > NiR > > --- In xl7@y..., "emufreak1" <mmcquay@m...> wrote: > > > > > NiR, > > > > > > You will not(cannot)overwrite the "ROM". The arp patterns will > > load > > > in the "User" arp locations on your unit and the presets will > load > > > into user bank 2(make sure you relocate any personal presets that > > you > > > have in that bank). If you open up the read me file that is > > enclosed > > > in the Zip file, it will have all the info you need. Also verify > > > which ver. ROM you received so that you download the correct > > > presets. This can be done simply by scrolling to Techno ROM > preset > > > 127 in bank 3 which is usually a default and should have the > > version > > > # in it. > > > > > > Later, > > > > > > M2 > > > > > > > > > --- In xl7@y..., "nbaryosef100" <nir.baryosef@v...> wrote: > > > > I got the Techno Synth Rom, I wanted to download to the XL > > > Extension > > > > Presets and ARP patterns from Papen web site but before I do > that > > > > small question. > > > > > > > > Now I have 2 ROMs inside my XL I will make sure that the *.mid
> > will > > > > be downloaded into the Techno Synth Yard ROM and not the XL1 > Rom > > > > inside. > > > > Is there anything I need to do before downloading the files??? > > > > > > > > > > > > Thank you > > > > > > > > <<|_NiR_|>>
2002-06-13 by nbaryosef100
Hi, i just wonder id did you had the chance to check it with the e-loader in your place. i mean only if you can. Thank you NiR --- In xl7@y..., "emufreak1" <mmcquay@m...> wrote: > NiR, > > For the Rob Papen Extension presets, it is one giant midi file with > all 128 presets. They are not broken down individually. When I > downloaded them to my P2K, I used a playback only sequencer called > Massiva which used to be freeware ( www.massiva.com ) which once the > file was ready for playback, I hit enter and playback began and the > files appeared in UB 2. I will try with E-loader tonight on the XL- 7 > to see if the transfer method works. > > You had the sequence downloader portion open in E-Loader correct? > When you clicked add file and picked the midi file from the folder in > which you had it stored, nothing appeared? > > Later, > > M2 > > > --- In xl7@y..., "nbaryosef100" <nir.baryosef@v...> wrote: > > Yes I meant the user bank, but if I want to download one pattern to > > one specific user memory example 005 or other, is there way to do > it. > > Because I downloaded one and I can't find where it is stored on the > > XL. > > Any hints. > > Plus, I downloaded the files from Papen web site into my XL but > when > > I checked the locations the files weren't there. > > 1- I used E-loader to download > > 2- The midi in (Red led) shows receiving information. > > 3- Device ID is 000 > > 4- Midi is enabled > > > > Do you think there is something that I am doing wrong??? > > > > Any help will be appreciated > > > > NiR > > --- In xl7@y..., "emufreak1" <mmcquay@m...> wrote: > > > > > NiR, > > > > > > You will not(cannot)overwrite the "ROM". The arp patterns will > > load > > > in the "User" arp locations on your unit and the presets will > load > > > into user bank 2(make sure you relocate any personal presets that > > you > > > have in that bank). If you open up the read me file that is > > enclosed > > > in the Zip file, it will have all the info you need. Also verify > > > which ver. ROM you received so that you download the correct > > > presets. This can be done simply by scrolling to Techno ROM > preset > > > 127 in bank 3 which is usually a default and should have the > > version > > > # in it. > > > > > > Later, > > > > > > M2 > > > > > > > > > --- In xl7@y..., "nbaryosef100" <nir.baryosef@v...> wrote: > > > > I got the Techno Synth Rom, I wanted to download to the XL > > > Extension > > > > Presets and ARP patterns from Papen web site but before I do > that > > > > small question. > > > > > > > > Now I have 2 ROMs inside my XL I will make sure that the *.mid
2002-06-13 by emufreak1
NiR, No I didn't get a chance yet. I was out of town and just got back so I did not try it. When you used the Sequence downloader, did they then appear in the user banks for you? --- In xl7@y..., "nbaryosef100" <nir.baryosef@v...> wrote: > Hi, > > i just wonder id did you had the chance to check it with the e- loader > in your place. i mean only if you can. > > Thank you > NiR > --- In xl7@y..., "emufreak1" <mmcquay@m...> wrote: > > NiR, > > > > For the Rob Papen Extension presets, it is one giant midi file with > > all 128 presets. They are not broken down individually. When I > > downloaded them to my P2K, I used a playback only sequencer called > > Massiva which used to be freeware ( www.massiva.com ) which once > the > > file was ready for playback, I hit enter and playback began and the > > files appeared in UB 2. I will try with E-loader tonight on the XL- > 7 > > to see if the transfer method works. > > > > You had the sequence downloader portion open in E-Loader correct? > > When you clicked add file and picked the midi file from the folder > in > > which you had it stored, nothing appeared? > > > > Later, > > > > M2 > > > > > > --- In xl7@y..., "nbaryosef100" <nir.baryosef@v...> wrote: > > > Yes I meant the user bank, but if I want to download one pattern > to > > > one specific user memory example 005 or other, is there way to do > > it. > > > Because I downloaded one and I can't find where it is stored on > the > > > XL. > > > Any hints. > > > Plus, I downloaded the files from Papen web site into my XL but > > when > > > I checked the locations the files weren't there. > > > 1- I used E-loader to download > > > 2- The midi in (Red led) shows receiving information. > > > 3- Device ID is 000 > > > 4- Midi is enabled > > > > > > Do you think there is something that I am doing wrong??? > > > > > > Any help will be appreciated > > > > > > NiR > > > --- In xl7@y..., "emufreak1" <mmcquay@m...> wrote: > > > > > > > NiR, > > > > > > > > You will not(cannot)overwrite the "ROM". The arp patterns will > > > load > > > > in the "User" arp locations on your unit and the presets will > > load > > > > into user bank 2(make sure you relocate any personal presets > that > > > you > > > > have in that bank). If you open up the read me file that is > > > enclosed > > > > in the Zip file, it will have all the info you need. Also > verify > > > > which ver. ROM you received so that you download the correct > > > > presets. This can be done simply by scrolling to Techno ROM > > preset > > > > 127 in bank 3 which is usually a default and should have the > > > version > > > > # in it. > > > > > > > > Later, > > > > > > > > M2 > > > > > > > > > > > > --- In xl7@y..., "nbaryosef100" <nir.baryosef@v...> wrote: > > > > > I got the Techno Synth Rom, I wanted to download to the XL > > > > Extension > > > > > Presets and ARP patterns from Papen web site but before I do > > that > > > > > small question. > > > > > > > > > > Now I have 2 ROMs inside my XL I will make sure that the > *.mid > > > will > > > > > be downloaded into the Techno Synth Yard ROM and not the XL1 > > Rom > > > > > inside. > > > > > Is there anything I need to do before downloading the files???
> > > > > > > > > > > > > > > Thank you > > > > > > > > > > <<|_NiR_|>>
NiR, It does not work. When I tried it, the E-Loader prompts only allow you to choose pattern or song so when it was done, Pattern 0, Bank 0 read TSCY bank 2 presets but they were nowhere to be found in the user bank 2 location. I will go upstairs on my other computer and try the Massiva playback only sequencer to see if that works. Bye for now, M2 --- In xl7@y..., "emufreak1" <mmcquay@m...> wrote: > NiR, > > No I didn't get a chance yet. I was out of town and just got back so > I did not try it. When you used the Sequence downloader, did they > then appear in the user banks for you? > > --- In xl7@y..., "nbaryosef100" <nir.baryosef@v...> wrote: > > Hi, > > > > i just wonder id did you had the chance to check it with the e- > loader > > in your place. i mean only if you can. > > > > Thank you > > NiR > > --- In xl7@y..., "emufreak1" <mmcquay@m...> wrote: > > > NiR, > > > > > > For the Rob Papen Extension presets, it is one giant midi file > with > > > all 128 presets. They are not broken down individually. When I > > > downloaded them to my P2K, I used a playback only sequencer > called > > > Massiva which used to be freeware ( www.massiva.com ) which once > > the > > > file was ready for playback, I hit enter and playback began and > the > > > files appeared in UB 2. I will try with E-loader tonight on the > XL- > > 7 > > > to see if the transfer method works. > > > > > > You had the sequence downloader portion open in E-Loader > correct? > > > When you clicked add file and picked the midi file from the > folder > > in > > > which you had it stored, nothing appeared? > > > > > > Later, > > > > > > M2 > > > > > > > > > --- In xl7@y..., "nbaryosef100" <nir.baryosef@v...> wrote: > > > > Yes I meant the user bank, but if I want to download one > pattern > > to > > > > one specific user memory example 005 or other, is there way to > do > > > it. > > > > Because I downloaded one and I can't find where it is stored on > > the > > > > XL. > > > > Any hints. > > > > Plus, I downloaded the files from Papen web site into my XL but > > > when > > > > I checked the locations the files weren't there. > > > > 1- I used E-loader to download > > > > 2- The midi in (Red led) shows receiving information. > > > > 3- Device ID is 000 > > > > 4- Midi is enabled > > > > > > > > Do you think there is something that I am doing wrong??? > > > > > > > > Any help will be appreciated > > > > > > > > NiR > > > > --- In xl7@y..., "emufreak1" <mmcquay@m...> wrote: > > > > > > > > > NiR, > > > > > > > > > > You will not(cannot)overwrite the "ROM". The arp patterns > will > > > > load > > > > > in the "User" arp locations on your unit and the presets will > > > load > > > > > into user bank 2(make sure you relocate any personal presets > > that > > > > you > > > > > have in that bank). If you open up the read me file that is > > > > enclosed > > > > > in the Zip file, it will have all the info you need. Also > > verify > > > > > which ver. ROM you received so that you download the correct > > > > > presets. This can be done simply by scrolling to Techno ROM > > > preset > > > > > 127 in bank 3 which is usually a default and should have the > > > > version > > > > > # in it. > > > > > > > > > > Later, > > > > > > > > > > M2 > > > > > > > > > > > > > > > --- In xl7@y..., "nbaryosef100" <nir.baryosef@v...> wrote: > > > > > > I got the Techno Synth Rom, I wanted to download to the XL
> > > > > Extension > > > > > > Presets and ARP patterns from Papen web site but before I > do > > > that > > > > > > small question. > > > > > > > > > > > > Now I have 2 ROMs inside my XL I will make sure that the > > *.mid > > > > will > > > > > > be downloaded into the Techno Synth Yard ROM and not the > XL1 > > > Rom > > > > > > inside. > > > > > > Is there anything I need to do before downloading the > files??? > > > > > > > > > > > > > > > > > > Thank you > > > > > > > > > > > > <<|_NiR_|>>
2002-06-14 by emufreak1
NiR, That worked. After I hooked up the midi cables to the XL-7, I launched the Massiva program, selected the arp pattern midi file first, hit enter and they appeared in the user arp section. I then did the same for the bank 2 and 3 extension presets for the TSCY ROM and they all appeared with no problem. It's seems that until the E- loader program can except preset mode, an outside sequencer will do the trick. The Massiva program (www.massiva.com) that I use, used to be freeware but I don't think so anymore but there is one that is still freeware called Midi-Ox at (www.midiox-com) which is primarily used for sysex transfers but has a playback utility in it called Midibar. Once you open that program(midiox), you will see what looks like a little red fish (it's actually the letters m & b)in the task bar. Click on it to open up the midibar utility, click on the folder icon and select the midi file that you want and click the "play" arrow. What are the other user's on this group doing to download presets? Later, M2 --- In xl7@y..., "emufreak1" <mmcquay@m...> wrote: > NiR, > > It does not work. When I tried it, the E-Loader prompts only allow > you to choose pattern or song so when it was done, Pattern 0, Bank 0 > read TSCY bank 2 presets but they were nowhere to be found in the > user bank 2 location. I will go upstairs on my other computer and > try the Massiva playback only sequencer to see if that works. > > Bye for now, > > M2 > > --- In xl7@y..., "emufreak1" <mmcquay@m...> wrote: > > NiR, > > > > No I didn't get a chance yet. I was out of town and just got back > so > > I did not try it. When you used the Sequence downloader, did they > > then appear in the user banks for you? > > > > --- In xl7@y..., "nbaryosef100" <nir.baryosef@v...> wrote: > > > Hi, > > > > > > i just wonder id did you had the chance to check it with the e- > > loader > > > in your place. i mean only if you can. > > > > > > Thank you > > > NiR > > > --- In xl7@y..., "emufreak1" <mmcquay@m...> wrote: > > > > NiR, > > > > > > > > For the Rob Papen Extension presets, it is one giant midi file > > with > > > > all 128 presets. They are not broken down individually. When > I > > > > downloaded them to my P2K, I used a playback only sequencer > > called > > > > Massiva which used to be freeware ( www.massiva.com ) which > once > > > the > > > > file was ready for playback, I hit enter and playback began and > > the > > > > files appeared in UB 2. I will try with E-loader tonight on > the > > XL- > > > 7 > > > > to see if the transfer method works. > > > > > > > > You had the sequence downloader portion open in E-Loader > > correct? > > > > When you clicked add file and picked the midi file from the > > folder > > > in > > > > which you had it stored, nothing appeared? > > > > > > > > Later, > > > > > > > > M2 > > > > > > > > > > > > --- In xl7@y..., "nbaryosef100" <nir.baryosef@v...> wrote: > > > > > Yes I meant the user bank, but if I want to download one > > pattern > > > to > > > > > one specific user memory example 005 or other, is there way > to > > do > > > > it. > > > > > Because I downloaded one and I can't find where it is stored > on > > > the > > > > > XL. > > > > > Any hints. > > > > > Plus, I downloaded the files from Papen web site into my XL > but > > > > when > > > > > I checked the locations the files weren't there. > > > > > 1- I used E-loader to download > > > > > 2- The midi in (Red led) shows receiving information. > > > > > 3- Device ID is 000 > > > > > 4- Midi is enabled > > > > > > > > > > Do you think there is something that I am doing wrong??? > > > > > > > > > > Any help will be appreciated > > > > > > > > > > NiR > > > > > --- In xl7@y..., "emufreak1" <mmcquay@m...> wrote: > > > > > > > > > > > NiR, > > > > > > > > > > > > You will not(cannot)overwrite the "ROM". The arp patterns > > will > > > > > load > > > > > > in the "User" arp locations on your unit and the presets > will > > > > load > > > > > > into user bank 2(make sure you relocate any personal > presets > > > that > > > > > you > > > > > > have in that bank). If you open up the read me file that > is > > > > > enclosed > > > > > > in the Zip file, it will have all the info you need. Also > > > verify > > > > > > which ver. ROM you received so that you download the > correct > > > > > > presets. This can be done simply by scrolling to Techno > ROM > > > > preset > > > > > > 127 in bank 3 which is usually a default and should have > the > > > > > version > > > > > > # in it. > > > > > > > > > > > > Later, > > > > > > > > > > > > M2 > > > > > > > > > > > > > > > > > > --- In xl7@y..., "nbaryosef100" <nir.baryosef@v...> wrote: > > > > > > > I got the Techno Synth Rom, I wanted to download to the > XL > > > > > > Extension > > > > > > > Presets and ARP patterns from Papen web site but before I > > do > > > > that > > > > > > > small question. > > > > > > > > > > > > > > Now I have 2 ROMs inside my XL I will make sure that the > > > *.mid > > > > > will > > > > > > > be downloaded into the Techno Synth Yard ROM and not the
> > XL1 > > > > Rom > > > > > > > inside. > > > > > > > Is there anything I need to do before downloading the > > files??? > > > > > > > > > > > > > > > > > > > > > Thank you > > > > > > > > > > > > > > <<|_NiR_|>>
2002-06-14 by dbaryosef
Thank you i will try it soon --- In xl7@y..., "emufreak1" <mmcquay@m...> wrote: > NiR, > > That worked. After I hooked up the midi cables to the XL-7, I > launched the Massiva program, selected the arp pattern midi file > first, hit enter and they appeared in the user arp section. I then > did the same for the bank 2 and 3 extension presets for the TSCY ROM > and they all appeared with no problem. It's seems that until the E- > loader program can except preset mode, an outside sequencer will do > the trick. The Massiva program (www.massiva.com) that I use, used to > be freeware but I don't think so anymore but there is one that is > still freeware called Midi-Ox at (www.midiox-com) which is primarily > used for sysex transfers but has a playback utility in it called > Midibar. > Once you open that program(midiox), you will see what looks like a > little red fish (it's actually the letters m & b)in the task bar. > Click on it to open up the midibar utility, click on the folder icon > and select the midi file that you want and click the "play" arrow. > > > What are the other user's on this group doing to download presets? > > Later, > > M2 > > --- In xl7@y..., "emufreak1" <mmcquay@m...> wrote: > > NiR, > > > > It does not work. When I tried it, the E-Loader prompts only allow > > you to choose pattern or song so when it was done, Pattern 0, Bank > 0 > > read TSCY bank 2 presets but they were nowhere to be found in the > > user bank 2 location. I will go upstairs on my other computer and > > try the Massiva playback only sequencer to see if that works. > > > > Bye for now, > > > > M2 > > > > --- In xl7@y..., "emufreak1" <mmcquay@m...> wrote: > > > NiR, > > > > > > No I didn't get a chance yet. I was out of town and just got > back > > so > > > I did not try it. When you used the Sequence downloader, did > they > > > then appear in the user banks for you? > > > > > > --- In xl7@y..., "nbaryosef100" <nir.baryosef@v...> wrote: > > > > Hi, > > > > > > > > i just wonder id did you had the chance to check it with the e- > > > loader > > > > in your place. i mean only if you can. > > > > > > > > Thank you > > > > NiR > > > > --- In xl7@y..., "emufreak1" <mmcquay@m...> wrote: > > > > > NiR, > > > > > > > > > > For the Rob Papen Extension presets, it is one giant midi > file > > > with > > > > > all 128 presets. They are not broken down individually. > When > > I > > > > > downloaded them to my P2K, I used a playback only sequencer > > > called > > > > > Massiva which used to be freeware ( www.massiva.com ) which > > once > > > > the > > > > > file was ready for playback, I hit enter and playback began > and > > > the > > > > > files appeared in UB 2. I will try with E-loader tonight on > > the > > > XL- > > > > 7 > > > > > to see if the transfer method works. > > > > > > > > > > You had the sequence downloader portion open in E-Loader > > > correct? > > > > > When you clicked add file and picked the midi file from the > > > folder > > > > in > > > > > which you had it stored, nothing appeared? > > > > > > > > > > Later, > > > > > > > > > > M2 > > > > > > > > > > > > > > > --- In xl7@y..., "nbaryosef100" <nir.baryosef@v...> wrote: > > > > > > Yes I meant the user bank, but if I want to download one > > > pattern > > > > to > > > > > > one specific user memory example 005 or other, is there way > > to > > > do > > > > > it. > > > > > > Because I downloaded one and I can't find where it is > stored > > on > > > > the > > > > > > XL. > > > > > > Any hints. > > > > > > Plus, I downloaded the files from Papen web site into my XL > > but > > > > > when > > > > > > I checked the locations the files weren't there. > > > > > > 1- I used E-loader to download > > > > > > 2- The midi in (Red led) shows receiving information. > > > > > > 3- Device ID is 000 > > > > > > 4- Midi is enabled > > > > > > > > > > > > Do you think there is something that I am doing wrong??? > > > > > > > > > > > > Any help will be appreciated > > > > > > > > > > > > NiR > > > > > > --- In xl7@y..., "emufreak1" <mmcquay@m...> wrote: > > > > > > > > > > > > > NiR, > > > > > > > > > > > > > > You will not(cannot)overwrite the "ROM". The arp > patterns > > > will > > > > > > load > > > > > > > in the "User" arp locations on your unit and the presets > > will > > > > > load > > > > > > > into user bank 2(make sure you relocate any personal > > presets > > > > that > > > > > > you > > > > > > > have in that bank). If you open up the read me file that > > is > > > > > > enclosed > > > > > > > in the Zip file, it will have all the info you need. > Also > > > > verify > > > > > > > which ver. ROM you received so that you download the > > correct > > > > > > > presets. This can be done simply by scrolling to Techno > > ROM > > > > > preset > > > > > > > 127 in bank 3 which is usually a default and should have > > the > > > > > > version > > > > > > > # in it. > > > > > > > > > > > > > > Later, > > > > > > > > > > > > > > M2 > > > > > > > > > > > > > > > > > > > > > --- In xl7@y..., "nbaryosef100" <nir.baryosef@v...> wrote: > > > > > > > > I got the Techno Synth Rom, I wanted to download to the > > XL > > > > > > > Extension > > > > > > > > Presets and ARP patterns from Papen web site but before
> I > > > do > > > > > that > > > > > > > > small question. > > > > > > > > > > > > > > > > Now I have 2 ROMs inside my XL I will make sure that > the > > > > *.mid > > > > > > will > > > > > > > > be downloaded into the Techno Synth Yard ROM and not > the > > > XL1 > > > > > Rom > > > > > > > > inside. > > > > > > > > Is there anything I need to do before downloading the > > > files??? > > > > > > > > > > > > > > > > > > > > > > > > Thank you > > > > > > > > > > > > > > > > <<|_NiR_|>>
2002-07-11 by mp3.com/koering
where can i find the site of rop papen... can anyone give me the link? ----- Original Message ----- From: "emufreak1" <mmcquay@...> To: <xl7@yahoogroups.com> Sent: Monday, June 10, 2002 9:50 PM Subject: [xl7] Re: I got the Techno Synth Rom, i wanted to download to the XL Extension Presets...
> NiR, > > You will not(cannot)overwrite the "ROM". The arp patterns will load > in the "User" arp locations on your unit and the presets will load > into user bank 2(make sure you relocate any personal presets that you > have in that bank). If you open up the read me file that is enclosed > in the Zip file, it will have all the info you need. Also verify > which ver. ROM you received so that you download the correct > presets. This can be done simply by scrolling to Techno ROM preset > 127 in bank 3 which is usually a default and should have the version > # in it. > > Later, > > M2 > > > --- In xl7@y..., "nbaryosef100" <nir.baryosef@v...> wrote: > > I got the Techno Synth Rom, I wanted to download to the XL > Extension > > Presets and ARP patterns from Papen web site but before I do that > > small question. > > > > Now I have 2 ROMs inside my XL I will make sure that the *.mid will > > be downloaded into the Techno Synth Yard ROM and not the XL1 Rom > > inside. > > Is there anything I need to do before downloading the files??? > > > > > > Thank you > > > > <<|_NiR_|>> > > > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@yahoogroups.com > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > > >
