I'm looking to the drum maps of the roms I own (xl-7, rob papen techno
yard, and ZR), I've found them on the emu site, and I need some more
explanations about sound browsing.
I see that each instruments it is build up by one or more samples.
instruments have their name and number, and so have samples. some
samples are present in more than an instruments, for example it is
present in a kit and in an instrument on its own. but not all the
samples have their own instrument (that is needed in order to have full
controll on it, I guess), many exists only in kit with other
when you create a new preset, or edit an existing preset, you usually
browse and use instruments, now my question is: is there a way to
select and use raw samples instead of instruments? and, if the answer
is no, how can I edit sounds that exists only in kits?
thx
davide
--- In xl7@yahoogroups.com, "eriksatie01" <waveplayer@t...> wrote:
> hi to everyone in the list, I'm a new user of an xl-7. I own it since
> one month and I'm very happy with it.
> some beginner questions:
> 1. is there a way to edit drum kits? I want to be able to change the
> volums of kick, the snare, etc... but I cannot find a separate volume
> for each instrument in the kit
> 2. are the instruments included in the drum kits also present
as "stand
> alone" instruments? how can I know the name of an istrument contained
> in a kit?
> thanks
> davide
