HELP: Problem on power up-all lights on
2005-08-06 by steve_the_composer
Any suggestions for solving the following problem (possible causes,
solutions, things to check, etc.):
After not using the P2500 for about 3 weeks, I attempted to powerup.
Almost immediately, all leds lit, all segments of the BPM display lit,
and the top line of the menu display were dark boxes. The E-Mu stayed
in that condition until >>manual<< powerdown.
--Steve
Re: [xl7] HELP: Problem on power up-all lights on
2005-08-06 by Bob S.
Hi Steve
Have you tried reseating things inside the unit.....like ROMs, cables, etc.
It sounds like the microprocessor hung up during boot up while it was going
out to memory or while it was expecting a response from something......
These things are just specialized computer based systems......
Bob
Corona/Riverside, CA
To: <xl7@yahoogroups.com>
Sent: Friday, August 05, 2005 9:30 PM
Subject: [xl7] HELP: Problem on power up-all lights on
> --Steve
2005-08-06 by K4d4w3r
Hey, the same thing was with my XL-7 when that quarts
thing happened...
It didnt boot bcause the problem was with the
controller board...
Cadaver Cum Spiritus Corpus Non Est!
____________________________________________________
Start your day with Yahoo! - make it your home page
http://www.yahoo.com/r/hs
Yes, it could be crystal from the microprocessor oscillator, power up would
force a reset mode and it would stay that way....CCS, do you have any
info/part number/freq./etc info to share so we (the group) know what
replacement part to get.....I can look up some mail order sources....
Bob
Sent: Saturday, August 06, 2005 1:45 AM
Subject: Re: [xl7] HELP: Problem on power up-all lights on
> thing happened...
> controller board...
Check this one out on Ebay....it may fit....compare model number/size to
yours...
http://cgi.ebay.com/Rotary-Encoder-Data-Entry-Knob-for-Emu-E-mu-Samplers_W0Q
QitemZ7341113307QQcategoryZ38070QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Bob
Sent: Saturday, August 06, 2005 7:11 AM
Subject: RE: [xl7] HELP: Problem on power up-all lights on
> I need a part for an emu Planet Earth Module-- the rotary encoder.
> Any suggestions?
> -m@
Re: HELP: Problem on power up-all lights on
2005-08-06 by vibesart
> Any suggestions?
> -m@
EPR Pro - tel. 813-232-3907
they know the part by description i.e. "for the Emu model XXX" etc
Thanks for the replies.  I unscrewed the E-Mu from the rack, had it
1/2 way out and just to test it, turned it on. IT POWERED UP! I am
hoping that something was ever so slightly loose and just moving it
fixed it. I may open it in a few days just to make sure everything is
seated properly. I will keep the quartz crystal problem in mind, too.
Again, thanks!
--Steve
2005-08-07 by K4d4w3r
I'll try to find out whats this part is...But you
know, i'm situated in one of the former USSR
republics, and i dont know, maybe this part is one of
our production kind, but i'll look for the numbers)
Yahoo! Mail
Stay connected, organized, and protected. Take the tour:
http://tour.mail.yahoo.com/mailtour.html
Re: [xl7] Re: HELP: Problem on power up-all lights on
By the way...when i had those quarts problems with my
XL-7. It also randomly powered up, but, through 15-30
minutes it hang up... so stay alarmed...) after
hanging it didnt turned on for some hours and then the
situation reapeted...
