Hello i thank you for this post; there were many months i have tried to make good breaks for jungle but without the real effect i want to have. So i will try what you tell us and probably resample the loops in an inferior bit rate.
Bye bye
gutman75 <bgutman@...> wrote:
I personally doubt it's possible without sampling heavily compressed
loops, but here's a couple of things to try:
- one of artefacts of heavy compression is loss of high frequencies
at the beginning of sound; set up a subtly opening filter envelope on
drums for that "squashed" effect;
- to simulate compression on longer sounds (crashes, cymbals) set up
an amp envelope that dips soon after beginning and then goes back up;
- a fun thing to do is layer a drum kit with noise oscillator. The
noise layer can be monophonic. A noise osc with gradual release can
sound somewhat like reverb tail. You can probably achieve the effect
of ghost notes by setting up an opening amp envelope (or maybe even
note-off layer). Noise with sharp attack and release can be used to
fatten and dirtify the drums. I didn't invest enough time in this
area to give you a more specific advice - just play with filter,
volume and tuning of noise for fun and profit :-)
have a nice day,
Boris.
--- In xl7@yahoogroups.com, "Daim" <ddsdv8@y...> wrote:
> Yes--
> I want to make these crunchy breakz with my command station
> any thoughts?
> --- In xl7@yahoogroups.com, "malik" <malik_martin@h...> wrote:
> > not really sure i understand ur question.
> > do you want to make amens with you command station?
> > you want to find loops or something?
> > --- In xl7@yahoogroups.com, Mark Fitt <mark@t...> wrote:
> > > >Does anyone know how to make jungle like amens?
> > > Sampled breaks and sounds, a lot lifted from Vinyl.....
> Probably
> > 12bit
> > > samplers in some cases (esp the earlier stuff). If your going
> for the
> > > muffled approach ;)
> > > and add some time stretching using an old algorythm.
> > > You can sequence beats, but the very nature of early jungle
is
> quite
> > > often the cut up brake beats. A lot of things where done much
> > simpler due
> > > to the limitations of the hardware at the time, that made
> this 'sound'
> > > dooable in the first place.
> > > The very fact that these recordings are Vinyl, means that
they
> have
> > > quite heavy compression.
> > > Cheers,
> > > Mark
> > > No virus found in this outgoing message.
> > > Checked by AVG Anti-Virus.
> > > Version: 7.0.300 / Virus Database: 265.8.5 - Release Date:
> 03/02/2005
Yahoo! Groups SponsorADVERTISEMENT
document.write('');
Yahoo! Groups Links
To visit your group on the web, go to:
Découvrez le nouveau Yahoo! Mail : 250 Mo d'espace de stockage pour vos mails !
Créez votre Yahoo! Mail
