12VDC Lamp
12VDC Lamp
2005-02-06 by vibesart
Greetings -
on the subject of loose or weird connections - I stopped using the
lamp on my XL7 months ago because when it is plugged in it causes the
machine to spark and sputter in a way that is scary - all the lights
flash - strange tramatic sounds come forth - machine crashes etc
anyone else had this problem?
I am trying to figure out if it is a bad light or something deeper
thanks
Ed
Re: [xl7] 12VDC Lamp
2005-02-06 by Mibrilane
Sounds like a short to me. The VDC connector is indeed a power socket.
Completing the circuit with the lamp is causing a system short - if its
getting to the main board (LEDs flashing etc) it could be a short with the
power supply - check the wires going from the PSU to the lamp connector.
Also, call E-mu service 'cause what the hell do I know? ;D
Mibrilane
Re: 12VDC Lamp
2005-02-06 by malik
eek!!!
sad to say i had my BNC ;amp for xactly a week now and it does seem a
bit flimsy. and it's the same model as the one emu sold for it. but in
different packaging
Re: 12VDC Lamp
2005-02-07 by n6i6s6
The lamp connector provides a LOW wattage.  Some of the 12 volt
lights out there draw more power than this connector can reliably
deliver.  I found that putting 14v lamps in gave me a bit less light
and lessened the power draw enough to keep my PX7 stable when the
light is in use.
Re: 12VDC Lamp
2005-02-08 by gonzinigonz
Someone must be doing LED little lites with BNC connectors by now??
That will cut the current draw by loads
G
light
> light is in use.
Re: 12VDC Lamp
2005-02-08 by An ONymous
Yup - I have the same problem, when I try to use the lamp, the
machine just crashes and it usually takes me 2 or 3 tries to get it
to come back up.  I just don't use the lamp.
--- In xl7@yahoogroups.com, "vibesart" <edmann@p...> wrote:
> Greetings -
> thanks
> Ed
