midi sync
2005-01-27 by thomaspotts666
Hi all, I've just started using my Mp7 with an 1820 soundcard and cubase. When it's slaved to cubase the bpm seems to wander either side of the setting on the pc. Is this usual? To my ear the timing is slightly off. Tom.
2005-01-27 by vibesart
press MIDI button - pg 1 is BASE TEMPO -hit Right Cursor button 1X to position cursor on TEMPO (bpm) - Scroll LEFT to below "1" - it will read EXT. Now the machine is ready to sync to MIDI beat clock --- In xl7@yahoogroups.com, "thomaspotts666" <thomaspotts666@y...> wrote:
> > Hi all, > I've just started using my Mp7 with an 1820 soundcard and cubase. > When it's slaved to cubase the bpm seems to wander either side of the > setting on the pc. Is this usual? To my ear the timing is slightly > off. > > Tom.
nothing that simple unfortunately, I've had it set to 'ext' already. Having recorded a 5min track the audio is definitely drifting out by the end on cubase (sx). Any more suggestions? Thanks though. Tom --- In xl7@yahoogroups.com, "vibesart" <edmann@p...> wrote: > > press MIDI button - pg 1 is BASE TEMPO -hit Right Cursor button 1X to > position cursor on TEMPO (bpm) - Scroll LEFT to below "1" - it will > read EXT. Now the machine is ready to sync to MIDI beat clock > > --- In xl7@yahoogroups.com, "thomaspotts666" <thomaspotts666@y...> wrote: > > > > Hi all, > > I've just started using my Mp7 with an 1820 soundcard and cubase. > > When it's slaved to cubase the bpm seems to wander either side of the > > setting on the pc. Is this usual? To my ear the timing is slightly
> > off. > > > > Tom.
2005-01-27 by Chris
is the timing set to a full bpm setting like i.e. 91, or to one with a fraction i.e. 91.250 within cubase? when sequencing the mp-7 only allows full bpm's, i don't know if that's also the case when slaved to another device or sequencer, but you might want to check that as well cheers Chris
-----Original Message----- From: thomaspotts666 [mailto:thomaspotts666@...] Sent: Donnerstag, 27. Januar 2005 17:37 To: xl7@yahoogroups.com Subject: [xl7] Re: midi sync nothing that simple unfortunately, I've had it set to 'ext' already. Having recorded a 5min track the audio is definitely drifting out by the end on cubase (sx). Any more suggestions? Thanks though. Tom --- In xl7@yahoogroups.com, "vibesart" <edmann@p...> wrote: > > press MIDI button - pg 1 is BASE TEMPO -hit Right Cursor button 1X to > position cursor on TEMPO (bpm) - Scroll LEFT to below "1" - it will > read EXT. Now the machine is ready to sync to MIDI beat clock > > --- In xl7@yahoogroups.com, "thomaspotts666" <thomaspotts666@y...> wrote: > > > > Hi all, > > I've just started using my Mp7 with an 1820 soundcard and cubase. > > When it's slaved to cubase the bpm seems to wander either side of the > > setting on the pc. Is this usual? To my ear the timing is slightly > > off. > > > > Tom. _____ Yahoo! Groups Links * To visit your group on the web, go to: http://groups.yahoo.com/group/xl7/ * To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com <mailto:xl7-unsubscribe@yahoogroups.com?subject=Unsubscribe> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> . [Non-text portions of this message have been removed]
2005-01-27 by [cYcLoThYmIqUe]
In my experience, MIDI clock timing depends *a lot* of the computer software and hardware configuration. You may want to use MidiTime and MidiTest to find out which clock is better for your system, and choose emulated or "real" ports accordingly: http://www.jay.fm/blog/pc-midi-timing-and-nuendo.html http://earthvegaconnection.com/evc/products/miditest -- Sebastien, -=-=-=-=-= I hit the CTRL key but I'm still not in control!
2005-01-28 by steve_the_composer
Thanks for the links; the sites were quite informative. Haven't run the timing utility yet, but it looks interesting. I had trouble syncing the original E-Mu OS that came with my P2500 with Cakewalk, but OS2.0 sees to have solved those problems. --Steve --- In xl7@yahoogroups.com, "[cYcLoThYmIqUe]" <poumtschak@f...> wrote: > In my experience, MIDI clock timing depends *a lot* of the computer > software and hardware configuration. > > You may want to use MidiTime and MidiTest to find out which clock is > better for your system, and choose emulated or "real" ports accordingly:
> http://www.jay.fm/blog/pc-midi-timing-and-nuendo.html > http://earthvegaconnection.com/evc/products/miditest > -- > Sebastien, > -=-=-=-=-= > I hit the CTRL key but I'm still not in control!
2005-01-30 by wildstar_1701
i've had the same problem with my XL-7 and Digital Performer on a Mac G4. i tried a million different tests and changes, with no luck. the problem finally seemed to go away when i connected the XL-7 to my MIDI interface with an expensive Mogami MIDI cable. but alas for me, the problem returned. now i think i've got it beat: once i got a new M-Audio MIDI interface, the problem vanished. completely. and it's been stable for weeks now. it seems that my XL-7 didn't like the sync sent through my MOTU Micro Lite interface. if you can, try a different interface from a different manufacterer. and high-end cables don't hurt either! good luck! --- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@p...> wrote:
> > Thanks for the links; the sites were quite informative. Haven't run > the timing utility yet, but it looks interesting. I had trouble > syncing the original E-Mu OS that came with my P2500 with Cakewalk, > but OS2.0 sees to have solved those problems. > > --Steve
