Kick drum question
2004-09-02 by Fab Claxton
Hey gang, I've been using the Protean Drums ROM pretty much exclusively since I got it, 'cause it's just so damn good! My question applies to any ROM, though. When you guys mix songs, do you spend a lot of time EQ'ing (or using filters to achieve the same effect) the kick drums in your patterns, or do you just use them "as is"? I record everything track-by-track into a Yamaha AW16G DAW, so I usually spend a bit of time EQ'ing the kick drum. I never EVER seem to be completely happy with the results, though. The kick is always either too bassy, or it lacks the real "oooomph" that I want it to have. The rest of the drums - I'm happy with. But the kick drums are a nightmare for me. I was really just wondering if this is a common problem for everyone, and what tips/tricks you guys use to overcome it. Thanks! Fab
