As stated before Program mode is one of the most powerful and underused
parts of the XX-7's IMO. With it, you can freely assign any CC on any
midi channel (in the Controllers Menu) to one of the 16 knobs. That way,
you can control external gear with the XX-7's, as well as software like
Reason or Cubase. This in effect, gives you a fully featured control
surface as part of your Command Station.
But it's not just external gear that can be controlled either. For
instance I have a Program setup where the knobs control the filter cutoff
for internal MIDI channels 1-16. That way I can tweak the cutoff of all
16 Tracks (err...channels really) without having to use the track up and
down buttons to select the track first.
Now if I could just figure out a way to control the effects parameters
while in Multimode with these knobs, I'll be happy. Anyone got any ideas?
Question.
Theres one button on my xx7 that I never use and what disturbs me is
that I cant imagine how I´d use it if i needed to. Its has the most
vague explanation for a feature in the user manual, too.
It´s the program button next to quick edit.
I use cubase to edit sequences (purely for the graphic interface)
then load the seqences into my xx7 via e-loader to jam with.
So, if it is ,as i suspect, for program changes do i need this
feature?
I noticed that the midi out LED lights up when i turn it. But nothing
changes on my external EMU vintage keys synth!!!
Does anybody use it? How do you use it?
Any suggestions/explainations welcome.
thx
:Paul
xl7-unsubscribe@...m
The information transmitted is intended only for the person(s)or entity to which it is addressed and may contain confidential and/or legally privileged material. Delivery of this message to any person other than the intended recipient(s) is not intended in any way to waive privilege or confidentiality. Any review, retransmission, dissemination or other use of , or taking of any action in reliance upon, this information by entities other than the intended recipient is prohibited. If you receive this in error, please contact the sender and delete the material from any computer.
For Translation:
