> Hey Greg!
> When testing that new module in your rig, it would be wise to first
> check the power connector for shorts before plugging it into the
> supply and turning the power on. This will alert you to problems on
> the module pcb before you apply power and smoke something. If you
> have a Power One or similar supply (like the MOTM supply), it is
> *very* unlikely that you will damage the power supply. It has
> excellent short circuit protection, even with the limiter maxxed.
> I made a simple jack multiple with a pair of BNC connectors for
> connecting signals to the 'scope. This allows me to monitor signals
> in action with the rest of the system. Of course, as Mike pointed
> out, it's fun to watch!
> Chub - easily entertained
> --- In motm@yahoogroups.com, Greg Amann <greg.amann@s...> wrote:
> > Testing "in situ" would remove the need for a bench power supply!
> Money
> > that could be better used to send Paul's wife on that well deserved
> spa
> > weekend (read: buy more modules!).
> > PLL, BFG
> > Mike Marsh wrote:
> > > I test 'in situ'. My scope is right next to my rig, though truth
> (and
> > > I know truth is relative) be told is use it mostly for the pretty
> > > waveforms :>
> > > My most useful debugging tool is my VOM. I can usually spot an
> > > correct errors, but every once in a while something comes along
> that I
> > > cna't figure out. Embarrassingly, that included a chip I soldered
> > > into the 480 BACKWARDS and could n't figure out why the HP channel
> > > didn't work :/
> > > Mike
> > > --- In motm@yahoogroups.com, "Greg Amann" <greg.amann@s...> wrote:
> > > > How do you more experienced MOTMers test new modules and DIY
> stuff?
> > > > Do you test them in situ or do you have a benchtop rig? Does
> the
> > > > module go to the 'scope or does the 'scope go to the mountain?
> (Damn,
> > > > forgot, no religious threads!)
> > > > I have seena photo of a get together where Cynthia had a module
> > > > mounted on extenders so that trim pots could be tweaked at the
> > > modular.
> > > > Opinions?
> > > > Thanks in advance, BFG
> > > *Yahoo! Groups Links*
> > > * To visit your group on the web, go to:
> > > http://groups.yahoo.com/group/motm/
> > > * To unsubscribe from this group, send an email to:
> > > motm-unsubscribe@yahoogroups.com
> > > <mailto:motm-unsubscribe@yahoogroups.com?
> subject=Unsubscribe>
> > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> > > Service <http://docs.yahoo.com/info/terms/>.
> <mailto:motm-unsubscribe@yahoogroups.com?subject=Unsubscribe>
