FW: Simple question.
2005-06-02 by Greg James
Are all TRS cables balanced by default?
2005-06-02 by Jason Proctor
someone correct me if i'm wrong, but i think it's the pieces of gear which balance the signal, not the cable. so all TRS cables are the same >Are all TRS cables balanced by default?
2005-06-02 by imorpheusl@aol.com
I agree - for example, a balanced cable plugged into an unbalanced input/output does not make the signal balanced. The circuitry has to be balanced. Look up "common mode rejection" (aka CMR) on google or some other search engine to get info on how balanced signals work compared to unbalanced. On gear with balanced I/O you will see the CMR ratio in the specs. -Chaz
-----Original Message----- From: Jason Proctor <jason@...> To: MOTM <motm@yahoogroups.com> Sent: Thu, 2 Jun 2005 11:13:48 -0700 Subject: Re: [motm] FW: Simple question. someone correct me if i'm wrong, but i think it's the pieces of gear which balance the signal, not the cable. so all TRS cables are the same >Are all TRS cables balanced by default? Yahoo! Groups Links
2005-06-02 by charlesosthelder
Balanced signals require a two-conductor-plus-shield (if needed) cable. TRS cables provide that, or they can be used for unbalanced two-signal(like stereo) connections. Jason is correct, too. The device has balanced or unbalanced ins and/or outs. TRS cables for audio are *usually* two-conductor-plus- shield, but it's best to check the manufacturer specs. Chub - he whose balance is hypothetical --- In motm@yahoogroups.com, Jason Proctor <jason@r...> wrote:
> someone correct me if i'm wrong, but i think it's the pieces of gear > which balance the signal, not the cable. > > so all TRS cables are the same > > >Are all TRS cables balanced by default?
In my case, I already know that my equipment is balanced - I'm really focusing here on the cable itself: Do TRS cables, assuming they're being plugged into balanced jacks on both ends, always create balanced connections? Or put it another way: are there TRS cables, that when plugged into balanced jacks, create an unbalanced connection? And just to head off one other possible detour, it's assumed that the cable is constructed properly. So that's not at issue here. Thanks, Greg
From: motm@yahoogroups.com [mailto:motm@yahoogroups.com]On Behalf Of
imorpheusl@...
Sent: Thursday, June 02, 2005 4:47 PM
To: motm@yahoogroups.com
specs.
-Chaz
Yahoo! Groups Links
Yahoo! Groups Links
a.. To visit your group on the web, go to:
http://groups.yahoo.com/group/motm/
b.. To unsubscribe from this group, send an email to:
motm-unsubscribe@yahoogroups.com
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.2005-06-02 by Greg James
Charles leapfrogged my last post and answered my question. Thanks all! -Greg
-----Original Message----- From: motm@yahoogroups.com [mailto:motm@yahoogroups.com]On Behalf Of charlesosthelder Sent: Thursday, June 02, 2005 5:00 PM To: motm@yahoogroups.com Subject: [motm] Re: FW: Simple question. Balanced signals require a two-conductor-plus-shield (if needed) cable. TRS cables provide that, or they can be used for unbalanced two-signal(like stereo) connections. Jason is correct, too. The device has balanced or unbalanced ins and/or outs. TRS cables for audio are *usually* two-conductor-plus- shield, but it's best to check the manufacturer specs. Chub - he whose balance is hypothetical --- In motm@yahoogroups.com, Jason Proctor <jason@r...> wrote: > someone correct me if i'm wrong, but i think it's the pieces of gear > which balance the signal, not the cable. > > so all TRS cables are the same > > >Are all TRS cables balanced by default? Yahoo! Groups Links
