To: <motm@yahoogroups.com>
Sent: Monday, December 08, 2003 6:51 PM
Subject: RE: [motm] Frequency Shifter - one 'final' question
Ok here's the one with "+" on the fine shift. I made the "+" a smaller font
size and that tightened it up a bit.
http://www.encoreelectronics.com/FS/FreqShift_ProductionNumbersAllBip.jpg
Now I'm not sure which one I like the best.
Let me know...
Tony
Sent: Monday, December 08, 2003 4:47 PM
To: 'groovyshaman@...'; 'motm@yahoogroups.com'
Ok, here's another option. There are numbers on all pots, but any number
that would have been partially obscured has been removed.
http://www.encoreelectronics.com/FS/FreqShift_ProductionNumbersAll.jpg
What do you think of this? If you like this one the best so far, do you like
the different numbers removed depending on where they are, or would you like
the same numbers removed on all of the small pots?
Also, I had the fine shift pot with +1, +2, etc, and I really didn't like
it. (Although it looks OK on the big knob). If you really want to see it, I
can post that too.
Tony
Sent: Monday, December 08, 2003 4:39 PM
To: tony@...; motm@yahoogroups.com
Subject: Re: [motm] Frequency Shifter - one 'final' question
[Although meaningless] the numbers look nice.
Maybe just a + and - on the Fine Shift control.
George
To: "'Mark'" <yahoogroups@...>; <motm@yahoogroups.com>
Sent: Monday, December 08, 2003 7:17 PM
> 0 to 10 wouldn't make sense because it doesn't communicate the ability
of
> the shifter to 'invert' or shift through zero. I've updated the info
> on
> site recently to indicate it's a through zero FS.
> Yes, the Fine Shift approaches zero towards the center of its rotation.
I'll
> look into text for that knob too.
> The CV is positive only.
> Tony
<snip>
