any UEG patches out there..?
2001-02-21 by sikorsky
hello all,
don't really know why i'm posting this, as it's bugger all use as patching
information, but i had a great time last night with my UEG and MOTM320 in a
feedback loop, (sine to tcv in, ueg out to v/oct in), then add a pair of
vcos, put the trigger out from the UEG into the trigger input of a MOTM100,
wire in a pair of MOTM700s (this is where it gets a little hazy), modulate
everything via everything else, put through a 4 track reel to reel rigged up
as a tape echo, put the controlroom feed from the console back into a filter
v/oct input via my oakley envelope follower, drink a cheeky little pinot
noir, and then become convinced you've created artificial intelligence...
...i swear the thing (sorry i've not named my system yet), was actually
talking to me - you know the score, moving off towards the door somehow
coincides with excited squeaks and burbling, move back toward the modular,
and thrill to the sound of relaxed purring & rumbling
    great fun, i'm sure you'll all agree - did i record any of it..? damn
right i did, but the really interesting stuff only occured after i'd
switched the DAT off - typical
so apart from complex envelopes / filter sweeps, and simple sequencing,
anyone had any other applications for this great little unit..?
cheers
paul b
Re: any UEG patches out there..?
2001-02-22 by doc@trocarrecords.com
h3y paul,
stereo pannin'...
http://slt.trocarrecords.com/ueg/tonyk/
i have the patch synopsis in a text file i can u/l to that dir if
anyone cares...
peace,
doc
--- In motm@y..., "sikorsky" <vulture.squadron@s...> wrote:
> hello all,
> cheers
> paul b
RE: [motm] UEG tweaks!
2001-02-22 by Tony Karavidas
Yes, I can't leave it alone!
What would you UEG owners say if the GATED-STEP mode (the simple sequencer
mode) had this enhancement:
Allow the level to be adjusted WHILE the UEG is sitting still? This would
aid in setting up pitch for each stage. Now if you like that idea, how about
having LEVEL 1 through 7 control stages 1 through 7, AND IN ADDITION, have
TIME1 control LEVEL8? Currently LEVEL8 must default to zero volts because
there is no level control for stage 8. Robert Rich and I were on the phone
and he suggested it's a little awkward to have to set the oscillators "base"
note to correlate with the zero volt output from stage 8. (I kind of don't
like burying things in the interface, but in this case it might be a good
compromise)
If I here overwhelming "go for it" I'll add it to all the units that haven't
shipped yet. For anyone that already has their UEG and wants this just send
it to me and I'll update it.
I've also extended the TRIG OUT time to 5mS. This should help it trigger
more things with ease.
Your quick reply is requested, people are waiting for these. The manual is
done with exception of the above issues.
Tony Karavidas
Encore Electronics
http://www.encoreelectronics.com
Designers of "The best MIDI to CV converter on the planet." -Keyboard Oct.
1997
RE: [motm] UEG tweaks!(updated)
There was a mistake in the previous email. I said TIME1 and I meant TIME8.
I've corrected it below:
TIME8 control LEVEL8? Currently LEVEL8 must default to zero volts because
compromise)
Tony Karavidas
Encore Electronics
1997
2001-02-22 by Dave Hylander
Go For It!!
>compromise)
>Tony Karavidas
>Encore Electronics
>1997
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Re: [motm] UEG tweaks!(updated)
2001-02-22 by Frank Vanaman
Hi-
Some people might complain, but I wouldn't mind this feature at all. Er,
that's because I don't reallly have any in-house step sequencers at the
moment!
Frank Vanaman
> compromise)
> Tony Karavidas
> Encore Electronics
> 1997
RE: [motm] More UEG tweaks!
One more issue I've been working on is the switch bounce. I have found an
implementation that doens't penalize the response to the leading edge of a
trigger, BUT it does limit the repetition rate of the GATE.
For example, if I use 5mS dead time on the rising and falling edge of the
switch, the input GATE is limited to just under 100Hz. This isn't a problem
when it comes to using the UEG as an envelope generator. It takes over 60mS
just to complete all the stages so most likely your input gate repetition
would be slower than 60mS. If you try to input a faster gate, you simple
start to chop off the final stages. The issue is with GATED-STEP mode
(sequencer). Without any debouce code, I can take the UEG up to about 450Hz
input, and it runs fine all day.
So I need more feedback: Would you like a little debounce is exchange for
some gate speed, or screw the debounce switch stuff (since you hardly use
the switch) and keep the speed?
Tony
2001-02-22 by James Holloway
I vote for speed.
James Holloway
jimh54@... - email
(972) 993-2023 x1188 - voicemail/fax
> an
> of a
> of the
> problem
> 60mS
> 450Hz
> for
> use
> Tony
FREE voicemail, email, and fax...all in one place.
Sign Up Now! http://www.onebox.com
Go for it. I don't mind waiting a little longer for more features.
James Holloway
jimh54@... - email
> would
> how about
> have
> phone
> "base"
> don't
> a good
> compromise)
> haven't
> send
> is
> Tony Karavidas
> Encore Electronics
> Oct.
> 1997
2001-02-22 by Tkacs, Ken
Go for it!
Sent:	Thursday, 22 February, 2001 3:28 AM
To:	motm@yahoogroups.com
Subject:	RE: [motm] UEG tweaks!
shipped yet....
2001-02-22 by alt-mode
Go for it Tony, at least on the GATE-STEP mode.  Regarding the debounce, the only
thing that I think is lost is the ability to use the UEG as a audio-waveform
generator.  I've tried this with other sequencers and the results have not been that
interesting so I don't think there is a great loss in reducing the input frequency.
Eric
> compromise)
> Tony Karavidas
> Encore Electronics
> 1997
Do You Yahoo!?
Yahoo! Auctions - Buy the things you want at great prices! http://auctions.yahoo.com/
You could have another switch that turns de-bounce on/off. But---_oh_, then
you'd need to de-bounce THAT switch... so you would need ANOTHER switch...
it's the Hasslein effect all over again!
--Mr. T
>>>...One more issue I've been working on is the switch bounce. ...
Re: [motm] More UEG tweaks!
2001-02-22 by J. Larry Hendry
Keep the speed
To: <motm@yahoogroups.com>
Sent: Thursday, February 22, 2001 4:16 AM
Subject: RE: [motm] More UEG tweaks!
Tony
2001-02-22 by Joe Bruno
Stick with the speed.
Sent: Thursday, February 22, 2001 4:17 AM
Importance: High
Tony
2001-02-22 by thomas white
I agree, speed is the necessary one for me too.
Thomas White
>From: "J. Larry Hendry" <jlarryh@...>
>Reply-To: motm@yahoogroups.com
>Subject: Re: [motm] More UEG tweaks!
>Date: Thu, 22 Feb 2001 09:57:24 -0600
>Keep the speed
>----- Original Message -----
>From: Tony Karavidas <tony@...>
>Tony
Get your FREE download of MSN Explorer at http://explorer.msn.com
2001-02-22 by The Old Crow
  Go for it.  Is there an in-circuit programming issue with the amtel
part, and can I just swap uCs?
Crow
For anyone that want this update and you ALREADY have your UEG, it either
has to come back here OR if you happen to have the Atmel in-circuit
programmer, I can send you a file and you can program it yourself.
There is no need to do a uC swap (it's soldered in anyway)
Tony Karavidas
Encore Electronics
1997
> -----Original Message-----
> From: The Old Crow [mailto:oldcrow@...]
> Sent: Thursday, February 22, 2001 9:11 AM
> that haven't
> this just send
> Crow
  I prefer debounce, myself.  Of course I spent years having to deal with
user interfaces to PID controllers, and debouncing was pretty much
mandatory.  Even so, not being driven nuts by a noisy switch would be
nice.
Crow
Re: More UEG tweaks!
2001-02-22 by andy@gooboworks.com
I vote for speed.
Andy Miller
found an
edge of a
of the
problem
over 60mS
repetition
simple
mode
about 450Hz
exchange for
hardly use
> Tony
visio
2001-02-22 by Cap'n F.M. Bleep
hi larry.
do you still need a *cough* evaluation copy of visio? i just got the disc
for it... let me know soon and i can send it out tomorrow morning.
fred.
bleep.
out.
Re: [motm] visio
gah!!Q!!!!
i hate this stupid hidden-reply-to-field business!!!!!! grrrrr on yahoo...
bleep.
out.
2001-02-23 by davevosh@aol.com
In a message dated 01-02-22 03:32:04 EST, you write:
tony,
the enhancement sounds worthwhile but, really, only if it doesn`t hold things
up too much. for me, sequencer type use is "serendipity".
best,
dave v.
In a message dated 01-02-22 05:15:58 EST, you write:
tony,
on this one, i`d say either choice works for me. whatever the bulk of your
purchasers want in regard to this change will be fine with me.
best,
dave v.
Re: [motm] visio
2001-02-23 by J. Larry Hendry
Yes, please.
LH
Sent: Thursday, February 22, 2001 3:10 PM
Subject: [motm] visio
hi larry.
fred.
bleep.
out.
Re: [motm] visio
Me too.  But, I really will buy it if it has any features I like.  I am
happy to pay for good software that is useful to me.  Same with music CDs.
I have nearly 1000, not one a copy.  But, I also HATE buying software only
to find it SUCKs.  It is one of the few products you cannot return.
Sent: Thursday, February 22, 2001 3:12 PM
Subject: Re: [motm] visio
gah!!Q!!!!
bleep.
out.
2001-02-23 by Hugo Haesaert
Hi All !
Why not make the debounce mode dependant ?
Just an idea, been some time since i looked at the module .
Bye for now .
Keep 'em oscillating :)
Hugo
Oh,  now there's an idea.
RE: [motm] UEG status
2001-02-24 by Tony Karavidas
This is an update to the UEG staus:
The manual is done and is up on the site again in the "Manuals" area.
All units that have been ordered to date have been either shipped or packed
and ready for shipment. They actually would have shipped today, but UPS's
website was all screwed up and I didn't get all the shipping done until 6PM.
Some of you received UEGs a week or two ago, and there have been some
enhancements to the unit, so I would strongly suggest you send them back at
your earliest convenience. And besides, I'll return them WITH manuals!
Here's what's new:
In GATED-STEP mode (aka sequencer), the output can now be adjusted while the
UEG is parked in a stage. So now you can step, adjust pitch (or whatever
else you're controlling) step to the next stage, adjust again, etc...
Stages 1 through 7 are adjusted by LEVEL 1 through 7, and stage 8 is
adjusted by TIME8. It's pretty cool.
In LOOP-ONLY mode, the loop point switches do not reset the UEG to stage
one, but rather reset it to the start loop point.
The TRIG OUT jack now outputs a 5mS pulse instead of a 300uS pulse.
and last but not least: A BUG was reported, found, and fixed which had to do
with certain TIME setting in LOOP mode with LOG slope! Ouch! (sorry about
that) There was a slight math error that caused the waveshape to overflow
and essentially "wrap sround." Could be a cool feature, but since I didn't
plan for it to do that, it's a bug. It's also dead....
Some of you have asked if you can perform this upgrade yourself instead of
shipping it back. The answer is no.
The microcontroller is soldered in and is not removeable. (not under
warranty at least) It is upgradeable in circuit; if you happen to have an
Atmel ISP you can do it. I have a feeling no one has one of these devices.
If you send it back here, I will upgrade it and get it back in the mail in
one day, maybe even the same day depending on how things are going.
There are also some of you asking about availability of the UEG. I have
plenty. I made 100 and I think about 40 of them pre-sold. (Thank you) So for
the rest of you, no worries.
Did you see it in the March Electronic Musician? Pretty good timing
considering the big MOTM review was is the same issue!!!! (Congrats Paul)
Tony Karavidas
Encore Electronics
1997
2001-02-24 by Tentochi
Very cool little write up and excellent timing.
UNFORTUNATELY THEY DIDN'T MENTION IT WAS IN MOTM FORMAT!  ARGH!!!!
--Shemp
> Regards,
> Tony Karavidas
> Encore Electronics
