Using the EMAX-1 Arpeggiator to control other Synths...
2006-05-26 by peter_vh01
Hey guys, I'm trying to figure out to use the arpeggiator on my Emax-1 to control my Juno 106. Anybody know how to do this? I was just playing with the arpeggiator today, and had it functioning wonderfully on the Emax itself, just not sure how to control other devices with it. Thanks! - Peter
2006-05-27 by rascalrevenge
Sadly Emax does NOT transmit arpeggiator-data to it´s MIDI OUT. RR --- In emax@yahoogroups.com, "peter_vh01" <petervh@...> wrote:
> > Hey guys, > > I'm trying to figure out to use the arpeggiator on my Emax-1 to > control my Juno 106. Anybody know how to do this? I was just playing > with the arpeggiator today, and had it functioning wonderfully on the > Emax itself, just not sure how to control other devices with it. > > Thanks! > > - Peter >
2006-05-27 by peter_vh01
Gah! So there is no possible way to use the Emax Arpeggiator to drive other gear? What a shame! Anybody know of any affordable midi modules out there that can do a good job of this? - Peter --- In emax@yahoogroups.com, "rascalrevenge" <rascalrevenge@...> wrote:
> > Sadly Emax does NOT transmit arpeggiator-data to it´s MIDI OUT. > > RR > > > > > > > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> wrote: > > > > Hey guys, > > > > I'm trying to figure out to use the arpeggiator on my Emax-1 to > > control my Juno 106. Anybody know how to do this? I was just playing > > with the arpeggiator today, and had it functioning wonderfully on the > > Emax itself, just not sure how to control other devices with it. > > > > Thanks! > > > > - Peter > > >
Hmm, just a thought, might it be possible to record an arpeggiated sequence with the sequencer, and play that back through the midi port? - Peter --- In emax@yahoogroups.com, "peter_vh01" <petervh@...> wrote: > > Gah! So there is no possible way to use the Emax Arpeggiator to drive > other gear? What a shame! > > Anybody know of any affordable midi modules out there that can do a > good job of this? > > - Peter > > --- In emax@...m, "rascalrevenge" <rascalrevenge@> wrote: > > > > Sadly Emax does NOT transmit arpeggiator-data to it´s MIDI OUT. > > > > RR > > > > > > > > > > > > > > > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> wrote: > > > > > > Hey guys, > > > > > > I'm trying to figure out to use the arpeggiator on my Emax-1 to > > > control my Juno 106. Anybody know how to do this? I was just playing > > > with the arpeggiator today, and had it functioning wonderfully on the
> > > Emax itself, just not sure how to control other devices with it. > > > > > > Thanks! > > > > > > - Peter > > > > > >
2006-05-28 by rascalrevenge
No, if doing so you´d still need to have the arpeggiator turned on and running into the same problem, the damn arp. just doesn´t transmit arpeggiated notes out, not even internal, whoever made that decission @ E-mu back then.... &%$§"!. My Yamaha AN1x has a great Arpeggiator and Pattern Seq. and transmits over MIDI, even on an independent MIDI Channel. RR --- In emax@yahoogroups.com, "peter_vh01" <petervh@...> wrote: > > Hmm, just a thought, might it be possible to record an arpeggiated > sequence with the sequencer, and play that back through the midi port? > > - Peter > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> wrote: > > > > Gah! So there is no possible way to use the Emax Arpeggiator to drive > > other gear? What a shame! > > > > Anybody know of any affordable midi modules out there that can do a > > good job of this? > > > > - Peter > > > > --- In emax@yahoogroups.com, "rascalrevenge" <rascalrevenge@> wrote: > > > > > > Sadly Emax does NOT transmit arpeggiator-data to it´s MIDI OUT. > > > > > > RR > > > > > > > > > > > > > > > > > > > > > > > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> wrote: > > > > > > > > Hey guys, > > > > > > > > I'm trying to figure out to use the arpeggiator on my Emax-1 to > > > > control my Juno 106. Anybody know how to do this? I was just playing
> > > > with the arpeggiator today, and had it functioning wonderfully > on the > > > > Emax itself, just not sure how to control other devices with it. > > > > > > > > Thanks! > > > > > > > > - Peter > > > > > > > > > >
2006-05-28 by Simon_Owen
err, that's odd then, becuase i'm using my emax as a master controller (via atari ST cubase) to record arpeggiated lines to my microkorg & jx3p without any problem. Cubase records all arpeggiated notes with no problem and plays them back. Also works if directly connected to external synth.... It does send arpeggiator to midi out. Cheers Simon --- In emax@yahoogroups.com, "rascalrevenge" <rascalrevenge@...> wrote:
> > No, if doing so you´d still need to have the arpeggiator turned on and > running into the same problem, the damn arp. just doesn´t transmit > arpeggiated notes out, not even internal, whoever made that decission > @ E-mu back then.... &%$§"!. > > My Yamaha AN1x has a great Arpeggiator and Pattern Seq. and transmits > over MIDI, even on an independent MIDI Channel. > > RR > > > > > > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> wrote: > > > > Hmm, just a thought, might it be possible to record an arpeggiated > > sequence with the sequencer, and play that back through the midi port? > > > > - Peter > > > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> wrote: > > > > > > Gah! So there is no possible way to use the Emax Arpeggiator to drive > > > other gear? What a shame! > > > > > > Anybody know of any affordable midi modules out there that can do a > > > good job of this? > > > > > > - Peter > > > > > > --- In emax@yahoogroups.com, "rascalrevenge" <rascalrevenge@> wrote: > > > > > > > > Sadly Emax does NOT transmit arpeggiator-data to it´s MIDI OUT. > > > > > > > > RR > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> wrote: > > > > > > > > > > Hey guys, > > > > > > > > > > I'm trying to figure out to use the arpeggiator on my Emax-1 to > > > > > control my Juno 106. Anybody know how to do this? I was just > playing > > > > > with the arpeggiator today, and had it functioning wonderfully > > on the > > > > > Emax itself, just not sure how to control other devices with it. > > > > > > > > > > Thanks! > > > > > > > > > > - Peter > > > > > > > > > > > > > > >
Err, great find then for me and you´re right, just tried it, works on both my Emax´ with SE and Plus Software, honestly I can´t remind reading that this was obviously changed with these software-versions, "shocking" news ;-), I never tried this with them until A MOMENT AGO, just because I am sure on Emax 1 Software version 3.2 this did NOT work, right ? If anyone can please confirm. In MASTER menu > Special > MIDI Analyzer > MIDI Data: Out I could now see the arpeggiated notes running, so on my old non SE- Emax in the same menu you could only see the note transmitted you pushed if I remember correctly, but not the arpeggiated notes (inbetween). Let me know someone with OS 3.2 if I´m right then it´s working only on SE and Plus OS, and thx again for that info. RR --- In emax@yahoogroups.com, "Simon_Owen" <iss049@...> wrote: > > err, that's odd then, becuase i'm using my emax as a master controller (via atari ST > cubase) to record arpeggiated lines to my microkorg & jx3p without any problem. Cubase > records all arpeggiated notes with no problem and plays them back. Also works if directly > connected to external synth.... It does send arpeggiator to midi out. > > Cheers > > Simon > > > > --- In emax@yahoogroups.com, "rascalrevenge" <rascalrevenge@> wrote: > > > > No, if doing so you´d still need to have the arpeggiator turned on and > > running into the same problem, the damn arp. just doesn´t transmit > > arpeggiated notes out, not even internal, whoever made that decission > > @ E-mu back then.... &%$§"!. > > > > My Yamaha AN1x has a great Arpeggiator and Pattern Seq. and transmits > > over MIDI, even on an independent MIDI Channel. > > > > RR > > > > > > > > > > > > > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> wrote: > > > > > > Hmm, just a thought, might it be possible to record an arpeggiated > > > sequence with the sequencer, and play that back through the midi port? > > > > > > - Peter > > > > > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> wrote: > > > > > > > > Gah! So there is no possible way to use the Emax Arpeggiator to drive > > > > other gear? What a shame! > > > > > > > > Anybody know of any affordable midi modules out there that can do a > > > > good job of this? > > > > > > > > - Peter > > > > > > > > --- In emax@yahoogroups.com, "rascalrevenge" <rascalrevenge@> wrote: > > > > > > > > > > Sadly Emax does NOT transmit arpeggiator-data to it´s MIDI OUT. > > > > > > > > > > RR > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> wrote: > > > > > > > > > > > > Hey guys, > > > > > > > > > > > > I'm trying to figure out to use the arpeggiator on my Emax-1 to > > > > > > control my Juno 106. Anybody know how to do this? I was just > > playing > > > > > > with the arpeggiator today, and had it functioning wonderfully > > > on the > > > > > > Emax itself, just not sure how to control other devices with it.
> > > > > > > > > > > > Thanks! > > > > > > > > > > > > - Peter > > > > > > > > > > > > > > > > > > > > >
2006-05-28 by peter_vh01
OK, So how can I find out if my EMAX has the SE revision on it? According to what it says under Master --> Special, my HD has the version "Emax HD Rev. 1.1" installed. Is this the SE version? According to some websites I was looking at, it should say "Emax SE HD Rev 1.1"..perhaps there just wasn't enough space on the display to include the SE? - Peter --- In emax@yahoogroups.com, "rascalrevenge" <rascalrevenge@...> wrote: > > Err, great find then for me and you´re right, just tried it, works on > both my Emax´ with SE and Plus Software, honestly I can´t remind > reading that this was obviously changed with these software-versions, > "shocking" news ;-), I never tried this with them until A MOMENT AGO, > just because I am sure on Emax 1 Software version 3.2 this did NOT > work, right ? If anyone can please confirm. In MASTER menu > Special > > MIDI Analyzer > MIDI Data: Out I could now see the arpeggiated notes > running, so on my old non SE- Emax in the same menu you could only see > the note transmitted you pushed if I remember correctly, but not the > arpeggiated notes (inbetween). Let me know someone with OS 3.2 if I´m > right then it´s working only on SE and Plus OS, and thx again for that > info. > > RR > > > > > > > > > > > > > --- In emax@yahoogroups.com, "Simon_Owen" <iss049@> wrote: > > > > err, that's odd then, becuase i'm using my emax as a master > controller (via atari ST > > cubase) to record arpeggiated lines to my microkorg & jx3p without > any problem. Cubase > > records all arpeggiated notes with no problem and plays them back. > Also works if directly > > connected to external synth.... It does send arpeggiator to midi out. > > > > Cheers > > > > Simon > > > > > > > > --- In emax@yahoogroups.com, "rascalrevenge" <rascalrevenge@> wrote: > > > > > > No, if doing so you´d still need to have the arpeggiator turned on and > > > running into the same problem, the damn arp. just doesn´t transmit > > > arpeggiated notes out, not even internal, whoever made that decission > > > @ E-mu back then.... &%$§"!. > > > > > > My Yamaha AN1x has a great Arpeggiator and Pattern Seq. and transmits > > > over MIDI, even on an independent MIDI Channel. > > > > > > RR > > > > > > > > > > > > > > > > > > > > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> wrote: > > > > > > > > Hmm, just a thought, might it be possible to record an arpeggiated > > > > sequence with the sequencer, and play that back through the midi > port? > > > > > > > > - Peter > > > > > > > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> wrote: > > > > > > > > > > Gah! So there is no possible way to use the Emax Arpeggiator > to drive > > > > > other gear? What a shame! > > > > > > > > > > Anybody know of any affordable midi modules out there that can > do a > > > > > good job of this? > > > > > > > > > > - Peter > > > > > > > > > > --- In emax@yahoogroups.com, "rascalrevenge" <rascalrevenge@> > wrote: > > > > > > > > > > > > Sadly Emax does NOT transmit arpeggiator-data to it´s MIDI OUT. > > > > > > > > > > > > RR > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> wrote: > > > > > > > > > > > > > > Hey guys, > > > > > > > > > > > > > > I'm trying to figure out to use the arpeggiator on my > Emax-1 to > > > > > > > control my Juno 106. Anybody know how to do this? I was just > > > playing > > > > > > > with the arpeggiator today, and had it functioning wonderfully
> > > > on the > > > > > > > Emax itself, just not sure how to control other devices > with it. > > > > > > > > > > > > > > Thanks! > > > > > > > > > > > > > > - Peter > > > > > > > > > > > > > > > > > > > > > > > > > > > >
Ah, no according to this site, http://www.silveriafamily.com/emax/emax_overview.html HD 1.1 came out before the SE. I don't really feel like going through the effort of setting up a DOS machine with a FAT drive to get an SE install disk. Is it truly not possible to send arpeggiated sequences through the midi out with the version I am running? Or perhaps it's just a setting somewhere I need to adjust? - peter --- In emax@yahoogroups.com, "peter_vh01" <petervh@...> wrote: > > OK, > > So how can I find out if my EMAX has the SE revision on it? According > to what it says under Master --> Special, my HD has the version "Emax > HD Rev. 1.1" installed. Is this the SE version? According to some > websites I was looking at, it should say "Emax SE HD Rev 1.1"..perhaps > there just wasn't enough space on the display to include the SE? > > - Peter > > --- In emax@yahoogroups.com, "rascalrevenge" <rascalrevenge@> wrote: > > > > Err, great find then for me and you´re right, just tried it, works on > > both my Emax´ with SE and Plus Software, honestly I can´t remind > > reading that this was obviously changed with these software-versions, > > "shocking" news ;-), I never tried this with them until A MOMENT AGO, > > just because I am sure on Emax 1 Software version 3.2 this did NOT > > work, right ? If anyone can please confirm. In MASTER menu > Special > > > MIDI Analyzer > MIDI Data: Out I could now see the arpeggiated notes > > running, so on my old non SE- Emax in the same menu you could only see > > the note transmitted you pushed if I remember correctly, but not the > > arpeggiated notes (inbetween). Let me know someone with OS 3.2 if I´m > > right then it´s working only on SE and Plus OS, and thx again for that > > info. > > > > RR > > > > > > > > > > > > > > > > > > > > > > > > > > --- In emax@yahoogroups.com, "Simon_Owen" <iss049@> wrote: > > > > > > err, that's odd then, becuase i'm using my emax as a master > > controller (via atari ST > > > cubase) to record arpeggiated lines to my microkorg & jx3p without > > any problem. Cubase > > > records all arpeggiated notes with no problem and plays them back. > > Also works if directly > > > connected to external synth.... It does send arpeggiator to midi out. > > > > > > Cheers > > > > > > Simon > > > > > > > > > > > > --- In emax@yahoogroups.com, "rascalrevenge" <rascalrevenge@> wrote: > > > > > > > > No, if doing so you´d still need to have the arpeggiator turned > on and > > > > running into the same problem, the damn arp. just doesn´t transmit > > > > arpeggiated notes out, not even internal, whoever made that > decission > > > > @ E-mu back then.... &%$§"!. > > > > > > > > My Yamaha AN1x has a great Arpeggiator and Pattern Seq. and > transmits > > > > over MIDI, even on an independent MIDI Channel. > > > > > > > > RR > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> wrote: > > > > > > > > > > Hmm, just a thought, might it be possible to record an arpeggiated > > > > > sequence with the sequencer, and play that back through the midi > > port? > > > > > > > > > > - Peter > > > > > > > > > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> wrote: > > > > > > > > > > > > Gah! So there is no possible way to use the Emax Arpeggiator > > to drive > > > > > > other gear? What a shame! > > > > > > > > > > > > Anybody know of any affordable midi modules out there that can > > do a > > > > > > good job of this? > > > > > > > > > > > > - Peter > > > > > > > > > > > > --- In emax@yahoogroups.com, "rascalrevenge" <rascalrevenge@> > > wrote: > > > > > > > > > > > > > > Sadly Emax does NOT transmit arpeggiator-data to it´s MIDI > OUT. > > > > > > > > > > > > > > RR > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> wrote: > > > > > > > > > > > > > > > > Hey guys, > > > > > > > > > > > > > > > > I'm trying to figure out to use the arpeggiator on my > > Emax-1 to > > > > > > > > control my Juno 106. Anybody know how to do this? I was just
> > > > playing > > > > > > > > with the arpeggiator today, and had it functioning > wonderfully > > > > > on the > > > > > > > > Emax itself, just not sure how to control other devices > > with it. > > > > > > > > > > > > > > > > Thanks! > > > > > > > > > > > > > > > > - Peter > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >
Actually, I decided to go ahead, and I installed DOS 6.22 onto an old box I had kicking around. Ran the software, created the disk, but when I run the disk I first get the message 'BAD BANKS' and then 'WRONG SOFTWARE'. Anyone else ever experience this? I took the SE software off of the Files section on this group. - Peter --- In emax@yahoogroups.com, "elmacaco" <elmacaco@...> wrote: > > I can make you an SE upgrade disk, if you like, it's $25 for the trouble. > > The good news then is you can run the Plus OS and have all the Emax features. > > > ----- Original Message ----- > From: peter_vh01 > To: emax@yahoogroups.com > Sent: Sunday, May 28, 2006 12:18 PM > Subject: [emax] Re: Using the EMAX-1 Arpeggiator to control other Synths... > > > Ah, no according to this site, > http://www.silveriafamily.com/emax/emax_overview.html HD 1.1 came out > before the SE. > > I don't really feel like going through the effort of setting up a DOS > machine with a FAT drive to get an SE install disk. Is it truly not > possible to send arpeggiated sequences through the midi out with the > version I am running? Or perhaps it's just a setting somewhere I need > to adjust? > > - peter > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> wrote: > > > > OK, > > > > So how can I find out if my EMAX has the SE revision on it? According > > to what it says under Master --> Special, my HD has the version "Emax > > HD Rev. 1.1" installed. Is this the SE version? According to some > > websites I was looking at, it should say "Emax SE HD Rev 1.1"..perhaps > > there just wasn't enough space on the display to include the SE? > > > > - Peter > > > > --- In emax@yahoogroups.com, "rascalrevenge" <rascalrevenge@> wrote: > > > > > > Err, great find then for me and you´re right, just tried it, works on > > > both my Emax´ with SE and Plus Software, honestly I can´t remind > > > reading that this was obviously changed with these software-versions, > > > "shocking" news ;-), I never tried this with them until A MOMENT AGO, > > > just because I am sure on Emax 1 Software version 3.2 this did NOT > > > work, right ? If anyone can please confirm. In MASTER menu > Special > > > > MIDI Analyzer > MIDI Data: Out I could now see the arpeggiated notes > > > running, so on my old non SE- Emax in the same menu you could only see > > > the note transmitted you pushed if I remember correctly, but not the > > > arpeggiated notes (inbetween). Let me know someone with OS 3.2 if I´m > > > right then it´s working only on SE and Plus OS, and thx again for that > > > info. > > > > > > RR > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In emax@yahoogroups.com, "Simon_Owen" <iss049@> wrote: > > > > > > > > err, that's odd then, becuase i'm using my emax as a master > > > controller (via atari ST > > > > cubase) to record arpeggiated lines to my microkorg & jx3p without > > > any problem. Cubase > > > > records all arpeggiated notes with no problem and plays them back. > > > Also works if directly > > > > connected to external synth.... It does send arpeggiator to > midi out. > > > > > > > > Cheers > > > > > > > > Simon > > > > > > > > > > > > > > > > --- In emax@yahoogroups.com, "rascalrevenge" <rascalrevenge@> wrote: > > > > > > > > > > No, if doing so you´d still need to have the arpeggiator turned > > on and > > > > > running into the same problem, the damn arp. just doesn´t transmit > > > > > arpeggiated notes out, not even internal, whoever made that > > decission > > > > > @ E-mu back then.... &%$§"!. > > > > > > > > > > My Yamaha AN1x has a great Arpeggiator and Pattern Seq. and > > transmits > > > > > over MIDI, even on an independent MIDI Channel. > > > > > > > > > > RR > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> wrote: > > > > > > > > > > > > Hmm, just a thought, might it be possible to record an > arpeggiated > > > > > > sequence with the sequencer, and play that back through the midi > > > port? > > > > > > > > > > > > - Peter > > > > > > > > > > > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> wrote: > > > > > > > > > > > > > > Gah! So there is no possible way to use the Emax Arpeggiator > > > to drive > > > > > > > other gear? What a shame! > > > > > > > > > > > > > > Anybody know of any affordable midi modules out there that can > > > do a > > > > > > > good job of this? > > > > > > > > > > > > > > - Peter > > > > > > > > > > > > > > --- In emax@yahoogroups.com, "rascalrevenge" <rascalrevenge@> > > > wrote: > > > > > > > > > > > > > > > > Sadly Emax does NOT transmit arpeggiator-data to it´s MIDI > > OUT. > > > > > > > > > > > > > > > > RR > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> wrote: > > > > > > > > > > > > > > > > > > Hey guys, > > > > > > > > > > > > > > > > > > I'm trying to figure out to use the arpeggiator on my > > > Emax-1 to > > > > > > > > > control my Juno 106. Anybody know how to do this? I > was just > > > > > playing > > > > > > > > > with the arpeggiator today, and had it functioning > > wonderfully > > > > > > on the > > > > > > > > > Emax itself, just not sure how to control other devices > > > with it. > > > > > > > > > > > > > > > > > > Thanks! > > > > > > > > > > > > > > > > > > - Peter > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Emax and Emax II User's Group Website > > http://www.silveriafamily.com > > > > SPONSORED LINKS Electronic instrument Emax Synthesizer music > Electronic music Music sampler Electronic musical instrument > > > ------------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > a.. Visit your group "emax" on the web. > > b.. To unsubscribe from this group, send an email to: > emax-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------------------
> > > > [Non-text portions of this message have been removed] >
2006-05-28 by elmacaco
I can make you an SE upgrade disk, if you like, it's $25 for the trouble. The good news then is you can run the Plus OS and have all the Emax features.
before the SE.
to adjust?
- peter
> OK,
> - Peter
> > info.
> > RR
> > any problem. Cubase
midi out.
> > > Cheers
> > > Simon
> on and
> decission
> transmits
> > > > RR
arpeggiated
> > port?
> > > > > - Peter
> > to drive
> > do a
> > > > > > good job of this?
> > > > > > - Peter
> OUT.
> > > > > > > RR
> > > > > > > > Hey guys,
> > Emax-1 to
was just
> > > > playing
> wonderfully
> > > > > on the
> > with it.
> > > > > > > > Thanks!
> > > > > > > > - Peter
YAHOO! GROUPS LINKS
[Non-text portions of this message have been removed]2006-05-28 by pasquale.aprea@...
i did a SE upgrade myself creating the floppy from dos, just following the directions you can find on this mailing list homepage. http://www.silveriafamily.com/emax/emax_repair.html check it out, easy step by step instructions davide
>-- Original Message -- >To: emax@yahoogroups.com >From: "peter_vh01" <petervh@...> >Date: Sun, 28 May 2006 20:09:55 -0000 >Subject: [emax] Re: Using the EMAX-1 Arpeggiator to control other Synths... >Reply-To: emax@yahoogroups.com > > >Actually, I decided to go ahead, and I installed DOS 6.22 onto an old >box I had kicking around. > >Ran the software, created the disk, but when I run the disk I first >get the message 'BAD BANKS' and then 'WRONG SOFTWARE'. Anyone else >ever experience this? I took the SE software off of the Files section >on this group. > >- Peter > >--- In emax@yahoogroups.com, "elmacaco" <elmacaco@...> wrote: >> >> I can make you an SE upgrade disk, if you like, it's $25 for the >trouble. >> >> The good news then is you can run the Plus OS and have all the Emax >features. >> >> >> ----- Original Message ----- >> From: peter_vh01 >> To: emax@yahoogroups.com >> Sent: Sunday, May 28, 2006 12:18 PM >> Subject: [emax] Re: Using the EMAX-1 Arpeggiator to control other >Synths... >> >> >> Ah, no according to this site, >> http://www.silveriafamily.com/emax/emax_overview.html HD 1.1 came out >> before the SE. >> >> I don't really feel like going through the effort of setting up a DOS >> machine with a FAT drive to get an SE install disk. Is it truly not >> possible to send arpeggiated sequences through the midi out with the >> version I am running? Or perhaps it's just a setting somewhere I need >> to adjust? >> >> - peter >> >> --- In emax@yahoogroups.com, "peter_vh01" <petervh@> wrote: >> > >> > OK, >> > >> > So how can I find out if my EMAX has the SE revision on it? >According >> > to what it says under Master --> Special, my HD has the version >"Emax >> > HD Rev. 1.1" installed. Is this the SE version? According to some >> > websites I was looking at, it should say "Emax SE HD Rev >1.1"..perhaps >> > there just wasn't enough space on the display to include the SE? >> > >> > - Peter >> > >> > --- In emax@yahoogroups.com, "rascalrevenge" <rascalrevenge@> wrote: >> > > >> > > Err, great find then for me and you´re right, just tried it, >works on >> > > both my Emax´ with SE and Plus Software, honestly I can´t remind >> > > reading that this was obviously changed with these >software-versions, >> > > "shocking" news ;-), I never tried this with them until A >MOMENT AGO, >> > > just because I am sure on Emax 1 Software version 3.2 this did NOT >> > > work, right ? If anyone can please confirm. In MASTER menu > >Special > >> > > MIDI Analyzer > MIDI Data: Out I could now see the arpeggiated >notes >> > > running, so on my old non SE- Emax in the same menu you could >only see >> > > the note transmitted you pushed if I remember correctly, but >not the >> > > arpeggiated notes (inbetween). Let me know someone with OS 3.2 >if I´m >> > > right then it´s working only on SE and Plus OS, and thx again >for that >> > > info. >> > > >> > > RR >> > > >> > > >> > > >> > > >> > > >> > > >> > > >> > > >> > > >> > > >> > > >> > > >> > > --- In emax@yahoogroups.com, "Simon_Owen" <iss049@> wrote: >> > > > >> > > > err, that's odd then, becuase i'm using my emax as a master >> > > controller (via atari ST >> > > > cubase) to record arpeggiated lines to my microkorg & jx3p >without >> > > any problem. Cubase >> > > > records all arpeggiated notes with no problem and plays them >back. >> > > Also works if directly >> > > > connected to external synth.... It does send arpeggiator to >> midi out. >> > > > >> > > > Cheers >> > > > >> > > > Simon >> > > > >> > > > >> > > > >> > > > --- In emax@yahoogroups.com, "rascalrevenge" ><rascalrevenge@> wrote: >> > > > > >> > > > > No, if doing so you´d still need to have the arpeggiator >turned >> > on and >> > > > > running into the same problem, the damn arp. just doesn´t >transmit >> > > > > arpeggiated notes out, not even internal, whoever made that >> > decission >> > > > > @ E-mu back then.... &%$§"!. >> > > > > >> > > > > My Yamaha AN1x has a great Arpeggiator and Pattern Seq. and >> > transmits >> > > > > over MIDI, even on an independent MIDI Channel. >> > > > > >> > > > > RR >> > > > > >> > > > > >> > > > > >> > > > > >> > > > > >> > > > > >> > > > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> wrote: >> > > > > > >> > > > > > Hmm, just a thought, might it be possible to record an >> arpeggiated >> > > > > > sequence with the sequencer, and play that back through >the midi >> > > port? >> > > > > > >> > > > > > - Peter >> > > > > > >> > > > > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> wrote: >> > > > > > > >> > > > > > > Gah! So there is no possible way to use the Emax >Arpeggiator >> > > to drive >> > > > > > > other gear? What a shame! >> > > > > > > >> > > > > > > Anybody know of any affordable midi modules out there >that can >> > > do a >> > > > > > > good job of this? >> > > > > > > >> > > > > > > - Peter >> > > > > > > >> > > > > > > --- In emax@yahoogroups.com, "rascalrevenge" ><rascalrevenge@> >> > > wrote: >> > > > > > > > >> > > > > > > > Sadly Emax does NOT transmit arpeggiator-data to >it´s MIDI >> > OUT. >> > > > > > > > >> > > > > > > > RR >> > > > > > > > >> > > > > > > > >> > > > > > > > >> > > > > > > > >> > > > > > > > >> > > > > > > > >> > > > > > > > >> > > > > > > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> >wrote: >> > > > > > > > > >> > > > > > > > > Hey guys, >> > > > > > > > > >> > > > > > > > > I'm trying to figure out to use the arpeggiator on my >> > > Emax-1 to >> > > > > > > > > control my Juno 106. Anybody know how to do this? I >> was just >> > > > > playing >> > > > > > > > > with the arpeggiator today, and had it functioning >> > wonderfully >> > > > > > on the >> > > > > > > > > Emax itself, just not sure how to control other >devices >> > > with it. >> > > > > > > > > >> > > > > > > > > Thanks! >> > > > > > > > > >> > > > > > > > > - Peter >> > > > > > > > > >> > > > > > > > >> > > > > > > >> > > > > > >> > > > > >> > > > >> > > >> > >> >> >> >> >> >> >> Emax and Emax II User's Group Website >> >> http://www.silveriafamily.com >> >> >> >> SPONSORED LINKS Electronic instrument Emax Synthesizer music >> Electronic music Music sampler Electronic musical instrument > >> >> >> >------------------------------------------------------------------------------ >> YAHOO! GROUPS LINKS >> >> a.. Visit your group "emax" on the web. >> >> b.. To unsubscribe from this group, send an email to: >> emax-unsubscribe@yahoogroups.com >> >> c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of >Service. >> >> >> >------------------------------------------------------------------------------ >> >> >> >> [Non-text portions of this message have been removed] >> > > > > > > > >Emax and Emax II User's Group Website > >http://www.silveriafamily.com >Yahoo! Groups Links > > > > > > >
also dos 6.22 is not necessary, you can use a more recent dos version as i did, so that even fat 32 partitions can be recognised. http://newdos.de/ davide >-- Original Message -- >To: emax@yahoogroups.com >From: pasquale.aprea@... >Date: Sun, 28 May 2006 23:41:44 +0200 >Subject: RE: [emax] Re: Using the EMAX-1 Arpeggiator to control other Synths... >Reply-To: emax@yahoogroups.com > > >i did a SE upgrade myself creating the floppy from dos, just following the >directions you can find on this mailing list homepage. > >http://www.silveriafamily.com/emax/emax_repair.html > >check it out, easy step by step instructions > >davide > >>-- Original Message -- >>To: emax@yahoogroups.com >>From: "peter_vh01" <petervh@...> >>Date: Sun, 28 May 2006 20:09:55 -0000 >>Subject: [emax] Re: Using the EMAX-1 Arpeggiator to control other Synths... >>Reply-To: emax@yahoogroups.com >> >> >>Actually, I decided to go ahead, and I installed DOS 6.22 onto an old >>box I had kicking around. >> >>Ran the software, created the disk, but when I run the disk I first >>get the message 'BAD BANKS' and then 'WRONG SOFTWARE'. Anyone else >>ever experience this? I took the SE software off of the Files section >>on this group. >> >>- Peter >> >>--- In emax@yahoogroups.com, "elmacaco" <elmacaco@...> wrote: >>> >>> I can make you an SE upgrade disk, if you like, it's $25 for the >>trouble. >>> >>> The good news then is you can run the Plus OS and have all the Emax >>features. >>> >>> >>> ----- Original Message ----- >>> From: peter_vh01 >>> To: emax@yahoogroups.com >>> Sent: Sunday, May 28, 2006 12:18 PM >>> Subject: [emax] Re: Using the EMAX-1 Arpeggiator to control other >>Synths... >>> >>> >>> Ah, no according to this site, >>> http://www.silveriafamily.com/emax/emax_overview.html HD 1.1 came out >>> before the SE. >>> >>> I don't really feel like going through the effort of setting up a DOS >>> machine with a FAT drive to get an SE install disk. Is it truly not >>> possible to send arpeggiated sequences through the midi out with the >>> version I am running? Or perhaps it's just a setting somewhere I need >>> to adjust? >>> >>> - peter >>> >>> --- In emax@yahoogroups.com, "peter_vh01" <petervh@> wrote: >>> > >>> > OK, >>> > >>> > So how can I find out if my EMAX has the SE revision on it? >>According >>> > to what it says under Master --> Special, my HD has the version >>"Emax >>> > HD Rev. 1.1" installed. Is this the SE version? According to some >>> > websites I was looking at, it should say "Emax SE HD Rev >>1.1"..perhaps >>> > there just wasn't enough space on the display to include the SE? >>> > >>> > - Peter >>> > >>> > --- In emax@yahoogroups.com, "rascalrevenge" <rascalrevenge@> wrote: >>> > > >>> > > Err, great find then for me and you´re right, just tried it, >>works on >>> > > both my Emax´ with SE and Plus Software, honestly I can´t remind >>> > > reading that this was obviously changed with these >>software-versions, >>> > > "shocking" news ;-), I never tried this with them until A >>MOMENT AGO, >>> > > just because I am sure on Emax 1 Software version 3.2 this did NOT >>> > > work, right ? If anyone can please confirm. In MASTER menu > >>Special > >>> > > MIDI Analyzer > MIDI Data: Out I could now see the arpeggiated >>notes >>> > > running, so on my old non SE- Emax in the same menu you could >>only see >>> > > the note transmitted you pushed if I remember correctly, but >>not the >>> > > arpeggiated notes (inbetween). Let me know someone with OS 3.2 >>if I´m >>> > > right then it´s working only on SE and Plus OS, and thx again >>for that >>> > > info. >>> > > >>> > > RR >>> > > >>> > > >>> > > >>> > > >>> > > >>> > > >>> > > >>> > > >>> > > >>> > > >>> > > >>> > > >>> > > --- In emax@yahoogroups.com, "Simon_Owen" <iss049@> wrote: >>> > > > >>> > > > err, that's odd then, becuase i'm using my emax as a master >>> > > controller (via atari ST >>> > > > cubase) to record arpeggiated lines to my microkorg & jx3p >>without >>> > > any problem. Cubase >>> > > > records all arpeggiated notes with no problem and plays them >>back. >>> > > Also works if directly >>> > > > connected to external synth.... It does send arpeggiator to >>> midi out. >>> > > > >>> > > > Cheers >>> > > > >>> > > > Simon >>> > > > >>> > > > >>> > > > >>> > > > --- In emax@yahoogroups.com, "rascalrevenge" >><rascalrevenge@> wrote: >>> > > > > >>> > > > > No, if doing so you´d still need to have the arpeggiator >>turned >>> > on and >>> > > > > running into the same problem, the damn arp. just doesn´t >>transmit >>> > > > > arpeggiated notes out, not even internal, whoever made that >>> > decission >>> > > > > @ E-mu back then.... &%$§"!. >>> > > > > >>> > > > > My Yamaha AN1x has a great Arpeggiator and Pattern Seq. and >>> > transmits >>> > > > > over MIDI, even on an independent MIDI Channel. >>> > > > > >>> > > > > RR >>> > > > > >>> > > > > >>> > > > > >>> > > > > >>> > > > > >>> > > > > >>> > > > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> wrote: >>> > > > > > >>> > > > > > Hmm, just a thought, might it be possible to record an >>> arpeggiated >>> > > > > > sequence with the sequencer, and play that back through >>the midi >>> > > port? >>> > > > > > >>> > > > > > - Peter >>> > > > > > >>> > > > > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> wrote: >>> > > > > > > >>> > > > > > > Gah! So there is no possible way to use the Emax >>Arpeggiator >>> > > to drive >>> > > > > > > other gear? What a shame! >>> > > > > > > >>> > > > > > > Anybody know of any affordable midi modules out there >>that can >>> > > do a >>> > > > > > > good job of this? >>> > > > > > > >>> > > > > > > - Peter >>> > > > > > > >>> > > > > > > --- In emax@yahoogroups.com, "rascalrevenge" >><rascalrevenge@> >>> > > wrote: >>> > > > > > > > >>> > > > > > > > Sadly Emax does NOT transmit arpeggiator-data to >>it´s MIDI >>> > OUT. >>> > > > > > > > >>> > > > > > > > RR >>> > > > > > > > >>> > > > > > > > >>> > > > > > > > >>> > > > > > > > >>> > > > > > > > >>> > > > > > > > >>> > > > > > > > >>> > > > > > > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> >>wrote: >>> > > > > > > > > >>> > > > > > > > > Hey guys, >>> > > > > > > > > >>> > > > > > > > > I'm trying to figure out to use the arpeggiator on my
>>> > > Emax-1 to >>> > > > > > > > > control my Juno 106. Anybody know how to do this? I >>> was just >>> > > > > playing >>> > > > > > > > > with the arpeggiator today, and had it functioning >>> > wonderfully >>> > > > > > on the >>> > > > > > > > > Emax itself, just not sure how to control other >>devices >>> > > with it. >>> > > > > > > > > >>> > > > > > > > > Thanks! >>> > > > > > > > > >>> > > > > > > > > - Peter >>> > > > > > > > > >>> > > > > > > > >>> > > > > > > >>> > > > > > >>> > > > > >>> > > > >>> > > >>> > >>> >>> >>> >>> >>> >>> >>> Emax and Emax II User's Group Website >>> >>> http://www.silveriafamily.com >>> >>> >>> >>> SPONSORED LINKS Electronic instrument Emax Synthesizer music >>> Electronic music Music sampler Electronic musical instrument >> >>> >>> >>> >>------------------------------------------------------------------------------ >>> YAHOO! GROUPS LINKS >>> >>> a.. Visit your group "emax" on the web. >>> >>> b.. To unsubscribe from this group, send an email to: >>> emax-unsubscribe@yahoogroups.com >>> >>> c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of >>Service. >>> >>> >>> >>------------------------------------------------------------------------------ >>> >>> >>> >>> [Non-text portions of this message have been removed] >>> >> >> >> >> >> >> > >> >>Emax and Emax II User's Group Website >> >>http://www.silveriafamily.com >>Yahoo! Groups Links >> >> >> >> >> >> >> > > > > > >Emax and Emax II User's Group Website > >http://www.silveriafamily.com >Yahoo! Groups Links > > > > > >
I tried following those instructions, and I also tried the Plus OS disk. I get the same message, first 'BAD BANK ON DISK', shortly followed by 'WRONG SOFTWARE'. Any other suggestions? Dos 6.22 should work just fine I assume? - Peter --- In emax@yahoogroups.com, pasquale.aprea@... wrote: > > also dos 6.22 is not necessary, you can use a more recent dos version as > i did, so that even fat 32 partitions can be recognised. > http://newdos.de/ > > davide > > > >-- Original Message -- > >To: emax@yahoogroups.com > >From: pasquale.aprea@... > >Date: Sun, 28 May 2006 23:41:44 +0200 > >Subject: RE: [emax] Re: Using the EMAX-1 Arpeggiator to control other Synths... > >Reply-To: emax@yahoogroups.com > > > > > >i did a SE upgrade myself creating the floppy from dos, just following the > >directions you can find on this mailing list homepage. > > > >http://www.silveriafamily.com/emax/emax_repair.html > > > >check it out, easy step by step instructions > > > >davide > > > >>-- Original Message -- > >>To: emax@yahoogroups.com > >>From: "peter_vh01" <petervh@...> > >>Date: Sun, 28 May 2006 20:09:55 -0000 > >>Subject: [emax] Re: Using the EMAX-1 Arpeggiator to control other Synths... > >>Reply-To: emax@yahoogroups.com > >> > >> > >>Actually, I decided to go ahead, and I installed DOS 6.22 onto an old > >>box I had kicking around. > >> > >>Ran the software, created the disk, but when I run the disk I first > >>get the message 'BAD BANKS' and then 'WRONG SOFTWARE'. Anyone else > >>ever experience this? I took the SE software off of the Files section > >>on this group. > >> > >>- Peter > >> > >>--- In emax@yahoogroups.com, "elmacaco" <elmacaco@> wrote: > >>> > >>> I can make you an SE upgrade disk, if you like, it's $25 for the > >>trouble. > >>> > >>> The good news then is you can run the Plus OS and have all the Emax > >>features. > >>> > >>> > >>> ----- Original Message ----- > >>> From: peter_vh01 > >>> To: emax@yahoogroups.com > >>> Sent: Sunday, May 28, 2006 12:18 PM > >>> Subject: [emax] Re: Using the EMAX-1 Arpeggiator to control other > >>Synths... > >>> > >>> > >>> Ah, no according to this site, > >>> http://www.silveriafamily.com/emax/emax_overview.html HD 1.1 came out > >>> before the SE. > >>> > >>> I don't really feel like going through the effort of setting up a DOS > >>> machine with a FAT drive to get an SE install disk. Is it truly not > >>> possible to send arpeggiated sequences through the midi out with the > >>> version I am running? Or perhaps it's just a setting somewhere I need > >>> to adjust? > >>> > >>> - peter > >>> > >>> --- In emax@yahoogroups.com, "peter_vh01" <petervh@> wrote: > >>> > > >>> > OK, > >>> > > >>> > So how can I find out if my EMAX has the SE revision on it? > >>According > >>> > to what it says under Master --> Special, my HD has the version > >>"Emax > >>> > HD Rev. 1.1" installed. Is this the SE version? According to some > >>> > websites I was looking at, it should say "Emax SE HD Rev > >>1.1"..perhaps > >>> > there just wasn't enough space on the display to include the SE? > >>> > > >>> > - Peter > >>> > > >>> > --- In emax@yahoogroups.com, "rascalrevenge" <rascalrevenge@> wrote: > >>> > > > >>> > > Err, great find then for me and you´re right, just tried it, > >>works on > >>> > > both my Emax´ with SE and Plus Software, honestly I can´t remind > >>> > > reading that this was obviously changed with these > >>software-versions, > >>> > > "shocking" news ;-), I never tried this with them until A > >>MOMENT AGO, > >>> > > just because I am sure on Emax 1 Software version 3.2 this did > NOT > >>> > > work, right ? If anyone can please confirm. In MASTER menu > > >>Special > > >>> > > MIDI Analyzer > MIDI Data: Out I could now see the arpeggiated > >>notes > >>> > > running, so on my old non SE- Emax in the same menu you could > >>only see > >>> > > the note transmitted you pushed if I remember correctly, but > >>not the > >>> > > arpeggiated notes (inbetween). Let me know someone with OS 3.2 > >>if I´m > >>> > > right then it´s working only on SE and Plus OS, and thx again > >>for that > >>> > > info. > >>> > > > >>> > > RR > >>> > > > >>> > > > >>> > > > >>> > > > >>> > > > >>> > > > >>> > > > >>> > > > >>> > > > >>> > > > >>> > > > >>> > > > >>> > > --- In emax@yahoogroups.com, "Simon_Owen" <iss049@> wrote: > >>> > > > > >>> > > > err, that's odd then, becuase i'm using my emax as a master > >>> > > controller (via atari ST > >>> > > > cubase) to record arpeggiated lines to my microkorg & jx3p > >>without > >>> > > any problem. Cubase > >>> > > > records all arpeggiated notes with no problem and plays them > >>back. > >>> > > Also works if directly > >>> > > > connected to external synth.... It does send arpeggiator to > >>> midi out. > >>> > > > > >>> > > > Cheers > >>> > > > > >>> > > > Simon > >>> > > > > >>> > > > > >>> > > > > >>> > > > --- In emax@yahoogroups.com, "rascalrevenge" > >><rascalrevenge@> wrote: > >>> > > > > > >>> > > > > No, if doing so you´d still need to have the arpeggiator > >>turned > >>> > on and > >>> > > > > running into the same problem, the damn arp. just doesn´t > >>transmit > >>> > > > > arpeggiated notes out, not even internal, whoever made that > >>> > decission > >>> > > > > @ E-mu back then.... &%$§"!. > >>> > > > > > >>> > > > > My Yamaha AN1x has a great Arpeggiator and Pattern Seq. and > >>> > transmits > >>> > > > > over MIDI, even on an independent MIDI Channel. > >>> > > > > > >>> > > > > RR > >>> > > > > > >>> > > > > > >>> > > > > > >>> > > > > > >>> > > > > > >>> > > > > > >>> > > > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> wrote: > >>> > > > > > > >>> > > > > > Hmm, just a thought, might it be possible to record an > >>> arpeggiated > >>> > > > > > sequence with the sequencer, and play that back through > >>the midi > >>> > > port? > >>> > > > > > > >>> > > > > > - Peter > >>> > > > > > > >>> > > > > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> wrote: > >>> > > > > > > > >>> > > > > > > Gah! So there is no possible way to use the Emax > >>Arpeggiator > >>> > > to drive > >>> > > > > > > other gear? What a shame! > >>> > > > > > > > >>> > > > > > > Anybody know of any affordable midi modules out there > >>that can > >>> > > do a > >>> > > > > > > good job of this? > >>> > > > > > > > >>> > > > > > > - Peter > >>> > > > > > > > >>> > > > > > > --- In emax@yahoogroups.com, "rascalrevenge" > >><rascalrevenge@> > >>> > > wrote: > >>> > > > > > > > > >>> > > > > > > > Sadly Emax does NOT transmit arpeggiator-data to > >>it´s MIDI > >>> > OUT. > >>> > > > > > > > > >>> > > > > > > > RR > >>> > > > > > > > > >>> > > > > > > > > >>> > > > > > > > > >>> > > > > > > > > >>> > > > > > > > > >>> > > > > > > > > >>> > > > > > > > > >>> > > > > > > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> > >>wrote: > >>> > > > > > > > > > >>> > > > > > > > > Hey guys, > >>> > > > > > > > > > >>> > > > > > > > > I'm trying to figure out to use the arpeggiator on > my > >>> > > Emax-1 to > >>> > > > > > > > > control my Juno 106. Anybody know how to do this? I > >>> was just > >>> > > > > playing > >>> > > > > > > > > with the arpeggiator today, and had it functioning > >>> > wonderfully > >>> > > > > > on the > >>> > > > > > > > > Emax itself, just not sure how to control other > >>devices > >>> > > with it. > >>> > > > > > > > > > >>> > > > > > > > > Thanks! > >>> > > > > > > > > > >>> > > > > > > > > - Peter > >>> > > > > > > > > > >>> > > > > > > > > >>> > > > > > > > >>> > > > > > > >>> > > > > > >>> > > > > >>> > > > >>> > > >>> > >>> > >>> > >>> > >>> > >>> > >>> Emax and Emax II User's Group Website > >>> > >>> http://www.silveriafamily.com > >>> > >>> > >>> > >>> SPONSORED LINKS Electronic instrument Emax Synthesizer music > >>> Electronic music Music sampler Electronic musical instrument
> >> > >>> > >>> > >>> > >>------------------------------------------------------------------------------ > >>> YAHOO! GROUPS LINKS > >>> > >>> a.. Visit your group "emax" on the web. > >>> > >>> b.. To unsubscribe from this group, send an email to: > >>> emax-unsubscribe@yahoogroups.com > >>> > >>> c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of > >>Service. > >>> > >>> > >>> > >>------------------------------------------------------------------------------ > >>> > >>> > >>> > >>> [Non-text portions of this message have been removed] > >>> > >> > >> > >> > >> > >> > >> > > > >> > >>Emax and Emax II User's Group Website > >> > >>http://www.silveriafamily.com > >>Yahoo! Groups Links > >> > >> > >> > >> > >> > >> > >> > > > > > > > > > > > > >Emax and Emax II User's Group Website > > > >http://www.silveriafamily.com > >Yahoo! Groups Links > > > > > > > > > > > > >
I haven't been able to write a working OS disk with EMX since I made a Plus OS once disk years ago. I can burn banks OK but all the OS's get the error you get, Try burning the plus OS, that's the only one I could ever burn successfully. I have a bunch of Emax disks with various OS's and that's what I use to make OS disks for others. you could make the SE upgrade with that OS though.
Sent: Sunday, May 28, 2006 3:09 PM
on this group.
- Peter
trouble.
features.
> From: peter_vh01
Synths...
> before the SE.
> to adjust?
> - peter
> > OK,
According
"Emax
1.1"..perhaps
> > - Peter
works on
software-versions,
MOMENT AGO,
Special >
notes
only see
not the
if I´m
for that
> > > info.
> > > RR
without
> > > any problem. Cubase
back.
> midi out.
> > > > Cheers
> > > > Simon
turned
> > on and
transmit
> > decission
> > transmits
> > > > > RR
> arpeggiated
the midi
> > > port?
> > > > > > - Peter
Arpeggiator
> > > to drive
that can
> > > do a
> > > > > > > good job of this?
> > > > > > > - Peter
<rascalrevenge@>
it´s MIDI
> > OUT.
> > > > > > > > RR
wrote:
> > > > > > > > > Hey guys,
> > > Emax-1 to
> was just
> > > > > playing
> > wonderfully
> > > > > > on the
devices
> > > with it.
> > > > > > > > > Thanks!
> > > > > > > > > - Peter
> YAHOO! GROUPS LINKS
Service.
YAHOO! GROUPS LINKS
keep on trying, it should work. try creating many floppies. dos 6.22 surely is ok, every dos should be ok according to my own experience. make sure you first format those floppies on a real EMAX, no matter the os, or else EMAXUTIL WON'T work davide >-- Original Message -- >To: emax@yahoogroups.com >From: "peter_vh01" <petervh@...> >Date: Sun, 28 May 2006 22:14:58 -0000 >Subject: [emax] Re: Using the EMAX-1 Arpeggiator to control other Synths... >Reply-To: emax@yahoogroups.com > > >I tried following those instructions, and I also tried the Plus OS >disk. I get the same message, first 'BAD BANK ON DISK', shortly >followed by 'WRONG SOFTWARE'. > >Any other suggestions? Dos 6.22 should work just fine I assume? > >- Peter > >--- In emax@yahoogroups.com, pasquale.aprea@... wrote: >> >> also dos 6.22 is not necessary, you can use a more recent dos version as >> i did, so that even fat 32 partitions can be recognised. >> http://newdos.de/ >> >> davide >> >> >> >-- Original Message -- >> >To: emax@yahoogroups.com >> >From: pasquale.aprea@... >> >Date: Sun, 28 May 2006 23:41:44 +0200 >> >Subject: RE: [emax] Re: Using the EMAX-1 Arpeggiator to control >other Synths... >> >Reply-To: emax@yahoogroups.com >> > >> > >> >i did a SE upgrade myself creating the floppy from dos, just >following the >> >directions you can find on this mailing list homepage. >> > >> >http://www.silveriafamily.com/emax/emax_repair.html >> > >> >check it out, easy step by step instructions >> > >> >davide >> > >> >>-- Original Message -- >> >>To: emax@yahoogroups.com >> >>From: "peter_vh01" <petervh@...> >> >>Date: Sun, 28 May 2006 20:09:55 -0000 >> >>Subject: [emax] Re: Using the EMAX-1 Arpeggiator to control other >Synths... >> >>Reply-To: emax@yahoogroups.com >> >> >> >> >> >>Actually, I decided to go ahead, and I installed DOS 6.22 onto an old >> >>box I had kicking around. >> >> >> >>Ran the software, created the disk, but when I run the disk I first >> >>get the message 'BAD BANKS' and then 'WRONG SOFTWARE'. Anyone else >> >>ever experience this? I took the SE software off of the Files section >> >>on this group. >> >> >> >>- Peter >> >> >> >>--- In emax@yahoogroups.com, "elmacaco" <elmacaco@> wrote: >> >>> >> >>> I can make you an SE upgrade disk, if you like, it's $25 for the >> >>trouble. >> >>> >> >>> The good news then is you can run the Plus OS and have all the Emax >> >>features. >> >>> >> >>> >> >>> ----- Original Message ----- >> >>> From: peter_vh01 >> >>> To: emax@yahoogroups.com >> >>> Sent: Sunday, May 28, 2006 12:18 PM >> >>> Subject: [emax] Re: Using the EMAX-1 Arpeggiator to control other >> >>Synths... >> >>> >> >>> >> >>> Ah, no according to this site, >> >>> http://www.silveriafamily.com/emax/emax_overview.html HD 1.1 >came out >> >>> before the SE. >> >>> >> >>> I don't really feel like going through the effort of setting >up a DOS >> >>> machine with a FAT drive to get an SE install disk. Is it >truly not >> >>> possible to send arpeggiated sequences through the midi out >with the >> >>> version I am running? Or perhaps it's just a setting somewhere >I need >> >>> to adjust? >> >>> >> >>> - peter >> >>> >> >>> --- In emax@yahoogroups.com, "peter_vh01" <petervh@> wrote: >> >>> > >> >>> > OK, >> >>> > >> >>> > So how can I find out if my EMAX has the SE revision on it? >> >>According >> >>> > to what it says under Master --> Special, my HD has the version >> >>"Emax >> >>> > HD Rev. 1.1" installed. Is this the SE version? According to >some >> >>> > websites I was looking at, it should say "Emax SE HD Rev >> >>1.1"..perhaps >> >>> > there just wasn't enough space on the display to include the SE? >> >>> > >> >>> > - Peter >> >>> > >> >>> > --- In emax@yahoogroups.com, "rascalrevenge" ><rascalrevenge@> wrote: >> >>> > > >> >>> > > Err, great find then for me and you´re right, just tried it, >> >>works on >> >>> > > both my Emax´ with SE and Plus Software, honestly I can´t >remind >> >>> > > reading that this was obviously changed with these >> >>software-versions, >> >>> > > "shocking" news ;-), I never tried this with them until A >> >>MOMENT AGO, >> >>> > > just because I am sure on Emax 1 Software version 3.2 this did >> NOT >> >>> > > work, right ? If anyone can please confirm. In MASTER menu > >> >>Special > >> >>> > > MIDI Analyzer > MIDI Data: Out I could now see the arpeggiated >> >>notes >> >>> > > running, so on my old non SE- Emax in the same menu you could >> >>only see >> >>> > > the note transmitted you pushed if I remember correctly, but >> >>not the >> >>> > > arpeggiated notes (inbetween). Let me know someone with OS 3.2 >> >>if I´m >> >>> > > right then it´s working only on SE and Plus OS, and thx again >> >>for that >> >>> > > info. >> >>> > > >> >>> > > RR >> >>> > > >> >>> > > >> >>> > > >> >>> > > >> >>> > > >> >>> > > >> >>> > > >> >>> > > >> >>> > > >> >>> > > >> >>> > > >> >>> > > >> >>> > > --- In emax@yahoogroups.com, "Simon_Owen" <iss049@> wrote: >> >>> > > > >> >>> > > > err, that's odd then, becuase i'm using my emax as a master >> >>> > > controller (via atari ST >> >>> > > > cubase) to record arpeggiated lines to my microkorg & jx3p >> >>without >> >>> > > any problem. Cubase >> >>> > > > records all arpeggiated notes with no problem and plays them >> >>back. >> >>> > > Also works if directly >> >>> > > > connected to external synth.... It does send arpeggiator to >> >>> midi out. >> >>> > > > >> >>> > > > Cheers >> >>> > > > >> >>> > > > Simon >> >>> > > > >> >>> > > > >> >>> > > > >> >>> > > > --- In emax@yahoogroups.com, "rascalrevenge" >> >><rascalrevenge@> wrote: >> >>> > > > > >> >>> > > > > No, if doing so you´d still need to have the arpeggiator >> >>turned >> >>> > on and >> >>> > > > > running into the same problem, the damn arp. just doesn´t >> >>transmit >> >>> > > > > arpeggiated notes out, not even internal, whoever made >that >> >>> > decission >> >>> > > > > @ E-mu back then.... &%$§"!. >> >>> > > > > >> >>> > > > > My Yamaha AN1x has a great Arpeggiator and Pattern >Seq. and >> >>> > transmits >> >>> > > > > over MIDI, even on an independent MIDI Channel. >> >>> > > > > >> >>> > > > > RR >> >>> > > > > >> >>> > > > > >> >>> > > > > >> >>> > > > > >> >>> > > > > >> >>> > > > > >> >>> > > > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> >wrote: >> >>> > > > > > >> >>> > > > > > Hmm, just a thought, might it be possible to record an >> >>> arpeggiated >> >>> > > > > > sequence with the sequencer, and play that back through >> >>the midi >> >>> > > port? >> >>> > > > > > >> >>> > > > > > - Peter >> >>> > > > > > >> >>> > > > > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> >wrote: >> >>> > > > > > > >> >>> > > > > > > Gah! So there is no possible way to use the Emax >> >>Arpeggiator >> >>> > > to drive >> >>> > > > > > > other gear? What a shame! >> >>> > > > > > > >> >>> > > > > > > Anybody know of any affordable midi modules out there >> >>that can >> >>> > > do a >> >>> > > > > > > good job of this? >> >>> > > > > > > >> >>> > > > > > > - Peter >> >>> > > > > > > >> >>> > > > > > > --- In emax@yahoogroups.com, "rascalrevenge" >> >><rascalrevenge@> >> >>> > > wrote: >> >>> > > > > > > > >> >>> > > > > > > > Sadly Emax does NOT transmit arpeggiator-data to >> >>it´s MIDI >> >>> > OUT. >> >>> > > > > > > > >> >>> > > > > > > > RR >> >>> > > > > > > > >> >>> > > > > > > > >> >>> > > > > > > > >> >>> > > > > > > > >> >>> > > > > > > > >> >>> > > > > > > > >> >>> > > > > > > > >> >>> > > > > > > > --- In emax@yahoogroups.com, "peter_vh01" <petervh@> >> >>wrote: >> >>> > > > > > > > > >> >>> > > > > > > > > Hey guys, >> >>> > > > > > > > > >> >>> > > > > > > > > I'm trying to figure out to use the arpeggiator on >> my >> >>> > > Emax-1 to >> >>> > > > > > > > > control my Juno 106. Anybody know how to do >this? I >> >>> was just >> >>> > > > > playing >> >>> > > > > > > > > with the arpeggiator today, and had it functioning >> >>> > wonderfully >> >>> > > > > > on the >> >>> > > > > > > > > Emax itself, just not sure how to control other >> >>devices >> >>> > > with it. >> >>> > > > > > > > > >> >>> > > > > > > > > Thanks! >> >>> > > > > > > > > >> >>> > > > > > > > > - Peter >> >>> > > > > > > > > >> >>> > > > > > > > >> >>> > > > > > > >> >>> > > > > > >> >>> > > > > >> >>> > > > >> >>> > > >> >>> > >> >>> >> >>> >> >>> >> >>> >> >>> >> >>> >> >>> Emax and Emax II User's Group Website >> >>> >> >>> http://www.silveriafamily.com >> >>> >> >>> >> >>> >> >>> SPONSORED LINKS Electronic instrument Emax Synthesizer music >> >>> Electronic music Music sampler Electronic musical >instrument >> >> >> >>> >> >>> >> >>> >> >>>------------------------------------------------------------------------------ >> >>> YAHOO! GROUPS LINKS >> >>> >> >>> a.. Visit your group "emax" on the web. >> >>> >> >>> b.. To unsubscribe from this group, send an email to: >> >>> emax-unsubscribe@yahoogroups.com >> >>> >> >>> c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>> >>Service. >> >>> >> >>> >> >>> >> >>>------------------------------------------------------------------------------ >> >>> >> >>> >> >>> >> >>> [Non-text portions of this message have been removed] >> >>> >> >> >> >> >> >> >> >> >> >> >> >> >> > >> >> >> >>Emax and Emax II User's Group Website >> >> >> >>http://www.silveriafamily.com >> >>Yahoo! Groups Links >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> > >> > >> > >> > >> >> > >> >Emax and Emax II User's Group Website >> > >> >http://www.silveriafamily.com >> >Yahoo! Groups Links >> > >> > >> > >> > >> > >> > >> > > > > > > > > >Emax and Emax II User's Group Website > >http://www.silveriafamily.com >Yahoo! Groups Links > > > > > > >
Yes, I have been using floppies formatted on the Emax. It sounds very finicky, so i'll do it another couple dozen times or so. Hopefully it'll work!!! - Peter
2006-05-29 by pasquale.aprea@...
hope so, good luck davide
>-- Original Message -- >To: emax@yahoogroups.com >From: "peter_vh01" <petervh@...> >Date: Sun, 28 May 2006 22:42:52 -0000 >Subject: [emax] Re: Using the EMAX-1 Arpeggiator to control other Synths... >Reply-To: emax@yahoogroups.com > > >Yes, I have been using floppies formatted on the Emax. It sounds very >finicky, so i'll do it another couple dozen times or so. Hopefully >it'll work!!! > >- Peter > > > > > > >Emax and Emax II User's Group Website > >http://www.silveriafamily.com >Yahoo! Groups Links > > > > > >
