Weird Problem On My Emax HD
2006-06-02 by jimstout303
Ok, Here's a good one. Every time I sample on the emax the PLACE SAMPLE function will not allow me to select a HI Range greater than D#3. Any Ideas? And it will not let me Edit Assignments later either. Thanks, Jim
2006-06-02 by rascalrevenge
On the Emax 1 it´s dependent on the sample-rate how far you can reach higher notes, the lower the rate the higher you can get. Let´s say you sampled Orig C4 you can play up to 42 khz samplerate >> C#4 (Wow, 1 semitone ;-) !!) 31 kHz samplerate >> F#4 28 kHz samplerate >> G#4 even higher then with lower samplerates. That´s it. Regards RR --- In emax@yahoogroups.com, "jimstout303" <jim303@...> wrote: > > Ok, Here's a good one. > > Every time I sample on the emax the PLACE SAMPLE function will not allow me to select a HI
> Range greater than D#3. Any Ideas? > > And it will not let me Edit Assignments later either. > > Thanks, > Jim >
2006-06-03 by elmacaco
Also remember to set your original note right before you set the hi note, since that will limit the range like Rascal Revenge said.
To: emax@yahoogroups.com
Sent: Friday, June 02, 2006 6:38 PM
Subject: [emax] Re: Weird Problem On My Emax HD
Regards
RR
> Thanks,
> Jim
Emax and Emax II User's Group Website
http://www.silveriafamily.com
SPONSORED LINKS Electronic instrument Emax Synthesizer music
Electronic music Music sampler Electronic musical instrument
YAHOO! GROUPS LINKS
a.. Visit your group "emax" on the web.
b.. To unsubscribe from this group, send an email to:
emax-unsubscribe@yahoogroups.com
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
[Non-text portions of this message have been removed]2006-06-03 by jimstout303
Thank You very much. I though I was going crazy! - In emax@yahoogroups.com, "rascalrevenge" <rascalrevenge@...> wrote:
> > On the Emax 1 it´s dependent on the sample-rate how far you can reach > higher notes, the lower the rate the higher you can get. Let´s say you > sampled Orig C4 you can play up to > > 42 khz samplerate >> C#4 (Wow, 1 semitone ;-) !!) > 31 kHz samplerate >> F#4 > 28 kHz samplerate >> G#4 > > even higher then with lower samplerates. That´s it. > Regards > > RR > > > > > > --- In emax@yahoogroups.com, "jimstout303" <jim303@> wrote: > > > > Ok, Here's a good one. > > > > Every time I sample on the emax the PLACE SAMPLE function will not > allow me to select a HI > > Range greater than D#3. Any Ideas? > > > > And it will not let me Edit Assignments later either. > > > > Thanks, > > Jim > > >
