1 hour drill press
1 hour drill press
2005-12-12 by Chris Horne
Several people have mentioned drill presses lately...
Just thought I would share one of mine..
I use a hand mini drill and judge theholes by eye, using 0.85 mm
carbide bits at about 10,000 rpm.  I think I tend to breal about 1
bit in every 5,000 holes.
However, I have a CNC micro mill that I can use for drilling,  scan
the actual circuit board and software does the rest..  that uses the
same 0.85mm carbide bits at around 30,000 rpm
Finally my wife wanted to do some drilling but was unable to hold
the drill steady enough so I threw together this little press in
about an hour...
Its in the photos section under Spiyda
http://photos.groups.yahoo.com/group/homebrew_pcbs/lst?.dir=/Spiyda
The main features of note are ...  it cost less than $3 (+ the drill)
It is foot operated and adjustable (the black cable is tied above
the top board and has a terminal block under the second board.. the
cable then continus to the floor, where it is tied 2" above the
floor to a 2" x 1")
There is an old valve spring between the boards to push the drill
back up...
The hinge is a bit of old piano hinge but anything would do.
The boards are about third or fourth hand..  they have previously
been used a s a drawing board, a microwave support and a cutting
board.
The weird thing about this drill press is that it actually works
quite well.
It is more accurate than by hand and as it is foot operated, you
have two hands free for the board !
Chris
Re: [Homebrew_PCBs] 1 hour drill press
2005-12-12 by Stefan Trethan
nice example of a pivoting drill press, i would prefer it over a dremel
stand any day for PCBs.
I'm amazed you can hand-drill with carbide, even 0.85, and get any
significant mileage out of it, you must have a very steady hand. Ever
thought of learning how to tinker with peoples internal workings? I gather
those doctors get neat pay out of it ;-)
One thing i found very useful on my pivoting press is a screw as a stop
very close to the drill bit. This will help hold down the board in the
critical moment when the drill breaks through - has saved me a few drills
already.
The foot activation seems neat, righ now i have mine balanced with a
counterweight and use the back of my hand to lift it, so i can use all
fingers to help positioning the PCB.
ST
> about an hour...
> floor to a 2" x 1")
> back up...
> board.
> quite well.
> Chris
> Photos:
Re: 1 hour drill press
2005-12-12 by soffee83
Yeah, the foot thing is really cool. I'll probably be doing that even
if I don't keep using the small press. The handles are always on the
right, so I have to use my left for the board. :( I've seen some
really nice cable operated foot controls on biscuit joiners (like
bicycle brake cable), but a pulley system would be fine for me.
With me, it has helped to keep the press table up high. My last
drilling was with the table almost at eye level and the surface the
press was on was around elbow height, so I could set my right elbow on
a block of padded styrofoam with my forearm up around 90 degrees and
just drop the quill with an inch or two of finger pull (I keep the tip
as close to the board as possible). I've also kept one of the three
handles removed for extra space and the table stays off to the left,
with a "cover table" clamped to it that extends over to the right.
This allows me to get right up on the drill area while I work (with
eye-wear of course). The last drilling was at a standing position.
I see that there's plans for attaching Dremels,etc. to other press
type stuff. The clamping doesn't seem that difficult and there may be
something "motorless" out there really solid and simple. I've also got
a really small cheap router (Black&Decker) which I only use for
plastics. The motor unit is almost as small as a laminate trimmer,
plus I've got an external speed control. I might look into that.
I'd like to see some additional pictures of that table if you've got
the time (mostly the lift and lower parts).
I hadn't considered the bit stop thing, but I usually have a
replaceable backer board under the PCB. I may try that (assuming it
doesn't obstruct the view). I've got actual bit stops here around that
size.
                                  -Take Care
George
PS- I don't have very good luck with hand drilling. I think I've
broken more stuff that way. I usually only resort to that for trying
to widen a few holes for stuff that has larger legs.
Another thought-
If anyone could think of some type of readily available metal
standoffs which could slide up and down a greased chrome pipe,etc.,
that would be simple as crap. I've got drum hardware here which might
be able to hold the main tube down (like bass drum tomtom mounts), but
you could probably do a two piece wooden clamp around the tube and
screw it down to the work surface. The top could also be strengthened
by a wood rig. I've seen guys use a homemade pulley system on a radial
saw, with counter weights hanging from the far end to return the saw
to the back.
-George
PS- I know the Dremel presses are cheap as dirt. ;)
Re: [Homebrew_PCBs] Re: 1 hour drill press
No sliding system can be built with the same low play as the pivoting
press has, as easily.
A pivoting press can probably be built in the time it takes to find
suitable rails and sliding parts, or ordering expensive linear bearings.
ST
On Mon, 12 Dec 2005 21:57:30 +0100, soffee83 <soffee83@...> wrote:
> Another thought-
> to the back.
> -George
Here's some quick sketches if anyone could make sense out of them (the
proportions are probably screwed up) -->
The press-
http://tinyurl.com/cgc5x
The holders-
http://tinyurl.com/cz6av
This would be with wooden standoffs. There's also no foot cable shown.
I guess that would take an additional pulley or screw eye mounted to
the base or table to pull downward on the drill.
I'm sort of guessing that wooden holes in the holders would have an
acceptable amount of play (maybe a harder wood). I've used that to
spin a drum with just pine, for 1" pipe, and greased the holes. It
held up fine and even had to spin. I think with more than one screw
eye and cable attached to the upper quill part, it would keep too much
unbalanced pull from tilting the holders and screwing things up
(hopefully). An extra thick holder (laminated layers) might also help.
 ---- don't know?
-George
2005-12-12 by lcdpublishing
I agree completly.  The drilling depth (stroke) required for PCBs is
less than 1/4" which is fine for a pivoting press as long as the
pivot point is back a bit from the tool center line.  This sort of
rig only requires a moderate amount of precision in construction and
about the only "critical" item is the hinges - you wouldn't want
sloppy ones.  But otherwise, it don't get much simpler than that.
If the drilling stroke was an inch or so - even a 1/2", problems
could crop up.
Chris
pivoting
find
bearings.
> ST
> On Mon, 12 Dec 2005 21:57:30 +0100, soffee83 <soffee83@y...> wrote:
> > Another thought-
pipe,etc.,
might
mounts), but
and
strengthened
radial
saw
> > to the back.
> > -George
2005-12-12 by Mike Young
http://cgi.ebay.com/5-THK-RSR-12M-Miniature-Linear-Carriage-Rail-Set-CNC_W0QQitemZ7571078254QQcategoryZ55826QQrdZ1QQcmdZViewItem
http://cgi.ebay.com/THK-RSR9MK-Miniature-Linear-Carriage-and-Rail-CNC_W0QQitemZ7571078961QQcategoryZ55826QQrdZ1QQcmdZViewItem
http://cgi.ebay.com/THK-RSR9-Linear-Motion-Slides-Rail-CNC-4-5-inch_W0QQitemZ7572058619QQcategoryZ42899QQrdZ1QQcmdZViewItem
Sent: Monday, December 12, 2005 3:31 PM
Subject: Re: [Homebrew_PCBs] Re: 1 hour drill press
2005-12-12 by Jim Miller
www.mcmaster.com the place isn't free but you can have more fun than a
barrel of monkeys designing things you'll never build or even building or
(gasp!) using them!
have fun
jim
Pardon the dumb question, but what is a pivoting press?
It sounds like a hinge type of carrier instead of vertical movement.
Sounds scary. I have enough trouble with double sided stuff not lining
up top to bottom.
I still think that with extra thick wooden standoffs on more than one
"large enough" pipe, or more than one at the top and bottom of the
drilling unit, plus a "centered" upward pull, it shouldn't have enough
play to screw up most previously etched holes. I do have a fair amount
of wood tools here, so it may be more of a bitch without them. The
only critical parts are really the two holes that the pipes ride
through, and they would be done with a 1" holesaw or something anyway.
The rest would only have to be screw eyes and junk, and the shapes
could be whatever's easiest. I think with a piloted straight cutter in
a router, I could clone and mass-cut a few standoffs without much
hassle. If you did three of the standoff triangles glued together,
you'd have a full 2.25" of support along the pipes. It doesn't seem
like it could move around that much, but this is for sort of "pre-
piloted" holes.
Again this is "paper theory" and most of us know how that often goes
after it hits earth. ;)  If I can control my compulsive buying habits
for a bit and don't end up with Dremel press, I may try a simple pine
one, to see how it performs. I've got Christmas presents to build, so
if it looks like too much time, it's out.
                              -Take Care
George
                                   -George
I'm glad to have started a few comments..
I think I ought to clarify a few points...
I'm not the first to build this type of pivot drill press, but I
reckon I probably built is faster than most.
The 1 hour pivot press as I showed in the picture is, (apart from
CNC) the best all round way I have found for drilling pcbs..  as
Stefan said, the limited vertical movement required means that the
pivot type is ideal.  I have previously tried all manner of devices
based on off the shelf machines, but none of them can compare to the
speed and accuracy of this concoction.
I will add some more pictures. in a few minutes.
No accuracy is required in construction, I didn't measure anything
The only parts I bought were the plastic pipe clips for the tool
mount.
I really did start from scratch and build this in less than 1 hour,
no plans, no sketches, just a jigsaw (I'm lazy) and a few bits and
bobs
I threw it together, not knowing if it would be successfiul because
my wife wanted to drill some boards and i couldn't afford the
wastage from an unskilled driller  :-)  (I'll probably suffer for
that)
The repeatability of the tool is excellent, and, what is even more
important is that the flexibility of the components means that the
drill bit will find the centre of the etched pad...  in other words,
if you are off by less than 0.5 mm , the bit will centre itself into
the hole!
I have a few minor wrist and shoulder problems, and I can drill 3 or
4 times as many holes with this as I can do on a conventional press
and 10 times as many as I can do by hand. This is due to the foot
operation (heel actually)
If it wasn't so cheap to put together I would think about producing
them for sale!  They are so simple to make, anyone could do it.
The secret is in the fine tuning...  on the main picture, the black
cable that connects to the foot pedal also controls the travel...
underneath is part of a cable terminal block which allows
adjustment. Move the drill bit down to 1mm above the board, slide
the terminal block up and lock in position.
If you are not CNCing boards, and you haven't tried one of these...
it is well worth it...  what have you got to lose!
Of course you can always build it better, but this is a case of just
good enough is plenty good enough!
cheers
Chris  (-=Spiyda=-)
 --- In Homebrew_PCBs@yahoogroups.com, "Chris Horne" <chris@s...>
scan
> about an hour...
drill)
> floor to a 2" x 1")
> back up...
> board.
> quite well.
> Chris
Here are a couple refinements to the kindergarten sketch-
Press-
http://tinyurl.com/98w3p
That candystriped support at the back could be a fat dowel or
whatever, attached to the base to stiffen up the guide bars.
Holders-
http://tinyurl.com/ccpp3
It could maybe be less complicated than that and still work (paper
theory again). The front, drill holding part of the standoffs could
just be pipe clamps or a metal strap. The holders could also maybe be
cut out of a single triangular piece with the drill mount hole already
in it, then you could just saw the front off to get the two pieces.
Also, all the pulley crap could just be large screw eyes.
PS- I've probably spent more time typing and sketching than it might
have taken to make the damn thing. ;)
-George
I forgot to mention that the short length of copper tube is to stop
the spring from wandering off...
All that holds it in place is that it is slipped over a woodscrew that
is screwed down into the baseboard, then the spring is dropped over
that.
Chris  (-=Spiyda=-)
George,
I did some quick maths and on my jury rig, the alignment from one
side of the board to the other will be within 0.01 of a millimetre
at worst, and considering my eyes are only accurate to about 0.25mm
when drilling, I don't think it really comes into the equation.
I have the drill bit sitting about 1 - 2 mm above the board when the
pedal is not pressed, and it projects through the board about 1mm at
full downstroke..  so total travel is only about 5 mm
Chris
 --- In Homebrew_PCBs@yahoogroups.com, "soffee83" <soffee83@y...>
movement.
lining
> up top to bottom.
one
enough
amount
anyway.
cutter in
seem
> piloted" holes.
goes
habits
pine
so
>                               -Take Care
> George
>                                    -George
2005-12-12 by JanRwl@AOL.COM
In a message dated 12/12/2005 3:51:25 P.M. Central Standard Time,
lcdpublishing@... writes:
The  drilling depth (stroke) required for PCBs is less than 1/4" which is
pivot point is back a bit from the tool  center line.<<
Yes, but what IS the distance between the pivot-axis and the  drill-axis?  30
cm?  More?  Anyone "in here" have a source for  fine 400 Hz "capacitor-run"
or three-phase "aircraft instrument" motors that  spin @ 24,000 RPM?  I found
one years back at a "junk shop" that was only  12,000 RPM, but it does PCB
drilling fine.  Hadda build my OWN 400 Hz  source.  Hassle!  But no motor-brushes,
sparks, "buzz",  etc.         Jan Rowland
2005-12-13 by Alan King
  Intersection of two areas of free play that are barely touching is
reasonably close to a point or line.  A couple of cheap ($.88 last time)
hinges from Lowes, slightly misaligned to one another so each excludes
the other's play, works fine.  Even when you use the good drawer rails
for linear motion, it's best to do the same and get rid of most of their
free play..  Got too much free play when aligned exactly parallel, then
don't align them parallel.. :)
Alan
2005-12-13 by soffee83
Chris, just noticed the new pictures and read the descriptions.
Thanks! I wouldn't have guessed any of that stuff from the first
picture.
The extended downward-pull bar and the spring to return upward are
great (and easy). Even if I try a vertical bar thing, I like those.
One other thing I was just thinking about wooden glides on pipes, if
anyone ever has to do such a thing, is that maybe a pair of pipes
would be the tightest fit and hold up much longer. If you could find
two pipes that could telescope, one within the other, like for an old
tripod stand, you could slice a segment out of the larger one and glue
it into a hole in whatever you needed to slide, that way you'd get
metal on metal (the paper theory just keeps on coming). I also do some
fiberglass here. I could maybe just grease up and wrap the "pipe of
choice" a few times to form a nice FG tube. I've had to do that
sliding hole thing a couple times for stuff. I've also used a piece of
thin aluminum pipe and cut a slit along it, so that it could stretch
around a piece of it's same original diameter. Again, the wood holes
did hold up just fine, and the sizes were all standard bit/pipe size.
-George
2005-12-13 by JanRwl@AOL.COM
In a message dated 12/12/2005 5:39:40 P.M. Central Standard Time,
chris@... writes:
because  my wife wanted to drill some boards <<
Wot, she does PCB's?  WOW!  Wanna talk  trade???  LOL!!!
--- In Homebrew_PCBs@yahoogroups.com, JanRwl@A... wrote:
>Hassle!  But no motor-brushes,sparks, "buzz",  etc.
I was meaning to mention that I wasn't looking forward to the
recommended speed change thing.:(
With the press on low speed like it's been, and the belt-cover top
flipped open, it puts off a mild soothing "rumble", which is great for
that tedious million hole stuff. I can't imagine sitting in front of
my B&D router for that. I'm not even sure about that length of "Dremel
time" now that I think about it.
I found three raw 120VAC motors here, but they're gigantic. They're
also a lot slower. I use one in a drum spinning thing I made. Is the
thing you're talking about small enough to mount directly in a
travelling carriage? Is it noisy, and does it take a chuck attachment
directly?
Good point also on the pivot to bit distance and it's "skew" factor.
Not to change the subject, but I was also wondering how bad it is to
sink the bits further up in a chuck to shorten the amount of
unsupported bit material? I fear that jaws gripping the spiralled part
of it is not good. Like everyone's saying though, we really only need
a little more than the board thickness.
                    -George
2005-12-13 by Chris Horne
Well, thats the first measurement on the whole job!
the distance from the drill bit to the hinge is 37 cm
Chris
> lcdpublishing@y... writes:
which is
drill-axis?  30
Hz "capacitor-run"
RPM?  I found
does PCB
no motor-brushes,
George,
If I was building with a big motor, i would make the pcb move up and
down rather than the motor..
its only a few millimetres so i don't think it would affect your
grip on the board
Chris
(ps  i'm kind of known for lateral thinking  :-)
for
of
of "Dremel
They're
> directly?
factor.
to
part
need
>                     -George
No, I don't think I would dare do anything small with these monsters.
They do have an assortment of pulley/drive wheels here, so I guess
they could be geared up faster and maybe the motor could wall mount or
something behind the drill with a belt, but I have no idea how to get
a chuck mounted on a spindle. That's getting way too complicated for
what I need. A cheap second Dremel or generic wouldn't even be bad
just to keep mounted in the harness. I've got that handle/cable thing
with mine too, but I've never tried to use it.
What would anyone guess does have a "quiet" motor for something like
this? I think even my Dremel sounds like a swarm of bees on the higher
settings. It seems risky on motor wear running for the duration of
longer PCB drilling too. Those big motors here are about as quiet as
my press (good).
BTW- Are any of the generic Dremel-press rigs that the home stores are
currently carrying comparable to the legendary older ones.
                                -George
I don't have a dremel, just the minicraft drill
surprisingly it is now over 10 years old, and as well as drilling
100s of thousands of pcb holes, it has drilled over 80 thousand 4mm
holes in steel and plastic about 2.5 mm thick as i used it as part
of a production tool in my previous business.
It seems to be incredibly robust.
I have mentioned before that the proxxon collet chucks are 500%
better than the dremmel ones, i don't know about the motors though.
I have heard it said that the best motors for this application are
the brushless motors used for model aircraft.
However, you need an appropriate motor speed controller to run them.
So for me the price outweighs the noise from the current setup.
Chris-- In Homebrew_PCBs@yahoogroups.com, "soffee83" <soffee83@y...>
and
monsters.
mount or
get
for
thing
like
higher
as
> my press (good).
are
>                                 -George
>my press (good).
  1st, the Walmart generic I have that's grey is better than a stock
dremel, for smoothness and sound level and play in general.  Good for
$18 I paid.
  2nd, brushless helps.  Brushless fan motors are good here, take the
fan off and most are very quiet running.  Need to find one with good
high speed so will have bearings that can handle it, or buy VHQ
replacement bearings for one.  I have several candidates on hand, but so
far the Dremel isn't yet annoying enough to drive me to doing it..
Leave the Dremel on low speed, come back 3X later, your stuff is still
cut/drilled, yet you had far less peak noise..  :)
Alan
My CNC
I have about 8-10 days until my boards get back, which need some
internal routes, so time to get my CNC back up and running and tuned
up.  Since it could stand a clean and some more mechanical fine tuning,
I will deconstruct it and take pictures and measurements and write up a
guide on how to assemble and align it easily and properly.  $75-ish for
the mechanics not including motors and driver, metal in basically all
critical areas, parts all from Lowes, and only takes a drill and the
ability to cut ends off etc, straight lines are from the metal parts not
cuts.  Haven't tweaked it to 100% in all ways, but it's pretty good
already and I think almost anyone could get this built fairly well
without a ton of tools or time.  In fact, I think I'll get going on it
some tonight, should have pictures within the next day or two.
Alan
-snipped-
That's not surprising. I went and looked at Evan's link yesterday and
they had some really nice looking stuff. Some of the "googled"
Minicraft machines I saw looked about like machine shop quality.
Re: [Homebrew_PCBs] My CNC
2005-12-13 by PPC
Wonderful! Where will you post the pic? I'll be interested to see how you do
it.
Can you list the parts you have in this CNC?
Sent: Tuesday, December 13, 2005 10:20 AM
Subject: [Homebrew_PCBs] My CNC
> Alan
> Photos:
>it.
  Well going to write and list things as I go along, so it'll be a day
or two, and sticking it up on my webspace..
Really is:
1  8' x 1.5" x 1.5" aluminium angle rail at around $20.
6 rails at $36.  (3 two packs, and maybe a bit more money by now..)
2 metal electrical boxes at $6-8.
Plastic electrical boxes for motor mounts.
Wood base at about 24" by 18" for the base, and wood plate for the tool
mounting plate.
  Rest is little stuff like nuts and bolts, angle brackets etc.  Main
goal was fairly decent machine without machining either wood or metal,
and almost all metal, so no relying on wood parts for anything
important.  Really I'm sure it could be greatly improved, especially in
the traveling nut to rail connections.  My initial crude hacks just to
get it up and running for test worked well enough that I never even gave
it a proper second look for better common parts at the hardware store
etc.  Couldn't get rebuilding it when it already worked ok for what I
wanted at the time.
  First one takes a few days, after that you could probably build the
second in an afternoon or less.  Once going, I could probably build them
at the rate of 1/hour or faster, thought about selling them on Ebay
myself.  Still might do so even, if I get back into it.  For now though
I have the other products coming, and their price per build time and
leading into other related products demands my attention, even if they
won't sell that fast at first.
  Nothing too much special about the machine, other than the work is
done for how to make it go together and get it aligned.  If I  gave you
the parts with holes etc as pieces, and no instructions, it'd probably
take a week or two for most to rearrange things and get it working, and
have even more trouble making it well.  Several other ways to arrange
the components of course, but most cut down the work area or have other
interference problems.  I've already worked it all out for the most part
over the few weeks it took to get this one ok for use, so you won't have
to reinvent all the wheels.  I've got to get it up and routing, so it'll
be coming shortly.
Alan
2005-12-13 by adicont2
I have 2 ideeas about homemade drill press:
- car shock absorbers: have zero play, and are verry strong. If I use
3 of them in triangle arangement...I think I can make hi precision
component for NASA :-)
- typewriter machine carriage: allmost zero play. I have a old one,
verry abused and still have hi precision.
Adrian
--- In Homebrew_PCBs@yahoogroups.com, "adicont2" <adicont2@y...>
Great, NOW you tell me. ;)
I ripped up a big electric one a while back and just kept the keyboard
and the rubber roller. I do remember bars like that, with zero-play
looking inserts and stuff. Oh well.
-George
2005-12-13 by Stefan Trethan
> up top to bottom.
The tangential movement is so identcal to a linear one for the 2mm or so
travel it does not matter. You need to put the hinges back like 40mm and
you need to set things up so that the tangent is perpendicular to the
board, and everything will work great.
About your wood sliding thingy.
I think wood would have too much friction (if it is tight). Look at metal
presses to see how you could improve on it. If you add a second sliding
block above the first at a distance, and connect the sides of the two via
plates, the play would be greatly reduced. Otherwise the forces exerted by
moving the drill will bind the slider, even if it is relatively thick.
I reckon if you used plastic plates like PE or PP cutting boards or
something, or maybe only line the wood with brass sheet, it could well
work, but it still is definitely more work than a pivoting press.
I still do not think it is a viable idea, but hey, never listen to the nay
sayers ;-)
ST
> $18 I paid.
> Alan
The proxxon IB-E is much less noisy than the other tools i had, but still
quite loud on higher settings.
Brushless is a good idea, after all, brushless motors are not hard to
build.
But i'd need a spindle with collet and bearings where i could fit my motor
onto. I don't have a lathe.....
ST
>                     -George
Since the shaft is usually standard size and thus much wider that'd be
very hard to do.
However, the idea is good. I use a broken bit that did break 2mm down the
spiral part to enlarge/add holes free-hand. It didn't break again so far.
I think they'd last much longer if all bits were that short. I guess the
reason for long bits is many PCB houses drill stacks of boards at once. If
they break, they usually break right where the thin part starts, only good
to re-grind as scribe tips.
Maybe one could strengthen the unused spiral part with epoxy or something?
ST
keyboard
> -George
Sorry for delay ;)
Think about auto shock absorbers. There is some little shock absorbers
for car back door (hatch back), or clasical big ones for weels.
Adrian
be
> very hard to do.
down the
far.
once. If
only good
something?
> ST
Maybe a little steel tube, like a seringe needle and some epoxy in it.
I will try this.
Adrian
On Tue, 13 Dec 2005 15:02:02 +0100, adicont2 <adicont2@...> wrote:
> Sorry for delay
> Adrian
But wouldn't you need to drill a hole or something to let the oil out?
ST
2005-12-13 by Mycroft2152
The auto shock absorbers seem to be a bit of an
overkill. Besides the effort needed to compress them
is very high.
I would suggest a small rubber ball instead. With the
arm length needed for tangental motion, there would be
plenty of room.
Heavy duty rubber pneumatic cushions are in use don
trucks instead of the standard shock absorbers.
Myc
> <soffee83@y...>
> <adicont2@y...>
> just kept the
> keyboard
> > -George
> Sorry for delay ;)
> for weels.
> Adrian
Do You Yahoo!?
http://mail.yahoo.com
out?
> ST
In my knowlege all shock absorbers must have a one way valve inside.
If you remouve this valve and let all oil out you have a allready made
press for drilling.
I don't know if all shock absorbers are dismountable. I have a old one
for car back door and it is. It have no play at all. I mean real zero
play.
Adrian
I refer to those little shock absorbers for car back door, or even
normal ones, but consider a haked shock absorber whithout oil inside.
This whay, the effort needed to compress it is low, and arm lenght can
be adjusted to minimum (something like 300mm).
I don't know nothing about heavy duty rubber pneumatic cushions.
Please, can you give me some details, or a link.
Adrian
--- In Homebrew_PCBs@yahoogroups.com, Mycroft2152 <mycroft2152@y...>
> is very high.
> plenty of room.
> Myc
Re: My CNC
2005-12-13 by Keith Applegarth
I would be interested in seeing it as well.
Keith
--- In Homebrew_PCBs@yahoogroups.com, Alan King <alan@n...> wrote:
how you do
> >it.
day
> Really is:
tool
> mounting plate.
Main
metal,
especially in
just to
even gave
store
what I
> wanted at the time.
build them
Ebay
though
and
they
is
gave you
probably
working, and
arrange
other
most part
won't have
it'll
> be coming shortly.
> Alan
They were made by Goodrich or Firestone and called
something like "air cushions". It's been a while since
I saw the reference.
These were very large and heavy duty, used on the
semi-trailers.
Myc
> door, or even
> and arm lenght can
> pneumatic cushions.
> Adrian
> <mycroft2152@y...>
> them
> > is very high.
> the
> would be
> > plenty of room.
> don
> > Myc
Do You Yahoo!?
On Tue, 13 Dec 2005 17:54:01 +0100, Mycroft2152 <mycroft2152@...>
> semi-trailers.
> Myc
But, how exactly helps that with a drill? i mean wouldn't they wobble
around a bit, break the drills?
I can see how someone would take a shock absorber and modify it into a
short travel linear slide, but i don't see how the air cushions can be
used.
By the way, train carriages here use a similar system of very large
pneumatic cushions for shock dampening - the kind of train you are in
danger of falling asleep and missing your stop because the ride is so
smooth.
ST
>it.
That's what I had thought. I've got aluminum standoff material here. I
don't have much trouble with breaking lately, unless I do something
stupid. I've just never liked the idea of that long "wobbly" section
of exposed bit. BTW- Those diamond burrs I couldn't use are extra
short (like 3/4") and also have a thicker shoulder leading to the
ball. (sort of a shame)
The carbide .033's should be here within the next couple days, and the
speed will be going up. :(
-George
Back to the original 'train' of thought... Not
everyone has a spare valve spring in their workshop.
The rubber ball would replace the spring in a long
lever drill press.
The 'wobble' would be controlled by the type of hinge
used, not the ball or spring.
It seemed that, an auto shock absorber was a clever
use, it was a serious overkill and huge for a simple
driller with a few mm travel. Now if there were some
10 cm shock abosrbers, it would be different.
Myc
> <mycroft2152@...>
> since
> > semi-trailers.
> > Myc
> air cushions can be
> used.
> train you are in
> smooth.
> ST
> Get fast access to your favorite Yahoo! Groups. Make
> Yahoo! your home page
http://us.click.yahoo.com/dpRU5A/wUILAA/yQLSAA/bGYolB/TM
> Links, Files, and Photos:
> them here:
>     Homebrew_PCBs-unsubscribe@yahoogroups.com
Do You Yahoo!?
Thanks Jim. Those would work. About $12 for a small
stroke with 15 lb pressure and the hardware, Not bad.
Now, the question is how to motorize it. Trying to
avoid the standard screw based z axis setup.
Myc
--- Jim Miller <jim@...> wrote:
> they're gas springs. checkout mcmaster.com for
> details.
> jtm
> them here:
Do You Yahoo!?
On Tue, 13 Dec 2005 19:39:37 +0100, Mycroft2152 <mycroft2152@...>
> lever drill press.
> Myc
AH, i see, just to balance the pivoting arm!
I thought (and still do) the car shock absorbers were intended to be used
as linear slides for a non-pivoting type of press.
I don't think it is very difficult to find a spring, and a counterweight
on the back of the arm works well here, but a rubber ball of some sort
would surely work as well. I reckon even rubber bands can be used if some
standoff mechanism is used.
ST
> -George
I was thinking, maybe ferrules or rivets might be a source for small
diameter tubing.
Getting the epoxy in there should not be too difficult, i hope ;-)
but then, i don't break so many, if i make no mistake. And if i make a
mistake it will probably still break.
Let us know if you try it and notice they don't break.
I know a electronics distributor here sold "spade" carbide bits that were
very short. I bet those are harder to break.
ST
On Tue, 13 Dec 2005 20:09:01 +0100, Mycroft2152 <mycroft2152@...>
> Myc
Maybe a air cylinder?
ST
> On Tue, 13 Dec 2005 19:39:37 +0100, Mycroft2152 <mycroft2152@y...>
> > lever drill press.
> > Myc
used
counterweight
sort
some
> ST
My "back door car shock absorber" is a gas spring. You can see it at
http://www.mcmaster.com/
Yes there is some missunderstandings here ;-)
I talk about a linear slides for a non-pivoting type of press. A
absolutly now play one. This is not a 1 hour project, but 2-3 hours...
Take a look here for a simple schematic:
http://tinypic.com/view/?pic=ilfuh1
Adrian
Missed that turn off. :0
I cant see why they wouldn't work as linear slides.
Definitely need to reduce force needed to move them.
Might even consider for x - y use on a small platform
also.
Myc
> <mycroft2152@...>
> workshop.
> > lever drill press.
> hinge
> clever
> simple
> some
> > Myc
> and a counterweight
> ball of some sort
> ST
> them here:
Do You Yahoo!?
Makes sense now.
I see you are using DipTRace. How do you like it? I'm
an old EAGLE user and just started using DipRace.
Myc
> Trethan"
> <mycroft2152@y...>
> workshop.
> long
> > > lever drill press.
> hinge
> clever
> simple
> some
> > > Myc
> were intended to be
> used
> spring, and a
> counterweight
> rubber ball of some
> sort
> some
> > ST
> You can see it at
> of press. A
> Adrian
Do You Yahoo!?
I still think the additional "upper rail support" might be needed to
keep the whole thing vertical and steady, and I like the idea of
fatter posts for those too, so having the posts protrude up through
the carriage pipes might be a necessity. The whole thing could be
short enough that you could just slice a couple sections out of the
larger tube. The small tube would only have to be tall enough to
handle a PCB plus the bit and Dremel nose section. The Dremel itself
could extend up past the whole rig, and you could just stack plywood/
hardboard "shim" plates to get the table height from the base for
different bit lengths.
I just mailed someone who might have car stuff laying around. If she
has something good, I may try it over the next few days. I'm not
really familiar with shock parts, but if that large (1"?) outer tube
I've seen has a tight fit to the smaller one on the main visible body,
it would be perfect (and thanks again for the suggestion).
-George
Some might also be interested in this, although not proven yet.
To speed up my CNC drilling I am experimenting with this item I got
from ebay.
http://photos.groups.yahoo.com/group/homebrew_pcbs/lst?&.dir=/Spiyda
or if that doesn't work,  in the Spiydafolder in the photos section
item ... slide
It is a small pneumatic slide with two cylinders inside.. It both
takes care of the parallel movement and the actuation.
I also got some 24 Volt pneamatic valves from the same guy that I
have had Mach3 switching on and off.
It should not only be faster than the x axis movement but will also
reduce the wear as i didn't take the same care with the z as i did
with the x and y.
Just a case of finding the time to do it !
It was a cheap way to get a small movement axis  at $29 shipped to
me!
Chris
to
through
itself
plywood/
she
tube
body,
> -George
2005-12-14 by adicont2
Is ok.
There is some little bugs, but all bugs reported is rapidly fixed.
I use free version of Deeptrace and there is some limitations, but not
significant ones.
So...for me...is ok.
Adrian
wrote:
> Makes sense now.
> Myc
The design can be inprouved, take a look
http://tinypic.com/view/?pic=im1i7l
There is 2 big problems here:
- strong and right connection between base and absorbers
- strong and right connection between both absorbers and drill suport
Idealy, this connections must be all metall and welded.
Next days I will try to imagine a "in house" strong connection (I
don't have a welding machine).
Adrian
plywood/
body,
> -George
