On Jan 12, 2010, at 4:44 PM, WT wrote:
> Yeah, the SMPTE is only trigger of start time. No true tempo-mapping.
> Cool, thanks for the help !
> WT
> From: "Tim Curtis" <sexsymbol@execpc.com>
> To: <Fairlight-CMI@yahoogroups.com>
> Sent: Tuesday, January 12, 2010 11:35 PM
> Subject: Re: [Fairlight-CMI] Re: Syncing a IIx
> Glad that you got it to work.
> As for the SMPTE sync, that was never implemented at all. IIRC, it
> will trigger off SMPTE, but then it just free runs.
> I think that they were planning on implementing it in a later
> revision, but them they decided to build the Series III instead.
> -T
> On Jan 12, 2010, at 4:22 PM, WT wrote:
> > Hi Tim ( and everybody else ),
> > I can happily report that my IIx is now in sync with the rest of the
> > world.
> > Indeed, one uses the Sync-connector on the mainframe. It has dual
> > functions,
> > Sync In on Pin 2, Metronome Click Out on Pin 3, with a common ground
> > on Pin
> > 1.
> > One must apply 384 PPQ ( 1536 pulses per bar ). I tested it with
> > both a
> > Garfield Masterbeat and a Friendchip SRC.
> > Seems a shame if the Multi Sync out and Din-sync out on the Midibox
> > never
> > was implemented.....kind of hard to use the IIx as a SMPTE slave/
> sync
> > provider for other gear.
> > Looking at the service documents, I can´treally decipher from where
> > the
> > 68A40´s get the sync input. Ah well.....guess I´ll look into that
> > another
> > time.
> > WT
> > Sent: Tuesday, January 12, 2010 4:25 AM
> > As I recall, the sync input in the General Interface box was never
> > implemented. (It's been a while since I've checked it out, but I
> > believe that this is the case. I'll be inside the CMI soon, so I can
> > verify this)
> > You sync the IIx by using a 384 PPQ sync into the sync input on the
> > back of the mainframe, in the row along the bottom.
> > You will need to make a custom cable for this. Going by memory, the
> > IIx (as well as the I and II) use that jack for both input and
> > output. One is to pin 2, one is to pin 3, and they share a common
> > ground to pin 1. The manual has this diagram in the back)
> > This works for Page R. For Page 9 and for MCL you will have
> different
> > clock rates.
> > -Tim
> > On Jan 11, 2010, at 5:09 PM, WT wrote:
> >> Hi Billy !
> >> Thanks for the answer.
> >> The IIx unfortunately doesn´t sync to Midi.
> >> The manuals that I have for the General Interface card doesn´t go
> >> into
> >> detail about how to sync the IIx.
> >> What I like to do is feed clocks ( 384 ppq as I can decipher from
> >> various
> >> sources ) into the CMI IIx.
> >> But should I connect it to the Midi box Sync input with a cable
> from
> >> the
> >> Midi box clock out to the CMI sync input or
> >> should I only connect to the Midi Box or
> >> should I only connect to the CMI Sync input.
> >> That´s the question.
> >> Hmmm.....
> >> Maybe I should solder some adapters.
> >> WT
> >> From: "Bill" <billyrockplay@yahoo.com>
> >> Sent: Monday, January 11, 2010 11:41 PM
> >> Subject: [Fairlight-CMI] Re: Syncing a IIx
> >> In the past - we would record a track of sync tone and then feed it
> >> back to
> >> the Fairlight (IIx) to sync the Fairlight to tape. I never ttried
> >> synching
> >> with midi though i would assume this can be done on the IIx. I sync
> >> with
> >> SMPTE now on a series III.
> >> good luck.
> >> billyrock
> >> --- In Fairlight-CMI@yahoogroups.com, "WT" <waveterm@...> wrote:
> >>> Bump !
> >>> No one ?
> >>> WT
> >>> From: "WT" <waveterm@...>
> >>> Sent: Sunday, January 03, 2010 2:03 AM
> >>> Subject: [Fairlight-CMI] Syncing a IIx
> >>>> So....I´ve made my masterpiece of music using Page R and want to
> >> sync it
> >>>> to
> >>>> an external clock source.
> >>>> Where do I connect my syncsource ?
> >>>> To the CMI XLR Sync connector or,
> >>>> to the 3-pin DIN connector on the General Interface box ?
> >>>> And/or should I make a special cable that goes from the General
> >>>> Interface
> >>>> Box Sync Out ( 4 ) to the CMI XLR Sync input ?
> >>>> WT
> > Yahoo! Groups Links
