Doepfer
A-113
A-113
2016-04-28 by Alexander Wassermann
Hi group,
I haven't used my sub harmonic oscillator for some time but reinstalled it recently, albeit without success. First I thought I had an issue with the 5 V but that was not the problem. I just cannot get any sound out of the single or mix output, no matter what I feed into the input and which divider settings I use. If I crank the volume up I can barely hear some oscillation sound, also the effect of altering the divisions but always with one stable frequency dominating (again, no matter what the input frequency identification, or what the divider settings are).
Any ideas or should I send the module in for inspection?
Best regards,
Alex
Von meinem iPad gesendet
Re: [Doepfer_a100] A-113
2016-04-28 by Jacco Ville
Hello Alex,
First thing in mind....
 did you check all the (ribbon)connections?
Jacco
Verstuurd vanaf mijn iPhone 5 Black OPS Edition
> Op 28 apr. 2016 om 18:35 heeft Alexander Wassermann aua130@yahoo.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> het volgende geschreven:
> Hi group,
> Best regards,
> Alex
2016-04-29 by Alexander Wassermann
Yes, always one of the first checks (and actually one of the only ones I can perform - I have no DIY ambitions or skills).
BR,
Alex
> Am 28.04.2016 um 21:09 schrieb Jacco Ville jaccoville@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com>:
> Hello Alex,
> Jacco
>> Hi group,
>> Best regards,
>> Alex
AW: [Doepfer_a100] A-113
2016-04-29 by yahoo@doepfer.de
> Hi group,
> Best regards,
> Alex
Sorry for the troubles with the module. If the +5V are OK the module has to be repaired (but only the old version of the module with
16 pin bus connector required the +5V). For details please refer to the repair notes on the FAQ page of our website.
Maybe the processor is defective (but that's only a guess). But in this case the display and the buttons would not work anymore. If
the display and the buttons are still working it's another fault.
Best wishes
Dieter Doepfer
Re: AW: [Doepfer_a100] A-113
2016-04-30 by Alexander Wassermann
OK, Danke Dieter.
Dann bringe ich das Modul nach Gräfelfing, ich wohne nicht weit weg.
BG,
Alex
> Am 29.04.2016 um 10:08 schrieb yahoo@doepfer.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com>:
> > Hi group,
> > Best regards,
> > Alex
> Best wishes
> Dieter Doepfer
2016-04-30 by Bakis Sirros
the official language of this group is English.
thank you,Bakis.
      From: "Alexander Wassermann aua130@yahoo.de [Doepfer_a100]" <Doepfer_a100@yahoogroups.com>
 To: Doepfer_a100@yahoogroups.com
 Sent: Saturday, April 30, 2016 8:12 AM
 Subject: Re: AW: [Doepfer_a100] A-113
    OK, Danke Dieter.
BG,Alex
    > Hi group,
> Best regards,
> Alex
Best wishes
Dieter Doepfer
Yes of course, how could I forget. Just seemed to be a nice touch. I will officially refrain from doing something German in this forum again ;-)))
Happy weekend
> Am 30.04.2016 um 08:35 schrieb Bakis Sirros synth_freak_2000@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com>:
> thank you,
> Bakis.
> OK, Danke Dieter.
> BG,
> Alex
>> > Hi group,
>> > Best regards,
>> > Alex
>> Best wishes
>> Dieter Doepfer
2016-04-30 by Jacco Ville
Hahaha... LOL
...." Don't mention the war"... (John Cleese)
Cheers
Jacco
> Op 30 apr. 2016 om 08:35 heeft Bakis Sirros synth_freak_2000@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> het volgende geschreven:
> thank you,
> Bakis.
> OK, Danke Dieter.
> BG,
> Alex
>> > Hi group,
>> > Best regards,
>> > Alex
>> Best wishes
>> Dieter Doepfer
