Digital BW, The Print
Re: [Digital BW] Windows XP / Epson 1160 printer driver
2003-09-23 by Bob Frost
David,
Are you selecting the Epson 1160 printer driver (rather than the XP 1160
version) in the Printer box? There should be two 1160 printers showing up,
and you need to select the correct one. If that is OK, what about the Epson
Status Monitor? Is that installed properly?
Bob Frost.
> I can install the Epson XP drivers for the printer, and receive a
> confirmation message that they have been correctly installed. Within
> Photoshop, the dialogue with the printer driver appears normal, and
> follows the same process as before. However, printing fails, because
> of a "communication error". I think what is happening is that Windows
> XP wants to use its own "plug and play" driver, which will work, but
> not at the resolution that I am looking for (1400 dpi). Consequently
> I think I end up with a conflict between the Epson and the Windows
> driver, leading to an apparent communiction problem with the printer.
> I do not know how to resolve this - can anyone help me? I have tried
> all sorts of things - both USB and parallel port connections, and
> reloaded the drivers several times - so far without success and am
> feeling increasingly desperate!
2003-09-23 by djhedley
Bob,
I'm selecting the Epson 1160 driver, rather than the generic XP
driver. I have installed both the driver and the status monitor that
are available on the Epson site. However, I do not get a reading of
the ink levels in the print dialogue boxes. Apart from this, the
print dialogue is the same as before (i.e. I can establish a series
of profiles under the "advanced" tab, depending on how I want to
print). However, when I try to print, I get a "comunication error",
which seems to be pointing to a cable problem - but I don't think
that there is a problem with the cable, as I have treid both USB and
parallel port connections, and end up with the same problem.
Regards
David
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Bob Frost"
<bobfrost@b...> wrote:
> David,
1160
showing up,
the Epson
> Bob Frost.
> From: "djhedley" <djhedley@y...>
Within
and
because
Windows
but
Consequently
printer.
tried
2003-09-23 by wharfwalker
Is your printer attached to a local network? I get this exact problem
printing from XP Pro to a 1290 on another computer BUT I just ignore
it, even though the message Coms Error comes up I can see disc
activity on the other machine so I just leave it and the print
prints - no status of ink levels though. Certainly no cable problems.
I hope it helps.
John
2003-09-24 by djhedley
John,
It's not on a network - it's just stand-alone. I do seem to be able
to print now, albeit that it takes much longer than before (the file
size is about 250MB from a 4x5 negative), but I still get hte
communication error message.
David
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "wharfwalker"
problem
ignore
problems.
> I hope it helps.
> John
2003-09-25 by Barry Kelsall
This sounds like you haven't loaded the chipset drivers for your
motherboard. Your hardware (USB, etc.) will not work properly without the
correct drivers. NT 5.1 (Win XP) is very fussy that way...
-BK
To: <DigitalBlackandWhiteThePrint@yahoogroups.com>
Sent: Tuesday, September 23, 2003 3:01 AM
Subject: Re: [Digital BW] Windows XP / Epson 1160 printer driver
> Bob,
> Regards
> David
> > David,
> 1160
> showing up,
> the Epson
> > Bob Frost.
> Within
> and
> because
> Windows
> but
> Consequently
> printer.
> tried
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and
other resources as they are often being updated. The page is at:
> http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
> If you wish to receive no emails or just a daily digest, or you wish to
unsubscribe, please edit your Membership preferences by visiting this same
page.
> Please follow these basic guidelines:
> - Include your full name with your message.
> - Include the address of your website, if you have one.
> - As threads develop, trim off excess portions of earlier messages to keep
them short.
> - As the topic of a thread changes remember to change the subject header.
> - Good manners are required at all time. No personal attacks or flames
> - Complete your Yahoo profile.
> - Before posting a question, search the message archives and the various
resources on the homepage.
2003-09-25 by djhedley
Barry,
Please excuse my ignorance, but what is a motherboard chipset driver,
and where can I locate what I need to install?
David
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Barry Kelsall"
without the
> -BK
> > Bob,
that
of
series
error",
and
> > Regards
> > David
> > > David,
the XP
> > 1160
> > showing up,
about
> > the Epson
> > > Bob Frost.
receive a
> > Within
normal,
> > and
> > because
> > Windows
work,
> > but
> > Consequently
Windows
> > printer.
> > tried
and
and am
Polls and
wish to
this same
> page.
messages to keep
> them short.
header.
flames
various
2003-09-25 by Bob Frost
David,
If yours is an motherboard with an Intel chipset, then you simply go to
Intel's website and download the latest driver for your board. If it is not
Intel, then someone else will have to answer!
Bob Frost.
> Barry,
2003-09-26 by djhedley
Thanks, Bob, but after several days of frustration bordering on
desperation, I have just uninstalled XP to return to ME, and
everything is now working fine - I have just run off a few of my
favourite prints in celebration.
Cheers
David
> David,
is not
> Bob Frost.
> > Barry,
2003-09-27 by Barry Kelsall
This is why I like to build my own boxes - I know exactly what is in them. I
have an Asus P4PE motherboard that uses the Intel 845 PE chipset. It came
with a CD that contained all the necessary drivers for my OS, NT 5.0
(Win2K). It also contains utilities for obtaining updates automatically over
the Internet from Asus.com.
You need to contact the manufacturer of your computer to find out how &
where to get drivers. You may have documentation that could help you. You
might even have that magical CD. But if your hardware was manufactured
before the release of XP, that CD is useless.
I also strongly recommend that you do not *upgrade* to XP; instead do a
clean install. It is a pain to have to start over & re-install all of your
software, but you will have a more stable system for it. In fact, I would
buy a new hard disk, & format it using NTFS & have your new system live on
it. FAT32 & FAT16 are the source of many of Windows instabilities.
Good luck, David. The journey you have embarked upon is not trivial, but
once successfully completed, you will have a solid OS.
-BK
Sent: Thursday, September 25, 2003 3:49 AM
> Barry,
> Thanks
> David
> without the
> > -BK
