Digital BW, The Print
Ink leaking out
Ink leaking out
2015-07-01 by Bharat Patel
HI,
I had leak problems with my Epson 1400 and MIS inks. I replace the printer and also the cartridges but problem continued. Then it dawn on me that I must be doing something wrong while filling the cartridges. Though it is important how to refill cartriges there is not enough emphasis on adhering to the process and one (someone like myself) tend to cut corners. With some trial and error I have managed to stop the leaks. So here is the process I use. It is important to follow the process.
1. Leave the rubber bung on the air-vent in and fill ink through the refill hole.2. Fill slowly to the top until there is only some space left. Try to avoid making bubble but there will be some anyway.3. Leave the cartridge upright for a while and tap it to ensure there no bubbles trapped in the ink.4. Put the refill hole rubber bung back in its place. Make sure this rubber bung fits tightly so that it does not let any air in.5. Push a syringe with a plastic adaptor (one which is for sucking out ink from the cartridge) into the cartridge hole which will sit on the tray and suck out a few drops of the ink. I is important that the refill hole and air-vent have the rubber bungs in them when you do this. This will create a small pressure in the cartridge.7. Cartridge preparation is ready. Now push the cartridge in its position on the tray.8. Now and only now remove the air-vent bung.
I am not sure why but this seems to do the trick!
Just thought I will pass this on.
Bharat
Re: Ink leaking out
2015-07-02 by jeff.grant@...
Thanks Bharat,
That's excellent info and different to what I was doing. Have you used different carts with this method?
Cheers,
Jeff
Re: [Digital BW] Ink leaking out
2015-07-02 by Jeff Grant
Hi Bharat,
Do you do the same for refilling carts? I have just been looking at the IJM site and they say to leave the air vent open when refilling, and make no mention of the syringe either for filling or refilling.
Cheers,
Jeff
www.jeff-grant.com
Facebook: Jeff Grant Landscape Photographer
On 1 Jul 2015, at 10:29 pm, Bharat Patel yoursnaps@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
> HI,
> Bharat
Re: Ink leaking out
2015-07-02 by paulmwhiting@...
Hello Jeff,
Please tell me what IJM stands for... sounds like a site I should get to know!
Thanks!
Paul
Re: Ink leaking out
Hello Paul,
IJM is InkjetMall which is the retail and support site for Jon Cone's Piezography ink sets. It is a bit of an archaeological dig but there are some real gems hidden in there inkjetmall Forums.
PiezoPress
is the Piezography site, also with lots of good info. It's well worth a look whether you are interested in his products or not.
Re: Ink leaking out
2015-07-04 by paulmwhiting@...
Thanks, Jeff.
Of course! InkjetMall, why didn't I think of that. I know that site and have ordered empty refillable carts from them for my 1400. I first started refilling carts using supplies from MIS for my R1800 and they do recommend the adapter on a syringe to withdraw about 1cc of ink, and then insert the refill plug. The idea apparently was to create a slight vacuum in the cart and prevent leakage. The air vent remains open..
When I bought some carts from IJM on the other hand, their instructions do not mention withdrawing ink from the bottom of the cart.
I've not had leakage from either method. Hard to know who to believe! I tend to think withdrawing that 1cc is probably the best approach. Any leakage I've had (and I have had that happen) I attribute to worn out seals in the refill port on the bottom - then it's time for a new cartridge.
My $0.02,
Paul
Re: [Digital BW] Re: Ink leaking out
2015-07-04 by Dr. Elliot Puritz
If I recall correctly, IJM recommends replacing carts after about a year. If one buys OEM carts and inks then obviously the carts are replaced every time one buys new inks. So replacing refillable carts periodically seems very reasonable.
Elliot
> On Jul 4, 2015, at 3:56 PM, paulmwhiting@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
> Thanks, Jeff.
> My $0.02,
> Paul
2015-07-04 by Jeff Grant
I just don't understand how I could have had 4 sets of carts that all leaked or let in air. I guess that it points to the printer or operator error. I really want a printer that I can hibernate or easily swap inks so I'm thinking that another 1430 is the way to go. The printers with ink lines are just too expensive to run that way. Epson has done us no favours with the current printer selection.
I could look for a used printer but a quick perusal of the IJM forum, and my own experience with an old 2400 lead me to believe that new is the way to go with 3rd party inks.
Cheers,
Jeff
www.jeff-grant.com
On 5 Jul 2015, at 9:17 am, 'Dr. Elliot Puritz' drpuritz@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
> Elliot
> Sent from my iPhone
>> Thanks, Jeff.
>> My $0.02,
>> Paul
2015-07-05 by Dr. Elliot Puritz
You are correct Jeff. Swapping inks on the 1430 is very easily done.
I would strongly suggest that if you buy another 1430 that you  consider buying an extra set of carts and filling the carts with a flush solution of some kind. When changing from one ink set to another it is a simple matter to facilitate the change by removing one set of carts,inserting the other set with the cleaning solution and running several cleaning cycles, and then installing the new set of carts with a different ink set.  In addition when hibernating the printer it is a good idea to remove the carts with the current ink set and store the printer with the carts having the flush solution.
Elliot
> On Jul 4, 2015, at 4:37 PM, Jeff Grant jeff.grant@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
> Cheers,
> Jeff
> www.jeff-grant.com
>> Elliot
>> Sent from my iPhone
>>> Thanks, Jeff.
>>> My $0.02,
>>> Paul
2015-07-05 by paulmwhiting@...
Elliot, I agree with you (and IJM) on annual replacement... sometimes I'm too cheap, and then suffer expensive consequences. Thanks for that reminder!
Paul
2015-07-06 by jeff.grant@...
I've just ordered another 1430. I'm reminded of that old saying about madness being the doing of the same thing and expecting different results. I'll report back. I have ordered a set of carts from HK and two sets of IJM Easyfills.
2015-07-06 by Jeff Grant
Hong Kong, I must learn to stop talking in abbreviations.
Cheers,
Jeff
www.jeff-grant.com
On 6 Jul 2015, at 10:15 pm, paulmwhiting@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
> Um, sorry, but what's "HK"?
> Paul
2015-07-06 by Dr. Elliot Puritz
OK....Let's solve the problems... Before changing any carts would you mind printing 10 pages with the color inks?
> On Jul 5, 2015, at 10:08 PM, jeff.grant@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
Do you have the flush solution that is available from MIS, IJM, and others?
You will need to have one set of carts dedicated to the flush Jeff.
After printing the color sheets one will be sure that the printer is working.  Remove the color carts and then put in the the carts with the flush/cleaning solution; run several cleaning cycles.
Insert the properly filled carts with the black and white inks, print a few nozzle checks, print an image, and let us know the results...
Elliot
> On Jul 6, 2015, at 7:49 AM, 'Dr. Elliot Puritz' drpuritz@... [DigitalBlackandWhiteThePrint] <DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
> Sent from my iPhone
2015-07-07 by jeff.grant@...
Thanks Elliot,
I have plenty of flush, in fact, I have another 700ml bottle on the way so I can hibernate my 3880 when I'm away. With the 3880, I never put the colour carts in it. My reasoning is that I have never had an issue with any Epson printer at delivery. However, getting rid of yellow is hard work.
My plan is to put a set of carts with Piezography ink in on the basis that it should work. If there is an issue with the carts leaking or not getting a good nozzle check, I'll try another set with flush.
I'm only planning on putting the Epson carts in if I encounter any issues. I started my 3880 this way and it worked very well. I now have a new set of colour carts to use in my other 3880.
I may be crazy but it occurs to me the highest probability is that my first 1430 was the issue.
Cheers,
Jeff
2015-07-31 by jeff.grant@...
Reporting back on the new 1430, and refillables, I started off with a set of Auatralian MIR refillabes with Piezoflush. Once they looked OK, I loaded a set of normal carts from Hong Kong. I could not get the magenta cart to maintain a good nozzle check. Cyan was occasionally off too. After a few days,I loaded a set of IJM carts, swapped the chips, and put them in. After the normal fiddling with purge patterns and nozzle checks, they came clean, and have been so for a couple of days. I have seen no sign of leaking along the way in any of the carts.
I don't know what this all means, I suspect that my first 1430 was a dud in some way for Piezography inks. The new 1430 still doesn't seem to like standard carts but is working with the new two part ones.
I'm eternally grateful to Richard Boutwell for pointing me towards the two part carts. Getting this solution to work was important to me, and it's now looking good.
Cheers,
Jeff
2015-08-01 by richard@...
Jeff, I'm happy to hear that you got the new kit working for you.
Here is something to be aware of with the EZ Fill Capsules: The air pressure inside the cart can built up somehow, causing the ink to push up into the real vent area and saturate the cotton filter at the top. I am not sure if this is from temperature changes here or what, but I had this happen last week and ink leaked onto a nice 13x19 print... I just stuck a push pin into the vent hole of the offending insert to make sure it was cleared out and cleaned the outside of the cart and capsule. That seemed to solve it and there haven't been any issues with subsequent prints.
Richard Boutwell
2015-08-01 by jeff.grant@...
Richard, thanks. All helpful hints are very welcome. I had one cart get the air vent full of ink while loading with a subsequent spill, but it still worked afterwards. The HK supplier is replacing two of my normal carts so I'll try that set again. My inclination is to stick with easy fills from now on.
