Settings for Pintech AX14S Snare
2003-01-02 by dennisw562003 <dennisw56@insightbb.com>
I have added the AX14 snare to my DTXpress. Can anyone help me out with the DTXpress settings for the new snare. I only get sound when the head is hit directly in the middle. I also learned talking to Pintech, to get the snare and rim sound a Y1 splitter must be used with the head mono connected to the snare and the rim mono connected to 9/10. Thanks, Dennis
2003-01-02 by liberatusvirus <liberatusvirus@yahoo.com>
Hi Dennis, Scott just got one of these, too. Maybe he'll have another story. I have noticed a hot spot in the middle of the AX14S under the trigger; it's unavoidable. But you can work around it. What I did is change the type of pad for input 2 from TP snare to DT snare. My global trigger setting is DT 10/20 (medium is the default). Because the AX14S is on a separate stand, you don't have to worry about crosstalk. I have rejection and specific rejection at zero and self- rejection at 1 or 2, depending on which way the wind blows. My gain is usually high, in the 90s, and my minimum velocity at rock bottom. One more component to this ultra-hot setup is to flip the DIP switch corresponding to input 2 at the back of the module to the up position. You'll need a tiny screwdriver or needle to do it, unless you've got great finger nails. The result should be good sensitivity all around the drum, from center to rim, almost as though the module were capable of positional sensing. Although I cannot claim perfection for this method (I've had an inexplicable dropout or two), it generally works pretty well. Pressed rolls near the tension rods were unthinkable with the standard gum rubber, or even the otherwise wonderful Pintech ConcertCasts. But now they're pretty accurate--not to say that tweaking is a thing of the past. It goes on forever. Ed --- In DTXpress@yahoogroups.com, "dennisw562003 <dennisw56@i...>" <dennisw56@i...> wrote: > I have added the AX14 snare to my DTXpress. Can anyone help me out > with the DTXpress settings for the new snare. > > I only get sound when the head is hit directly in the middle. > > I also learned talking to Pintech, to get the snare and rim sound a
> Y1 splitter must be used with the head mono connected to the snare > and the rim mono connected to 9/10. > > Thanks, Dennis
2003-01-02 by hairytrigger <artifax@internetcds.com>
Hey, Dennis My story is about the same as Ed's. But I have the switch in back low, and gain around 60. I'm still experimenting. Great response though. I am going to try Ed's settings. Nothing to lose, and maybe lots to gain.. About your no trigger at all near the rim... Did you tension the head after you got it? Pintech says it needs a full turn on each rod.I think mine was more like three. This can make a huge difference in response.The tighter the head, the less noticeable the hot spot is, also. The only 'dropouts I've noticed is when I do a "pressroll/flam". I don't know what it is really called, but when you do a short pressroll with the right hand followed immediately by a shot with the left.Anyway, if I don't end that pressroll part soon enough, the left-hand-shot doesn't trigger.I've had to modify my playing a bit to ensure it is heard. Or worse, play it properly, with both hands doing the roll (R-L-R-L) with the last L played hard. It's all played in the time it takes to play a flam. I don't know why the last one drops out. My rejection settings are all '0'. This problem caused me to set up a kit with my extra pad as a second indetical snare. The drums in the Door's 'Love Me Two Times' is played as a snare shuffle, with flams on the 2 and 4.Some of my 2's and 4's were dropping out, so I set up the other pad as snare, and played it as though it were the HiHat. Problem solved. I hope all this makes sense...And I hope it helps!!! Good luck Scott --- In DTXpress@yahoogroups.com, "liberatusvirus <liberatusvirus@y...>" <liberatusvirus@y...> wrote:
> Hi Dennis, > > Scott just got one of these, too. Maybe he'll have another story. I > have noticed a hot spot in the middle of the AX14S under the > trigger; it's unavoidable. But you can work around it. What I did is > change the type of pad for input 2 from TP snare to DT snare. My > global trigger setting is DT 10/20 (medium is the default). Because > the AX14S is on a separate stand, you don't have to worry about > crosstalk. I have rejection and specific rejection at zero and self- > rejection at 1 or 2, depending on which way the wind blows. My gain > is usually high, in the 90s, and my minimum velocity at rock bottom. > One more component to this ultra-hot setup is to flip the DIP switch > corresponding to input 2 at the back of the module to the up > position. You'll need a tiny screwdriver or needle to do it, unless > you've got great finger nails. The result should be good sensitivity > all around the drum, from center to rim, almost as though the module > were capable of positional sensing. Although I cannot claim > perfection for this method (I've had an inexplicable dropout or > two), it generally works pretty well. Pressed rolls near the tension > rods were unthinkable with the standard gum rubber, or even the > otherwise wonderful Pintech ConcertCasts. But now they're pretty > accurate--not to say that tweaking is a thing of the past. It goes > on forever. > > Ed > > --- In DTXpress@yahoogroups.com, "dennisw562003 <dennisw56@i...>" > <dennisw56@i...> wrote: > > I have added the AX14 snare to my DTXpress. Can anyone help me out > > with the DTXpress settings for the new snare. > > > > I only get sound when the head is hit directly in the middle. > > > > I also learned talking to Pintech, to get the snare and rim sound > a > > Y1 splitter must be used with the head mono connected to the snare > > and the rim mono connected to 9/10. > > > > Thanks, Dennis
This is just a test. I just posted and it does not come up. It was a long one and I hope I don't have to post again. Scott --- In DTXpress@yahoogroups.com, "liberatusvirus <liberatusvirus@y...>" <liberatusvirus@y...> wrote:
Scott, If your self-rejection setting is at 0, and you're still getting dropouts when you buzz with one hand and try a whack with the other, the trigger or trigger/module may be masking itself when the transition is too abrupt and dynamic. (I seem to recall something like that to be an artifact of piezos but not FSRs, but don't quote me). But raising sensitivity can cover a multitude of sins. I'm curious to learn what flipping the DIP and raising the gain will do in your case. The result may not necessarily be compatible with your playing style or voicings. By the way, I think that my sporadic dropouts have a similar pattern. Thanks for doing a better analysis of them. One caution when tightening heads on electronic drums: you can strip the rods. Take it from me. I tighten like mad and have had to change rods and lugs on two different drums. Moderation is the key. But then again, everybody is probably more intelligent about it than I am. Ed --- In DTXpress@yahoogroups.com, "hairytrigger <artifax@i...>" <artifax@i...> wrote: > Hey, Dennis > My story is about the same as Ed's. But I have the switch in back low, > and gain around 60. I'm still experimenting. Great response though. I > am going to try Ed's settings. Nothing to lose, and maybe lots to > gain.. About your no trigger at all near the rim... Did you tension > the head after you got it? Pintech says it needs a full turn on each > rod.I think mine was more like three. This can make a huge difference > in response.The tighter the head, the less noticeable the hot spot is, > also. > The only 'dropouts I've noticed is when I do a "pressroll/flam". > I don't know what it is really called, but when you do a short > pressroll with the right hand followed immediately by a shot with the > left.Anyway, if I don't end that pressroll part soon enough, the > left-hand-shot doesn't trigger.I've had to modify my playing a bit to > ensure it is heard. Or worse, play it properly, with both hands doing > the roll (R-L-R-L) with the last L played hard. It's all played in the > time it takes to play a flam. I don't know why the last one drops out. > My rejection settings are all '0'. > This problem caused me to set up a kit with my extra pad as a second > indetical snare. The drums in the Door's 'Love Me Two Times' is played > as a snare shuffle, with flams on the 2 and 4.Some of my 2's and 4's > were dropping out, so I set up the other pad as snare, and played it > as though it were the HiHat. Problem solved. I hope all this makes > sense...And I hope it helps!!! > > Good luck > > Scott > > --- In DTXpress@yahoogroups.com, "liberatusvirus > <liberatusvirus@y...>" <liberatusvirus@y...> wrote: > > Hi Dennis, > > > > Scott just got one of these, too. Maybe he'll have another story. I > > have noticed a hot spot in the middle of the AX14S under the > > trigger; it's unavoidable. But you can work around it. What I did is > > change the type of pad for input 2 from TP snare to DT snare. My > > global trigger setting is DT 10/20 (medium is the default). Because > > the AX14S is on a separate stand, you don't have to worry about > > crosstalk. I have rejection and specific rejection at zero and self- > > rejection at 1 or 2, depending on which way the wind blows. My gain > > is usually high, in the 90s, and my minimum velocity at rock bottom. > > One more component to this ultra-hot setup is to flip the DIP switch > > corresponding to input 2 at the back of the module to the up > > position. You'll need a tiny screwdriver or needle to do it, unless > > you've got great finger nails. The result should be good sensitivity > > all around the drum, from center to rim, almost as though the module > > were capable of positional sensing. Although I cannot claim > > perfection for this method (I've had an inexplicable dropout or > > two), it generally works pretty well. Pressed rolls near the tension > > rods were unthinkable with the standard gum rubber, or even the > > otherwise wonderful Pintech ConcertCasts. But now they're pretty > > accurate--not to say that tweaking is a thing of the past. It goes > > on forever. > > > > Ed > > > > --- In DTXpress@yahoogroups.com, "dennisw562003 <dennisw56@i...>" > > <dennisw56@i...> wrote: > > > I have added the AX14 snare to my DTXpress. Can anyone help me out > > > with the DTXpress settings for the new snare. > > > > > > I only get sound when the head is hit directly in the middle. > > > > > > I also learned talking to Pintech, to get the snare and rim sound > > a > > > Y1 splitter must be used with the head mono connected to the snare
> > > and the rim mono connected to 9/10. > > > > > > Thanks, Dennis
2003-01-03 by hairytrigger <artifax@internetcds.com>
Thanks, Ed. I will try raising the gain and flipping the switch. I hope I haven't tightened the head beyond reason. Just trying to get it to feel good! Scott --- In DTXpress@yahoogroups.com, "liberatusvirus <liberatusvirus@y...>" <liberatusvirus@y...> wrote:
> Scott, > > If your self-rejection setting is at 0, and you're still getting > dropouts when you buzz with one hand and try a whack with the other, > the trigger or trigger/module may be masking itself when the > transition is too abrupt and dynamic. (I seem to recall something > like that to be an artifact of piezos but not FSRs, but don't quote > me). But raising sensitivity can cover a multitude of sins. I'm > curious to learn what flipping the DIP and raising the gain will do > in your case. The result may not necessarily be compatible with your > playing style or voicings. By the way, I think that my sporadic > dropouts have a similar pattern. Thanks for doing a better analysis > of them. One caution when tightening heads on electronic drums: you > can strip the rods. Take it from me. I tighten like mad and have had > to change rods and lugs on two different drums. Moderation is the > key. But then again, everybody is probably more intelligent about it > than I am. > > Ed > > > --- In DTXpress@yahoogroups.com, "hairytrigger <artifax@i...>" > <artifax@i...> wrote: > > Hey, Dennis > > My story is about the same as Ed's. But I have the switch in back > low, > > and gain around 60. I'm still experimenting. Great response > though. I > > am going to try Ed's settings. Nothing to lose, and maybe lots to > > gain.. About your no trigger at all near the rim... Did you > tension > > the head after you got it? Pintech says it needs a full turn on > each > > rod.I think mine was more like three. This can make a huge > difference > > in response.The tighter the head, the less noticeable the hot spot > is, > > also. > > The only 'dropouts I've noticed is when I do a "pressroll/flam". > > I don't know what it is really called, but when you do a short > > pressroll with the right hand followed immediately by a shot with > the > > left.Anyway, if I don't end that pressroll part soon enough, the > > left-hand-shot doesn't trigger.I've had to modify my playing a bit > to > > ensure it is heard. Or worse, play it properly, with both hands > doing > > the roll (R-L-R-L) with the last L played hard. It's all played in > the > > time it takes to play a flam. I don't know why the last one drops > out. > > My rejection settings are all '0'. > > This problem caused me to set up a kit with my extra pad as a > second > > indetical snare. The drums in the Door's 'Love Me Two Times' is > played > > as a snare shuffle, with flams on the 2 and 4.Some of my 2's and > 4's > > were dropping out, so I set up the other pad as snare, and played > it > > as though it were the HiHat. Problem solved. I hope all this makes > > sense...And I hope it helps!!! > > > > Good luck > > > > Scott > > > > --- In DTXpress@yahoogroups.com, "liberatusvirus > > <liberatusvirus@y...>" <liberatusvirus@y...> wrote: > > > Hi Dennis, > > > > > > Scott just got one of these, too. Maybe he'll have another > story. I > > > have noticed a hot spot in the middle of the AX14S under the > > > trigger; it's unavoidable. But you can work around it. What I > did is > > > change the type of pad for input 2 from TP snare to DT snare. My > > > global trigger setting is DT 10/20 (medium is the default). > Because > > > the AX14S is on a separate stand, you don't have to worry about > > > crosstalk. I have rejection and specific rejection at zero and > self- > > > rejection at 1 or 2, depending on which way the wind blows. My > gain > > > is usually high, in the 90s, and my minimum velocity at rock > bottom. > > > One more component to this ultra-hot setup is to flip the DIP > switch > > > corresponding to input 2 at the back of the module to the up > > > position. You'll need a tiny screwdriver or needle to do it, > unless > > > you've got great finger nails. The result should be good > sensitivity > > > all around the drum, from center to rim, almost as though the > module > > > were capable of positional sensing. Although I cannot claim > > > perfection for this method (I've had an inexplicable dropout or > > > two), it generally works pretty well. Pressed rolls near the > tension > > > rods were unthinkable with the standard gum rubber, or even the > > > otherwise wonderful Pintech ConcertCasts. But now they're pretty > > > accurate--not to say that tweaking is a thing of the past. It > goes > > > on forever. > > > > > > Ed > > > > > > --- In DTXpress@yahoogroups.com, "dennisw562003 > <dennisw56@i...>" > > > <dennisw56@i...> wrote: > > > > I have added the AX14 snare to my DTXpress. Can anyone help me > out > > > > with the DTXpress settings for the new snare. > > > > > > > > I only get sound when the head is hit directly in the middle. > > > > > > > > I also learned talking to Pintech, to get the snare and rim > sound > > > a > > > > Y1 splitter must be used with the head mono connected to the > snare > > > > and the rim mono connected to 9/10. > > > > > > > > Thanks, Dennis
2003-01-03 by liberatusvirus <liberatusvirus@yahoo.com>
Scott, Mesh heads seem to bring out the torque in me, and I've paid the price. And I still have more to pay; I noticed at least one more damaged rod yesterday. I guess I've become a charter member of the Steward Copeland "you can never get the heads too tight" club. I was never that way with acoustics. Pintech does well by me. Ed --- In DTXpress@yahoogroups.com, "hairytrigger <artifax@i...>" <artifax@i...> wrote: > Thanks, Ed. > I will try raising the gain and flipping the switch. > I hope I haven't tightened the head beyond reason. Just trying to get > it to feel good! > Scott > > --- In DTXpress@yahoogroups.com, "liberatusvirus > <liberatusvirus@y...>" <liberatusvirus@y...> wrote: > > Scott, > > > > If your self-rejection setting is at 0, and you're still getting > > dropouts when you buzz with one hand and try a whack with the other, > > the trigger or trigger/module may be masking itself when the > > transition is too abrupt and dynamic. (I seem to recall something > > like that to be an artifact of piezos but not FSRs, but don't quote > > me). But raising sensitivity can cover a multitude of sins. I'm > > curious to learn what flipping the DIP and raising the gain will do > > in your case. The result may not necessarily be compatible with your > > playing style or voicings. By the way, I think that my sporadic > > dropouts have a similar pattern. Thanks for doing a better analysis > > of them. One caution when tightening heads on electronic drums: you > > can strip the rods. Take it from me. I tighten like mad and have had > > to change rods and lugs on two different drums. Moderation is the > > key. But then again, everybody is probably more intelligent about it > > than I am. > > > > Ed > > > > > > --- In DTXpress@yahoogroups.com, "hairytrigger <artifax@i...>" > > <artifax@i...> wrote: > > > Hey, Dennis > > > My story is about the same as Ed's. But I have the switch in back > > low, > > > and gain around 60. I'm still experimenting. Great response > > though. I > > > am going to try Ed's settings. Nothing to lose, and maybe lots to > > > gain.. About your no trigger at all near the rim... Did you > > tension > > > the head after you got it? Pintech says it needs a full turn on > > each > > > rod.I think mine was more like three. This can make a huge > > difference > > > in response.The tighter the head, the less noticeable the hot spot > > is, > > > also. > > > The only 'dropouts I've noticed is when I do a "pressroll/flam". > > > I don't know what it is really called, but when you do a short > > > pressroll with the right hand followed immediately by a shot with > > the > > > left.Anyway, if I don't end that pressroll part soon enough, the > > > left-hand-shot doesn't trigger.I've had to modify my playing a bit > > to > > > ensure it is heard. Or worse, play it properly, with both hands > > doing > > > the roll (R-L-R-L) with the last L played hard. It's all played in > > the > > > time it takes to play a flam. I don't know why the last one drops > > out. > > > My rejection settings are all '0'. > > > This problem caused me to set up a kit with my extra pad as a > > second > > > indetical snare. The drums in the Door's 'Love Me Two Times' is > > played > > > as a snare shuffle, with flams on the 2 and 4.Some of my 2's and > > 4's > > > were dropping out, so I set up the other pad as snare, and played > > it > > > as though it were the HiHat. Problem solved. I hope all this makes > > > sense...And I hope it helps!!! > > > > > > Good luck > > > > > > Scott > > > > > > --- In DTXpress@yahoogroups.com, "liberatusvirus > > > <liberatusvirus@y...>" <liberatusvirus@y...> wrote: > > > > Hi Dennis, > > > > > > > > Scott just got one of these, too. Maybe he'll have another > > story. I > > > > have noticed a hot spot in the middle of the AX14S under the > > > > trigger; it's unavoidable. But you can work around it. What I > > did is > > > > change the type of pad for input 2 from TP snare to DT snare. My > > > > global trigger setting is DT 10/20 (medium is the default). > > Because > > > > the AX14S is on a separate stand, you don't have to worry about > > > > crosstalk. I have rejection and specific rejection at zero and > > self- > > > > rejection at 1 or 2, depending on which way the wind blows. My > > gain > > > > is usually high, in the 90s, and my minimum velocity at rock > > bottom. > > > > One more component to this ultra-hot setup is to flip the DIP > > switch > > > > corresponding to input 2 at the back of the module to the up > > > > position. You'll need a tiny screwdriver or needle to do it, > > unless > > > > you've got great finger nails. The result should be good > > sensitivity > > > > all around the drum, from center to rim, almost as though the > > module > > > > were capable of positional sensing. Although I cannot claim > > > > perfection for this method (I've had an inexplicable dropout or > > > > two), it generally works pretty well. Pressed rolls near the > > tension > > > > rods were unthinkable with the standard gum rubber, or even the > > > > otherwise wonderful Pintech ConcertCasts. But now they're pretty > > > > accurate--not to say that tweaking is a thing of the past. It > > goes > > > > on forever. > > > > > > > > Ed > > > > > > > > --- In DTXpress@yahoogroups.com, "dennisw562003 > > <dennisw56@i...>" > > > > <dennisw56@i...> wrote: > > > > > I have added the AX14 snare to my DTXpress. Can anyone help me > > out > > > > > with the DTXpress settings for the new snare. > > > > > > > > > > I only get sound when the head is hit directly in the middle. > > > > > > > > > > I also learned talking to Pintech, to get the snare and rim > > sound > > > > a > > > > > Y1 splitter must be used with the head mono connected to the
> > snare > > > > > and the rim mono connected to 9/10. > > > > > > > > > > Thanks, Dennis
