-I only have 2 voices set on all my pads....HOW can I get 3
different sounds on all these pads?
-- In DTXpress@yahoogroups.com, "hairytrigger <artifax@i...>"
<artifax@i...> wrote:
> I have the original DTXpress, but I think the answer is the same.
All
> inputs, except 9/10, have rim switches. So two sounds are
> possible(three on the DTx II). On mine, no sounds were assigned to
> kick rim.
> I think the reason for this is that, If you need an extra multi-
zone
> input, you can plug the kick into the 9/10(which are mono inputs),
and
> free up a 2 (3_) zone input.
> OR, if you used a two or three zone pad for kick, you cuuld, with
> another pedal, access a foot-played cowbell, tambourine or soun
effect
> etc.
> The possibilities are almost endless.I've had mine over two years
and
> still find new and different ways to do stuff!!!
> Scott
> --- In DTXpress@yahoogroups.com, "underneathheaven
<realvast@s...>"
> <realvast@s...> wrote:
> > Hey people, hope you had a safe new year! OK I've got a
question
> > about rim switches. In the instruction book for the DTXII it
has a
> > section where it lists all the pre-set drum kits and there
sounds.
> > I think in all of the kits it claims the kick pad or bass drum
to
> > have one sound and then a rim switch sound. For example I
remember
> > one kit had a normal bass drum sound and for a kickpad rim
switch it
> > had a cowbell sound. So how do you get the cowbell sound off of
> > kickpad? How can the kickpad have two sounds in the first
place?
> > I'm confused! Thanks a bunch!
