Re: [AN1x] MIDI problems...HELP!
2002-05-11 by terryfunken@aol.com
In a message dated 11/5/02 10:00:07 am, jacker@... writes:
>NEXT: I had in meantime bought a newer soundcard (Creative Labs Soundbolaster
>PCI card) and changed out the soundcard I had which was an older Soundblaster
>card. I installed the drivers and am experiencing exactly the same symptoms.
Hi Jim,
I my experience- DON'T go for cheap soundcards that offer both midi and
sound. Usually the midi is only designed for gaming and basic music
applications. The AN1x requires high level data to be sent to and fro with
midi keyboard info on top of that. If you are pleased with the quality of the
soundblaster card, then stick with that- but only for sound- also the
soundblaster drivers are unreliable (for the time being- although, i would
recommend spending a bit extra and getting a Korg 12/12 secondhand-for eg.).
IMO it is better to get a seperate MIDI card such as a Midiman WINMAN PCI
card- and with that you do have the option of multi midi ins and outs too.
good luck!
Tom
2002-05-12 by James R. Acker
Thanks, and I probably will follow that advice in the end, but for now...I had this thing working to the point it was usable and see no reason I shouldn't at least be able to get there again.
The MAIN thing that hits me is....as I mentioned, when I have the AN1X powered up, as soon as I hit the power on the PC the An1x begins flickering...this happens EVEN when I have the device set to OFF. THis puzzles me and also I react to the second power comes on, that means before the drivers are even loaded...we're talking at the hardware level. Unless the BIOS is set to poll there or something like that. It may be something along those lines.
Jim
Please check out my original music at my site http://home.online.no/~jacker
Or at http://www.soundclick.com/bands/jacker_music.htm
                              -James R. Acker-
To: <AN1x-list@yahoogroups.com>
Sent: Saturday, May 11, 2002 11:41 AM
Subject: Re: [AN1x] MIDI problems...HELP!
> Hi Jim,
> good luck!
> Tom
> Community email addresses:
>   Post message: AN1x-list@yahoogroups.com
>   Subscribe:    AN1x-list-subscribe@yahoogroups.com
>   Unsubscribe:  AN1x-list-unsubscribe@yahoogroups.com
>   List owner:   AN1x-list-owner@yahoogroups.com
> Shortcut URL to this page:
>    http://groups.yahoo.com/group/AN1x-list
By the way...I will never give another cent to Creative Labs...I have never seen such rot. I bought two different boards from them. In both cases the installation is screwy and doesn't follow ANY of the standards that are considered normal...like progress bars to let you know install hasn't hung up, and also the fact that I end up wildly different software after each install...of the SAME installation CD.
    And to top it off, just try going to their web site and getting a download or an online manual. Half the time they redirect you to nonexistent/broken web pages, or take forever to load...
    No, I agree with you on that, I am through supporting this kind of crap, and will spread the word whenever I get a chance. I just meant that SINCE I have the thing...and have made it work before, I want to get it to work now.
                              -James R. Acker-
> In a message dated 11/5/02 10:00:07 am, jacker@online.no writes:
> Hi Jim,
> good luck!
> Tom
> Are you using Win2K?  If so, I am also having problems with AN1xEdit and a "legacy" (gameport) adapter.  I believe that I had it working at one time, but somewhere in the process of installing applications and MS security patches, it stopped functioning.  Win98SE is much better for MIDI.
Bruce, thanks for some really helpful hints. I am using Win95 actually, but I see what you mean about the "Legacy" stuff...I saw that in the devices and wasn't sure what it was. Now I know that is part of the problem at least.
AS I said in another answer to Terry, the thing that puzzles me most is this "ILLEGAL DATA" message that comes all the time, it starts coming in to the AN1x just as soon as I have power on the PC.
    Maybe you could help me, any of you, if you guys that have the AN1x hooked up to a PC have the AN1x already powered up, and turn on the PC after, does it flicker on the LCD screen up until Windows is loaded? Or does it flicker a short time and then stop?
    And I tried even turning OFF the device ID on the An1x side expecting it to help but it didn't.
> If that's not the case, it sounds like you might have both Local On set in the AN1x and MIDI Thru Enable set in AN1xEdit.
I don't see how this could affect at start up, but maybe it could (just cause I don't see how it could doesn't mean much :-) I had Thru set to off (I mean if we are talking about the check box in the MIDI settings).
Suddenly last night when I try to start the an1x editor I get "Bad ID" in a pop up box. I wasn't getting that before, so I must have screwed something up. Am once again (fifth time's a charm eh?) installing the damn Soundblaster PCI stuff.
>This could cause multiple data messages, which would likely drive the AN1x crazy.  MIDI Out from the PC always goes to MIDI In of the synth, and vice versa.  It won't damage anything if you hook things up backwards, but it won't give you MIDI, either.
> If that doesn't fix you up, try uninstalling and reinstalling the drivers for the legacy adapter.
> Also, just as an aside, you might want to power up the AN1x first, rather than last.
That is what I do now normally. I have also tried it the other way to see if that helped....it didn't.
Thanks though, this is helpful and if you think of anything more please don't hesitate to email!
Jim
> Regards,
> -BW
> Bruce Wahler
> Design Consultant
> Ashby SolutionsT   http://consult.ashbysolutions.com
> CloneWheel Support Group and HiNote moderator
> 978.386.7389  voice/fax
> bruce@...
> At 12:01 P 5/11/2002 +0200, you wrote:
> >Hey all,
> >    Over a year ago I bought a gameport-MIDI adapter for my soundcard. I think I spent some time setting it up and finally was able to use it partially. I remember I was able to use An1x-Edit (a GREAT help of a program!) at least one way...I was able to change parameters on the PC and have them affect the AN1x. I was able to send patches to the AN1x from the PC also. I was NOT able to receive patches from the AN1x.
> >    Here it is over a year later. We got a new PC down in the living room, so I finally get the chance to take the old PC that I referred to above up to the music room and hook it up premanently to the AN1x (yeah!!).
> >    So I do.
> >    And immidiately upon starting the AN1x I see the display flicker like crazy...I have no contact.
> >    I try both ways hooking up the adapter..the way I think it should be and one other possible way (Call the first way "A" which was the MIDI cable marked OUT connected to the IN on the An1x and the MIDI cable marked IN connected to OUT from the An1x, and "B" which is the opposite.)
> >    With hookup "A", immidiately at power up, even with the An1x already on and as SOON as I hit the power button on the PC to turn it on, the LCD display on the An1x flickers like crazy and if I hit any button or move the selector knob I can faintly and briefly see the message "ILLEGAL DATA" flash. If I pull out the AN1x IN cable the flickering messages go away (the thing that flickers is the "edit" icon on the LCD) and it is just blank there.
> >    If I reverse the cables (please tell me it does no harm to hook MIDI up wrong :-) I think it should not hurt anything but am not certain) none of the above happens but I never get any contact.
> >    NEXT: I had in meantime bought a newer soundcard (Creative Labs Soundbolaster PCI card) and changed out the soundcard I had which was an older Soundblaster card. I installed the drivers and am experiencing exactly the same symptoms.  The thing that bothers me most is I get the symptoms with hookup A absolutely the second there is power to the PC. This means to me that it probably isn't a setting anywhere UNLESS one of you tells me that they all behave this way and that you shouldn't turn the AN1x on until the PC is fully powered up?
> >    I eventually had gotten some MIDI tools off the net (the PC is no hooked up to the net anymore but from before) and one that monitors MIDI shows me with hookup A the PC receiving "SENSE" messages about one or two per second. I tried taking the cable out from the AN1x MIDI OUT, and moving it to THRU in hopes of passing whatever "ILLEGAL DATA" was coming into the AN1x.
> >    Please, has anyone got some insights, or been through this and have some answers? It is SO frustrating when something worked before and not now. It may be cables..I will switch the two at both ends and try method A again now. I doubt it will help.
> >Any ideas, or at least insights or suggestions would really be appreciated!
> >Thanks,
> >Jim
2002-05-12 by Reggie
What Soundblaster card is it?  I've got a PCI128 I think (Can't
remember, it's working OK AFAIK, I only use it for games mostly, but the
Midi I/O works fine).  BTW. I agree that Creative are absolute rubbish,
their support is amongst the worst I have ever come across, and to cap
it all they want to charge some users of their products for driver
updates!!
Anyway, my point is I have a 2nd PC hooked up to this machine, so I can
use midi-ox on the 2nd machine to monitor what the midi-out from the SB
is doing at boot time.
I'll get back to you in a second when I have rebooted this machine and
checked.
In article <002601c1f9a3$874de8a0$f79f7a94@w0x3x7>, James R. Acker
<jacker@...> writes
>get it to work now.
>                              -James R. Acker-
>----- Original Message -----
>From: <terryfunken@...>
>> >Soundbolaster
>> >Soundblaster
>> Hi Jim,
>>quality of the
>> good luck!
>> Tom
See ya,
Reggie
OK, so, I checked the midi output of the crappy SB card on my other PC,
and it is sending out 24 'bank' messages on channel 16.
  0011E38A    4     BF    00    00   16   --  CC: Bank MSB
  0011E38B    4     BF    00    00   16   --  CC: Bank MSB
  0011E38C    4     BF    00    00   16   --  CC: Bank MSB
  0011E38D    4     BF    00    00   16   --  CC: Bank MSB
  0011E391    4     BF    00    00   16   --  CC: Bank MSB
  0011E392    4     BF    00    00   16   --  CC: Bank MSB
  0011E393    4     BF    00    00   16   --  CC: Bank MSB
  0011E394    4     BF    00    00   16   --  CC: Bank MSB
  0011E395    4     BF    00    00   16   --  CC: Bank MSB
  0011E396    4     BF    00    00   16   --  CC: Bank MSB
  0011E397    4     BF    00    00   16   --  CC: Bank MSB
But it only does this from a 'Cold' boot. Doing a plain restart does
nothing, so I suspect that it is a spike through the card when it gets
it's initial power.
I suggest that you try plugging in the midi out of the card to the midi
in only on the AN1x (Don't connect the other one) AFTER the PC has
booted.  That way you can test just the output once all the spurious
junk has gone out of the cable.  Once the bootup junk has gone there is
no other midi data coming from the SB PCI card.
Now you know that it is a load of 'Bank' messages at least you can
filter it from the AN1x.
I hope this helps.
In article <$u2J$PENTl38EwEU@...>, Reggie
<reggie@...> writes
>updates!!
>checked.
><jacker@...> writes
>>get it to work now.
>>                              -James R. Acker-
>>> >Soundbolaster
>>> >Soundblaster
>>> >symptoms.
>>> Hi Jim,
>>>quality of the
>>> good luck!
>>> Tom
See ya,
Reggie
> updates!!
Mine (the second one) is also a PCI 128. The thing is it has the same problem as the original (SB16) card that was in that I had once got to work halfways.
> checked.
> Reggie
Thanks, that would be a huge help!!
The thing I began wondering is...if the hardware card starts polling right away until it really gets init'ed, or if it may act unpredictably until init'ed... It may be a red herring, but I am suspicious that it happens RIGHT from power on. I have a MIDI monitor I found on the net...I will recheck so I don't mislead but I see some messages coming back from the An1x...I cannot see what is sent out to it, and I tried using MIDI THRU instead of out to see if I could see the messages but I couldn't. I do see "SENSE" messages coming back from the An1x, and I see at the very start "PITCH bend" or "pitch change" (I will check) messages coming from the An1x like one or two times at the beginning and then no more.
I keep feeling like things are changing under my feet...that after messing around I can suddenly get "Bad ID" again from An1x edit and nothing appears in the "add MIDI instrumet" menu...I will try some more things and if ity doesn't help, I feel like I ought to get it as close as I cvan and write down some settings and post them...see if anyone sees anything I am missing here...
Thanks.
Jim
THANKS! We crossed each other...I was writing a reply to your earlier mail and as soon as I sent it I saw this one!
Good suggestion, I will try narrowning down, only using one cable, etc.
I will let you know what happens! Thanks again, that is really useful info!
Jim
                              -James R. Acker-
To: <An1x-list@yahoogroups.com>
Sent: Sunday, May 12, 2002 2:06 PM
> it's initial power.
> I hope this helps.
> <reggie@...> writes
> >updates!!
> >checked.
> ><jacker@...> writes
> >>get it to work now.
> >>                              -James R. Acker-
> >>> >Soundbolaster
> >>> >Soundblaster
> >>> >symptoms.
> >>> Hi Jim,
> >>>quality of the
> >>> good luck!
> >>> Tom
> See ya,
> Reggie
Thanks again for getting me pointed in the right direction. I have some more info now....it still seems to be that same problem, but I now have verified that messages coming OUT of the An1x are normal and as they should be. I can ONLY monitor the An1x OUT ( PC Soundcard IN) with what I have now. I see though that if the PC is up and I power up the An1x it sends back the following messages:
timestamp    port    status    data1    data2    channel    event
11D16            1          B0        07        7F          1         Control Change
11D16            1          B0        04        7F          1         Control Change (these first happen at same time)
11D18            1          E0        00        40          1         Pitch bend (had my hands off the pitch wheel...)
then status all the time...
11DDC           1           FE       --          --                      Active Sensing
11EE2            ----------------- " ---------------------------------------
This keeps up all the time.
If I filter out these, or simply press a key I see "key on" and "key off" happening and it all looks reasonable. I conclude from this that the PC soundcard IN and An1x OUT is okay. The problem is somehow in the PC soundcard OUT or An1x IN.
Have swapped cables and the problem stays, but I don't have another MIDI-splitter cable so I could only test the extension cables. Both are okay.
I remembered that I have MIDI on my DR770 Drum machine. I hooked it up and as soon as I power on the PC I get "SERIAL ERROR!" on the LCD of my drum machine. Here again...if I disconnect the OUT from the PC soundcard( IN on the DR770) it comes up. I can even try a bulk dump and see messaged coming in to the PC.
So that narrows the problem to the PC soundcard OUT OR the cable from gameport out, or the PC setup somehow.
If I can find the original drivers I can try putting back the SB16 card that once worked and verifying that this in fact is failing in the same way...or I can try and find the receipt and get a trade.
It helped to see that you see some messages. I undesrtand from your mail that you see just the 24 messages and after that things are quiet on the OUT line...that there is no more "chatter" after that right? I don't see that...I see the chatter all the time.
Could you check in your setup and see if in the control panel, if you go into the joystick icon, there is a check box for something about "polling joystick" down at the bottom of the second menu. I have tried both settings, but should this be off? It is damn confusing, because if the SB card is "acting" like a joystick it might need some joystick stuff enabled...on the other hand it might need it off...hard to know.
Any more ideas? You have been a big help so far!
Jim
                              -James R. Acker-
To: <An1x-list@...m>
> it's initial power.
> I hope this helps.
> In article <$u2J$PENTl38EwEU@...n.co.uk>, Reggie
> <reggie@...> writes
> >updates!!
> >checked.
> ><jacker@...> writes
> >>get it to work now.
> >>                              -James R. Acker-
> >>> >Soundbolaster
> >>> >Soundblaster
> >>> >symptoms.
> >>> Hi Jim,
> >>>quality of the
> >>> good luck!
> >>> Tom
> See ya,
> Reggie
2002-05-12 by jondl_2000
James,
Would you mind editing the extraneous text from your replies -
this thread is getting hard to follow with all that extra text. Thanks
in advance - I appreciate it.
regards,
Jon
In article <000901c1f9c3$f4283820$ca9f7a94@w0x3x7>, James R. Acker
<jacker@...> writes
>11D16            1          B0        07        7F          1
>Control Change
Volume message!!
>11D16            1          B0        04        7F          1
Footswitch message!!
>11D18            1          E0        00        40          1
>11DDC           1           FE       --          --
>Active Sensing
The active sensing is OK, it is supposed to happen, it is to allow the
synth to stop all notes if a cable is pulled out from it.
>okay.
Yep, 24 messages all the same, each cold reboot.  Nothing else after
that, not even active sensing.  Don't forget I'm monitoring the midi out
of the card before my bios has completely POST'ed, once windows is
running there is absolutely nothing from the card.
I don't have anything like that, I see the 'creative gameport' but
nothing about polling.
Unfortunately not, all I have installed are the drivers that came with
the OS (XP in my case, but they are real WDM drivers), so that's really
where my help stops.
Actually, maybe, the Active sensing could be coming from the AN1x, which
would explain the constant chatter that you see. If you can see the
chatter with just the output of the AN1x connected to the SB midi in
then that would prove it.  Then you can effectively ignore the constant
chatter.
Have you tried turning on the PC and the AN1x without anything connected
then try connecting the out of the card to the in of the synth?
>Jim
>                              -James R. Acker-
>From: "Reggie" <reggie@...>
>> it's initial power.
>> I hope this helps.
>> <reggie@...> writes
>> >updates!!
>> >checked.
>> ><jacker@...> writes
>> >>get it to work now.
>> >>                              -James R. Acker-
>> >>> >Soundbolaster
>> >>> >Soundblaster
>> >>> >symptoms.
>> >>> Hi Jim,
>> >>>fro with
>> >>>quality of the
>> >>>although, i would
>> >>>outs too.
>> >>> good luck!
>> >>> Tom
>> See ya,
>> Reggie
See ya,
Reggie
Was this AFTER jondl said the same exact thing?
How about giving us a chance before piling on, as you can see, I AM editing the responses.
> Folks, please edit your mails. Thanks.
> - Peter
I just did this. It fails in exactly the same way, but seems to take a half second longer before
freezing. This is with the SB16 now...I put it back in and plug&play recognized it an set up the
appropriate drives.
This has to be the crux of the problem. I get the chatter even after Windows is up.
Strange, when I went back to the SB card, I didn't have that option anymore either.
> chatter.
I tried it....it didn't make a difference.
Another thing (god...there are so many) that puzzles me is I can turn OFF transmit channel, receive channel, device ID and STILL it reacts as soon as power up. Again, I can do this with the IN (sb card) cable pulled out of the An1x (OUT) and it makes no difference. I would expect it to ignore anything coming in in the MIDI port with all those things turned off. Maybe I misunderstand the meaning of IFF in the context.
In article <004d01c1f9f0$7d693a40$b4f84382@w0x3x7>, James R. Acker
<jacker@...> writes
>appropriate drives.
Did you ask it to?  Or did it go off and find the old drivers?  If it
went off and found it's own drivers then it could be that you are
getting a mixture of old and new drivers installed?  Do you have any
system backup software?  If so then a reasonable idea might be to
completely backup your boot partition (Just in case you need to get
things back) and then re-format and re-install windows?  Or did you
install the card with a fresh install?
It's a pity I haven't got win2k knocking around, then I could install it
and the drivers but I waited and went for XP instead.
>Windows is up.
>anymore either.
Hold on a mo', I've got A dual boot PC (win98&XP), I just checked in
Device manager in win98 and there are some 'extra' options that aren't
in XP.
there is a thing about joystick and sharing an IRQ with the LPT port,
were they the options you were talking about?
This is indeed strange, basically you are switching off the synths
ability to receive those types of messages.
See ya,
Reggie
2002-05-13 by Peter Korsten
Nope, this was Reggie, who sent his 15 Kb, unedited mail after Jon sent his.
- Peter
2002-05-13 by Reggie
I sincerely apologise for the extra few KB in the message.
But did you know that your own 2 messages covered around half the amount
of data but weren't of any help to anyone?  + this one to apologise and
James response to you too and your 2 posts will have added around 15KB
to this thread.  All seems a bit pointless?
This isn't a dig at anyone, just an observation.
I will try and remember to edit quotes.
See ya,
Reggie
2002-05-14 by James R. Acker
To those (Reggie especially) who have taken the time to help, thank you.
To people that complained about the size, an excuse you can take or leave but is honest....the thing is, I am extremely frustrated trying to get this to work. I work with programming and have to troubleshoot a lot of different equipment....it is kind of a habit to let the whole history stay in the message, because if more than one person is involved they can simply page down and see what has been tried right from the start and what conclusions have been reached and what were dead ends.
This saves getting a lot of "did you try ..." when it was already tried. At this point, and especially in this group that can go weeks with maybe 10 messages, I didn't see the problem. I am looking for any help I can get and the most recent exchange was always at the top of the message. I figured, calculated, that it wouldn't be all that much bother for folks not interested to simply delete. If you ever go out on the net you get many times the size of our exchange literally daily in the form of spam.
So I didn't see the problem. But I know that you all may have different views on things.
But when one person asks us to snip our replies and another does it within hours....I felt like replying. I know that there was an uncut message even AFTER (heaven forbid!) but anyone that has been on lists for any length of time knows most of us reply when we see a message and not AFTER reading ALL messages.
For that reason if you make a request to a list, you ought to wait until everyone has a chance to see it, before making the same complaint that already has been made.
Again...I am getting some great help from a few people, and complaints from two other. The volume of this is such that I cannot understand how it is a problem unless someone is STILL sitting on a slow modem...and I doubt that.
Sorry if I am reacting, but I expected a little slack....trying to fix a problem and there actually may be other people that might get help by this too...
Jim
> >appropriate drives.
No... I hadn't asked it to, so it must have just found the drivers.
Unfortunately I don't have a backup option, no tape, no CD burner...and floppies would need too many. I may have to do something like that but will keep it as last resort.
> >anymore either.
> in XP.
I found the option and why it comes up. It is about "polling" the game port for multiple interrupts.
I found out you get the box ONLY when the slotted choice box above is set to something other than blank. I saw it appear when I choose something there.
That is what I thought.
Reggie, listen I do want to thank you for going through all the bother and trying to help out.  I have at least a better idea of where the problem must be (cable or PC setup or hardare in PC). I need to figure out where to take it from here...I am going to try to resintall windows drivers for joystick, etc and see if it helps.
Thanks again, and I owe you one!
Jim
> See ya,
> Reggie
Sent: Sunday, May 12, 2002 6:00 PM
Subject: [AN1x] MIDI problems...HELP!
> Mr. Acker,
> I have exactley the same problems I'm using a mpu401 joystick interface & if
> I power up/down my PC with the AN1X switched on, I get the same "ILLEGAL
> DATA"  message flashing up the only way to avoid this is by making sure I
> switch the AN1X on AFTER powering up, & off BEFORE powering down.
Thanks Peter. This also was helpful. I know that there is that "window" in the sequence of starting up that things are not valid. I hadn't remembered that from before.
THanks!
Jim
> in the meantime I'm saving for a new midi I/O, but be aware that some USB
> ones can exhibit problems with large sysex dumps, & users have ezperianced
> problems with ANedit.
> Hope this helps
