Sent: Monday, May 12, 2003 2:15 AM
Subject: [xl7] Re: Data wheel going mad!
I have exactly the same problem. Yes, I even got my XL-7 repleaced by
another one, but after a while it got the same problem again.
Since so many have has this problem, I believe it's something about
the hardware. Perhaps not absolutley the best hardware components...
If anyone finds a solution, please tell me about it.
//Nifflas
--- In xl7@yahoogroups.com, khjkkkkk khjkhjk <extra_mayo79@y...>
wrote:
> When you push it down it does work better, also if the mashine is
on for long time it works better.Thanks guys for your replies. I
guess its just the nature of the beast.
> David DeciBel <spec@s...> wrote:Mine does this and I can tell you
that in my unit it is a hardware,
> not a software problem. I have ordered the replacement part which
> was about $10... If you push down on it and turn you will have
more
> luck.
> wrote:
> > Hi everyone,I just got this baby and its amazing.I upgraded it to
> 2.0 OS and everything seems to be great except the data wheel
> control.When I turn it slowly it works fine , but when I try to go
> faster with turning, it jumps like creazy.For example, when I wanna
> sellect new pattern, and if I move it faster its gonna jump to like
> next bank and sometimes it will even go into opposite direction so
I
> have to wheel it realy slowly and I am afraid its gonna even be
> worse in the future. Is there a way to fix this or is it just a bug?
> Is anyone else having this problem? Thanks
> > Do you Yahoo!?
> > The New Yahoo! Search - Faster. Easier. Bingo.
> > [Non-text portions of this message have been removed]
> Yahoo! Groups SponsorADVERTISEMENT
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
> Do you Yahoo!?
