Réf. : Re: Réf. : [xl7] Trying to update to new O.S..........
2003-02-19 by Jean Kergutuil
This is not the original poster's problem. Note that the SYSEX PACKET DELAY parameter is NOT applicable to OS updates (nor to Sequence transfers when using E-Loader). That parameter is only used in open-loop (non-handshaked) transfers. OS updates are done closed-loop (handshaked) and do not require fixed delay times between packets in data transfers. Closed-loop transfers occur at the maximum speed that the unit can accept MIDI and use check-summed packets and support retries in cases of dropped/corrupted packets. YEAR !! but i have had the same problem when i tried to update to new OS ... and when i set the sysex delay on 300 ms, that's solved my problem !! and i wasn't the only one with this problem ...a friend advice me to do this and it's works fine !
