more sending arps to external gear
2003-02-14 by mikexl7 <curiousproductions@rogers.com>
Ok this is making me crazy. I can get the arps to send to external gear by creating a empty preset with the arp saved to the preset. This works fine. This is what is happening. On track 9 i have a bass line arp being sent to my sampler. On track 10 I am trying to play the same arp to a lead synth sound in the XL7. The arp plays the lead sound within the XL just fine but it is also playing the sund that is set up on the sampler on that chanel even though the chanel is set to internal. I can't think of a way around this since i have to set the xl to send the arps to external gear via the arp menue to get it to send to the bass line. The reason this is a pain in the ass is that in a live situation i would have to create a pattern just to switch to an empty preset on the sampler. This is work aroundable but is sloppy. I can't belive that a box that has the most powerfull arps in the land cant work with external gear with out jumping through hoops. I am begging and pleading to you Aaron that you help me out here or tell me that this problem is being taking care of in the long awaited new OS. I Personaly see this as a major fault in the XL. I am not one to bitch at the drop of a hat as i know that all gear has it't faults. I would just love to see this worked out. Bottom line.... Setting the chanel to internal should stop the arps from sending to external gear. I would love some feed back on this one. It seems that I am not missing sompthing but if I am I would love to know. Mike G. Ps if ya want to hear some tunes my myself go to www.mp3.com/michaelgoodwin
