pattern mode
2003-02-13 by studio_6512 <studio6512@cinense.org>
when in pattern mode, I copied a pattern to an empty sequence, and tried to modify the mixer volume setting for a channel, and saved it, but it does not save. can someone tell me what I am doing wrong. DJ_vgrep
2003-02-13 by Andre Lewis
You should have a read through the FAQ up on the Yahoo site, it will make your life a bit easier. The entire instrumnent mappings are actually saved as part of a multi setup, you can see them under the Global Menu, this will include instrument and volume sets (I believe). Also you have allready updated OS's? Andre
-----Original Message----- From: studio_6512 <studio6512@...> [mailto:studio6512@...] Sent: Wednesday, February 12, 2003 8:20 PM To: xl7@yahoogroups.com Subject: [xl7] pattern mode when in pattern mode, I copied a pattern to an empty sequence, and tried to modify the mixer volume setting for a channel, and saved it, but it does not save. can someone tell me what I am doing wrong. DJ_vgrep To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
2003-02-13 by studio6512
Thanks for the reply Andre. Yup, the OS is up to 1.32. Just like everyone else, waiting for 2.xx. You're right, I should look at the faq. Do I just search for it, because I did not see a link for it on the XL7 group homepage. DJ_vgrep
-----Original Message----- From: Andre Lewis [mailto:andrel@...] Sent: Wednesday, February 12, 2003 9:55 PM To: xl7@yahoogroups.com Subject: RE: [xl7] pattern mode You should have a read through the FAQ up on the Yahoo site, it will make your life a bit easier. The entire instrumnent mappings are actually saved as part of a multi setup, you can see them under the Global Menu, this will include instrument and volume sets (I believe). Also you have allready updated OS's? Andre -----Original Message----- From: studio_6512 <studio6512@...> [mailto:studio6512@...] Sent: Wednesday, February 12, 2003 8:20 PM To: xl7@yahoogroups.com Subject: [xl7] pattern mode when in pattern mode, I copied a pattern to an empty sequence, and tried to modify the mixer volume setting for a channel, and saved it, but it does not save. can someone tell me what I am doing wrong. DJ_vgrep To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service. [Non-text portions of this message have been removed]
2003-02-13 by Aaron Eppolito
--- "studio_6512 <studio6512@...>" wrote: > when in pattern mode, I copied a pattern to an empty sequence, and > tried to modify the mixer volume setting for a channel, and saved > it, but it does not save. can someone tell me what I am doing wrong. Since you have 1.32, you got a little bit of my brain failure (along with some good features though, I hope!). There's a bug that causes volume and pan information to not be saved reliably unless the pattern is PLAYING while you save it. Yeah, I know...screwy. -Aaron __________________________________________________ Do you Yahoo!? Yahoo! Shopping - Send Flowers for Valentine's Day http://shopping.yahoo.com
Hal... what does that mean? Hal... -A few good men So are you telling me that with this upgrade, in pattern mode, I can't change the volume and save it the way I want? Is this true... I will try and call E-mu today, hopefully they can answer this. I called them on Tuesday, and they said that muting the tracks in song mode was not what is was meant for. Does someone want to touch that one? DJ_vgrep --- In xl7@yahoogroups.com, Aaron Eppolito <synthesis77@y...> wrote: > --- "studio_6512 <studio6512@c...>" wrote: > > when in pattern mode, I copied a pattern to an empty sequence, and > > tried to modify the mixer volume setting for a channel, and saved > > it, but it does not save. can someone tell me what I am doing wrong. > > Since you have 1.32, you got a little bit of my brain failure (along > with some good features though, I hope!). There's a bug that causes > volume and pan information to not be saved reliably unless the pattern
> is PLAYING while you save it. > > Yeah, I know...screwy. > -Aaron > > __________________________________________________ > Do you Yahoo!? > Yahoo! Shopping - Send Flowers for Valentine's Day > http://shopping.yahoo.com
--- "studio_6512 <studio6512@...>" wrote: > So are you telling me that with this upgrade, in pattern mode, I > can't change the volume and save it the way I want? Is this true... No. Just make sure you're playing when you save. That's it. > I will try and call E-mu today, hopefully they can answer this. Um...considering I wrote the software (and this bug!), you can probably take my word for it... =) -Aaron __________________________________________________ Do you Yahoo!? Yahoo! Shopping - Send Flowers for Valentine's Day http://shopping.yahoo.com
Aaron, thanks... Any chance this will get fixed in the next release? DJ_vgrep --- In xl7@yahoogroups.com, Aaron Eppolito <synthesis77@y...> wrote: > --- "studio_6512 <studio6512@c...>" wrote: > > So are you telling me that with this upgrade, in pattern mode, I > > can't change the volume and save it the way I want? Is this true... > > No. Just make sure you're playing when you save. That's it. > > > I will try and call E-mu today, hopefully they can answer this. > > Um...considering I wrote the software (and this bug!), you can probably
> take my word for it... =) > > -Aaron > > __________________________________________________ > Do you Yahoo!? > Yahoo! Shopping - Send Flowers for Valentine's Day > http://shopping.yahoo.com
--- "studio_6512 <studio6512@...>" wrote: > Aaron, thanks... Any chance this will get fixed in the next release? Yes, it will. __________________________________________________ Do you Yahoo!? Yahoo! Shopping - Send Flowers for Valentine's Day http://shopping.yahoo.com
Whoo not sure, it should be in groups.yahoo.com under the XL7 group somewhere on the left, probably under downloads. Andre
-----Original Message----- From: studio6512 [mailto:studio6512@...] Sent: Thursday, February 13, 2003 3:39 AM To: xl7@yahoogroups.com Subject: RE: [xl7] pattern mode Thanks for the reply Andre. Yup, the OS is up to 1.32. Just like everyone else, waiting for 2.xx. You're right, I should look at the faq. Do I just search for it, because I did not see a link for it on the XL7 group homepage. DJ_vgrep -----Original Message----- From: Andre Lewis [mailto:andrel@...] Sent: Wednesday, February 12, 2003 9:55 PM To: xl7@yahoogroups.com Subject: RE: [xl7] pattern mode You should have a read through the FAQ up on the Yahoo site, it will make your life a bit easier. The entire instrumnent mappings are actually saved as part of a multi setup, you can see them under the Global Menu, this will include instrument and volume sets (I believe). Also you have allready updated OS's? Andre -----Original Message----- From: studio_6512 <studio6512@...> [mailto:studio6512@...] Sent: Wednesday, February 12, 2003 8:20 PM To: xl7@yahoogroups.com Subject: [xl7] pattern mode when in pattern mode, I copied a pattern to an empty sequence, and tried to modify the mixer volume setting for a channel, and saved it, but it does not save. can someone tell me what I am doing wrong. DJ_vgrep To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service. [Non-text portions of this message have been removed] To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Andre, Bummer, I did as you said, and no luck with saving. This is happening with the drivinghom pattern. Not sure what the factory pattern number was, but I saved it to a user template, and that is what I am working with. any ideas... DJ_vgrep --- In xl7@yahoogroups.com, Aaron Eppolito <synthesis77@y...> wrote: > --- "studio_6512 <studio6512@c...>" wrote: > > So are you telling me that with this upgrade, in pattern mode, I > > can't change the volume and save it the way I want? Is this true... > > No. Just make sure you're playing when you save. That's it. > > > I will try and call E-mu today, hopefully they can answer this. > > Um...considering I wrote the software (and this bug!), you can probably
Yes, apparently you will have to save the pattern to the new pattern while the sequencer is actually running... or set your volumes and pans while the sequencer is running and save while the sequencer is running. Fixed in upcoming OS apparently... Andre
-----Original Message----- From: studio_6512 <studio6512@...> [mailto:studio6512@...] Sent: Thursday, February 13, 2003 3:04 PM To: xl7@yahoogroups.com Subject: [xl7] Re: pattern mode Andre, Bummer, I did as you said, and no luck with saving. This is happening with the drivinghom pattern. Not sure what the factory pattern number was, but I saved it to a user template, and that is what I am working with. any ideas... DJ_vgrep --- In xl7@yahoogroups.com, Aaron Eppolito <synthesis77@y...> wrote: > --- "studio_6512 <studio6512@c...>" wrote: > > So are you telling me that with this upgrade, in pattern mode, I > > can't change the volume and save it the way I want? Is this true... > > No. Just make sure you're playing when you save. That's it. > > > I will try and call E-mu today, hopefully they can answer this. > > Um...considering I wrote the software (and this bug!), you can probably > take my word for it... =) > > -Aaron > > __________________________________________________ > Do you Yahoo!? > Yahoo! Shopping - Send Flowers for Valentine's Day > http://shopping.yahoo.com To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
2003-02-14 by Aaron Eppolito
> Bummer, I did as you said, and no luck with saving. This is > happening with the drivinghom pattern. Not sure what the factory > pattern number was, but I saved it to a user template, and that is > what I am working with. Whoa. "Template" alert. You do have data on the tracks you're trying to save the volume and pan for, right? The XL-7 (intentionally) does not save track data for empty tracks. -Aaron PS. The reason the save while stopped bug occurs is because it now reloads the "initial" settings on save, but doesn't correctly ignore those settings if the user changed them. While playing, it can't RTZ, so it doesn't do that. __________________________________________________ Do you Yahoo!? Yahoo! Shopping - Send Flowers for Valentine's Day http://shopping.yahoo.com
2003-02-14 by studio_6512 <studio6512@cinense.org>
Hey guys, thanks for the input. but I hate being the newbie to correct this issue, considering it is my own issue. too bad it had to cost me a call to E-mu. so get this, what I wanted to do was change the volume setting for one of the tracks on a factory pattern. So here is what I had to do, Thanks goes to Ned from E-mu, much props man... 1. in pattern mode, press the pattern edit button next to the jog dial. 2. blinking cursor on the top line, use the jog dial to get the ERASE EVENTS option. 3. use the cursor to select the bottom line, CC# 1, you then use the dial again to scrool and get CC# 7 (volume). 4. the Home/Enter button will turn on (red). 5. at this point pay attention to the light in the command functions area. this is where the 16 track buttons are located, and probably blinking. click on the track button you want to clear the volume event. you can also click more than one track at a time. 6. once the track(s) are selected, click the Home/Enter button. 7. DONE. oh wait don't forget to save your work... doh... I speak from experience here. Please don't hate me, I have only had the MP-7 since Monday, and I work during the day, so I am extremely new to this awesome piece of equipment. thanks... DJ_vgrep --- In xl7@yahoogroups.com, Aaron Eppolito <synthesis77@y...> wrote: > > Bummer, I did as you said, and no luck with saving. This is > > happening with the drivinghom pattern. Not sure what the factory > > pattern number was, but I saved it to a user template, and that is > > what I am working with. > > Whoa. "Template" alert. You do have data on the tracks you're trying > to save the volume and pan for, right? The XL-7 (intentionally) does > not save track data for empty tracks. > > -Aaron > > PS. The reason the save while stopped bug occurs is because it now > reloads the "initial" settings on save, but doesn't correctly ignore > those settings if the user changed them. While playing, it can't RTZ,
> so it doesn't do that. > > __________________________________________________ > Do you Yahoo!? > Yahoo! Shopping - Send Flowers for Valentine's Day > http://shopping.yahoo.com
what I meant was I hate being the one to correct the veterans of the group... not "being the newbie to correct this issue" DJ_vgrep --- In xl7@yahoogroups.com, "studio_6512 <studio6512@c...>" <studio6512@c...> wrote: > Hey guys, > > thanks for the input. but I hate being the newbie to correct this > issue, considering it is my own issue. too bad it had to cost me a > call to E-mu. so get this, what I wanted to do was change the > volume setting for one of the tracks on a factory pattern. So here > is what I had to do, Thanks goes to Ned from E-mu, much props man... > > 1. in pattern mode, press the pattern edit button next to the jog > dial. > > 2. blinking cursor on the top line, use the jog dial to get the > ERASE EVENTS option. > > 3. use the cursor to select the bottom line, CC# 1, you then use > the dial again to scrool and get CC# 7 (volume). > > 4. the Home/Enter button will turn on (red). > > 5. at this point pay attention to the light in the command > functions area. this is where the 16 track buttons are located, and > probably blinking. click on the track button you want to clear the > volume event. you can also click more than one track at a time. > > 6. once the track(s) are selected, click the Home/Enter button. > > 7. DONE. oh wait don't forget to save your work... doh... I speak > from experience here. > > Please don't hate me, I have only had the MP-7 since Monday, and I > work during the day, so I am extremely new to this awesome piece of > equipment. > > thanks... > > DJ_vgrep > > > --- In xl7@yahoogroups.com, Aaron Eppolito <synthesis77@y...> wrote: > > > Bummer, I did as you said, and no luck with saving. This is > > > happening with the drivinghom pattern. Not sure what the factory > > > pattern number was, but I saved it to a user template, and that > is > > > what I am working with. > > > > Whoa. "Template" alert. You do have data on the tracks you're > trying > > to save the volume and pan for, right? The XL-7 (intentionally) > does > > not save track data for empty tracks. > > > > -Aaron > > > > PS. The reason the save while stopped bug occurs is because it now > > reloads the "initial" settings on save, but doesn't correctly > ignore > > those settings if the user changed them. While playing, it can't
> RTZ, > > so it doesn't do that. > > > > __________________________________________________ > > Do you Yahoo!? > > Yahoo! Shopping - Send Flowers for Valentine's Day > > http://shopping.yahoo.com
2003-02-14 by Andre Lewis
I think we can let it slide, _this time_ ;) Andre
-----Original Message----- From: studio_6512 <studio6512@...> [mailto:studio6512@...] Sent: Thursday, February 13, 2003 4:25 PM To: xl7@yahoogroups.com Subject: [xl7] Re: pattern mode what I meant was I hate being the one to correct the veterans of the group... not "being the newbie to correct this issue" DJ_vgrep --- In xl7@yahoogroups.com, "studio_6512 <studio6512@c...>" <studio6512@c...> wrote: > Hey guys, > > thanks for the input. but I hate being the newbie to correct this > issue, considering it is my own issue. too bad it had to cost me a > call to E-mu. so get this, what I wanted to do was change the > volume setting for one of the tracks on a factory pattern. So here > is what I had to do, Thanks goes to Ned from E-mu, much props man... > > 1. in pattern mode, press the pattern edit button next to the jog > dial. > > 2. blinking cursor on the top line, use the jog dial to get the > ERASE EVENTS option. > > 3. use the cursor to select the bottom line, CC# 1, you then use > the dial again to scrool and get CC# 7 (volume). > > 4. the Home/Enter button will turn on (red). > > 5. at this point pay attention to the light in the command > functions area. this is where the 16 track buttons are located, and > probably blinking. click on the track button you want to clear the > volume event. you can also click more than one track at a time. > > 6. once the track(s) are selected, click the Home/Enter button. > > 7. DONE. oh wait don't forget to save your work... doh... I speak > from experience here. > > Please don't hate me, I have only had the MP-7 since Monday, and I > work during the day, so I am extremely new to this awesome piece of > equipment. > > thanks... > > DJ_vgrep > > > --- In xl7@yahoogroups.com, Aaron Eppolito <synthesis77@y...> wrote: > > > Bummer, I did as you said, and no luck with saving. This is > > > happening with the drivinghom pattern. Not sure what the factory > > > pattern number was, but I saved it to a user template, and that > is > > > what I am working with. > > > > Whoa. "Template" alert. You do have data on the tracks you're > trying > > to save the volume and pan for, right? The XL-7 (intentionally) > does > > not save track data for empty tracks. > > > > -Aaron > > > > PS. The reason the save while stopped bug occurs is because it now > > reloads the "initial" settings on save, but doesn't correctly > ignore > > those settings if the user changed them. While playing, it can't > RTZ, > > so it doesn't do that. > > > > __________________________________________________ > > Do you Yahoo!? > > Yahoo! Shopping - Send Flowers for Valentine's Day > > http://shopping.yahoo.com To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
thanks to everyone that replied, and was kind to me... DJ_vgrep (8o) --- In xl7@yahoogroups.com, "Andre Lewis" <andrel@s...> wrote: > I think we can let it slide, _this time_ ;) > > Andre > > -----Original Message----- > From: studio_6512 <studio6512@c...> > [mailto:studio6512@c...] > Sent: Thursday, February 13, 2003 4:25 PM > To: xl7@yahoogroups.com > Subject: [xl7] Re: pattern mode > > > what I meant was I hate being the one to correct the veterans of the > group... not "being the newbie to correct this issue" > > DJ_vgrep > > --- In xl7@yahoogroups.com, "studio_6512 <studio6512@c...>" > <studio6512@c...> wrote: > > Hey guys, > > > > thanks for the input. but I hate being the newbie to correct this > > issue, considering it is my own issue. too bad it had to cost me > a > > call to E-mu. so get this, what I wanted to do was change the > > volume setting for one of the tracks on a factory pattern. So > here > > is what I had to do, Thanks goes to Ned from E-mu, much props > man... > > > > 1. in pattern mode, press the pattern edit button next to the jog > > dial. > > > > 2. blinking cursor on the top line, use the jog dial to get the > > ERASE EVENTS option. > > > > 3. use the cursor to select the bottom line, CC# 1, you then use > > the dial again to scrool and get CC# 7 (volume). > > > > 4. the Home/Enter button will turn on (red). > > > > 5. at this point pay attention to the light in the command > > functions area. this is where the 16 track buttons are located, > and > > probably blinking. click on the track button you want to clear > the > > volume event. you can also click more than one track at a time. > > > > 6. once the track(s) are selected, click the Home/Enter button. > > > > 7. DONE. oh wait don't forget to save your work... doh... I > speak > > from experience here. > > > > Please don't hate me, I have only had the MP-7 since Monday, and I > > work during the day, so I am extremely new to this awesome piece > of > > equipment. > > > > thanks... > > > > DJ_vgrep > > > > > > --- In xl7@yahoogroups.com, Aaron Eppolito <synthesis77@y...> > wrote: > > > > Bummer, I did as you said, and no luck with saving. This is > > > > happening with the drivinghom pattern. Not sure what the > factory > > > > pattern number was, but I saved it to a user template, and > that > > is > > > > what I am working with. > > > > > > Whoa. "Template" alert. You do have data on the tracks you're > > trying > > > to save the volume and pan for, right? The XL-7 (intentionally) > > does > > > not save track data for empty tracks. > > > > > > -Aaron > > > > > > PS. The reason the save while stopped bug occurs is because it > now > > > reloads the "initial" settings on save, but doesn't correctly > > ignore > > > those settings if the user changed them. While playing, it > can't > > RTZ, > > > so it doesn't do that. > > > > > > __________________________________________________ > > > Do you Yahoo!? > > > Yahoo! Shopping - Send Flowers for Valentine's Day > > > http://shopping.yahoo.com > > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@yahoogroups.com > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
2003-02-14 by erik_magrini@Baxter.com
Hehehe, there's a little bit of Aaron with us all apparently :) rEalm Since you have 1.32, you got a little bit of my brain failure (along with some good features though, I hope!). [Non-text portions of this message have been removed]
You can save the Volume settings reliably, just don't do it while the
sequencer is stopped. Just make your changes whil the XX-7 is playing,
then save before you stop it. It works, just a bit goofy for a few more
weeks :)
"studio_6512 <studio6512@...>" <studio6512
02/13/2003 11:22 AM
Please respond to xl7
cc: Subject: [xl7] Re: pattern mode Hal... what does that mean? Hal... -A few good men So are you telling me that with this upgrade, in pattern mode, I can't change the volume and save it the way I want? Is this true... I will try and call E-mu today, hopefully they can answer this. I called them on Tuesday, and they said that muting the tracks in song mode was not what is was meant for. Does someone want to touch that one? DJ_vgrep --- In xl7@yahoogroups.com, Aaron Eppolito <synthesis77@y...> wrote: > --- "studio_6512 <studio6512@c...>" wrote: > > when in pattern mode, I copied a pattern to an empty sequence, and > > tried to modify the mixer volume setting for a channel, and saved > > it, but it does not save. can someone tell me what I am doing wrong. > > Since you have 1.32, you got a little bit of my brain failure (along > with some good features though, I hope!). There's a bug that causes > volume and pan information to not be saved reliably unless the pattern > is PLAYING while you save it. > > Yeah, I know...screwy. > -Aaron > > __________________________________________________ > Do you Yahoo!? > Yahoo! Shopping - Send Flowers for Valentine's Day > http://shopping.yahoo.com To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ [Non-text portions of this message have been removed]
Under Files, it's the first one I believe. You should have gotten a copy
when you first signed up for this list too, are people not getting those
now? Let me know and I'll fix it. I'll have a new FAQ up soon too.
"Andre Lewis" <andrel@...>
02/13/2003 03:56 PM
cc: Subject: RE: [xl7] pattern mode Whoo not sure, it should be in groups.yahoo.com under the XL7 group somewhere on the left, probably under downloads. Andre -----Original Message----- From: studio6512 [mailto:studio6512@...] Sent: Thursday, February 13, 2003 3:39 AM To: xl7@yahoogroups.com Subject: RE: [xl7] pattern mode Thanks for the reply Andre. Yup, the OS is up to 1.32. Just like everyone else, waiting for 2.xx. You're right, I should look at the faq. Do I just search for it, because I did not see a link for it on the XL7 group homepage. DJ_vgrep -----Original Message----- From: Andre Lewis [mailto:andrel@...] Sent: Wednesday, February 12, 2003 9:55 PM To: xl7@yahoogroups.com Subject: RE: [xl7] pattern mode You should have a read through the FAQ up on the Yahoo site, it will make your life a bit easier. The entire instrumnent mappings are actually saved as part of a multi setup, you can see them under the Global Menu, this will include instrument and volume sets (I believe). Also you have allready updated OS's? Andre -----Original Message----- From: studio_6512 <studio6512@...> [mailto:studio6512@...] Sent: Wednesday, February 12, 2003 8:20 PM To: xl7@yahoogroups.com Subject: [xl7] pattern mode when in pattern mode, I copied a pattern to an empty sequence, and tried to modify the mixer volume setting for a channel, and saved it, but it does not save. can someone tell me what I am doing wrong. DJ_vgrep To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service. [Non-text portions of this message have been removed] To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ [Non-text portions of this message have been removed]
