Updating the O.S.
Updating the O.S.
2003-02-02 by stx303 <stx303@yahoo.com>
can you update the O.S. on a command station via USB. I have o.s. 1.0
(what it came with when i bought it) and i do not have midi
interface, and i wnat to get up to the current o.s as well as get the
orginal XL-1 sounds, can it be done with e-loader over USB? and if it
can, can it be done with a standard usb cable or do i need a specific
model?
Re: [xl7] Updating the O.S.
2003-02-02 by ->Nobody<-
Infortunately you can't use USB to upgrade the O.S.
If your computer's PC and have a gameport connector, you could buy or
borrow a MIDI cable for this. A cheap USB 1x1 MIDI could also do the
job I suppose.
> I have o.s. 1.0 (what it came with when i bought it) and i do not
> have midi interface
Sebastien,
The best defense against logic is stupidity.
2003-02-02 by ByronE
I think I remeber hearing that midi is necessary to do the update unless
you have a higher version than that already, or maybe it's needed no matter
what?
I just wish they would make support for a usb floppy or zip drive or
something to use instead to be honest.
ByronIV
> model?
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
2003-02-02 by Aaron Eppolito
Wrong type of port.  USB is host to slave.  PC/Macs are host devices,
the XL-7 is a slave device, and floppy/zip drives are also slave
devices.
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
http://mailplus.yahoo.com
